uus teema   vasta Tarkvara »  Arvutimängude foorum »  Just Cause 2 märgi kõik teemad loetuks
mine lehele 1, 2, 3, 4, 5, 6, 7, 8  järgmine
Andykas
Andykas
sõnum 12.12.2009 15:13:37 Just Cause 2 vasta tsitaadiga
Just Cause 2 uses a new version of the Avalanche Engine, Avalanche Engine 2.0; an updated version of the engine used in Just Cause. The game will be set on the other side of the world, compared to Just Cause, on the fictional tropical island of Panau in Southeast Asia. Rico Rodriguez will return as the protagonist, who has to overthrow the evil dictator Baby Panay and confront his former boss, Tom Sheldon.
Gameplay
The gameplay is similar to that of its predecessor, in which the player is free to roam the game's open world at will without having to focus on the game's storyline, much similar to that of other sandbox style action games, like the Grand Theft Auto series of video games.
Several new additions and improvements to the game were explained by the lead designer of the game, Peter Johansson. The AI has been rewritten for Just Cause 2. It now uses a planning system which enables enemies to do all sorts of new things. For example, the enemies will use the environment to their advantage, taking cover behind objects and adapting dynamically to the objects around them. The hybrid aiming system is also a new feature that helps the player to quickly aim at enemies while leaving the player in full control over the cross-hair; as such, the player is rewarded for skillful manual aiming. It also enables you to pinpoint specific limbs manually and have varied crippling effects on the enemy. Just Cause 2 also has an adaptive difficulty system, gradually scaling the difficulty as the player does more in the game.
Development
Eidos originally announced a Christmas 2008 release date for Just Cause 2. However, on October 10, 2008, Eurogamer reported that Just Cause 2 was pushed back to 2009, and later, 2010.
Screenshotid:
Videod:
Kommentaarid: 25 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 22
Dude .
sõnum 03.03.2010 23:21:53 vasta tsitaadiga
http://www.gametrailers.com/video/nvidia-mini-doc-just-cause-2/62589
TALUSILDID
CoiL
CoiL
sõnum 03.03.2010 23:34:58 vasta tsitaadiga
See nVidia graafika-promo jutt on küll suht hale. Kõiki neid efekte nähtud varem ning imo see paadiga vees sõitmine nägi küll suht jube välja. Panustatud on blurri ja bloomi kompotile... imo.
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 83
Mafia
Mafia
sõnum 04.03.2010 19:19:20 vasta tsitaadiga
1,3Gb
Bawse
Kommentaarid: 19 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 17
erik911
erik911
sõnum 04.03.2010 21:02:26 vasta tsitaadiga
Täitsa tore mäng tõotab tulevat. Aga kõigile teadmiseks, et demol on timer peal, peale 30minutit, visatakse sind lihtsalt mängust välja thumbs_up.gif
Kommentaarid: 99 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 91
angel
angel
sõnum 04.03.2010 22:05:16 vasta tsitaadiga
Täitsa ok mäng. Bloomiga on ainult natuke liiale mindud kuid saan aru et nad üritavad näidata seda "troopia kõrbe" keskkonda. Oleksid võinud FarCry pealt maha teha (1 osa mitte see wannabe 2). Tunduks parem olevat kui 1 osa oli aga see on hale kuidas autod käituvad kui laus kokkupõrke teed. Mitte mingit häält nagu ei ole ja täitsa nagu mingid "kummi pallid" lihtsalt ujuvad ringi.
Mafia
Mafia
sõnum 05.03.2010 00:40:42 vasta tsitaadiga
Bawse
Ollaz
Ollaz
sõnum 07.03.2010 13:55:46 vasta tsitaadiga
Demo on isegi lõbusam mängida, kui kasutada time limit patchi icon_smile.gif
Helikaga ja hookiga on ikka pull mängida, üks lastakse tossama, ootad uue ära, hüppad hookiga kallale ja kaaperdad. Lennukiga kahjuks sõitnud veel ei ole.
Kommentaarid: 83 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 57
EvilKatarn
diivanilill
EvilKatarn
sõnum 07.03.2010 14:41:33 vasta tsitaadiga
Ollaz kirjutas:
Ega juhuslikult PC'l seda demo ala piiramist ei saa ära kaotada? Tundub nagu terve see map oleks tegelikult demos olemas icon_smile.gif
Mäng on aga tore. Näiteks sõidab mingi ment sinu juurde täiega, lased ühe vintsi otsa kuskile puu otsa ja teise auto külge, ning jälgid kino. Tuleb lihtsalt kujutlusvõimet kasutada.
Kommentaarid: 109 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 80
metsolend
sõnum 07.03.2010 14:48:15 vasta tsitaadiga
kuidas saab kaks eraldi vintsi lasta?
Mafia
Mafia
sõnum 07.03.2010 14:53:48 vasta tsitaadiga
EvilKatarn kirjutas:
Ollaz kirjutas:
Saab küll aga map ei ole olemas... lihtsalt kaugelt tundub ,et on. Tegelikult on ainult texturid ja kui ligemale lähed muutuvad need läbipaistvaks icon_biggrin.gif
Tegelt see on loogiline, et tervet mapi pole kuna demo ikkagi ja ala on piiratud lisaks oleks demo sell juhul hulka suurem jne.
