uus teema   vasta Tarkvara »  Arvutimängude foorum »  Formula 1 2010 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 61, 62, 63 ... 68, 69, 70  järgmine
sõnum 14.04.2011 22:10:59 vasta tsitaadiga
>>Mod Pakk 3.1<<
Muutuste nimekiri:
*Updated Pirelli Tyres (Now with yellow line on soft tyres).
*Updated paddocks for HRT,Ferrari and McLaren.
*Updated loading screens for HRT,Ferrari and McLaren.
*Updated garages for HRT,Ferrari and McLaren.
*Updated Toro Rosso STR6 skin to Sepang version.
*Added real sponsor logos for Shanghai track.
*Added real sponsor logos for Melbourne track.
*Added real sponsor logos and real track surface colors for Singapore track.
*Added TrueAI mod:
+Mistakes -- Implemented a new Mistake System that causes AI to make several different mistakes.
+Aggression -- AI tries harder to overtake, making it overall more competitive and engaging.
+Fuel and Tyre Wear -- Now the ai is affected by the fuel simulation in a much more realistic way and the Korean track was fixed as it had no fuel sim at all. The Tyre Ware sim has also been improved and made more noticeable.
+Damage -- AI gets affected by damage and has harder time racing with damage.
+Mechanical Failures -- Now AI can get blown engines and tires. It will also either DNF or get DSQ.
+Hot Laps -- AI can now do hot laps in practice and qualifying.
+Corner Stats -- Improved Corner Stats causing the AI to take corners smoother.
+Stall Chance -- There is a 1% chance that the AI will stall at the race start.
*Added Real Weather mod:
+Spiral-shaped water spray simulating the turbulence generated by the tires.
+New HD raindrops (not much difference with default).Based on sharper pre patch textures.Ultra sharp in DX11.
+New forms of smoke ( dry climate ).
+Car damage texture changed.
*Added Enhanced Audio mod:
+Replay audio settings reworked. It now sounds like a race
+AI audio filter changed, giving a nicer sound to AI cars.
+Tyre audio settings reworked including scrub, lock up and spin (different settings for wet and dry races).
+No audio dip when the engineer speaks in race.
+Louder collisions and scrapes with barriers.
+Bass and volume levels adjusted throughout the game.
Mõned videod kah:
See kaamera mod oleks kah päris lahe aga kahjuks kaotaks see ära praeguse T-Cam vaate mis suure FOV-ga on:
LeScribe
LeScribe
sõnum 14.04.2011 23:25:21 vasta tsitaadiga
Päris kena näeb välja, tõmban ka mingipäev, tänud.
Müüa HP Pavilion G series, lisainfo läbi postkasti.
www.iDrift.nl
#swag
sõnum 15.04.2011 06:19:00 vasta tsitaadiga
Üks hea video veel.Pole minu tehtud aga näeb päris kena välja icon_smile.gif :
Lauri0112
Lauri0112
sõnum 15.04.2011 06:24:20 vasta tsitaadiga
Suht hea video tõesti, aga videot oli suht palju ikka kiirendatud, muidu poleks nii head effekti jäänud. icon_smile.gif
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 61
Steff.
Steff.
sõnum 17.04.2011 12:46:25 vasta tsitaadiga
tomorrow, ma ei tea kas ma olen ainus kellel winrar selle Pack-i lahtipakkimisega hakkama ei saa. Kõik failid lihtsalt jäävad nö tühjaks.
Kui sind ei ole siin...Siis sind ei ole olemaski!
Kommentaarid: 44 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 41
davy73
sõnum 17.04.2011 13:03:15 vasta tsitaadiga
Proovi 7zip-iga, mul vähemalt sellega toimis.
olc
olc
sõnum 17.04.2011 13:24:08 vasta tsitaadiga
Kers ja DRS ka tuleb või on?
Kommentaarid: 137 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 125
sõnum 17.04.2011 17:05:43 vasta tsitaadiga
Steff. kirjutas:
olc kirjutas:
Ei tule F1 2010-sse.Modijad pole võimelised nii palju mängu muutma.Sama lugu uute radade ja uute auto kujudega (chassis).
