Ramm
23.08.2010 12:28:42
| p3000 kirjutas: |
| Ramm kirjutas: |
Edit: Või oskab keegi kaasa rääkida Sony KDL40HX700 mudelist,et miks sellel selline kirves hind? Tal tavaline LCD ekraan,mitte LED ega midagi...või ma eksin? |
-HX on +200Hz ja "Deep Black Panel" võrreldes EX500-ga. |
Ja see 200Hz ning "Deep Black Panel" on seda hinda väärt? Pole eriti kursis 100Hz vs 200Hz paremus...
| Kommentaarid: 19 loe/lisa |
19 |
p3000
23.08.2010 12:54:02
| Ramm kirjutas: |
| p3000 kirjutas: |
| Ramm kirjutas: |
Ja see 200Hz ning "Deep Black Panel" on seda hinda väärt? Pole eriti kursis 100Hz vs 200Hz paremus... |
-Motionflow 200Hz is the world’s first quadruple speed frame rate for TV, that takes picture clarity a giant leap further. Not one, but three new images are added to the action, predicting motion in all directions to create powerfully sharp images displayed at an astonishing 200 frames per second. You won’t miss a single detail of sporting action. Films and cartoons shot at 24 frames per second are enhanced with Motionflow 200Hz too, which inserts seven new images to get rid of annoying judder or blur.
-A specially constructed LCD panel that dramatically reduces glare and reflection from your television screen, even in bright rooms. Deep Black Panel technology guarantees realistic pictures with incredible contrast, superb brightness and vivid colours.
NB! Sony reklaamtekst.Antud mudelit ei ole kusagil müügil,sellepärast võibolla ka kallim hind,veel.
| Kommentaarid: 15 loe/lisa |
15 |
oliver.
23.08.2010 13:24:09
KDL40HX700 on mõnes kohas juba ammu müügil.
minu meelest on see tavaline CCFL-valgustus pigem eeliseks.
Ütlen ausalt, pole veel näinud LED-telerit, mis mulle pildi poolest enam meeldiks kui mõni n-ö tavaline.
| Kommentaarid: 280 loe/lisa |
239 |
2korda2
23.08.2010 14:47:09
| p3000 kirjutas: |
| -Motionflow 200Hz is the world’s first quadruple speed frame rate for TV, that takes picture clarity a giant leap further. Not one, but three new images are added to the action, predicting motion in all directions to create powerfully sharp images displayed at an astonishing 200 frames per second. You won’t miss a single detail of sporting action. Films and cartoons shot at 24 frames per second are enhanced with Motionflow 200Hz too, which inserts seven new images to get rid of annoying judder or blur. |
Enda Pana G20 seeria telekal on ka see "teeme kaadreid juurde" tehnika ja oli üks esimesi, mille välja lülitasin. Konkreetselt 24p loodud filmidest jäi mulje, nagu keegi oleks koduvideoid teinud, võeh.
| Kommentaarid: 7 loe/lisa |
rene p
23.08.2010 17:33:14
| 2korda2 kirjutas: |
| p3000 kirjutas: |
Enda Pana G20 seeria telekal on ka see "teeme kaadreid juurde" tehnika ja oli üks esimesi, mille välja lülitasin. Konkreetselt 24p loodud filmidest jäi mulje, nagu keegi oleks koduvideoid teinud, võeh. |
Kipub olema jah nii, et filmid just on kuidagi väga ebaloomulikud selle tehnikaga. Aga sporti ilmselt on parem just sellega vaadata. Lihtsalt peab näppima siis pidevalt seadeid vms.
68 |
MummikAl
23.08.2010 19:53:57
mul nii hea meel, et keegi 3d telekate osas on abiks olnud
| Kommentaarid: 42 loe/lisa |
39 |
oliver.
