keegi-Hannes
31.10.2003 22:29:05
Eriarvamused AGP FastWrite kohta. |
Teema selle nii vastuolulise suundumuse kohta hakkas huvituma: KAS TASUB SISSELÜLITADA "AGP FAST WRITE" (Intel P3 ja AMD K7 ning hilisemate süsteemide juures).
Mamma: Via Pro133a AGPx4 ja kaartTi4200 ning arvan et ei tasu.
Hulgi ka vastakaid seisukohti netist.
AGP Fast Write (FW)
Fast writes can be used to transfer such data as 2D operations, graphics data, or
textures. Fast writes are disabled for many chipsets, as they are not capable of supporting this feature. There are also quite a few chipsets that claim support for fast writes, but in reality they are incompatible with the majority of available graphics accelerators.
AGP Fast Write Control: This is by far one of the most beneficial, and overlooked video card tweak one can perform in the BIOS. You will need to make sure that your video card supports this feature as it can cause major problems if you try enabling this feature without the proper support. AGP Fast Writes can increase video speed roughly 1-5% and is supported by most recent video cards. Fast Writes allows the computer to send video-based calls directly to the video card, thereby bypassing the system's main memory system.
Fast Write. Fast writes allows the CPU to send data to the Graphics card without having to go through RAM, making it a far more optimal approach. That said in reality most benchmarks done on this have shown it to be of little actual benefit, in some cases performing slower, not mention on other systems it causes stability problems. As a result you might want to run a few benchmarks before choosing whether or not to leave this On or Off. On some systems this can cause stability problems & where it does you should set Off
Samas venekeelne sait kus keskendutakse mälukiruse taga-ajamisele on "OFF" seis pigem kasuks.
http://www.ferra.ru/online/system/15900/
Mida arvavate Teie?
| Kommentaarid: 42 loe/lisa |
38 |
VR53
31.10.2003 23:34:21
Mina paneks nVidial selle peale ja ATIl võtaks maha, viimasel katsetamine ei teeks muidugi paha.
_________________ Uued Lenovo sülearvutid: www.lenovoarvutid.ee - kasuta koodi "HINNAVAATLUS", et saada 50€ alla P14s Gen 6 R7 hinnast!
| Kommentaarid: 842 loe/lisa |
636 |
keegi-Hannes
01.11.2003 12:08:07
| CMaster kirjutas: |
| Mina paneks nVidial selle peale ja ATIl võtaks maha, viimasel katsetamine ei teeks muidugi paha. |
Noh aga profiles sul R9100 mida sa siis hetkel kasutad "ON" or "OFF"?
38 |
VR53
01.11.2003 12:34:42
| keegi-Hannes kirjutas: |
| Noh aga profiles sul R9100 mida sa siis hetkel kasutad "ON" or "OFF"? |
Off, see ei andnud viimati midagi juurde.
636 |
ZorroZip
01.11.2003 12:43:23
Hmm ma proovin ka kohe asja ära, kaart siis 9100.
Annan kohe teada kas vahet esineb minu arvutiga.
63p on vahe 3dmark2k1 fw kasuks.
| Kommentaarid: 51 loe/lisa |
50 |
tools
01.11.2003 17:50:57
| nVidial 3D Markis 500 punni rohkem kui fastwrite enabled aga Atil ei muutu midagi.
95 |
Oobik
| Kommentaarid: 74 loe/lisa |
keegi-Hannes
02.11.2003 03:28:45
| tools kirjutas: |
| nVidial 3D Markis 500 punni rohkem kui fastwrite enabled aga Atil ei muutu midagi. |
Oot! Ega sa ei taha öelda et sul ühel süsteemil kaks videokaarti korraga kasutusel?!
Või ehk korda-mööda? Ütle mis Geforce see selline on?
