14.04.2011 22:10:59
F1 2011 Mod Pack 3.1 F1 2010-le
>>Mod Pakk 3.1<<
Muutuste nimekiri:
*Updated Pirelli Tyres (Now with yellow line on soft tyres).
*Updated paddocks for HRT,Ferrari and McLaren.
*Updated loading screens for HRT,Ferrari and McLaren.
*Updated garages for HRT,Ferrari and McLaren.
*Updated Toro Rosso STR6 skin to Sepang version.
*Added real sponsor logos for Shanghai track.
*Added real sponsor logos for Melbourne track.
*Added real sponsor logos and real track surface colors for Singapore track.
*Added TrueAI mod:
+Mistakes -- Implemented a new Mistake System that causes AI to make several different mistakes.
+Aggression -- AI tries harder to overtake, making it overall more competitive and engaging.
+Fuel and Tyre Wear -- Now the ai is affected by the fuel simulation in a much more realistic way and the Korean track was fixed as it had no fuel sim at all. The Tyre Ware sim has also been improved and made more noticeable.
+Damage -- AI gets affected by damage and has harder time racing with damage.
+Mechanical Failures -- Now AI can get blown engines and tires. It will also either DNF or get DSQ.
+Hot Laps -- AI can now do hot laps in practice and qualifying.
+Corner Stats -- Improved Corner Stats causing the AI to take corners smoother.
+Stall Chance -- There is a 1% chance that the AI will stall at the race start.
*Added Real Weather mod:
+Spiral-shaped water spray simulating the turbulence generated by the tires.
+New HD raindrops (not much difference with default).Based on sharper pre patch textures.Ultra sharp in DX11.
+New forms of smoke ( dry climate ).
+Car damage texture changed.
*Added Enhanced Audio mod:
+Replay audio settings reworked. It now sounds like a race
+AI audio filter changed, giving a nicer sound to AI cars.
+Tyre audio settings reworked including scrub, lock up and spin (different settings for wet and dry races).
+No audio dip when the engineer speaks in race.
+Louder collisions and scrapes with barriers.
+Bass and volume levels adjusted throughout the game. |
Mõned videod kah:
See kaamera mod oleks kah päris lahe aga kahjuks kaotaks see ära praeguse T-Cam vaate mis suure FOV-ga on:
| Kommentaarid: 92 loe/lisa |
LeScribe
14.04.2011 23:25:21
Päris kena näeb välja, tõmban ka mingipäev, tänud.
_________________ Müüa HP Pavilion G series, lisainfo läbi postkasti.
www.iDrift.nl
#swag |
15.04.2011 06:19:00
Üks hea video veel.Pole minu tehtud aga näeb päris kena välja :
Lauri0112
15.04.2011 06:24:20
Suht hea video tõesti, aga videot oli suht palju ikka kiirendatud, muidu poleks nii head effekti jäänud.
| Kommentaarid: 61 loe/lisa |
61 |
Steff.
17.04.2011 12:46:25
tomorrow, ma ei tea kas ma olen ainus kellel winrar selle Pack-i lahtipakkimisega hakkama ei saa. Kõik failid lihtsalt jäävad nö tühjaks.
_________________ Kui sind ei ole siin...Siis sind ei ole olemaski! |
| Kommentaarid: 44 loe/lisa |
41 |
davy73
17.04.2011 13:03:15
| Proovi 7zip-iga, mul vähemalt sellega toimis.
olc
17.04.2011 13:24:08
| Kers ja DRS ka tuleb või on?
| Kommentaarid: 137 loe/lisa |
125 |
17.04.2011 17:05:43
| Steff. kirjutas: |
| tomorrow, ma ei tea kas ma olen ainus kellel winrar selle Pack-i lahtipakkimisega hakkama ei saa. Kõik failid lihtsalt jäävad nö tühjaks. |
Liiga vana versioon.Proovi 4.0 või siis uusim 7zip 9.21
| olc kirjutas: |
| Kers ja DRS ka tuleb või on? |
Ei tule F1 2010-sse.Modijad pole võimelised nii palju mängu muutma.Sama lugu uute radade ja uute auto kujudega (chassis).