23.08.2010 20:08:35
| MummikAl kirjutas: |
mul nii hea meel, et keegi 3d telekate osas on abiks olnud  |
nii palju võin soovitada, et kui see 3D on oluline, siis alla 46 tolli küll erilist mõtet soetada pole - 40 tolli on wow-elamuse jaoks ikka maru pisike.
Kui hind on oluline, võid ju Samsungi 46-tollise CCFL-valgustusega 7. seeria osta (LE40C7...).
Kui Philipsi eelmise aasta 8. seeria oli tõeline hitt ja lausa defitsiit, siis tänavune.. no ma ei tea, peab ikka tõsine Philipsi fänn olema.
239 |
2korda2
23.08.2010 20:11:46
MummikAl,
mõtle nüüd natuke loogiliselt. 3D telekate hinnatase on selline, mis väga suure osa inimeste jaoks tähendab päris mitut kuupalka. Seejuures üsna suur osa sellest hinnast on justnimelt 3D võimalusel. Viimase nautimine võib olla aga veel päris mitme aasta jooksul problemaatiline lihtsalt materjali puudumise tõttu (kaua sa seda paari demoplaati ikka vaatad?). Nimetet põhjusil on selliste telekate omamise kogemust (et hinnanagut anda, peaks omama võrdlevat kogemust erinevate mudelitega) niivõrd vähestel, et mingi soovituse andmiseks sellest lihtsalt ei piisa.
Ramones
23.08.2010 20:26:13
| 2korda2 kirjutas: |
| Viimase nautimine võib olla aga veel päris mitme aasta jooksul problemaatiline lihtsalt materjali puudumise tõttu (kaua sa seda paari demoplaati ikka vaatad?). |
Ei ütleks, et 3D materjali ainult paari demoplaadi jagu oleks: Ilmunud ja kohe saabuvate 3D tiitlite nimekiri blu-ray.com järgi
Keegi siit Philipsi 40" PFL5605 ekraani omab? Oskab ehk muljetada?
| Kommentaarid: 76 loe/lisa |
75 |
kaval
23.08.2010 20:44:20
mummik kas sinist või punast kütet ka müüd ???
kahjuks ei saanud privasse panna kirja kuna pole piisavalt pikalt HV-d kasutanud
MummikAl
23.08.2010 21:38:27
panin sulle ps'i.
ps3 mängud juba tulevad ka järjest 3d toega ja filmid on samuti. arvan, et paras aeg üks 3d telekas soetada. mis sellel philipsi 8 seerial siis viga on, et seda ei soovita? ja mida arvata sonyst?
39 |
p3000
24.08.2010 10:20:03
Philips |
46pfl9705h saabus Eestisse müüki..(aga ainult paar tükki)
hinnaklass ca 2400e
15 |
-Koppel-
24.08.2010 13:51:08
| Kas on olemas telerit, mis suudab LAN-i kaudu xvid kodeeringus *.avi ning h264 kodeeringus *.mkv faile mängida?
| Kommentaarid: 10 loe/lisa |
10 |
tozz
24.08.2010 22:37:27
| 2korda2 kirjutas: |
| 3D telekate hinnatase on selline, /.../ Seejuures üsna suur osa sellest hinnast on justnimelt 3D võimalusel. |
Asjatundjad ehk täiendavad, aga minuarust ei pea väide paika. Eelmisel aastal olid uued mudelid samas hinnas, mis sel aastal; lisaks muudele uuendustele on juurde tulnud ka 3D tugi. Kui überklassist võtta, siis minu mäletamist mööda maksis 40pfl9704 alguses 34 tuhat. Nüüd 40" hinda veel ei tea, aga kui 46" 9705 maksab 37+, siis loogiliselt võttes peaks uue 40pfl9705 hind samuti 30-35 tuhande vahele tulema. Ei saa väita, et uued mudelid on ainult 3D pärast kallimad, alati on uued mudelid kallimad. Kas mitte Samsungi õhukesed led-taustavalgustusega mudelid uutena kallimadki polnud, kui praegu 3D toega sama seeria (7. ja 8.) versioonid?
