AJ
08.12.2010 11:50:25
AMD Radeon HD 6900 series pictured, launches Dec 15
Nordichardware
AMD is said to have set the launch date for the new Radeon HD 6900 series. From the foggy statement of a launch in week 50 the date has been set to December 15th and now the first pictures have surfaced, while specifications are starting to leak.
AMD Radeon HD 6970 is the coming flagship and as we have reported in the past it has been the problematic one. The flagship needs to show good performance and supply should be good at launch. When the first specifications leaked there were still questions about the flagship product.
The looks of the card is no secret anymore as the Chinese site Mydrivers has published pictures of Radeon HD 6970 from UNIKA. The cooler is nearly identical to the cooler found on Radeon HD 6800 series and the price is said to be around $450.
AMD Radeon HD 6950 is the little brother that according to our sources was the card that first lived up to AMD's demands. The first pictures that was published by MyDrivers is what is said to be Radeon HD 6950 is actuall an identical copy of AMD's press picture of för Radeon HD 6870, beside a new sticker for UNIKA and the name HD6950. The price will be around $310. If this means that the new Cayman circuits are pin-compatible with Barts and use the same circuits board is too early to say, but it sure seems like it. If the picture is authentic.
Suuremat pilti näeb, kui pildile klikkida
If we look at the specifications we see that AMD raise the bar compared to the mid-range series Radeon HD 6800. With a new shader architecture it hasn't just introduced a more efficient handling of the stream processors, but also increase the total. The exact number is still unknown - which means AMD is keeping the lid on. At the same time it keeps to the 256-bit bus (NVIDIA uses 384-bit) but uses fast GDDR5 circuits to reach good bandwidth.
The specifications are in no way official and should be considered with a pinch of salt, but are starting to become all the more believeable with more sources posting similar information. In a week we will know for sure. |
| Kommentaarid: 37 loe/lisa |
36 |
chulo
08.12.2010 11:55:17
| Einoh... aina "paremaks" läheb, lükkame veel paar päeva edasi release date'i ja lõppudelõpuks tulevad veel kehvema kaardiga välja kui konkurendid. Kui see info tõesti peaks tõele vastama, siis on see "EPIC FAIL"-kategooriasse kuuluv sündmus (minu silmis). Kui mõelda, et alles paar kuud tagasi pasundati, et "nVidia's gonna eat our dust" ja nüüd kobisetakse mokaotsast, et tahtsime küll kõige paremat, aga välja tuli ikka sedapsi. Ma tõesti loodan, et pean enda sõnu sööma, sest vastasel juhul saab järgmises rig'is konkurentide kaart olema.
| Kommentaarid: 20 loe/lisa |
18 |
G80
08.12.2010 12:35:58
| AJ kirjutas: |
Nordichardware
Seda artiklit ei tasu tõsiselt võtta.
210 |
chulo
08.12.2010 12:39:15
| G80 kirjutas: |
| AJ kirjutas: |
Nordichardware
Seda artiklit ei tasu tõsiselt võtta. |
No loodame parimat ja ootame viieteistkümnendat kuupäeva! Vaevalt enne kuskilt adekvaatset infot tuleb.
18 |
trip
303 |
WäntWõll
make.believe
08.12.2010 16:17:13
| G80 kirjutas: |
| AJ kirjutas: |
Nordichardware
Kui bändvitsi number on õige siis peabki 6970 peksa saama 480/570 käest
300 |
G80
08.12.2010 16:34:46
| wanawoll kirjutas: |
| G80 kirjutas: |
| AJ kirjutas: |
Nordichardware
Kui bändvitsi number on õige siis peabki 6970 peksa saama 480/570 käest  |
pändivitsi järgi ei saa otsustada.
210 |
WäntWõll
make.believe
08.12.2010 16:49:42
| 15 on näha mis seal ikka
300 |
rene p
08.12.2010 17:48:41
| chulo kirjutas: |
| Einoh... aina "paremaks" läheb, lükkame veel paar päeva edasi release date'i ja lõppudelõpuks tulevad veel kehvema kaardiga välja kui konkurendid. Kui see info tõesti peaks tõele vastama, siis on see "EPIC FAIL"-kategooriasse kuuluv sündmus (minu silmis). Kui mõelda, et alles paar kuud tagasi pasundati, et "nVidia's gonna eat our dust" ja nüüd kobisetakse mokaotsast, et tahtsime küll kõige paremat, aga välja tuli ikka sedapsi. Ma tõesti loodan, et pean enda sõnu sööma, sest vastasel juhul saab järgmises rig'is konkurentide kaart olema. |
Keegi pole midagi 2 päeva edasi lükanud, sest kindlat kuupäeva pole kunagi välja hõigatudki. See 13 detsember oli öeldud nii, et tuleb nädalal, mis algab 13-da detsembriga.
Kui arvestada, et laupäeval ja pühapäeval ilmselgelt mingit launchi ei toimu, siis oleks see kuupäev võinud olla ükskõik milline, alates 13-st kuni 17-ndani.
