antsus1000
02.11.2011 19:44:47
ei oska aidata, aga võite mind ka lani kutsuda.
Kommentaarid: 10 loe/lisa |
10 |
xpander
10.11.2011 03:45:52
ETXreaL is a graphics mod for Wolfenstein: Enemy Territory using the enhanced XreaL id Tech 3 GPL engine.
*Modern OpenGL 3.2 renderer with all deprecated OpenGL calls removed
*Clever usage of vertex buffer objects (VBO) to speed up rendering of everything
*Avoids geometry processing each frame using the CPU (worst bottleneck with the Q3A engine)
*Renders up to 500 000 - 1 000 000 polygons at 80 - 200 fps on current hardware (DX10 generation)
*Optional GPU occlusion culling (improved Coherent Hierarchy Culling) useful for rendering large city scenes
*Doom 3 .MD5mesh/.MD5anim skeletal model and animation support
*Unreal Actor X .PSK/.PSA skeletal model and animation support
*True 64 bit HDR lighting with adaptive tone mapping
*Advanced projective and omni-directional soft shadow mapping methods like EVSM
*Real-time sun lights with parallel-split shadow maps
*Optional deferred shading
*Relief mapping that can be enabled by materials
*Optional uniform lighting and shadowing model like in Doom 3 including globe mapping
*Supports almost all Quake 3, Enemy Territory and Doom 3 material shader keywords
*TGA, PNG, JPG and DDS format support for textures
*Usage of frame buffer objects (FBO) to perform offscreen rendering effects
*Improved TrueType font support that does not require external tools
*Linux 64-bit support
*Linux sound backend using SDL
*.avi recorder from ioquake3 including sound support
*Optimized collision detection routines
*Support for Omni-bot
http://www.moddb.com/mods/etxreal
Download
http://www.moddb.com/mods/etxreal/downloads/etxreal-20110505
_________________ Linux Gaming Videos: Xpander69 |
Kommentaarid: 18 loe/lisa |
16 |
Dude .
10.11.2011 15:14:40
Võib-olla ma ei ole ET'd lihtsalt pikka aega mänginud ja seetõttu ei mäleta, milline mäng tegelikult välja näeb... või siis lihtsalt ei oska asja tehnilist poolt väärtustada, aga minu jaoks näeb küll üpris jube välja. Ka teised pildid näevad üsna sarnased välja. Madala polycountiga objektidele vistakse mingit üliteravad tekstuurid peale ja kohe absoluutselt ei sobi kokku ja riivab silma.
Kuigi kui seda aja jooksul natuke nuditakse, siis võib näha päris korralik välja. Pildid vajavad hädasti AA'd.
_________________ TALUSILDID |
Kommentaarid: 15 loe/lisa |
15 |
ampsu
10.11.2011 18:19:47
Keegi siit laseb veel aktiivselt ETprod?Võiks mingi õhtu mängida mõned 6on6d
Kommentaarid: 109 loe/lisa |
97 |
dud66
10.11.2011 18:21:29
ampsu, Ei saaks just öelda, et aktiivselt aga eks vahetevahel õhtul ikka
_________________ Kommenteerige kasutajaid, siis teavad teised ka mida oodata! |
Kommentaarid: 54 loe/lisa |
51 |
HellWalKeR
10.11.2011 18:24:55
xpander kirjutas: |
Hullem kui originaal.
Kommentaarid: 5 loe/lisa |
10.11.2011 18:35:10
selgelt kehvem...
Kommentaarid: 234 loe/lisa |
200 |
ertr2
10.11.2011 18:39:31
ampsu kirjutas: |
Keegi siit laseb veel aktiivselt ETprod?Võiks mingi õhtu mängida mõned 6on6d  |
võib
Kommentaarid: 67 loe/lisa |
65 |
hemmar
10.11.2011 18:48:07
HellWalKeR kirjutas: |
xpander kirjutas: |
Hullem kui originaal. |
Mis seal paremal üleval nurgas nende kaartega toimub? Ei ole teisi pilte vaadanud, aga puhtalt selle pildi järgi kõnniks ka sellest asjast kaarega mööda.
