Andykas
12.12.2009 15:13:37
Just Cause 2 |
Just Cause 2 uses a new version of the Avalanche Engine, Avalanche Engine 2.0; an updated version of the engine used in Just Cause. The game will be set on the other side of the world, compared to Just Cause, on the fictional tropical island of Panau in Southeast Asia. Rico Rodriguez will return as the protagonist, who has to overthrow the evil dictator Baby Panay and confront his former boss, Tom Sheldon.
Gameplay
The gameplay is similar to that of its predecessor, in which the player is free to roam the game's open world at will without having to focus on the game's storyline, much similar to that of other sandbox style action games, like the Grand Theft Auto series of video games.
Several new additions and improvements to the game were explained by the lead designer of the game, Peter Johansson. The AI has been rewritten for Just Cause 2. It now uses a planning system which enables enemies to do all sorts of new things. For example, the enemies will use the environment to their advantage, taking cover behind objects and adapting dynamically to the objects around them. The hybrid aiming system is also a new feature that helps the player to quickly aim at enemies while leaving the player in full control over the cross-hair; as such, the player is rewarded for skillful manual aiming. It also enables you to pinpoint specific limbs manually and have varied crippling effects on the enemy. Just Cause 2 also has an adaptive difficulty system, gradually scaling the difficulty as the player does more in the game.
Development
Eidos originally announced a Christmas 2008 release date for Just Cause 2. However, on October 10, 2008, Eurogamer reported that Just Cause 2 was pushed back to 2009, and later, 2010.
Screenshotid:
Videod:
| Kommentaarid: 25 loe/lisa |
22 |
Dude .
| Kommentaarid: 16 loe/lisa |
16 |
CoiL
03.03.2010 23:34:58
| See nVidia graafika-promo jutt on küll suht hale. Kõiki neid efekte nähtud varem ning imo see paadiga vees sõitmine nägi küll suht jube välja. Panustatud on blurri ja bloomi kompotile... imo.
| Kommentaarid: 95 loe/lisa |
83 |
Mafia
04.03.2010 19:19:20
Demo väljas steamis nüüd !!!
1,3Gb
_________________ Bawse |
| Kommentaarid: 19 loe/lisa |
17 |
erik911
04.03.2010 21:02:26
Täitsa tore mäng tõotab tulevat. Aga kõigile teadmiseks, et demol on timer peal, peale 30minutit, visatakse sind lihtsalt mängust välja
| Kommentaarid: 99 loe/lisa |
91 |
angel
04.03.2010 22:05:16
Täitsa ok mäng. Bloomiga on ainult natuke liiale mindud kuid saan aru et nad üritavad näidata seda "troopia kõrbe" keskkonda. Oleksid võinud FarCry pealt maha teha (1 osa mitte see wannabe 2). Tunduks parem olevat kui 1 osa oli aga see on hale kuidas autod käituvad kui laus kokkupõrke teed. Mitte mingit häält nagu ei ole ja täitsa nagu mingid "kummi pallid" lihtsalt ujuvad ringi.
157 |
Mafia
05.03.2010 00:40:42
Täitsa pull mäng
Graafika on kena ja actionit on kõvasti
17 |
Ollaz
07.03.2010 13:55:46
Demo on isegi lõbusam mängida, kui kasutada time limit patchi
Helikaga ja hookiga on ikka pull mängida, üks lastakse tossama, ootad uue ära, hüppad hookiga kallale ja kaaperdad. Lennukiga kahjuks sõitnud veel ei ole.