25.08.2010 00:01:59
sorry, et jälle tyytan, aga ma ostan siiamaani oma non 3d telekat lg-lt, sest minu tellitud 47le8500 on siiamaani mudel,mida batikumis olemas pole
sama variant, mis eestis olemas lx9500 , aga hinnavahe 8000-on olemas, aga see 3D. Ja selle mõttetu 3D eest ma nagu ei raatsi rohkem raha välja käia
Ramm
25.08.2010 11:13:21
| jeesus188 kirjutas: |
sama <b>variant</b>, mis eestis olemas lx9500 , aga hinnavahe 8000-on olemas, aga see 3D. Ja selle mõttetu 3D eest ma nagu ei raatsi rohkem raha välja käia  |
Pead leppima 42" ekraaniga.Seda 47" minu teada ei tule nii pea.
19 |
IntZ
25.08.2010 11:22:17
| Ramones kirjutas: |
| 2korda2 kirjutas: |
Ei ütleks, et 3D materjali ainult paari demoplaadi jagu oleks: Ilmunud ja kohe saabuvate 3D tiitlite nimekiri blu-ray.com järgi |
Mõnikümmend paska filmi... mis kasu neist? Lihtsalt sellepärast vaatad neid, et nad 3D on? :)
Mulle tundub ka, et on liiga vara veel 3D peale raha raisata.
| Kommentaarid: 41 loe/lisa |
39 |
1dumbpcuser
25.08.2010 11:30:51
Mis probleemiks, telli nt Pixmaniast ära siis?
_________________ M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat |
97 |
Ramones
25.08.2010 11:44:05
IntZ, Filmide vaadatavus jäägu iga inimese enda otsustada. Mina kommenteerisin ainult väidet, et neid filme on praegu vaid "paar demoplaati". Ma ise ka pole suurem asi 3D fanaatik - kuskil kinos ju mõnda filmi tore vaadata aga kodus küll ei viitsiks mingeid ebamugavaid prille kanda teleka vahtimise ajal. Pealegi neid tiitleid on vähe, mida ka tõesti tasuks 3D-na kaeda. Mõttetu gimmick minu jaoks veel hetkel.
Soovitage mõnda normaalset telekat arvuti taha mängimiseks / filmide vaatamiseks 40" mõõdus. Hinnaklass kuni 15k, plasmat ei taha.
75 |
IntZ
25.08.2010 13:16:20
Olgu olgu, maitse asi , aga väga väga vähe on neid sellegi poolest.. Ise olen rõõmus, et HD laialt levinud on, sellest mulle täitsa piisab.
Filmide jaoks tundub 42PFL5405H täitsa hea, mängimise koha pealt ei oska kommenteerida.
39 |
Ramones
25.08.2010 13:32:33
| IntZ, sul endal see teler olemas?
75 |
ms
MummikAl
29.08.2010 05:31:49
ok sain ka siin paar soovitust, et ennem ei ole mõtet 3d telekat osta kui ilma prillideta versioon väljas. äkki siis keegi soovitab parimat telekat, mis oleks 42" (kuna istun 2m kaugusel). parimaga ei pea ma silmas seda, mis on üle makstud vaid parima hinna ja kvaliteedi suhet kõrgemas hinnaklaasis. isegi ei ole vaja soovitada konkreetset mudelist, aga tootja on tähtis (märksõna: raha on, aga ei taha seda tuulde loopida)
39 |
1dumbpcuser
97 |
elukaz
29.08.2010 10:32:55
MummikAl, ilma prillita 3d-d võid ootama jäädagi.