38 |
EvilMick007
02.11.2003 19:11:24
Ütle mis Geforce see selline on? |
Minul oli näiteks kunagi kui ti4200-t omasin täpselt sama asi, et FW sisse lülitatud ja ~500 punkti rohkem kohe.
EDIT: inf mis järmises postis paluti,
Driver: Detonator 44.03
Masina conf sel hetkel: GF4ti4200 128MB(AGP 4x), AXP1700+, Gigabyte ga7vax(kt400) 384MB DDR333.
_________________ Pentestimise ja küberturbe konsultatsiooni soovi korral võib kirjutada..
viimati muutis EvilMick007 02.11.2003 21:30:02, muudetud 1 kord |
| Kommentaarid: 46 loe/lisa |
41 |
keegi-Hannes
02.11.2003 19:55:29
Kui nüüd Ti4200 kohalt võtta siis ksekmisele 8000 punnile +500, siis see teeb +6,25% aga imestama paneb miks minul nii +/- 25 punni ümber ehk siis pea muutumatu. Kuid "ON" asend teeb tunduvalt ebastabiilsemaks. Teoorjas peaks see FW võitu andma madala RAM-i sagedustega (66-100MHz) süsteemide juures. Sest siis ei saada "põhjasild", videokaardikohast inf. nii RAM-i kui ka AGP-se vaid ainiti AGP-se. Ning see aeg mille juures RAM videoandmetest loobuma peab jääb ära. Aga nüüdsete süsteemide põhjasillad kõik AGP 4x või 8x toega ja RAM-d ka 166-200MHz ja kiiremad ja see vastuvõtu- ja loobumise ajakadu na tühine? Märkige juurde ka mitmekordse AGP kiirusega emme ja v-kaart töötavad. Ah ja andke teada ka oma V-kaardi driverist, sest järjest vähem toiminguid jääb ju BIOS-e korraldada.
Rahvas kes tihti süsteeme kokku panevad! Äkki olete leidnud netist, niiöelda soovitavaid tabeleid FastWrite ON/OFF-i kohta (ühes veerus siis mammad ja teises videokaardid)?
38 |
yxmees
Aeg Maha 2a
02.11.2003 21:35:56
| ati ja via??, olen proovinud (video 9500pro ja ema via4x400) atiga fast write maha, via agp driveri unustada ja videole omega on vähemalt minul olnud parim valik
| Kommentaarid: 44 loe/lisa |
40 |
keegi-Hannes
02.11.2003 23:32:16
Kuus enamvähem järjest (vahepeal restart-to-BIOS ja ON or OFF) tehtud 3DMark2001SE tulemust.
Süstem: VIA Apollo Pro133T (VT82C694T kivi põhjasillas) (AGP 4x) P3-1200 ja Ti4200 64MB (AGP 8X). 256MB noname RAM (1-kahepoolne DIMM).
1.FW-ON =7871
2.FW-ON =7869
3.FW-OFF =7875
4.FW-OFF =7879
5.FW-ON =7859
6.FW-OFF =7872 -Nii ka jätsin jumal temaga.
Aga kuidas osale rahvale annab see "FW-ON" 500 "Marki" juurde on mystika?
38 |
tools
03.11.2003 21:47:54
Või ehk korda-mööda? Ütle mis Geforce see selline on? Vaata confi...
95 |
EvilMick007
03.11.2003 22:08:04
| Aga kuidas osale rahvale annab see "FW-ON" 500 "Marki" juurde on mystika? |
No 1 asi on see, sinu masin ei suuda seda ti4200 võimeid niigi ära kasutada, siis polegi sealt palju juurde saada ja kas kas need vanemad chipid midagi selle FW-ga midagi korralikku peale hakata oskasid on juba teine asi
_________________ Pentestimise ja küberturbe konsultatsiooni soovi korral võib kirjutada.. |
41 |
tools
03.11.2003 22:25:26
| Ongi kõige lihtsam teha mõned 3DMarki testid nii OFF kui ON ja vastavalt sellele teha järeldus mis konkreetsele masinale parem on.