Full version tõotab tulla päris kõva
| Kommentaarid: 83 loe/lisa |
57 |
EvilKatarn
diivanilill
07.03.2010 14:41:33
| Ollaz kirjutas: |
Demo on isegi lõbusam mängida, kui kasutada time limit patchi  |
Ega juhuslikult PC'l seda demo ala piiramist ei saa ära kaotada? Tundub nagu terve see map oleks tegelikult demos olemas
Mäng on aga tore. Näiteks sõidab mingi ment sinu juurde täiega, lased ühe vintsi otsa kuskile puu otsa ja teise auto külge, ning jälgid kino. Tuleb lihtsalt kujutlusvõimet kasutada.
| Kommentaarid: 111 loe/lisa |
metsolend
07.03.2010 14:48:15
| kuidas saab kaks eraldi vintsi lasta?
Mafia
07.03.2010 14:53:48
| EvilKatarn kirjutas: |
| Ollaz kirjutas: |
Saab küll aga map ei ole olemas... lihtsalt kaugelt tundub ,et on. Tegelikult on ainult texturid ja kui ligemale lähed muutuvad need läbipaistvaks
Tegelt see on loogiline, et tervet mapi pole kuna demo ikkagi ja ala on piiratud lisaks oleks demo sell juhul hulka suurem jne.
Aga mäng on väga fun, time limiti vist 10x vähemalt täis mänginud. Olen proovinud ka osasid time stop nippe aga enamasti mingi aeg asi crashib alati...
17 |
Ollaz
07.03.2010 16:45:18
Mafia, time patchid tuleb maha võtta, kui mingeid torusid õhku lased või nii (overload, kui koodi sisestad).
Kusjuures osa mapist oli veel pikalt olemas, mis kasutas samu tekstuure ja asju, mis demos juba on.
| metsolend kirjutas: |
| kuidas saab kaks eraldi vintsi lasta? |
Hoiad F-i peal kui oled lasknud ja siis sihid mingi muu asja peale ja lased lahti. Seob 2 asja kokku
Ma olen tihti kokku sidunud mehe+tünni ja kui tünni lased, siis lendab nagu rakett minema, mees järgi
57 |
EvilKatarn
diivanilill
07.03.2010 17:08:15
Või siis näiteks riputad mõne vandi oma auto taha ja viid sõidule. .)
Või vead mõne skulptuuri pea minema helikopteri või autoga ja lähed sellega teisi peksma.
Või hüppad sõidu pealt auto katusele, lased jälitava auto mõne maja külge.
Haigelt tore mäng on.
Andykas
07.03.2010 17:38:35
| Haigelt tore mäng on. |
On jah.
22 |
Marx112
07.03.2010 21:20:45
Tõmbasin mängu läbi steami ära. Panen siis launch, installib natuke teeb oma asju ja kui käima hakkab minema, siis tuleb "Error The specified program requires newer version of windows". Vapsee ülbeks läinud windows xp ei kõlbagi enam kuhugi?
EDIT: Googeldasin natuke ja tulebki välja, et alla dx 10 asi ei lähe käima :S
viimati muutis Marx112 07.03.2010 21:21:13, muudetud 1 kord |
angel
07.03.2010 21:21:05
Mäng omab vist vaid DX10 "asjandusi" seega on vaja Windows Vista või Windows 7'et. Konsool on siis töötab seal kenasti ilma igasugu käkkita. Lisaks vist vajab ka DX10 võimega VGA'd kui mängu nõuetest aru saan õieti.
157 |
Ollaz
07.03.2010 21:44:12
| angel kirjutas: |
| Mäng omab vist vaid DX10 "asjandusi" seega on vaja Windows Vista või Windows 7'et. Konsool on siis töötab seal kenasti ilma igasugu käkkita. Lisaks vist vajab ka DX10 võimega VGA'd kui mängu nõuetest aru saan õieti. |
No kui kaart DX10-t ei toeta, ega siis eriti DX10 ju käima ei lähe
57 |
CoiL
07.03.2010 22:18:37
| Marx112 kirjutas: |
| Vapsee ülbeks läinud windows xp ei kõlbagi enam kuhugi? |
Äkki oleks siis aeg kiviajast välja kolida?
83 |
Probleem.