Naljakas asi kah.Üritasin Shanghai rajal sellist taktikat, et alustasin TR autoga 13 kohalt kõvema rehviga ja plaaniga teha üks boksipeatus.Ehk siis auto oli seadistatud nii, et võimalikult vähe rehvi sööks.Muidugi olin megaaeglane selle tõttu.Eriti pidurdusmaa oli tohutu aga lootsin, et ainult üks peatus offsetib selle võrreldes AI mitme peatusega icon_smile.gif .
Ringe kokku 28 (50% reaalsest).Ringil 12 muutus esimene rehv kollaseks.Ringil 17 olid kõik kollased.Oranžiks õnneks ükski ei muutunud enne kui ma ringil 22 boksi läksin ja pehmed alla panin.Pehmed muidugi 6 ringiga läksid juba kollaseks thumbs_down.gif .
Siiski hea oli kah lõpus, kui kõik AI-d olid kõva rehviga ja ma sõitsin umbes 5-st mööda pehme rehviga.Paraku sellest ei piisanud.Olin kogu sõidu ikka nii aeglane olnud, et ei suutnud seda tasa teha ja lõpetasin kohal 18.
Seega ei midagi.Tuleb Webberit ikka teha ja auto endale ära seadistada, et võimalikult kiire oleks ja siis kõvaga alustada ja edasi muudkui pehmeid alla lapata icon_lol.gif .Tuleb kiirem icon_wink.gif
striker13
striker13
sõnum 17.04.2011 17:53:00 vasta tsitaadiga
Kuidas seda mod'i peale saab? pakkisin lahti ja copy-replace installi kausta, aga ei muutu nagu midagi.
edit: sain nüüd tööle, copisin uuesti kõik asjad ja toimib.
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 90
sõnum 17.04.2011 18:10:50 vasta tsitaadiga
Tweakisin setupi kah ja sain 1:33:191 Shangais RB autoga.Klaviatuuri kohta vist päris hea thumbs_up.gif
Platinet
sõnum 17.04.2011 18:38:01 vasta tsitaadiga
tomorrow kirjutas:
Proovisin rooliga, sain 1.32.902
default setup, kõik abid maas, manual shifting
LeScribe
LeScribe
sõnum 18.04.2011 12:15:35 vasta tsitaadiga
Manual käiguvahetus on täiesti jube, ei jõua nii palju neid labasid lapata kui vaja läheb, auto teel hoidmisegagi probleeme kui veojõukontroll maas on icon_biggrin.gif
www.iDrift.nl
#swag
Platinet
sõnum 18.04.2011 14:24:47 vasta tsitaadiga
LeScribe kirjutas:
Alguses veits jah, ainult piiraja tirin oli, nüüd juba ära harjunud
Isegi kui kõik abid maas on, siis mulle tundub, et mingi veojõukontroll on ikka mängusiseselt peal. Väga lihtne on ikka sõita võrreldes LFSiga.
sõnum 18.04.2011 16:57:00 vasta tsitaadiga
libe
kvaliteetne mees
libe
sõnum 18.04.2011 18:31:15 vasta tsitaadiga
nagu f1 manager 99
rastaman
rastaman
sõnum 18.04.2011 21:21:22 vasta tsitaadiga
alla taolise pildi ma ei tahaks vaadatagi icon_biggrin.gif -
viimati muutis rastaman 18.04.2011 21:23:41, muudetud 1 kord
striker13
striker13
sõnum 18.04.2011 21:21:28 vasta tsitaadiga
Ega ta siis päriselt selline pole, vähemalt mul, pigem lihtsalt youtube'i süü
rastaman
rastaman
sõnum 18.04.2011 21:24:47 vasta tsitaadiga
striker13
striker13
sõnum 26.04.2011 13:37:37 vasta tsitaadiga
Pärast seda mod'i ei saa enam career'is Montreali rajast edasi. Kui järjest sõita, siis toimib, aga kui pärast montreali mäng kinni panna, siis käivitades ikka jälle Montreali alguses...
