Andykas
12.12.2009 15:13:37
Just Cause 2 |
Just Cause 2 uses a new version of the Avalanche Engine, Avalanche Engine 2.0; an updated version of the engine used in Just Cause. The game will be set on the other side of the world, compared to Just Cause, on the fictional tropical island of Panau in Southeast Asia. Rico Rodriguez will return as the protagonist, who has to overthrow the evil dictator Baby Panay and confront his former boss, Tom Sheldon.
Gameplay
The gameplay is similar to that of its predecessor, in which the player is free to roam the game's open world at will without having to focus on the game's storyline, much similar to that of other sandbox style action games, like the Grand Theft Auto series of video games.
Several new additions and improvements to the game were explained by the lead designer of the game, Peter Johansson. The AI has been rewritten for Just Cause 2. It now uses a planning system which enables enemies to do all sorts of new things. For example, the enemies will use the environment to their advantage, taking cover behind objects and adapting dynamically to the objects around them. The hybrid aiming system is also a new feature that helps the player to quickly aim at enemies while leaving the player in full control over the cross-hair; as such, the player is rewarded for skillful manual aiming. It also enables you to pinpoint specific limbs manually and have varied crippling effects on the enemy. Just Cause 2 also has an adaptive difficulty system, gradually scaling the difficulty as the player does more in the game.
Development
Eidos originally announced a Christmas 2008 release date for Just Cause 2. However, on October 10, 2008, Eurogamer reported that Just Cause 2 was pushed back to 2009, and later, 2010.
Screenshotid:
Videod:
| Kommentaarid: 25 loe/lisa |
22 |
Dude .
| Kommentaarid: 15 loe/lisa |
15 |
CoiL
03.03.2010 23:34:58
| See nVidia graafika-promo jutt on küll suht hale. Kõiki neid efekte nähtud varem ning imo see paadiga vees sõitmine nägi küll suht jube välja. Panustatud on blurri ja bloomi kompotile... imo.
| Kommentaarid: 95 loe/lisa |
83 |
Mafia
04.03.2010 19:19:20
Demo väljas steamis nüüd !!!
1,3Gb
_________________ Bawse |
| Kommentaarid: 19 loe/lisa |
17 |
erik911
04.03.2010 21:02:26
Täitsa tore mäng tõotab tulevat. Aga kõigile teadmiseks, et demol on timer peal, peale 30minutit, visatakse sind lihtsalt mängust välja
| Kommentaarid: 99 loe/lisa |
91 |
angel
04.03.2010 22:05:16
Täitsa ok mäng. Bloomiga on ainult natuke liiale mindud kuid saan aru et nad üritavad näidata seda "troopia kõrbe" keskkonda. Oleksid võinud FarCry pealt maha teha (1 osa mitte see wannabe 2). Tunduks parem olevat kui 1 osa oli aga see on hale kuidas autod käituvad kui laus kokkupõrke teed. Mitte mingit häält nagu ei ole ja täitsa nagu mingid "kummi pallid" lihtsalt ujuvad ringi.
157 |
Mafia
05.03.2010 00:40:42
Täitsa pull mäng
Graafika on kena ja actionit on kõvasti
17 |
Ollaz
07.03.2010 13:55:46
Demo on isegi lõbusam mängida, kui kasutada time limit patchi
Helikaga ja hookiga on ikka pull mängida, üks lastakse tossama, ootad uue ära, hüppad hookiga kallale ja kaaperdad. Lennukiga kahjuks sõitnud veel ei ole.
Full version tõotab tulla päris kõva
| Kommentaarid: 83 loe/lisa |
57 |
EvilKatarn
diivanilill
07.03.2010 14:41:33
| Ollaz kirjutas: |
Demo on isegi lõbusam mängida, kui kasutada time limit patchi  |
Ega juhuslikult PC'l seda demo ala piiramist ei saa ära kaotada? Tundub nagu terve see map oleks tegelikult demos olemas
Mäng on aga tore. Näiteks sõidab mingi ment sinu juurde täiega, lased ühe vintsi otsa kuskile puu otsa ja teise auto külge, ning jälgid kino. Tuleb lihtsalt kujutlusvõimet kasutada.
80 |
metsolend
07.03.2010 14:48:15
| kuidas saab kaks eraldi vintsi lasta?
Mafia
07.03.2010 14:53:48
| EvilKatarn kirjutas: |
| Ollaz kirjutas: |
Saab küll aga map ei ole olemas... lihtsalt kaugelt tundub ,et on. Tegelikult on ainult texturid ja kui ligemale lähed muutuvad need läbipaistvaks
Tegelt see on loogiline, et tervet mapi pole kuna demo ikkagi ja ala on piiratud lisaks oleks demo sell juhul hulka suurem jne.
Aga mäng on väga fun, time limiti vist 10x vähemalt täis mänginud. Olen proovinud ka osasid time stop nippe aga enamasti mingi aeg asi crashib alati...
17 |
Ollaz
07.03.2010 16:45:18
Mafia, time patchid tuleb maha võtta, kui mingeid torusid õhku lased või nii (overload, kui koodi sisestad).