07.03.2010 22:46:55
Time limitist ja map limitist saab vabalt lahti. Map on väga väike tegelt demos, kui väga kaugele lähed kukkud lihtsalt mapist välja ja lendad kuskile ime kohta.
Full mäng tuleb väga kõva.
_________________ -.- |
CoiL
08.03.2010 00:17:27
Rääkige parem kuidas selle blurri ja bloomiga lood on? Väga üle vindi keeratud? Ei viitsi ise installida.
83 |
angel
08.03.2010 00:43:39
mõnuga üle keeratud... nagu ka eelmises osas. Blurri nagu ei oleks aga blooomi on küll mehiselt pandud. Üritavad vist simuleerida sellist troopika vms liiva keskkonda kus liiv kumab päikest tagasi... aga imo neil ei õnnestu see hästi. Aga kõige hullem ei ole s.t kui mõelda et "sellise stiiliga ajuvaba action mäng". On hullematki vist nähtud... Aga jah suht mööda on neil see graafiline esitlus. Õnneks dogshit brown on puudu, muidu oleks täitsa "nextgen". Textuurid tundusid kah asjalikud.
157 |
Mafia
08.03.2010 01:20:58
| angel kirjutas: |
| mõnuga üle keeratud... nagu ka eelmises osas. Blurri nagu ei oleks aga blooomi on küll mehiselt pandud. Üritavad vist simuleerida sellist troopika vms liiva keskkonda kus liiv kumab päikest tagasi... aga imo neil ei õnnestu see hästi. Aga kõige hullem ei ole s.t kui mõelda et "sellise stiiliga ajuvaba action mäng". On hullematki vist nähtud... Aga jah suht mööda on neil see graafiline esitlus. Õnneks dogshit brown on puudu, muidu oleks täitsa "nextgen". Textuurid tundusid kah asjalikud. |
Mai tea... aga mulle küll graafiline stiil JC2 meeldib. Ja see blur jms sobib IMO väga kenasti sinna
17 |
angel
08.03.2010 01:27:46
ütleks et olen kenamat ja "reaalsemat" troopika keskkonda näinud... aga kärab kah. Eks terve see mäng üks komöödia olegi
157 |
caarel123
08.03.2010 10:09:15
kas demo siis ainult saadavl ainult steami kaudu?
paistab päris huvitav arcade olevat
74 |
HDTanel
Overclocker
08.03.2010 14:30:00
Tore, et ma kõik maha magan, kus krt see demo saadaval on PC-le?
edit: steam... ffs
_________________ Minu Youtube - HDTanel |
496 |
Andykas
08.03.2010 15:47:23
Mulle just meeldib JC2 graafika. Päikeseloojangud meenutavad vice cityt.
22 |
Ollaz
08.03.2010 15:59:51
See blur ja bloom mis siin mängus on, sobib väga hästi siia mängu.
Siis kui peaksid liiva peale sattuma päevasel ajal, siis kuumad kohad virvendavad nagu päriselt
57 |
Vello.
08.03.2010 18:40:43
Esimese osa mängisin läbi kunagi ja meeldis.
Teine tundub ka mängitav.
Laske üks lask balooni ja siis konksuga kinni ning lendate sellega taevasse, kuid lõpuks plahvatab.
angel
08.03.2010 18:52:20
2 osa tundub parem olevat... vähemalt nüüd vist ei tehta seda nalja et mingi "konsoolidel on parem graafika ja rohkem bloomi" nagu esimese osaga tehti
157 |
Killerwave
10.03.2010 10:04:59
| CorsairX kirjutas: |
| Marx112 kirjutas: |
Äkki oleks siis aeg kiviajast välja kolida?  |
Ise oled kiviajast
Vihale ajab et normaalset op süsteemi blokitakse sedasi, tahtsin proovida aga nüüd piixus, neetult hea algus päevale.
Eks see vist hakkabki aina rohkem nii olema, jälle üks viis kuidas inimesi XP pealt lahti kangutada.
