Ramm
23.08.2010 11:28:42
| p3000 kirjutas: |
| Ramm kirjutas: |
Edit: Või oskab keegi kaasa rääkida Sony KDL40HX700 mudelist,et miks sellel selline kirves hind? Tal tavaline LCD ekraan,mitte LED ega midagi...või ma eksin? |
-HX on +200Hz ja "Deep Black Panel" võrreldes EX500-ga. |
Ja see 200Hz ning "Deep Black Panel" on seda hinda väärt? Pole eriti kursis 100Hz vs 200Hz paremus...
| Kommentaarid: 18 loe/lisa |
18 |
p3000
23.08.2010 11:54:02
| Ramm kirjutas: |
| p3000 kirjutas: |
| Ramm kirjutas: |
Ja see 200Hz ning "Deep Black Panel" on seda hinda väärt? Pole eriti kursis 100Hz vs 200Hz paremus... |
-Motionflow 200Hz is the world’s first quadruple speed frame rate for TV, that takes picture clarity a giant leap further. Not one, but three new images are added to the action, predicting motion in all directions to create powerfully sharp images displayed at an astonishing 200 frames per second. You won’t miss a single detail of sporting action. Films and cartoons shot at 24 frames per second are enhanced with Motionflow 200Hz too, which inserts seven new images to get rid of annoying judder or blur.
-A specially constructed LCD panel that dramatically reduces glare and reflection from your television screen, even in bright rooms. Deep Black Panel technology guarantees realistic pictures with incredible contrast, superb brightness and vivid colours.
NB! Sony reklaamtekst.Antud mudelit ei ole kusagil müügil,sellepärast võibolla ka kallim hind,veel.
| Kommentaarid: 15 loe/lisa |
15 |
oliver.
23.08.2010 12:24:09
KDL40HX700 on mõnes kohas juba ammu müügil.
minu meelest on see tavaline CCFL-valgustus pigem eeliseks.
Ütlen ausalt, pole veel näinud LED-telerit, mis mulle pildi poolest enam meeldiks kui mõni n-ö tavaline.
| Kommentaarid: 280 loe/lisa |
239 |
2korda2
23.08.2010 13:47:09
| p3000 kirjutas: |
| -Motionflow 200Hz is the world’s first quadruple speed frame rate for TV, that takes picture clarity a giant leap further. Not one, but three new images are added to the action, predicting motion in all directions to create powerfully sharp images displayed at an astonishing 200 frames per second. You won’t miss a single detail of sporting action. Films and cartoons shot at 24 frames per second are enhanced with Motionflow 200Hz too, which inserts seven new images to get rid of annoying judder or blur. |
Enda Pana G20 seeria telekal on ka see "teeme kaadreid juurde" tehnika ja oli üks esimesi, mille välja lülitasin. Konkreetselt 24p loodud filmidest jäi mulje, nagu keegi oleks koduvideoid teinud, võeh.
| Kommentaarid: 7 loe/lisa |
rene p
23.08.2010 16:33:14
| 2korda2 kirjutas: |
| p3000 kirjutas: |
Enda Pana G20 seeria telekal on ka see "teeme kaadreid juurde" tehnika ja oli üks esimesi, mille välja lülitasin. Konkreetselt 24p loodud filmidest jäi mulje, nagu keegi oleks koduvideoid teinud, võeh. |
Kipub olema jah nii, et filmid just on kuidagi väga ebaloomulikud selle tehnikaga. Aga sporti ilmselt on parem just sellega vaadata. Lihtsalt peab näppima siis pidevalt seadeid vms.
68 |
MummikAl
23.08.2010 18:53:57
mul nii hea meel, et keegi 3d telekate osas on abiks olnud
| Kommentaarid: 42 loe/lisa |
39 |
oliver.
23.08.2010 19:08:35
| MummikAl kirjutas: |
mul nii hea meel, et keegi 3d telekate osas on abiks olnud  |
nii palju võin soovitada, et kui see 3D on oluline, siis alla 46 tolli küll erilist mõtet soetada pole - 40 tolli on wow-elamuse jaoks ikka maru pisike.
Kui hind on oluline, võid ju Samsungi 46-tollise CCFL-valgustusega 7. seeria osta (LE40C7...).
Kui Philipsi eelmise aasta 8. seeria oli tõeline hitt ja lausa defitsiit, siis tänavune.. no ma ei tea, peab ikka tõsine Philipsi fänn olema.
239 |
2korda2
23.08.2010 19:11:46
MummikAl,
mõtle nüüd natuke loogiliselt. 3D telekate hinnatase on selline, mis väga suure osa inimeste jaoks tähendab päris mitut kuupalka. Seejuures üsna suur osa sellest hinnast on justnimelt 3D võimalusel. Viimase nautimine võib olla aga veel päris mitme aasta jooksul problemaatiline lihtsalt materjali puudumise tõttu (kaua sa seda paari demoplaati ikka vaatad?). Nimetet põhjusil on selliste telekate omamise kogemust (et hinnanagut anda, peaks omama võrdlevat kogemust erinevate mudelitega) niivõrd vähestel, et mingi soovituse andmiseks sellest lihtsalt ei piisa.
Ramones
23.08.2010 19:26:13
| 2korda2 kirjutas: |
| Viimase nautimine võib olla aga veel päris mitme aasta jooksul problemaatiline lihtsalt materjali puudumise tõttu (kaua sa seda paari demoplaati ikka vaatad?). |
Ei ütleks, et 3D materjali ainult paari demoplaadi jagu oleks: Ilmunud ja kohe saabuvate 3D tiitlite nimekiri blu-ray.com järgi
Keegi siit Philipsi 40" PFL5605 ekraani omab? Oskab ehk muljetada?
| Kommentaarid: 76 loe/lisa |
75 |
kaval
23.08.2010 19:44:20
mummik kas sinist või punast kütet ka müüd ???
kahjuks ei saanud privasse panna kirja kuna pole piisavalt pikalt HV-d kasutanud
MummikAl
23.08.2010 20:38:27
panin sulle ps'i.
ps3 mängud juba tulevad ka järjest 3d toega ja filmid on samuti. arvan, et paras aeg üks 3d telekas soetada. mis sellel philipsi 8 seerial siis viga on, et seda ei soovita? ja mida arvata sonyst?