158 |
p3000
29.08.2010 11:47:11
| elukaz kirjutas: |
| MummikAl, ilma prillita 3d-d võid ootama jäädagi. |
..ei,mitte kauem kui aastalõpus..(osad spetsialistid arvavad,et "bullshit" ,aga osad ,kes on ka pilti juba näinud ,arvavad,et asjal on jumet)
Toshiba siis , http://www.theinquirer.net/inquirer/news/1729601/toshiba-release-3d-tvs-dont-glasses
ja Sonyl ka samad plaanid http://www.npr.org/templates/story/story.php?storyId=129443079
mõned soome kommid (uskuda või mitte..):
-olen itse omin silmin katsonut televisiota, joka näytti upeaa 3d kuvaa ilman laseja eikä kulmalla ollut juurikaan väli. Kallishan se laite oli kuin mikä, sattui tulemaan työssä vastaan. tutustuin laitteeseen sattumalta, kävelin ohi ja pysähdyin katsomaan, että mitä h-vettiä..
-Olin yritykseni puolesta vuoden alussa ja viime vuoden alussa CES-messuilla ja siellä oli useita 3D-televisioita jotka eivät vaatineet laseja ja ko. televisioita pystyi katsomaan mistä tahansa kulmasta ongelmitta
-Messuilla on esitelty kahdenlaisia "seuraavan sukupolven" 3d-teknologioita. Yksinkertaisempi on 64 eri suuntaan kahta kuvaa tarjoava tekniikka, jossa kuva näkyy oikein kunhan sijoittaa päänsä jonkin sektorin kohdalle ja pitää sen sitten paikoillaan. Kehittyneempi suuntaus käyttää näyttöön integroitua kameraa katsojan pään sijainnin selvittämiseen, jolloin oikeanlainen kuva saadaan esitettyä katselupaikalle, mutta kuitenkin vain yhdelle katselijalle kerrallaan.
(rohkem infot ,Google otsinguga tehku igaüks ise..)
15 |
fedja
29.08.2010 23:39:23
Keegi LG 60PK250 / 550 / 750 mudelitega omab kogemusi ?
Pixmania-s on 60PK760 saadaval, 750 ja 760 vahe on milline, toitekaablis ?
Hetkel tundub see mudel 60" plasmadest kõige mõistlikum, või oskab keegi veel midagi välja pakkuda ?
116 |
tuut
| Kommentaarid: 27 loe/lisa |
26 |
uus kasuta
tuut
30.08.2010 19:18:50
telli ära, tahaks teada, kui kiiresti su tellimus kustutatakse
vaadates seda mudelit, siis allahindlus on 90%
26 |
Flavius
118 |
tuut
30.08.2010 20:01:52
on selles võimalus kahelda, et tegu vale hinnaga?
minu meelest nad ei tegele heategevusega
26 |
nah
| Kommentaarid: 150 loe/lisa |
141 |
p3000
15 |
tuut
31.08.2010 02:42:49
see veel ei tõesta midagi, räägi parem, kas tegid tellimuse või mitte
http://www.hometechworld.net/about.php
kuigi olen ise ka enam kui kindel, et scam, pakub see küsimus natuke meelelahutust ikkagi
26 |
p3000
31.08.2010 10:22:17
| tuut kirjutas: |
kuigi olen ise ka enam kui kindel, et scam, pakub see küsimus natuke meelelahutust ikkagi  |
tegin tellimuse ja sain arve,et maksta ülekandega:
Barclays Bank,HomeTech,IBAN:GB05 BARC 2073 5353 5762 72,Order Total: €1,625.95
ja selgitus:
Allow 3-7 working days for the payment to reach our account.
Kõik nagu oleks ok,aga maksma ma ikkagi ei hakka,risk liiga suur.
15 |
ms
31.08.2010 10:25:17
| ülekandega maksmine e-poes on muidugi hea absurd. tasuks reportida googlele ja teistele filtritele.
fedja
31.08.2010 10:34:11
| fedja kirjutas: |
Hetkel tundub see mudel 60" plasmadest kõige mõistlikum, või oskab keegi veel midagi välja pakkuda ? |
Oskab keegi veel midagi soovitada 60" plasmade puhul ?