68 |
kalluka
08.12.2010 18:06:53
Peab ootama korralikke ülevaateid.Piltide ja nn ,,leaked,, info järgi ei saa veel midagi öelda
| Kommentaarid: 16 loe/lisa |
12 |
G80
210 |
CoiL
09.12.2010 08:48:23
| Le Inc kirjutas: |
Fuzilla väidab et 6970 polegi kiirem kui 580? Siis on kahtlane ka 6950 edu 570 üle .. aga noh, nagu ikka, eks näis.  |
Sina true nvidiot hakkasid nüüd äkitseld fudzilla seenepoiste juttu uskuma?
| Kommentaarid: 95 loe/lisa |
83 |
Le Inc
09.12.2010 13:19:20
| CoiL kirjutas: |
| Le Inc kirjutas: |
Sina true nvidiot hakkasid nüüd äkitseld fudzilla seenepoiste juttu uskuma? |
Kui nimetada parima perfi/hinna suhte otsinguid "nvidiootlikuks" liikumiseks, siis jah.
Muide, rõõmus naerunägu lause lõpus võiks ju vihjata mida ma sellest arvan!?
Kui mul on valida sama hinna, sama jõudlusega ja sama voolutarbega kaardi vahel siis ma valiks AMD asemel nVidia. Miks? Lihtsalt parem draiverite tugi ja mingil määral ka PhysX tugi, mida jah, väga vähe kasutatakse, aga nVidia müügitöö mõjub.
PS! Miks mõned indiviidid ebameeldivalt ärrituvad kui nende pühasid eesmärke ja kohati tundub, et ka juurdunud kinnisideid väheselgi määral teise nurga all vaadatakse? Eriti arvestades väite hüpoteetilisusega!?
| Kommentaarid: 56 loe/lisa |
54 |
ossa
09.12.2010 13:19:46
Paraku sellist võimalust ei ole ja ei jäägi muud üle, kui valida AMD
20 |
AJ
09.12.2010 13:34:59
PowerColor Radeon 6870 PCS+ review
Guru3D
36 |
JoeKing
09.12.2010 13:52:14
6000 seeriaga asendus DisplayPort MiniDisplayPort'iga. Kas keegi teab, kust soodsa hinnaga üleminekuid saaks?
_________________ Sic itur ad astra... |
| Kommentaarid: 238 loe/lisa |
209 |
7 :: |
364 |
Le Inc
09.12.2010 15:56:55
| ossa kirjutas: |
Paraku sellist võimalust ei ole ja ei jäägi muud üle, kui valida AMD  |
Ära sa ütle, 570 GTX on peaaegu samade nummeritega mis 5870. Sips kiirem ja vaiksem, samas sutsu vooluõgardlikum. Vägagi sarnased ütleks.
54 |
SurfData
09.12.2010 15:57:57
| Le Inc kirjutas: |
| ossa kirjutas: |
Ära sa ütle, 570 GTX on peaaegu samade nummeritega mis 5870. Sips kiirem ja vaiksem, samas sutsu vooluõgardlikum. Vägagi sarnased ütleks.  |
ot. ainult et aasta aega hiljem välja tulnud.
| Kommentaarid: 84 loe/lisa |
74 |
WäntWõll
make.believe
09.12.2010 15:58:50
ikka omajagu kiirem
300 |
One
09.12.2010 16:10:49
~10% kiirem ja tunduvalt suurema voolutarbega
lisaks ka ~100 taala kallim.
728 |
WäntWõll
make.believe
09.12.2010 16:18:54
Kõikidel resodel koondtabel on väga üldistav 5870 vs. 480 vahe oli n äha igas rakenduses
ja 480 on täpselt samakiire + dx10 rakendustes isegi suti kiirem.
hind on teine teema üks on 4300 ja teine 5500, ning kaart on mõeldud konkureerima 6950, kui ATi oma kaardi välja saab siis võrdleme perfi ja hinda
seniks pole siin midagi leelotada.
300 |
kalluka
09.12.2010 16:57:33
Hmm ...
12 |
KrisVr
09.12.2010 16:58:55
What`s that?
| Kommentaarid: 30 loe/lisa |
Gizmoz
09.12.2010 17:01:13
| kalluka kirjutas: |
Hmm ... |
Turbo button!
| Kommentaarid: 15 loe/lisa |
14 |
CoiL
09.12.2010 17:01:57
turbo button ei oleks nii haleda välimusega
83 |
kalluka
09.12.2010 17:02:58
Ma arvan ,et niisama see sinna topitud ei ole.Kahtlen ,et CF-iga seost on ning kahtlen ka seda ,et see mingi turbo button on
12 |
One
09.12.2010 17:03:35
| maybe kaks erinevat biosi vms
728 |
kalluka
09.12.2010 17:05:27
| Kogu slaide pole veel saanud.Neid uusi , ma mõtlen.Ainuke pilt hetkel.