Kommentaarid: 11 loe/lisa |
dud66
10.11.2011 19:31:20
See ETXreaL tundub olema selline Beta versioon, eks näis kas sellest ka miskit asja saab
51 |
xpander
10.11.2011 20:06:30
dud66 kirjutas: |
See ETXreaL tundub olema selline Beta versioon, eks näis kas sellest ka miskit asja saab |
tegelt peaks alpha versioon olema...suht toores on hetkel veel jah..aga potentsiaali on
16 |
Kristjan94
10.11.2011 21:52:51
Pole sel graafikal midagi viga. Väga hea mäng on!
Võibolla hakkan uuesti mängima.
Kommentaarid: 9 loe/lisa |
9 |
zlenard
10.11.2011 22:04:30
Omnibotidega on piisavalt hea manual kaasas, et seda teha ise
Kommentaarid: 8 loe/lisa |
Xenomorph
10.11.2011 23:00:16
Kui keegi 5o5 6o6 mängida tahab siis võib pm saata.Algaja päris pole :=) on võidetud isegi lanil ja kaasa mängitud mitmel winter/summercupil
Kommentaarid: 30 loe/lisa |
29 |
HellWalKeR
10.11.2011 23:39:32
Kui juba pakkumiseks läks siis kellel huvi, võib mulle ka PM saata. Kunagi mängisin suht palju aga nüüd pole enam häid servusid. Kuid vahest võiks mängu ikka teha
hannes36
11.11.2011 00:46:37
StaticX kirjutas: |
Kui keegi 5o5 6o6 mängida tahab siis võib pm saata.Algaja päris pole :=) on võidetud isegi lanil ja kaasa mängitud mitmel winter/summercupil |
sa Hyf'ga pracima ei peaks v?
_________________ minu lugupeetus |
Kommentaarid: 121 loe/lisa |
111 |
The_Boss
11.11.2011 00:57:49
Pole vanal graafikal häda midagi, ei näe erilist mõtet uut teha. Ega see mängijaid tagasi ei too...
Kommentaarid: 358 loe/lisa |
283 |
xpander
12.11.2011 00:43:09
16 |
Flem
12.11.2011 00:57:36
Kui kellelgi on aega siin mingeid mänge korraldada , lööks isegi kaasa .
Sai pelatud kunagi suht pikalt AV/MOB-is ja UDU Battles aga enam ei ole jah kuskil võimalik normaalselt aega viita/mängida.
Kommentaarid: 3 loe/lisa |
ampsu
97 |
ertr2
12.11.2011 13:13:19
kas steami vms ei kasuta? Kui mänguks läheb saatke mulle HVs PS.
65 |
EvilMick007
12.11.2011 13:14:47
Hmm,.. ei tea palju see Xreal seda asja ikka elustab, kui pool kommuuni või enam veel harrastas/harrastab graafika 0 peale tweakimist, et fps 333 oleks ja vastaseid paremini märgata saaks...
_________________ Pentestimise ja küberturbe konsultatsiooni soovi korral võib kirjutada.. |
Kommentaarid: 46 loe/lisa |
41 |
ampsu
12.11.2011 13:56:01
EvilMick007 kirjutas: |
Hmm,.. ei tea palju see Xreal seda asja ikka elustab, kui pool kommuuni või enam veel harrastas/harrastab graafika 0 peale tweakimist, et fps 333 oleks ja vastaseid paremini märgata saaks... |
Ma arvan, et ei elusta see Xreal midagi.See lic asjaarmastajate poolt aretatud asi ja arvan, et officialiks see ei jõua kunagi.Vahetevahel äkki tõesti pubi ilus lasta kui visuaalne poolt natukene ilusam, aga selleks ongi eraldi pubid Xrealil.
ertr2 Steami võib ka mind lisada.Add: ampsu1337
97 |
antsus1000
14.11.2011 11:32:17
viimati muutis antsus1000 07.01.2018 13:44:19, muudetud 1 kord |
10 |
morfea
14.11.2011 15:05:56
antsus1000 kirjutas: |
Keegi mõni õhtu mängu viitsib teha siis lisage msn-i andresraja@hotmail.com . lepime serveri kokku ja TULD. |
et.kernwaffe.de esimeses servus...pelan 23-02 vahemikus tavaliselt pea iga päev.
Eestlased seal:
NightIFF
Narva
Optimus_Prime
Kommentaarid: 6 loe/lisa |
