välekx
02.10.2010 09:13:05
ei hakkagi enne seda x10 mini prod ostma, kui see update ära tehakse, mõttetu raha kulutamine tundub hetkel.
SE-l on jah nende uuendustega mingi jama, oma k850i-le pole ka miskit uuemat varianti kui aastast 2006 vist oli.
peaks vist mõtlema hakkama telefoni margi vahetusele.
lurr
02.10.2010 10:24:08
uudist tsiba - novembris võiks midagi loota nagu:
http://www.xperiax10.net/2010/10/01/x10-eclair-update-hitting-france-in-late-november-plus-more-details-on-improvements/#more-1446
Põhilised muutused X10 siis:
Main improvements from Android 2.1 Xperia update:
* 30% increase in battery life: Due to Android 2.1 as well as better OS task management.
* Each homescreen will now display 20 app icons instead of 16. There will be 5 homescreens overall instead of 3.
* Improvement in the dialler: Applies to application of text messages and e-mail that will help to simplify and streamline operations.
* New lock screen displays battery level.
* New start-up wizard: Helps configure the Xperia X10 easily when first setting up. This includes steps to import contacts, setting up Wi-Fi and Gmail account as well as synchronizing with Google sync.
* Single inbox for multiple emails (Gmail and other).
* Live wallpapers: Sony Ericsson will offer a selection of 11 live wallpapers to choose from.
* Ability to import contacts from Facebook and Twitter: Profile pictures will be imported too.
* 720p HD video recording with autofocus.
* HTML 5 support and Bluetooth 2.1.
Android 2.2 (Froyo) on Xperia X10 undecided
A decision regarding Android 2.2 has not been decided yet. One of the reasons against upgrading, generally speaking, is due to hardware limitations that can result in lag, crashes or further bugs.
| Kommentaarid: 124 loe/lisa |
112 |
vaana
02.10.2010 11:55:54
Ma rootisin oma telefoni ära aga nagu ikka ei näe, et market pakuks tasulisi appe
Kas keegi oskab seletada
jyrgen
02.10.2010 12:13:50
| vaana kirjutas: |
Kas keegi oskab seletada |
Väga täpselt ei oska, aga selleks et marketist tasulisi appe näha, ei piisa rootimisest, vaid peab ka valetama, et oled mingi korraliku riigi võrgus Olen kasutanud Market Enabler'it, mis peaks olema marketist kättesaadav. See vahetab mingi koodi ära (nt mõne Saksa võrgu omaks) ja pärast saab tagasi vahetada. Kuna väga kindel ei ole, mis rakendused ja kuidas seda koodi kasutavad, siis kasutangi ainult selleks ajaks kui suur huvi mõne tasulise appi vastu. Pärast uuendab sel viisil soetatud appe normaalsel viisil.
| Kommentaarid: 20 loe/lisa |
20 |
vaana
02.10.2010 12:59:42
Tänud jyrgen toimib väga hästi.
Telefoniks SE X10
fujitsu
04.10.2010 10:19:29
seda võiks isegi mõnitamiseks pidada.
_________________ Uus ärialane vanasõna: Minu tankisti tankist ei ole minu tankist.
in CoD - V3R1V0R5T |
| Kommentaarid: 35 loe/lisa |
WäntWõll
make.believe
04.10.2010 18:51:23
Teadaanne sellele AHV-ile kes PM-s mulle mingi aeg X8 kohta.
PS on paraku kustunud postkasti puhastuse käigus aga telefon ise on saadaval Elisas alates homsest ja hind nagu eeldasime on 3190.-
300 |
rocket
| Kommentaarid: 19 loe/lisa |
17 |
vaana
06.10.2010 09:47:50
Androidile olevat nüüd ametlik Skype valmis ja tasuta saadaval aga meie Ericssoni kasutajad peame hetkel
veel kõrvad lontis vaatama pealt kuidas teised kasutavad, sest toimib asi alles android 2.1 -ga
masmre
06.10.2010 12:25:01
krt, mind ajab see eeriksoni poliitika siga närvi. ei saa uuendusi normilt..., varsti on kõik head proged juba 2.2'le tehtud, meie jälle sitsime vanema versiooni peal. oi, ma olen kuri...
eeriksonile vitsa...
| Kommentaarid: 82 loe/lisa |
76 |
vindrek
vaana
06.10.2010 19:47:33
Äkki see liikuv taustapilt sööb jälle akut palju nagu iga vidin?