31 |
angel
10.03.2010 12:12:52
konsool lahedab selle probleemi... ps3'e peal vähemalt oli täitsa vinks vonks grafaga see mäng, jooksis hästi ja ei mingit Windows Vista/7 jura ega DirectX'i. Samuti ei ole steami vaja. Viska sisse ja mängi.
Kunagi näis ehk tulevad ka ülevaated kus võrreldakse konsool vs pc graafikat.
Kui PC mängu maailma täitsa ära ei tapeta siis tahest tahtmata pead sa windows 7 peale kolima... M$'il raha vaja ja nad pressivad selle sulle nii või naa peale... mis sest et XP täitsa asjalik ja korralik on.
157 |
Killerwave
10.03.2010 12:24:27
| angel kirjutas: |
| Kui PC mängu maailma täitsa ära ei tapeta siis tahest tahtmata pead sa windows 7 peale kolima... M$'il raha vaja ja nad pressivad selle sulle nii või naa peale... mis sest et XP täitsa asjalik ja korralik on. |
Nii see paraku on, lihtsalt et antud majanduslikes tingimustes on see pisut keeruline ülesanne 3k välja käia.
31 |
angel
10.03.2010 12:28:54
natu juurde ja saad selle raha eest juba konsooli
157 |
Killerwave
10.03.2010 12:31:54
| angel kirjutas: |
natu juurde ja saad selle raha eest juba konsooli  |
No mängu-kahe pärast küll konsooli ostma ei hakka, ikka PC peal. Lisaks win7-t sai testitud ja proovitud küll, kui selleks MSi poolt võimalust anti ja igal juhul läheks üle, kui vaid raha puu otsas kasvaks(antud seisuga) Jääme paremaid aegu ootama.
End OT.
31 |
Zadoc
13.03.2010 19:40:45
Omamoodi lahe m2ng, kuigi tegelane on ypris kuulikindel ja kukkumiskindel muidu on liikumine ysna normaalne ja mugav, ainult et masinatega, ja eriti langevarjuga liikumine, vajab harjumist. Muide, selleks et proovida demo, saab win7 ajutiselt teiseks op systeemiks panna, nii8elda demo win netis vedeleb 7 igal pool.
| Kommentaarid: 20 loe/lisa |
19 |
lopes39
13.03.2010 21:28:05
suht kõva mäng on aga demo on küll väga tebiilne
see ajalemiit mingi 30min on suht haiglane .. eriti sellepärast et asju saab avada nagu tank jne mis tulevad kaardile siis kui oled seal vähemalt ühe linna ära vallutanud
sain mingi cärkitud exe millega sain küll piiridest välja rännata ja rohkem tutvuda selle maailmaga aga see ei lahendand seda nõmedat ajalimiiti mis on arusaamatu kuna mängus on kõik asjad kinni ja neid lahti ei saagi
videosi skippida ka ei saa mis on ka suht nõme
loodan et selle täis versioonis mingit sellist jama ei ole nagu aja lemiit
pole õnneks kaua aega vaja oodata millal välja tuleb
mäng ise on hea .. meeldivad elemendid on et saab iga lendava asjaga lennata ja on kaatrid ja tankid jne millega saab igasugu möllu korraltada
ainuke asi mis käib tõsiselt närvidele on tänapäevane microsoftile perse pugemine et mängudes on 360 pult lubatud aga logitechi oma ei tunnista üldse
krt need pira vastu võitlejad võiks nende asutuste vastu ka võidelda nagu mängu tööstus arvuti peale kes ei lisa igasugu pulte jne mängu lisada .. hiirel ei tööta sellised nupud nagu mouse4 ja mouse5
zoom on mingi C nuppu peal siis käsi pidur on X jne .. see kes need nupud paika seal mängus pani on mingi ebard vist
| Kommentaarid: 10 loe/lisa |
veso
13.03.2010 22:06:53
| lopes39 kirjutas: |
| loodan et selle täis versioonis mingit sellist jama ei ole nagu aja lemiit |
Wat, selles see DEMO mõte ongi ju. Muidu näeksid liiga palju mängust ära ja mängiksid ehk sinu täis. Aja limiidiga aetakse sul korralikult hype peale kui mäng meeldib ja siis ostad hiljem ära kah. Sama hästi miks üldse mänge välja lastakse, lasku mängu täisversioon välja tasuta, pange nimi demoks ja ongi voila.