12 |
G80
09.12.2010 17:12:36
| Gizmoz kirjutas: |
| kalluka kirjutas: |
Hmm ... |
Turbo button! |
Automaatne enesehävitus süsteem.
210 |
kalluka
09.12.2010 17:15:55
| Hea kild on see , et mulle tundub ,et halli kasti taga on selgitus milleks see nupp mõeldud on.
12 |
SurfData
09.12.2010 17:21:31
| kalluka kirjutas: |
| Hea kild on see , et mulle tundub ,et halli kasti taga on selgitus milleks see nupp mõeldud on. |
mõni photohoppija võiks vaadata mis sinna oleks võimalik pikkusega kirjuata...et näiteks "Dual Bios Flash Switch" mahub sinna vms?
74 |
09.12.2010 17:35:50
| Gizmoz kirjutas: |
| kalluka kirjutas: |
Hmm ... |
Turbo button! |
Kuna amd-l alailma probleeme catalystis kellade alandamisega 2D-s või vastupidi, siis see on mehaaniline lüliti selle teostamiseks
Vidget
09.12.2010 17:46:30
Kas keegi 6nda seeria kaardil on display pordist vga kätte saanud? Plaan Eyefinityga 2 projektorit kokku ühendada, millel kahjuks vaid VGA sisendid. DVI'dest saab vaid ühest VGA kätte
128 |
WäntWõll
make.believe
300 |
kalluka
09.12.2010 19:04:31
| Väga absurd hind.Ei saa nii võtta.Kui euroopas maksab 6870 200 EUR.Ta ei saa tulla 300 EUR kallim.Ega see ju 5700 seeria ja 5800 seeriaga ka nii ei olnud.Igast pläma ei tasu võtta tõsiselt.
12 |
One
09.12.2010 19:26:27
mingi suvaline netipood lükkab asjad suva hinnaga "müüki".
vaata kui palju klikke, kisa ja kära saab.
728 |
kalluka
09.12.2010 19:27:16
...see on nagu nende ,,kogemata,, baari unustatud iphonedega.
viimati muutis kalluka 09.12.2010 19:48:17, muudetud 1 kord |
12 |
G80
09.12.2010 19:36:12
| Winterwind kirjutas: |
vaata kui palju klikke, kisa ja kära saab. |
210 |
omgwtf
09.12.2010 19:53:38
| jeesus188 kirjutas: |
| Gizmoz kirjutas: |
| kalluka kirjutas: |
Hmm ... |
Turbo button! |
Kuna amd-l alailma probleeme catalystis kellade alandamisega 2D-s või vastupidi, siis see on mehaaniline lüliti selle teostamiseks  |
137 |
pwnage
09.12.2010 20:33:49
| omgwtf kirjutas: |
| Gizmoz kirjutas: |
| kalluka kirjutas: |
Hmm ... |
Turbo button! |
Äkki mingi CF Bridge Switch või midagi
| Kommentaarid: 50 loe/lisa |
50 |
09.12.2010 20:53:56
| JoeKing kirjutas: |
| 6000 seeriaga asendus DisplayPort MiniDisplayPort'iga. Kas keegi teab, kust soodsa hinnaga üleminekuid saaks? |
Nad oleksid pidanud ülemineku kaasa panema aga no eks see jama ongi uut asjade esimesena adaptimisega.Midagi muutub võid vana kola nurka visata ja otsast alustada
| G80 kirjutas: |
| Gizmoz kirjutas: |
| kalluka kirjutas: |
Hmm ... |
Turbo button! |
Automaatne enesehävitus süsteem. |
This GPU will self destruct in 5 seconds
| Kommentaarid: 92 loe/lisa |
G80
09.12.2010 21:01:20
| kalluka kirjutas: |
Hmm ... |
The -20 to 20 slider is a %, you can adjust the power of your card in the overdrive tab by 20% up or down.
the 250W is the maximum board consumption, but the non-OC power consumption is 190/200W.
Cayman can actually clock almost as flexible as any modern CPU, so it can run at 650 MHz or 800 MHz during benchmarking if you enable Powertune |
210 |
AJ
09.12.2010 21:11:38
AMD kaartide launch järgmisel nädalal tundu tõsi olevat. Muropaketti sai AMD-lt jõulukingi, millest nad ei tohi lähemalt rääkida enne kui järgmisel nädalal. Siis pidi selle kohta ka artikkel tulema. Midagi muud kui uusi kaarte ei ole ju hetkel AMD-lt oodata.
http://plaza.fi/muropaketti/myos-amd-muisti-muropaketin-lukijoita-joululahjalla
36 |
kalluka
09.12.2010 22:03:22
| enamus ülevaatajatel kaardid käes..testid tehtud
12 |
WäntWõll
make.believe
09.12.2010 23:25:54
TRA elu lüliti
300 |
G80
210 |
ossa
10.12.2010 08:22:27
Täiesti mõtteto video
Krt need unwrapping videod YT-s ajavad alati ostuisu peale
Mille ostuisu, kas mullikile või?
20 |