Pead ootama F1 2011 ära mis Septembris tuleb
Naljakas asi kah.Üritasin Shanghai rajal sellist taktikat, et alustasin TR autoga 13 kohalt kõvema rehviga ja plaaniga teha üks boksipeatus.Ehk siis auto oli seadistatud nii, et võimalikult vähe rehvi sööks.Muidugi olin megaaeglane selle tõttu.Eriti pidurdusmaa oli tohutu aga lootsin, et ainult üks peatus offsetib selle võrreldes AI mitme peatusega .
Ringe kokku 28 (50% reaalsest).Ringil 12 muutus esimene rehv kollaseks.Ringil 17 olid kõik kollased.Oranžiks õnneks ükski ei muutunud enne kui ma ringil 22 boksi läksin ja pehmed alla panin.Pehmed muidugi 6 ringiga läksid juba kollaseks .
Siiski hea oli kah lõpus, kui kõik AI-d olid kõva rehviga ja ma sõitsin umbes 5-st mööda pehme rehviga.Paraku sellest ei piisanud.Olin kogu sõidu ikka nii aeglane olnud, et ei suutnud seda tasa teha ja lõpetasin kohal 18.
Taktika FAIL
Seega ei midagi.Tuleb Webberit ikka teha ja auto endale ära seadistada, et võimalikult kiire oleks ja siis kõvaga alustada ja edasi muudkui pehmeid alla lapata .Tuleb kiirem
striker13
17.04.2011 17:53:00
Kuidas seda mod'i peale saab? pakkisin lahti ja copy-replace installi kausta, aga ei muutu nagu midagi.
edit: sain nüüd tööle, copisin uuesti kõik asjad ja toimib.
| Kommentaarid: 95 loe/lisa |
90 |
17.04.2011 18:10:50
Tweakisin setupi kah ja sain 1:33:191 Shangais RB autoga.Klaviatuuri kohta vist päris hea
Platinet
17.04.2011 18:38:01
| tomorrow kirjutas: |
Tweakisin setupi kah ja sain 1:33:191 Shangais RB autoga.Klaviatuuri kohta vist päris hea  |
Ilmsel küll
Proovisin rooliga, sain 1.32.902
default setup, kõik abid maas, manual shifting
| Kommentaarid: 8 loe/lisa |
LeScribe
18.04.2011 12:15:35
Manual käiguvahetus on täiesti jube, ei jõua nii palju neid labasid lapata kui vaja läheb, auto teel hoidmisegagi probleeme kui veojõukontroll maas on
www.iDrift.nl
#swag |
Platinet
18.04.2011 14:24:47
| LeScribe kirjutas: |
Manual käiguvahetus on täiesti jube, ei jõua nii palju neid labasid lapata kui vaja läheb, auto teel hoidmisegagi probleeme kui veojõukontroll maas on  |
Alguses veits jah, ainult piiraja tirin oli, nüüd juba ära harjunud
Isegi kui kõik abid maas on, siis mulle tundub, et mingi veojõukontroll on ikka mängusiseselt peal. Väga lihtne on ikka sõita võrreldes LFSiga.
18.04.2011 16:57:00
Paar väikest videot jälle
libe
kvaliteetne mees
18.04.2011 18:31:15
jube graafika, rikud sellega mänguisu ära
nagu f1 manager 99
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
rastaman
18.04.2011 21:21:22
kuidas on võimalik üldse mängu nautida kui pilt on nii dos
alla taolise pildi ma ei tahaks vaadatagi -
viimati muutis rastaman 18.04.2011 21:23:41, muudetud 1 kord |
striker13
18.04.2011 21:21:28
| Ega ta siis päriselt selline pole, vähemalt mul, pigem lihtsalt youtube'i süü
90 |
rastaman
18.04.2011 21:24:47
no ega youtube graafikat detailsest kandiliseks ei muuda
striker13
26.04.2011 13:37:37
Pärast seda mod'i ei saa enam career'is Montreali rajast edasi. Kui järjest sõita, siis toimib, aga kui pärast montreali mäng kinni panna, siis käivitades ikka jälle Montreali alguses...