lopes39
14.03.2010 13:44:13
| veso kirjutas: |
| lopes39 kirjutas: |
Wat, selles see DEMO mõte ongi ju. Muidu näeksid liiga palju mängust ära ja mängiksid ehk sinu täis. Aja limiidiga aetakse sul korralikult hype peale kui mäng meeldib ja siis ostad hiljem ära kah. Sama hästi miks üldse mänge välja lastakse, lasku mängu täisversioon välja tasuta, pange nimi demoks ja ongi voila. |
no see on arusaadav et see nii on ja hea ta ka nii on
ainult kui on ajalemiit siis võiks asjad lahti olla et tutvuda see 30min mis see mäng pakkuda võib
ma isiklikult olen leidnud aint ühe käkki mis töötab niipalju et on unlimited amo aga ajalemiiti maha ei käkki ja mitte ükski neist ei käkki seda maha
kui tahta tankiga seal märulit teha siis vaja kõigepealt teha algus koht 100% peale mis pole keeruline .. kaks kasti korjata ja elektri torn maha võtta ja siis kolida end esimesse linna kus seal pisut märulit teha ja saab ka 100% täis siis avaneb kaardil lennu sõit ja mingi amee baas kuhu saab tankiga minna sest sealt ligidalt leiab ühe mingi külakese kus on mingi missioon sinna armee baasi
tegin seal mingi 85% ja läksin kopteri peale ja siis ei hookinud end selle esimese auto külge ja oligi mäng läbi pmst kuna enam ei jõudnud järgi ja transporti ka ei liikunud
see on üks mäng mis pmst tuleb osta naguinii nagu ka ac2
huvitav on see et mul riistvara on suht vana aga see mäng jookseb suht puhtalt maksi peal ja no vähemalt on mäng mis on fun peale ehitatud mitte mmingi erilise reaalsuse peale ehitatud kus naguinii reaalne pole (mäng nagu bad company 2 omastarust väga reaalne mäng aga ikka jumala mööda omadega ka .. kui keegi tuleb sulle nuga andma ja saad talle paar kuuli sisse siis reaalselt peks nuga shokki tõttu maha kukkuma mitte ei lähe edasi nuga andma ja veel palu asju mis selle m2ngu m6ttetuks muudab kui reaalsust taga ajada)
see on minu arvamus lihtsalt ja pole mõtet klähvima hakata kui midagi mu tekstist ei meeldi
Dude .
14.03.2010 14:55:16
lopes39, loomulikult on täismängus ajalimiit
/sarcasm
Igatahes peaks selle demo ajalimiidi maha võtmiseks väike vidin olemas olema küll. Täpselt ise ei tea, tüdinesin juba poole tunni lõpuks sellest ära. :/
_________________ TALUSILDID |
16 |
lopes39
14.03.2010 16:05:41
viimane gcw-st saadav trainer töötab isegi ... algul sain aint unlimited kuule ja siis nüüd lõpuks sain ajalimiidi ka 30k peale
pmst selle kaardi peal on jäänd 7 asja veel teha siis rändan niisama kaardil ringi et uurida mis seal huvitavat on
Nokia
Serverid.ee
14.03.2010 16:13:54
Kas demol ja täis versioonil on mingi vahe ka peale ajaliimidi?