Sarcasm is just one of the many services I offer to people who ask stupid questions.
raunzx
sõnum 26.04.2011 17:08:23 vasta tsitaadiga
Kui ma esimese aastal karjääri poolepeal kogemata aksepteerisin Lotuse pakkumise lepingut jätkata, on mul veel võimalust see ära katkesteda? Ise ei leidnud sellist varianti.
sõnum 29.04.2011 18:33:49 vasta tsitaadiga
striker13 kirjutas:
Proovin järgi kas mul õnnestub reprodutseerida see probleem.Ainuke mis hetkel pähe tuleb mis sda põhjustada võiks on /database.bin .Enamus teised on lihtsalt tekstuurid jms mis ei tohiks kuidagi asja mõjutada.
Olen ka ise suutnud tuvastada ühe crashi kus Toro Rossoga Grand Prix režiimis alustada Shanghai rajal, siis enne stardituledeni jõudmist mäng crashib iga kord.Näitab intro ära kus esimest,sind ja meeskonnakaaslast näidatakse ja siis on crash.Pole kindel, kas see on ainult sellel rajal või ainult selle autoga.
Samas järgmise etapini on aega seega mul on aega testida ja järgmisse readme-sse lisada known problems alajaotus thumbs_up.gif
raunzx kirjutas:
Kahjuks mitte.Ainus võimalus on teha käsitsi F1 2010 savegame kaustast koopiad, et kui midagi valesti läheb, siis saad vanema seivi võtta.Eriti kasulik on see hooaja lõpus kui ootad viimase minutini veel lepingupakkumisi ja siis avastad, et keegi enam ei pakugi icon_neutral.gif .
EDIT:
Eelmised pildid vist ei läinud mõnedele peale seega veel pilte WIP 4.0 modist.See erineb sellest mis 3.1 modiga teil hetkel on, kuna ma olen juba lisanud mõningaid asju juurde:
*Kokpit kaamera pöörab nüüd veidi rooli liikumise suunda.T-CAM kaamera asend ja FOV on samad nagu enne, seega pole vaja karta neil kes T-CAM-i kasutavad (mina ise k.a).
*Pehmetel rehvidel on nüüd valge triip kollase asemel (tänan väga Pirelli, et igal etapil kujundust muudad icon_rolleyes.gif )
*Testin hetkel uusi taeva tekstuure mida ka siin näha.
Pildid tehtud 1680x1050,2xMSAA,Kõik muud graafikasätted Ultra/High icon_wink.gif :
EDIT2:
Minu ringiaegade edetabel.hetkel ainult kuiva ilma ringid.Paljud ajad on veel Virgin,Lotus ja Force Indiaga tehtud.Ajad mis kindlalt päris timmitud on on Kuala Lumpur,Shanghai,Istanbul,Spa ja Monza.Ülejäänutel on kohati veel sekundeid parandamis ja timmimisruumi.
krist2an
krist2an
sõnum 30.04.2011 22:16:18 vasta tsitaadiga
Brasiilia GP, 4 ringi enne lõppu hakkas vihma sadama. Lootsin, et veab kõvade rehvidega lõpuni välja, aga viimasel ringil oli igasugunegi pidamine läinud. Täpselt nagu Timo Glock paar aastat tagasi icon_biggrin.gif
Custom 3d-prinditud mATX / ITX / APU case - http://bit.ly/4kIJQZs
rastaman
rastaman
sõnum 01.05.2011 13:31:00 vasta tsitaadiga
võiks tulla mod mis muudab masinate kuju 2011 sugusteks
sõnum 01.05.2011 13:44:26 vasta tsitaadiga
rastaman kirjutas:
Sellist modi ei ole ega tule, kuna modijad ei saa mudeleid importida mängu.Seega peate leppima skinnidega.
rastaman
rastaman
sõnum 05.05.2011 01:36:39 vasta tsitaadiga
hah, proovisin just nii sõita, et tegin terve ekraani puhtaks. hoopis teine elamus ütleks icon_biggrin.gif võiks siis ainult stardijoone juures need vennad plakatidega olla ja rohkem raadiosidet ringiaegade kohta jne.