Aga mäng on väga fun, time limiti vist 10x vähemalt täis mänginud. Olen proovinud ka osasid time stop nippe aga enamasti mingi aeg asi crashib alati...
Bawse
Ollaz
Ollaz
sõnum 07.03.2010 16:45:18 vasta tsitaadiga
Mafia, time patchid tuleb maha võtta, kui mingeid torusid õhku lased või nii (overload, kui koodi sisestad).
Kusjuures osa mapist oli veel pikalt olemas, mis kasutas samu tekstuure ja asju, mis demos juba on.
metsolend kirjutas:
Hoiad F-i peal kui oled lasknud ja siis sihid mingi muu asja peale ja lased lahti. Seob 2 asja kokku icon_biggrin.gif
Ma olen tihti kokku sidunud mehe+tünni ja kui tünni lased, siis lendab nagu rakett minema, mees järgi icon_biggrin.gif
EvilKatarn
diivanilill
EvilKatarn
sõnum 07.03.2010 17:08:15 vasta tsitaadiga
Või siis näiteks riputad mõne vandi oma auto taha ja viid sõidule. .)
Või vead mõne skulptuuri pea minema helikopteri või autoga ja lähed sellega teisi peksma.
Või hüppad sõidu pealt auto katusele, lased jälitava auto mõne maja külge. icon_smile.gif
Haigelt tore mäng on.
Andykas
Andykas
sõnum 07.03.2010 17:38:35 vasta tsitaadiga
Marx112
sõnum 07.03.2010 21:20:45 vasta tsitaadiga
Tõmbasin mängu läbi steami ära. Panen siis launch, installib natuke teeb oma asju ja kui käima hakkab minema, siis tuleb "Error The specified program requires newer version of windows". Vapsee ülbeks läinud windows xp ei kõlbagi enam kuhugi?
EDIT: Googeldasin natuke ja tulebki välja, et alla dx 10 asi ei lähe käima :S
viimati muutis Marx112 07.03.2010 21:21:13, muudetud 1 kord
angel
angel
sõnum 07.03.2010 21:21:05 vasta tsitaadiga
Mäng omab vist vaid DX10 "asjandusi" seega on vaja Windows Vista või Windows 7'et. Konsool on siis töötab seal kenasti ilma igasugu käkkita. Lisaks vist vajab ka DX10 võimega VGA'd kui mängu nõuetest aru saan õieti.
Ollaz
Ollaz
sõnum 07.03.2010 21:44:12 vasta tsitaadiga
angel kirjutas:
No kui kaart DX10-t ei toeta, ega siis eriti DX10 ju käima ei lähe icon_razz.gif
CoiL
CoiL
sõnum 07.03.2010 22:18:37 vasta tsitaadiga
Marx112 kirjutas:
Probleem.
Probleem.
sõnum 07.03.2010 22:46:55 vasta tsitaadiga
Time limitist ja map limitist saab vabalt lahti. Map on väga väike tegelt demos, kui väga kaugele lähed kukkud lihtsalt mapist välja ja lendad kuskile ime kohta.
Full mäng tuleb väga kõva.
CoiL
CoiL
sõnum 08.03.2010 00:17:27 vasta tsitaadiga
Rääkige parem kuidas selle blurri ja bloomiga lood on? Väga üle vindi keeratud? icon_rolleyes.gif Ei viitsi ise installida.
angel
angel
sõnum 08.03.2010 00:43:39 vasta tsitaadiga
mõnuga üle keeratud... nagu ka eelmises osas. Blurri nagu ei oleks aga blooomi on küll mehiselt pandud. Üritavad vist simuleerida sellist troopika vms liiva keskkonda kus liiv kumab päikest tagasi... aga imo neil ei õnnestu see hästi. Aga kõige hullem ei ole s.t kui mõelda et "sellise stiiliga ajuvaba action mäng". On hullematki vist nähtud... Aga jah suht mööda on neil see graafiline esitlus. Õnneks dogshit brown on puudu, muidu oleks täitsa "nextgen". Textuurid tundusid kah asjalikud.
Mafia
Mafia
sõnum 08.03.2010 01:20:58 vasta tsitaadiga
angel kirjutas:
Mai tea... aga mulle küll graafiline stiil JC2 meeldib. Ja see blur jms sobib IMO väga kenasti sinna icon_rolleyes.gif
Bawse
angel
angel
sõnum 08.03.2010 01:27:46 vasta tsitaadiga
ütleks et olen kenamat ja "reaalsemat" troopika keskkonda näinud... aga kärab kah. Eks terve see mäng üks komöödia olegi beer_yum.gif
caarel123
caarel123
sõnum 08.03.2010 10:09:15 vasta tsitaadiga
kas demo siis ainult saadavl ainult steami kaudu?
Mis vahe on tegelikkusel ja reaalsusel? Vahet pole!
Kommentaarid: 83 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 74
HDTanel
Overclocker
HDTanel
sõnum 08.03.2010 14:30:00 vasta tsitaadiga
Tore, et ma kõik maha magan, kus krt see demo saadaval on PC-le?
edit: steam... ffs thumbs_down.gif
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Just Cause 2 mine lehele 1, 2, 3, 4, 5, 6, 7, 8  järgmine