39 |
p3000
24.08.2010 09:20:03
Philips |
46pfl9705h saabus Eestisse müüki..(aga ainult paar tükki)
hinnaklass ca 2400e
15 |
-Koppel-
24.08.2010 12:51:08
| Kas on olemas telerit, mis suudab LAN-i kaudu xvid kodeeringus *.avi ning h264 kodeeringus *.mkv faile mängida?
| Kommentaarid: 10 loe/lisa |
10 |
tozz
24.08.2010 21:37:27
| 2korda2 kirjutas: |
| 3D telekate hinnatase on selline, /.../ Seejuures üsna suur osa sellest hinnast on justnimelt 3D võimalusel. |
Asjatundjad ehk täiendavad, aga minuarust ei pea väide paika. Eelmisel aastal olid uued mudelid samas hinnas, mis sel aastal; lisaks muudele uuendustele on juurde tulnud ka 3D tugi. Kui überklassist võtta, siis minu mäletamist mööda maksis 40pfl9704 alguses 34 tuhat. Nüüd 40" hinda veel ei tea, aga kui 46" 9705 maksab 37+, siis loogiliselt võttes peaks uue 40pfl9705 hind samuti 30-35 tuhande vahele tulema. Ei saa väita, et uued mudelid on ainult 3D pärast kallimad, alati on uued mudelid kallimad. Kas mitte Samsungi õhukesed led-taustavalgustusega mudelid uutena kallimadki polnud, kui praegu 3D toega sama seeria (7. ja 8.) versioonid?
24.08.2010 23:01:59
sorry, et jälle tyytan, aga ma ostan siiamaani oma non 3d telekat lg-lt, sest minu tellitud 47le8500 on siiamaani mudel,mida batikumis olemas pole
sama variant, mis eestis olemas lx9500 , aga hinnavahe 8000-on olemas, aga see 3D. Ja selle mõttetu 3D eest ma nagu ei raatsi rohkem raha välja käia
Ramm
25.08.2010 10:13:21
| jeesus188 kirjutas: |
sama <b>variant</b>, mis eestis olemas lx9500 , aga hinnavahe 8000-on olemas, aga see 3D. Ja selle mõttetu 3D eest ma nagu ei raatsi rohkem raha välja käia  |
Pead leppima 42" ekraaniga.Seda 47" minu teada ei tule nii pea.
18 |
IntZ
25.08.2010 10:22:17
| Ramones kirjutas: |
| 2korda2 kirjutas: |
Ei ütleks, et 3D materjali ainult paari demoplaadi jagu oleks: Ilmunud ja kohe saabuvate 3D tiitlite nimekiri blu-ray.com järgi |
Mõnikümmend paska filmi... mis kasu neist? Lihtsalt sellepärast vaatad neid, et nad 3D on? :)
Mulle tundub ka, et on liiga vara veel 3D peale raha raisata.
| Kommentaarid: 41 loe/lisa |
39 |
1dumbpcuser
25.08.2010 10:30:51
Mis probleemiks, telli nt Pixmaniast ära siis?
_________________ M: |
96 |
Ramones
25.08.2010 10:44:05
IntZ, Filmide vaadatavus jäägu iga inimese enda otsustada. Mina kommenteerisin ainult väidet, et neid filme on praegu vaid "paar demoplaati". Ma ise ka pole suurem asi 3D fanaatik - kuskil kinos ju mõnda filmi tore vaadata aga kodus küll ei viitsiks mingeid ebamugavaid prille kanda teleka vahtimise ajal. Pealegi neid tiitleid on vähe, mida ka tõesti tasuks 3D-na kaeda. Mõttetu gimmick minu jaoks veel hetkel.
Soovitage mõnda normaalset telekat arvuti taha mängimiseks / filmide vaatamiseks 40" mõõdus. Hinnaklass kuni 15k, plasmat ei taha.
75 |
IntZ
25.08.2010 12:16:20
Olgu olgu, maitse asi , aga väga väga vähe on neid sellegi poolest.. Ise olen rõõmus, et HD laialt levinud on, sellest mulle täitsa piisab.
Filmide jaoks tundub 42PFL5405H täitsa hea, mängimise koha pealt ei oska kommenteerida.
39 |
Ramones
25.08.2010 12:32:33
| IntZ, sul endal see teler olemas?
75 |
ms
MummikAl
29.08.2010 04:31:49
ok sain ka siin paar soovitust, et ennem ei ole mõtet 3d telekat osta kui ilma prillideta versioon väljas. äkki siis keegi soovitab parimat telekat, mis oleks 42" (kuna istun 2m kaugusel). parimaga ei pea ma silmas seda, mis on üle makstud vaid parima hinna ja kvaliteedi suhet kõrgemas hinnaklaasis. isegi ei ole vaja soovitada konkreetset mudelist, aga tootja on tähtis (märksõna: raha on, aga ei taha seda tuulde loopida)
39 |
1dumbpcuser
29.08.2010 09:02:52
tootja on tähtis
Panasonicu plasmad,
LCD-d: Sharp, Sony, Philipsi tippmudelid pidid ka suht head olema
96 |
elukaz
29.08.2010 09:32:55
MummikAl, ilma prillita 3d-d võid ootama jäädagi.
155 |