_________________ Sarcasm is just one of the many services I offer to people who ask stupid questions. |
90 |
raunzx
26.04.2011 17:08:23
Kui ma esimese aastal karjääri poolepeal kogemata aksepteerisin Lotuse pakkumise lepingut jätkata, on mul veel võimalust see ära katkesteda? Ise ei leidnud sellist varianti.
Ei viitsiks teine hooaeg uuesti sama autoga sõita
29.04.2011 18:33:49
| striker13 kirjutas: |
| Pärast seda mod'i ei saa enam career'is Montreali rajast edasi. Kui järjest sõita, siis toimib, aga kui pärast montreali mäng kinni panna, siis käivitades ikka jälle Montreali alguses... |
Proovin järgi kas mul õnnestub reprodutseerida see probleem.Ainuke mis hetkel pähe tuleb mis sda põhjustada võiks on /database.bin .Enamus teised on lihtsalt tekstuurid jms mis ei tohiks kuidagi asja mõjutada.
Olen ka ise suutnud tuvastada ühe crashi kus Toro Rossoga Grand Prix režiimis alustada Shanghai rajal, siis enne stardituledeni jõudmist mäng crashib iga kord.Näitab intro ära kus esimest,sind ja meeskonnakaaslast näidatakse ja siis on crash.Pole kindel, kas see on ainult sellel rajal või ainult selle autoga.
Samas järgmise etapini on aega seega mul on aega testida ja järgmisse readme-sse lisada known problems alajaotus
| raunzx kirjutas: |
Ei viitsiks teine hooaeg uuesti sama autoga sõita  |
Kahjuks mitte.Ainus võimalus on teha käsitsi F1 2010 savegame kaustast koopiad, et kui midagi valesti läheb, siis saad vanema seivi võtta.Eriti kasulik on see hooaja lõpus kui ootad viimase minutini veel lepingupakkumisi ja siis avastad, et keegi enam ei pakugi .
EDIT:
Eelmised pildid vist ei läinud mõnedele peale seega veel pilte WIP 4.0 modist.See erineb sellest mis 3.1 modiga teil hetkel on, kuna ma olen juba lisanud mõningaid asju juurde:
*Kokpit kaamera pöörab nüüd veidi rooli liikumise suunda.T-CAM kaamera asend ja FOV on samad nagu enne, seega pole vaja karta neil kes T-CAM-i kasutavad (mina ise k.a).
*Pehmetel rehvidel on nüüd valge triip kollase asemel (tänan väga Pirelli, et igal etapil kujundust muudad )
*Testin hetkel uusi taeva tekstuure mida ka siin näha.
Pildid tehtud 1680x1050,2xMSAA,Kõik muud graafikasätted Ultra/High :
EDIT2:
Minu ringiaegade edetabel.hetkel ainult kuiva ilma ringid.Paljud ajad on veel Virgin,Lotus ja Force Indiaga tehtud.Ajad mis kindlalt päris timmitud on on Kuala Lumpur,Shanghai,Istanbul,Spa ja Monza.Ülejäänutel on kohati veel sekundeid parandamis ja timmimisruumi.
krist2an
30.04.2011 22:16:18
Brasiilia GP, 4 ringi enne lõppu hakkas vihma sadama. Lootsin, et veab kõvade rehvidega lõpuni välja, aga viimasel ringil oli igasugunegi pidamine läinud. Täpselt nagu Timo Glock paar aastat tagasi
| Kommentaarid: 42 loe/lisa |
41 |
rastaman
01.05.2011 13:31:00
| võiks tulla mod mis muudab masinate kuju 2011 sugusteks
01.05.2011 13:44:26
| rastaman kirjutas: |
| võiks tulla mod mis muudab masinate kuju 2011 sugusteks |
Sellist modi ei ole ega tule, kuna modijad ei saa mudeleid importida mängu.Seega peate leppima skinnidega.
Õnneks F1 2011 tuleb juba Septembris
rastaman