viskasin mõned uuemad modid ka peale, pole enne mäng selline välja näinud icon_biggrin.gif
edit: schumiga eau rouges buttoni vastu icon_biggrin.gif
http://www.youtube.com/watch?v=GuVNLWRG9BA
http://www.youtube.com/watch?v=qZ33j_XcPnQ
http://www.youtube.com/watch?v=xvnAkoAr_BU
viskan oma praegused modid ka siia siis -
[RDDev] Gl4dLights Ultra :: Update 3
http://www.racedepartment.com/downloads/f1-2010-rddev-mods-69/rddev-gl4dlights-ultra-update-3-4571/
[RDDev] Pirelli Tires With Yellow stripe
http://www.racedepartment.com/downloads/f1-2010-rddev-mods-69/rddev-pirelli-tires-yellow-stripe-4452/
[RDDev] TrueAI Mod 1.4
http://www.racedepartment.com/downloads/f1-2010-rddev-mods-69/rddev-trueai-mod-1-4-3708/
[RDDev] Daftboy HD Helmets Pack 1.1
http://www.racedepartment.com/downloads/f1-2010-rddev-mods-69/rddev-daftboy-hd-helmets-pack-1-1-3603/
[RDDev] Mercedes MGP W01 - C.ReTextured - UltraHD
http://www.racedepartment.com/downloads/f1-2010-rddev-mods-69/rddev-mercedes-mgp-w01-c-retextured-ultrahd-3587/
[RDDev] Williams Cosworth FW33 HD v1.0.2011
http://www.racedepartment.com/downloads/f1-2010-rddev-mods-69/williams-cosworth-fw33-hd-v1-0-2011-4286/
[RDDev] Lotus Renault GP
http://www.racedepartment.com/downloads/f1-2010-rddev-mods-69/rddev-lotus-renault-gp-4194/
[RDDev] McLaren MP4-25 - SpEdit - UltraHD 3.1
http://www.racedepartment.com/downloads/f1-2010-rddev-mods-69/rddev-mclaren-mp4-25-spedit-ultrahd-3-1-3511/
Red Bull RB7 Melbourne v1.0 [HD]
http://www.racedepartment.com/downloads/f1-2010-skins-helmets-rims-gloves-53/red-bull-rb7-melbourne-v1-0-hd-4603/
Ferrari f150 Melbourne v1.0 [HD]
http://www.racedepartment.com/downloads/f1-2010-skins-helmets-rims-gloves-53/ferrari-f150-melbourne-v1-0-hd-4546/
Force India VJM 04 HD
http://www.racedepartment.com/downloads/f1-2010-skins-helmets-rims-gloves-53/force-india-vjm-04-hd-4508/
Toro Rosso sepang 2011 HD
http://www.racedepartment.com/downloads/f1-2010-skins-helmets-rims-gloves-53/toro-rosso-sepang-2011-hd-4476/
Williams FW33(Ka-b00m) Melbourne Livery Update
http://www.racedepartment.com/downloads/f1-2010-skins-helmets-rims-gloves-53/williams-fw33-ka-b00m-melbourne-livery-update-4415/
HRT 2011 skin
http://www.racedepartment.com/downloads/f1-2010-skins-helmets-rims-gloves-53/hrt-2011-skin-4260/
Sky Mod
http://www.racedepartment.com/downloads/f1-2010-misc-54/sky-mod-4568/
From Prime/Option to Hard/Soft
http://www.racedepartment.com/downloads/f1-2010-misc-54/prime-option-hard-soft-4554/
another RAINDROPS and VISIBILITY FIX
http://www.racedepartment.com/downloads/f1-2010-misc-54/another-raindrops-visibility-fix-4084/
2x brake light glow
http://www.racedepartment.com/downloads/f1-2010-misc-54/2x-brake-light-glow-3887/
Enhanced Audio v1.0
http://www.racedepartment.com/downloads/f1-2010-misc-54/enhanced-audio-v1-0-3880/
+40 Flashbacks Mod
http://www.racedepartment.com/downloads/f1-2010-misc-54/40-flashbacks-mod-3296/
My Pack Cams For All Cars
http://www.racedepartment.com/downloads/f1-2010-misc-54/my-pack-cams-for-all-cars-3465/
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Formula 1 2010 mine lehele eelmine  1, 2, 3 ... 61, 62, 63 ... 68, 69, 70  järgmine
