Asgate
14.10.2010 20:12:37
| G80 kirjutas: |
| Cayman XT ja Antilles tulevad huvitavad. |
Just "AMD koopamehi" tuleb oodata !
| Kommentaarid: 17 loe/lisa |
14 |
KrisVr
14.10.2010 20:15:12
| Keegi on jah vist põlve otsas teinud, väga odav näeb välja.
| Kommentaarid: 30 loe/lisa |
AJ
14.10.2010 20:17:47
Need pildid ei ole vist siit teemast läbi käinud.
Pldid pärit siit
Radeon HD 6870 card captured in the nude
TechConnect Magazine
| Kommentaarid: 37 loe/lisa |
36 |
G80
14.10.2010 20:18:26
| NATAS999 kirjutas: |
Killhoven, mingi custom made plekk seal taga. nii roostes kruvidega kaarti küll ei taha. wait wat? keegi põlve otsas nüri noaga nüsind selle XFX sinna ve? sest väga kole näeb välja teglt ju. ja tobe ka. varajane aprillinali ehk? |
Ise oled roostes, kui ei meeldi kruvi ja võta plekk ära.
210 |
AJ
14.10.2010 20:32:45
Radeon HD 6850 & HD 6870 get listed, real clocks confirmed?
Craving more info about AMD's Barts-based Radeon HD 6850 and HD 6870 graphics cards? You're in luck as both these cards, which are still a week away from being made official, have been listed by a Dutch store who may or not may get in trouble very soon for jumping the gun.
Found by the guys @ Dinox PC , the listings are of the Sapphire Radeon HD 6850 and HD 6870 featuring DirectX 11 support, updated multi-monitor capabilities (up to six monitors per card), a 256-bit memory interface, 1GB of GDDR5 memory, two DVI, one HDMI 1.4 and two mini DisplayPort 1.2 outputs, CrossFire chops and a TDP of just under 150W.
The Radeon HD 6850 GPU and memory clocks published are 725 MHz and 4000 MHz, respectively, while the card's price tag is €189 ($265.7). The conversion probably isn't an accurate estimate as to how much the card will cost in the US but we just have to underline the higher prices here in Europe.
As for the Radeon HD 6870, it has the GPU/memory set to 900/4200 MHz and costs €255 ($358.5). |
36 |
pohmakas,
käed värisevad
14.10.2010 21:33:44
hetkeseisuga jään nvidia juurde, jätab täitsa külmaks miskipärast
| Kommentaarid: 166 loe/lisa |
137 |
Kristoferr
216 |
G80
14.10.2010 22:59:12
6870 näeb hea välja.
Nüüd ootaks testides tulemusi DX11 benchides ja mängudes.
210 |
trip
15.10.2010 09:33:13
6870 pcb vs 5870/5850
303 |
KrisVr
15.10.2010 12:37:08
NVIDIA to Counter Radeon HD 6970 ''Cayman'' with GeForce GTX 580
TechPowerUP
AMD is undertaking its product development cycle at a breakneck pace, NVIDIA trailed it in the DirectX 11 and performance leadership race by months. This November, AMD will release the "Cayman" GPU, its newest high end GPU, the expectations are that it will outperform the NVIDIA GF100, that is a serious cause for concern, for the green team. It's back to its old tactics of talking about GPUs that haven't even taken shape, to try and water down AMD's launch. Enter, the GF110, NVIDIA's new high-end GPU under design, on which is based the GeForce GTX 580.
The new GPU is speculated to have 512 CUDA cores, 128 TMUs, and a 512-bit wide GDDR5 memory interface holding 2 GB of memory, with a TDP of close to that of the GeForce GTX 480. In the immediate future, there are prospects of a more realistic-sounding GF100b, which is basically GF100 with all its 512 CUDA cores enabled, while retaining its 384-bit GDDR5 memory interface, 64 TMUs, and slightly higher TDP than that of the GTX 480. |
Dolph
15.10.2010 12:42:41
| Lauri Kiissel kirjutas: |
hetkeseisuga jään nvidia juurde, jätab täitsa külmaks miskipärast  |
Hoia meid kursis, et kuidas Su emotsioonid muutuvad.
| Kommentaarid: 16 loe/lisa |
14 |
G80
15.10.2010 12:52:49
| Dolph kirjutas: |
Hoia meid kursis, et kuidas Su emotsioonid muutuvad. |
Mind huvitab ka ehk teeb oma blogi, et saaks tema emotsioonidega kursis olla?
210 |
Kemmukas
15.10.2010 15:44:11
| Kas ma olen nüüd õigesti aru saanud, et nime poolest uued hd 6850 ja hd 6870 tulevad nende 5750 ja 5770 asemele ning nüüd see hd 6970 vastab 5870-le?
| Kommentaarid: 13 loe/lisa |
KrisVr
15.10.2010 15:45:45
| Kemmukas kirjutas: |
| Kas ma olen nüüd õigesti aru saanud, et nime poolest uued hd 6850 ja hd 6870 tulevad nende 5750 ja 5770 asemele ning nüüd see hd 6970 vastab 5870-le? |
Peaks nii olema jah!
kalluka
15.10.2010 15:50:21
| Ausaltöeldes see tekitab ainult segadust,hindade üle arutlemist ja väga raske on aru saada.Miks ei võiks panna samade nimedega mis 4000 seeria ja 5000 seeria?