95 |
eeRuheeRu
03.11.2003 22:36:30
mul pole vahet, kas panen on või off, ikka Sisoft sandra näitab, et off
_________________ M:Corsair 512MB CL2 PC3200, Spire cooler WR3 90.- |
| Kommentaarid: 10 loe/lisa |
9 |
keegi-Hannes
04.11.2003 10:09:54
| EvilMick007 kirjutas: |
sinu masin ei suuda seda ti4200 võimeid niigi ära kasutada  |
Ei saa aru mida sa just öelda tahtsid. . aga mind pani imestama, et mõnedel süsteemidel annab BIOSE seting FastWrite ON 500 lisakiirusepunkti. Mõnedel aga mitte tuhkagi, kuigi emaplaat seda sätet toetab ja videokaart on ka selleks valmis. Minu Sandra ja ka 3DMark näitavad FW-ON, siis kui olen selle Bioses aktiviseerinud nii et kahtlust et säte sisse ei lülitu on alusetu (ka SB-addressing on aktiivne).
38 |
xtr
07.11.2003 10:14:52
| eeRuheeRu kirjutas: |
| mul pole vahet, kas panen on või off, ikka Sisoft sandra näitab, et off |
tahaks ka teada miks...
_________________ M: Magic Mouse + Keyboard, MX Master 3S
M: Ryzen 1700X/16GB DDR4/1TB SSD/650W Gold
M: 2021 MacBook Pro 14 M1/16/500/SWE |
| Kommentaarid: 327 loe/lisa |
271 |
eeRuheeRu
07.11.2003 11:07:30
ma kah, sest BIOS-is on asi peale krutitud
9 |
EvilMick007
07.11.2003 15:59:19
Ei saa aru mida sa just öelda tahtsid. . |
Tahtsin öelda seda, et sul arvuti natuke nõrk, et Ti4200 kaardi võimeid ära kasutada, see FW oleks boost sel juhul, kui su masin suudaks kaarti korralikult ära tarvitada, p3 1200 ei ole Gf4TI seeria kaardi täis võimsuse jaoks piisav prose ja kui ei suuda niisama täit võimu ära kasutada, kuidas siis peaks veel lisa võimsusega hakkama saama...
41 |
keegi-Hannes
07.11.2003 23:02:30
Aitüma püüdluse eest selgitada!
Aga Videokaart jääb ikka selleks mis ta on. Olgu siis TNT või FX5900 (GF4 seal keskel kuskil).
Üks on nõrgem teine keskmine kolmas tipus(hetkel). See milise prosega ta koostöötama on pandud seda pingerida ei muuda (olgu cel300 või Xeon).
Aga sinukirjeldatud "boonust" või "boosti" jagub siis ainult alumisse otsa ja ülemisse otsa (miskipärast "keskmikutele" boonust ei jagata)?
Kas ma mõistsin nüüd sind õieti?
Võimsusest või ärakasutamisest on ju asi veidi mööda!? Võiks ju iseloomustada et üks on teisele võimendustegurit Lisav/Vähendav komponent, aga miks FW mõjutab ning minu süsteemi just ei MÕJUTA (lisa perfomancit)?
Ärge isiklikuna võtke, mulle lihtsalt meeldivad koomilised võrdlused:
Müüa pakutakse bensiini-lisandit aga müüja ütleb, et see "toimib" ainult Trabantide ja Feraaridega!
38 |
EvilMick007
08.11.2003 00:34:44
Ega ma ei väida, et mul mingi julmalt tõsi on, samas on selline mulje jäänud , endal oli see ti4200 kasutada 3 eri prosega, celeron 900(i815 chipset), p3 1200(i815 chipset) ja atlon XP1800(kt400) ning ainus millisega neist see boonus ilmnes oli XP1800(KT400 chip), teistel nagu ei olnud kasu sellest fw-st
41 |