Aga äkki eksin ka.
lux
07.10.2010 14:36:07
kas keegi viitsib x10 mini juures iGO'ga veidi abiks olla, nimelt resolutsioon on vale? palun pm
| Kommentaarid: 38 loe/lisa |
36 |
rocket
07.10.2010 18:08:16
iGO pole Mini jaoks tehtud, kasuta mingit muud tarkvara, näiteks Navigoni, mis Mini peal töötab.
_________________ www.allarifoto.eu |
17 |
lux
08.10.2010 07:43:45
| rocket kirjutas: |
iGO pole Mini jaoks tehtud, kasuta mingit muud tarkvara, näiteks Navigoni, mis Mini peal töötab.  |
navigon sain korralikult tööle, aga kas keegi saaks eesti mapi jagada?
E: Üks mure on veel, telefoniga kaasas olnud klappide küljes olev pult ei tööta millegipärast. Iseenesest klapid ja mikrofon töötavad ideaalselt, aga nupuvajutus ei avalda mingit mõju. Kas seda tuleks softipõhiselt reguleerida?
36 |
WaHur
08.10.2010 10:14:25
x10 mini pro väidab et uus tarvara on saadaval ..tuleb uurida
pc companion ei tea asjast midagi!
37 |
wiilweer
08.10.2010 11:36:39
Võibolla said 1.2.A.1.174 uuenduse
| Kommentaarid: 37 loe/lisa |
WaHur
08.10.2010 13:58:30
| peal on 1.1.A.0.8. Siiani on mobla väitnud et see ongi kõige uuem.
37 |
softis
08.10.2010 16:25:10
x8 on ka Android 1.6 ja saab 2.1 veel peale X10t. No wtf see SE mõtleb ometi...
| Kommentaarid: 21 loe/lisa |
21 |
Osiris
08.10.2010 17:14:27
| softis kirjutas: |
| x8 on ka Android 1.6 ja saab 2.1 veel peale X10t. No wtf see SE mõtleb ometi... |
Endalgi mõttes kas X10 või X8 - oleneb kummale enne Android 2.1 selga tuleb....
103 |
wiilweer
08.10.2010 19:12:58
| Ennem tuleb X10 perele. Hiljem aga X8le. Arvatavasti on vahe sellepärast, et X8l pole Mediascape'i.
lux
09.10.2010 08:47:55
kas keegi viitsib teha mingi listi must have appidest x10 mini peale, olen üritanud siit teemast leida, aga pole õnnestunud.. tean, et googles neid rivis, aga otsin just siinsete kasutajate arvamusi
36 |
WaHur
09.10.2010 10:45:54
maitse+asi muidugi aga:
Gesture Search
Bluetooth File Transfer
Google Goggles
ColorNote Notepad Notes
Barcode Scanner
RMaps
ePhonebook
Handcent SMS
37 |
FR3AK
09.10.2010 11:39:43
| Handcent SMS'i kohta mainiks niipalju, et vähemalt x10'l saab sellest paroolivärgist väga kergelt lahti, advanced task killeriga see kinni panna ja sõnumeid saab niisama lugeda, samamoodi on ka timescape'is sõnumid nähtavad ja inifinity nupuga saab samuti sõnumeid vaadata. Seda siis eeldusel et peaeesmärgiks on sõnumite kaitsmine. (Aga noh, kui suvaline jorss kuskil peol tahab endale reiti solle tellida, siis niipalju peaks ikka ära kaitsma jah)
| Kommentaarid: 42 loe/lisa |
40 |
vaana
09.10.2010 19:15:32
| FR3AK kirjutas: |
| Seda siis eeldusel et peaeesmärgiks on sõnumite kaitsmine. (Aga noh, kui suvaline jorss kuskil peol tahab endale reiti solle tellida, siis niipalju peaks ikka ära kaitsma jah) |
Ma ei saa midagi aru, kas sõnumeid on võimalik kuidagi teistel näha või?
Miks peab sõnumeid kaitsma?