Hetkel kaldun ise 60PK760 poole, PK250 mudel tundub liiga nuditud, 2x HDMI jne.
116 |
abc9
| Kommentaarid: 194 loe/lisa |
168 |
o7af
31.08.2010 13:42:20
| Kui keegi valdab teemat: sony 40EX500-40EX600-40EX700 , hinnavahe ca 2000 krooni - kas oleks põhjust see maksta uuema mudeli eest või pole vahet?
15 |
p3000
31.08.2010 14:08:55
| ms kirjutas: |
| ülekandega maksmine e-poes on muidugi hea absurd. tasuks reportida googlele ja teistele filtritele. |
ei,saab ka krediitkaardiga maksta:
�1,625.95
Sub-Total: �1,625.95
Shipping: �0.00
International Credit Card Charge (17.5%): �284.54
Total: �1,910.49
sellise poe puhul oleks turvaline variant kohapeal poes kaup vastu võtta ja maksta..
15 |
erko
31.08.2010 16:48:19
| p3000 kirjutas: |
| ms kirjutas: |
�1,625.95
Shipping: �0.00
Total: �1,910.49
sellise poe puhul oleks turvaline variant kohapeal poes kaup vastu võtta ja maksta.. |
Minu teada ei tohiks kaupmehed kaardimaksele eritasu lisada. Vähemalt VISA süsteemis ei ole see lubatud. Ja 17.5% !! kõlab ikka erilise rip-off'ina.
Ma ei oleks elu sees sellisest poest nõus ostma.
| Kommentaarid: 26 loe/lisa |
26 |
Flavius
31.08.2010 16:51:19
| 17.5% on Inglismaa käibemaksumäär.
118 |
erko
31.08.2010 17:46:16
17.5% võib UK VAT olla kuid see peaks hinnas juba sees olema. Kindlasti ei ole see müstiline International Credit Card Charge käibemaks, sest valides makseviisiks Bank transfer või Store card seda Charge'i ei lisandu.
Kas keegi siinsetest töötab pangas vms. ning võiks seda kinnitada või ümber lükata, et VISA/MC/Amer'i kaarte aktsepteeriv kaupmees ei tohi kaardimaksele rakendada mingit täiendavat tasu? Minu teada rikub kaupmees sellega nende kaardisüsteemidega sõlmitud lepingut.
26 |
Syncmahv
31.08.2010 18:18:11
Suvilasse sai selline soetatud, väga hea teler, tõsiselt Hiljem sai teine veel juurde ostetud
102 |
B6
159 |
jonnipunn
01.09.2010 10:22:42
| o7af kirjutas: |
| Kui keegi valdab teemat: sony 40EX500-40EX600-40EX700 , hinnavahe ca 2000 krooni - kas oleks põhjust see maksta uuema mudeli eest või pole vahet? |
Võta EX500. EX600 ja 700 on ääreleedidega ja võid saada väga koleda plekilise pildiga isendi.
| Kommentaarid: 24 loe/lisa |
24 |
tuut
01.09.2010 11:15:06
| EX600 on ju 100hz süsteemita ka?
26 |
p3000
01.09.2010 14:05:59
soovitaks ka 47pfl5604h kui veel kusagil on saada..
või uuematest:
-LG 47LD450 h eestis 755.-e
-Samsung LE46C530 h 775.-e
-Samsung le46C670 h1000.-e
-Samsung LE46B650 h 915.-e
või
-LG 52LD550 h1180.-e (selle mudeli ostaks isegi endale.. hind/kvaliteet eriti hea ,sest tänapäeval alla 50" pole mõtet norm.mõõtmetega tuppa osta )
15 |
MummikAl
01.09.2010 20:33:02
| küsiks siis vastupidi, et milline 42" (42" kuna vaatan 2m kauguselt) kallim telekas tasuks hetkel osta. ps3, filmid ja natukene ka digi-tv'd plaanis vaadata.
39 |