Kusjuures osa mapist oli veel pikalt olemas, mis kasutas samu tekstuure ja asju, mis demos juba on.
| metsolend kirjutas: |
| kuidas saab kaks eraldi vintsi lasta? |
Hoiad F-i peal kui oled lasknud ja siis sihid mingi muu asja peale ja lased lahti. Seob 2 asja kokku
Ma olen tihti kokku sidunud mehe+tünni ja kui tünni lased, siis lendab nagu rakett minema, mees järgi
57 |
EvilKatarn
diivanilill
07.03.2010 17:08:15
Või siis näiteks riputad mõne vandi oma auto taha ja viid sõidule. .)
Või vead mõne skulptuuri pea minema helikopteri või autoga ja lähed sellega teisi peksma.
Või hüppad sõidu pealt auto katusele, lased jälitava auto mõne maja külge.
Haigelt tore mäng on.
80 |
Andykas
07.03.2010 17:38:35
| Haigelt tore mäng on. |
On jah.
22 |
Marx112
07.03.2010 21:20:45
Tõmbasin mängu läbi steami ära. Panen siis launch, installib natuke teeb oma asju ja kui käima hakkab minema, siis tuleb "Error The specified program requires newer version of windows". Vapsee ülbeks läinud windows xp ei kõlbagi enam kuhugi?
EDIT: Googeldasin natuke ja tulebki välja, et alla dx 10 asi ei lähe käima :S
viimati muutis Marx112 07.03.2010 21:21:13, muudetud 1 kord |
angel
07.03.2010 21:21:05
Mäng omab vist vaid DX10 "asjandusi" seega on vaja Windows Vista või Windows 7'et. Konsool on siis töötab seal kenasti ilma igasugu käkkita. Lisaks vist vajab ka DX10 võimega VGA'd kui mängu nõuetest aru saan õieti.
157 |
Ollaz
07.03.2010 21:44:12
| angel kirjutas: |
| Mäng omab vist vaid DX10 "asjandusi" seega on vaja Windows Vista või Windows 7'et. Konsool on siis töötab seal kenasti ilma igasugu käkkita. Lisaks vist vajab ka DX10 võimega VGA'd kui mängu nõuetest aru saan õieti. |
No kui kaart DX10-t ei toeta, ega siis eriti DX10 ju käima ei lähe
57 |
CoiL
07.03.2010 22:18:37
| Marx112 kirjutas: |
| Vapsee ülbeks läinud windows xp ei kõlbagi enam kuhugi? |
Äkki oleks siis aeg kiviajast välja kolida?
83 |
Probleem.
07.03.2010 22:46:55
Time limitist ja map limitist saab vabalt lahti. Map on väga väike tegelt demos, kui väga kaugele lähed kukkud lihtsalt mapist välja ja lendad kuskile ime kohta.
Full mäng tuleb väga kõva.
_________________ -.- |
CoiL
08.03.2010 00:17:27
Rääkige parem kuidas selle blurri ja bloomiga lood on? Väga üle vindi keeratud? Ei viitsi ise installida.
83 |
angel
08.03.2010 00:43:39
mõnuga üle keeratud... nagu ka eelmises osas. Blurri nagu ei oleks aga blooomi on küll mehiselt pandud. Üritavad vist simuleerida sellist troopika vms liiva keskkonda kus liiv kumab päikest tagasi... aga imo neil ei õnnestu see hästi. Aga kõige hullem ei ole s.t kui mõelda et "sellise stiiliga ajuvaba action mäng". On hullematki vist nähtud... Aga jah suht mööda on neil see graafiline esitlus. Õnneks dogshit brown on puudu, muidu oleks täitsa "nextgen". Textuurid tundusid kah asjalikud.
157 |
Mafia
08.03.2010 01:20:58
| angel kirjutas: |
| mõnuga üle keeratud... nagu ka eelmises osas. Blurri nagu ei oleks aga blooomi on küll mehiselt pandud. Üritavad vist simuleerida sellist troopika vms liiva keskkonda kus liiv kumab päikest tagasi... aga imo neil ei õnnestu see hästi. Aga kõige hullem ei ole s.t kui mõelda et "sellise stiiliga ajuvaba action mäng". On hullematki vist nähtud... Aga jah suht mööda on neil see graafiline esitlus. Õnneks dogshit brown on puudu, muidu oleks täitsa "nextgen". Textuurid tundusid kah asjalikud. |
Mai tea... aga mulle küll graafiline stiil JC2 meeldib. Ja see blur jms sobib IMO väga kenasti sinna
17 |
angel
08.03.2010 01:27:46
ütleks et olen kenamat ja "reaalsemat" troopika keskkonda näinud... aga kärab kah. Eks terve see mäng üks komöödia olegi
157 |
caarel123
08.03.2010 10:09:15
kas demo siis ainult saadavl ainult steami kaudu?
paistab päris huvitav arcade olevat
74 |
HDTanel
Overclocker
08.03.2010 14:30:00
Tore, et ma kõik maha magan, kus krt see demo saadaval on PC-le?
edit: steam... ffs
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