12 |
Kristoferr
15.10.2010 15:51:16
| kalluka kirjutas: |
| Ausaltöeldes see tekitab ainult segadust,hindade üle arutlemist ja väga raske on aru saada.Miks ei võiks panna samade nimedega mis 4000 seeria ja 5000 seeria? |
Loe teemat palun. Seda küsimust on juba mitmeid kordi küsitud ja sellele on mitmeti vastatud.
_________________ Liitu Z.ai soodsa coding plaaniga
Liitu Wise'ga! |
216 |
NATAS999
15.10.2010 16:07:13
| kalluka kirjutas: |
sest amd teab paremini kui ati, mis nimega mis radeon peab olema.
| Kommentaarid: 41 loe/lisa |
39 |
One
15.10.2010 16:09:37
ei saa aru mis segadust see nime vahetus ikka tekitab.
ostuhuvi korral võtad suvalise hinnakirja lahti, valid sobiva kaardi välja,
kirjutad guuglisse kaardi nime + review ja ongi kõik maailma vastused käes.
728 |
AJ
15.10.2010 16:31:01
| G80 kirjutas: |
| Dolph kirjutas: |
Mind huvitab ka ehk teeb oma blogi, et saaks tema emotsioonidega kursis olla?  |
Mind huvitaks nimekirja kõigist inimestest, kes jäävad Nvidia juurde.
36 |
omgwtf
15.10.2010 16:32:37
| Mina ja tema.
137 |
15.10.2010 16:39:22
| AJ kirjutas: |
| G80 kirjutas: |
| Dolph kirjutas: |
Mind huvitaks nimekirja kõigist inimestest, kes jäävad Nvidia juurde.  |
Salastatud Huangi poolt 50 aastaks, et vältida punaste repressioone
| Kommentaarid: 92 loe/lisa |
NATAS999
15.10.2010 17:24:44
| Winterwind kirjutas: |
kirjutad guuglisse kaardi nime + review ja ongi kõik maailma vastused käes. |
mitu seeriat juba x870 olnud high-end single GPU ja x9xx dual GPU. milleks nüüd siis sellist jama tekitada? mul täiega pohhui, mis nimi kaardil on, pangu kasvõi 6250 highend dual gpu ja 6132 highend single gpu ja 6198 näiteks lowend dual gpu vms. lihtsalt mingi järjepidevus võiks olla, et tead täpselt, mis miski number olema peaks.
39 |
AJ
15.10.2010 19:42:25
AMD Quietly Reveals Next Radeon Series, Launches Next Week
AnandTech
The cat is out of the bag, so to speak, after today's earnings conference call for AMD. One of the things that ended up being discussed by AMD CEO Dirk Meyer in today's call was the future of AMD's graphics division, where AMD's "second-generation DX11" GPUs were mentioned.
We will be launching our second-generation DX11 graphics offerings next week.
Later on, he also had the following to say about what's launching and what the expected volume is:
We'll be introducing our second-generation of DX11 technology into the market with some launch activities actually next week. We'll be shipping all the family members of that product line I'll call it, by the end of this quarter, and total volume think in terms of several hundred thousand, or hundreds of thousands of units.
No further details were given, so we'll have to see what they're up to next week. |
AMD CEO: Expect tablet chip with 'great graphics'
CNET
Advanced Micro Devices CEO Dirk Meyer said that his company will address the tablet market with a design that packs "great graphics," but isn't in any great hurry.
The discussion came during the chipmaker's conference call on third-quarter earnings, which the company reported today.
"I expect we're going to see tablets in various form factors and thicknesses over time. From everything we understand today, it's still a pretty new market," he said. Currently, by far the most popular tablet is Apple's iPad, which uses that company's A4 processor. Intel has targeted its Oak Trail Atom processor for the tablet market.
Meyer continued. "A tablet would optimally have power dissipation of two to three watts, which is a little more than half of what a fanless Netbook would tolerate. I expect customers will take components designed with Netbooks in mind and put them in tablets. And I think you'll see AMD solutions in tablets in the next couple of years for that reason."
Allocating significant research and development resources is a wait-and-see scenario, he said. "It's [a market] we'll devote significant R&D energy towards when the market is big enough to justify that investment. Frankly, we're still so small in the notebook market that it doesn't make sense for us to turn R&D dollar spending toward the tablet market yet. We'll start doing that when the market is big enough."
And what might an AMD tablet chip offer? "We'll show up with a differentiated offering with great graphics and video technology," Meyer said.
Speaking more generally about the tablet market, he said: "The tablet is a disruption in the notebook market. If you ask five people you'll get five different answers as to what degree there has been cannibalization by tablets of either Netbooks or notebooks. I think the answer is both."
He continued: "There's no question that the tablet phenomenon has been a source of volatility relative to any of our customer's ability to predict the market. But [we're] still looking at pretty healthy notebook growth." |
36 |
XeStAiSy
Aeg Maha 2a
16.10.2010 07:47:13
Nagu näga nendelt piltidelt mis puudutavad 6870 siis mälu ei asetse rohkem sellel küljel kust soe õhk peab väljuma. Samuti voolukontra on eesotsas. 4870X2 peamine suremine on mälu kus need mälud küpsevad.
| Kommentaarid: 12 loe/lisa |
NATAS999
16.10.2010 09:12:18
Margus, mis sa sogad, pildilt ju ilusti näha, et mälud on ju täpselt samas kohas, kus 58xx seerial ju
_________________ "Kuidas on see hea?"
-Auto kirurgia kliinik |
39 |