_________________ Web3 | ERC721A |
| Kommentaarid: 44 loe/lisa |
43 |
lopes39
14.03.2010 17:19:09
| Nokia kirjutas: |
| Kas demol ja täis versioonil on mingi vahe ka peale ajaliimidi? |
kindlasti on
saab kaatreid ja rohkem tanke
saab terve mapi peal ringi käia jne
kindlasti on seal igasugu relvi jne mida demos ei saa nagu bazuuka jne
demos näiteks isegi selle käkkiga millega saad piiridest välja minna on mingi teatud ala kus saad uurida sest siis juba rohkem ei saa
sõitsin lennukiga näiteks saartele mis on vasakul üleval et linna näha ja siis kui lennukist välja hyppasin siis oli majad küll aga all oli meri ja pmst tagasi ei hakkand ujuma ja lihtsalt lasin ära uppuda mis võttis küll palju aega
angel
14.03.2010 18:13:06
| Nokia kirjutas: |
eee doh?
Fullis on missioonid, relvad, masinad, map lahti etc. Loogiline, et fullis on rohkem kui demos. Ja kui demo ei meeldi üldse siis suht tõene, et ei meeldi ka full.
157 |
lopes39
14.03.2010 18:43:16
tegelt raketiheitja saab ikka seal mängus ja igasugu erinevaid autosi
2 mingit suht mõttetut soomus autot oli ja üks tank
see on siis nii kui tellid endale vajutades 4 ja siis USE nuppu ja tuleb kopteriga toob kõike
Aah
14.03.2010 20:22:23
veso, battlefieldi demo võiks ka selline tulla. Autod, tankid,lennukid,laevad,kopterid seisavad niisama platsil, ilu pärast ja keegi sõita ei saa
| Kommentaarid: 21 loe/lisa |
21 |
angel
14.03.2010 20:23:57
why not
aga siiski... see on DEMO. Hea et sellinegi asi kätte anti... enamasti sedasorti mängudel demo üldse puudub
157 |
Andykas
14.03.2010 20:36:57
Uskumatu milline ülbus. Demos jagati just ülisuur osa mängust kätte ja ikka veel vähe...
22 |
lopes39
17.03.2010 11:53:01
no hea et demo tehti sellest
nüüd lihtsalt tean et on hea mäng ja peab soetama selle endale
2 nädalat veel jäänd aga see selleks
loodan et sellel ei ole samasugust jama nagu mw2-l vene keelse keyga ja steamiga
juhul kui see mäng tuleb eraldatult steamist siis vast ei tohiks probleemi olla aga kardan et on ikka steamiga see kuna demo on sellega
edit:
ahh krt see eelnevalt mis ma rääkisin et raketiheitjat saab mustalt turult osta kopteriga see oli pisut mööda
mul oli mingi traineri otsingutelt jäänud selline folder nagu dropzone mis lisab mängule autosi koptereid soomustatud sõjamasinaid ja relvi nagu raketiheitja ja pumppüss jne
vähemalt on mida mängida ja millega mängid niikaua kui full välja tuleb
The Man
19.03.2010 01:09:05
Demo oli lahe, sõidukid liikusid veidi harjumatult, ujudes aga muidu oli tip-top madistamine. Üle time-limiidi ei viitsinud proovida, kui kunagi odavalt ette jääb siis vast ostan ja mängin ära.
_________________ Press A to disagree.
<Too late!> |
KrisVr
19.03.2010 01:21:42
| The Man kirjutas: |
| Demo oli lahe, sõidukid liikusid veidi harjumatult, ujudes aga muidu oli tip-top madistamine. Üle time-limiidi ei viitsinud proovida, kui kunagi odavalt ette jääb siis vast ostan ja mängin ära. |
Mulle ka demo meeldis, aga ka ostma kohe kui välja tule ei kutsu. Eks siis proovib ära kui midagi muud mängida ei ole.
| Kommentaarid: 30 loe/lisa |
