uus teema   vasta Tarkvara »  Arvutimängude foorum »  Anno 1404 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  järgmine
Maailm
Maailm
sõnum 04.02.2010 21:17:50 vasta tsitaadiga
Videodriverid uusimad peal jah, patche pole sikutada viitsinud, kuna nett sakib :S
Kommentaarid: 38 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 35
pioneeros
pioneeros
sõnum 04.02.2010 23:20:17 Mangule tuleb lisaosa (MP-ga) vasta tsitaadiga
Anno 1404: Venice (Expansion Pack) PC
Release Date: 26 February 2010
Anno 1404 is unique and award-winning combination of construction, economy, discovery, diplomacy and combat. The game now offers multiplayer support, more adventures, new buildings, new quests and plenty of customisable content in order to go even further in gaming entertainment. Anno 1404: Venice is grandiose, improved, larger, innovative, living, and now allow you to share this experience with friends.
* Requries Anno 1404 to play
* Play Anno 1404 in multiplayer and online!
* Up to 4 players
* Challenge your friends by playing Versus Mode
* Choose Co-Op Mode and defeat the AI by merging your techniques
* A totally improved environement to be played: Venice!
* Embody a new venetian character: Giacomo Garibaldi
* Build an armada and reinvent your very own ships with custom builds
* Develop secret cabinets, infiltrate your enemies and sabotage their expansion
* Take control over a city thanks to your economical influence
* New challenges and quests!
* Up to 300 new quests with two new types: trading race and ship boarding
* 60 new items to increase your domination
* Discover, exploit a new type of islands, the Volcano Islands
* New islands to build giant cities
* New scenarios to face new challenges
* New achievements, medals and crests
Maailm
Maailm
sõnum 04.02.2010 23:34:21 vasta tsitaadiga
Pokkerit mängid aga rakeback ei saa? Liitu!
destiny12
destiny12
sõnum 05.02.2010 11:53:05 vasta tsitaadiga
Endal jookseb 30-40 fps.
4xAA,8xAF.
Mingi imelik nõksumine on ainult sees kui nooltega ringi liikuda.
Muidu täitsa tore mäng.
Ainult ei jaga asja eriti hästi veel.
Kommentaarid: 83 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 77
Lovvi
Lovvi
sõnum 05.02.2010 14:56:01 vasta tsitaadiga
Maailm kirjutas:
Ei pidanud kaua ootama? Ma lootsin, et multiplayer patch tuleb mingi 1-2 kuuga, aga noh..
Kommentaarid: 59 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 56
Redikate
Redikate
sõnum 11.02.2010 03:46:02 vasta tsitaadiga
Tore, igaljuhul proovin MP ka ära.
Juba kujutan ette neid 20h mänge.
http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
Maailm
Maailm
sõnum 11.02.2010 10:11:10 vasta tsitaadiga
Hmm, panin 1.1 patchi peale, nüüd ikka maapinnad mustad kuid siin seal saarel on lõigud kus ilus roheline maapind... ons veel patche väljas või mis teha tuleb?
Lordlesta
sõnum 11.02.2010 18:00:55 vasta tsitaadiga
Maailm, mine "C:\Users\KASUTAJA\AppData\Roaming\Ubisoft\Anno1404\Config" ja ava fail nimega "Engine.ini", nüüd otsi üles rida "<DirectXVersion>0</DirectXVersion>" ning pane nulli asemel 9.
Kommentaarid: 31 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 27
Lovvi
Lovvi
sõnum 11.02.2010 18:07:16 vasta tsitaadiga
Lordlesta kirjutas:
Või pane vanemad draiverid peale (juhul kui ATI), ehk siis 9.7, kui ei taha dx10 kaotada.
Maailm
Maailm
sõnum 11.02.2010 18:57:22 vasta tsitaadiga
Mul ati jah, HD4870. Selge, proovin kõigepealt 9.7 ja kui ei aita siis katsetan seda dx9 varianti.
Edit: 9.7 catalyst peal ja voila, graafika oki icon_biggrin.gif Väga mõnus icon_smile.gif Aga arusaamatu miks uuemad driverid asja piixu keeravad... loodetavasti järgmine uuendus asja parandab.
Lovvi
Lovvi
sõnum 28.02.2010 13:00:29 vasta tsitaadiga
Kellelgi soovi koos mängida (LAN)?
Renq
Renq
sõnum 28.02.2010 13:51:06 vasta tsitaadiga
hetkel mitte, a muidu täitsa võimalik, läbi hamatsi siis?
Redikate
Redikate
sõnum 28.02.2010 14:38:55 vasta tsitaadiga
Läbi hamachi täiesti toimib. Ise olen juba ühe mängu teinud 3 inimesega.
http://nodejs.org/
Lovvi
Lovvi
sõnum 28.02.2010 15:01:29 vasta tsitaadiga
Kui kellelgi on soovi mängida siis saate PS.
Redikate
Redikate
sõnum 28.02.2010 20:36:14 vasta tsitaadiga
Sai üks mäng tehtud siis Lovvi ja ühe tuttavaga.
Winning conditioniks oli 150k goldi, mängisime umbkaudu 5-6h ning võitsin ise päris pika eduga.
http://nodejs.org/
Renq
Renq
sõnum 28.02.2010 21:53:39 vasta tsitaadiga
kui ma üldse mängiks, siis ma teeks ilma kindla sihtmärgita, lihtsalt et saaks mängida.
Redikate
Redikate
sõnum 28.02.2010 22:03:25 vasta tsitaadiga
Renq kirjutas:
Peale winning conditioni täitmist saab edasi mängida. Winning conditioneid saab ka mitu panna, niiet võib pärast vaadata kes enim ära tegi vms.
Meie mängu mängib veel mu tuttav edasi igatahes, ei ole uurind mis seis on tal.
Ma isiklikult ilma winning conditionita ei kannata mängida. Tundub kuidagi lihtsalt aja maha viskamisena, siis ikka mingi point ka.
http://nodejs.org/
Lovvi
Lovvi
sõnum 01.03.2010 15:24:00 vasta tsitaadiga
Redikate kirjutas:
Pro
Ma algul oli ehmatasin, kui küsisid ka 8h vaba aega on icon_eek.gif . Nüüd siis tean, et laupäeva hommikul tuleb pelama hakata thumbs_up.gif . Aga päris 5h välja tulnud, mingi 4.30 äkki.
RassK
RassK
sõnum 01.03.2010 18:35:19 vasta tsitaadiga
Kommentaarid: 116 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 101
Redikate
Redikate
sõnum 01.03.2010 18:49:18 vasta tsitaadiga
Paar pilti ka siis meie mängust, kuna frapsiga pildistatud siis kellaaega kenasti näha. Loodetavasti pole mängus osalenud osapooled piltide postimise vastu.
Lovvi baas kell 15:49. Mäng on just-just alanud.
Natuke üle 1h mängitud. Kerge ülevaade.
Mu enda baas kell 17:30. Natuke alla 2h mängitud.
18:34. Minu baas koos mõne ressursiga.
Kell on 20:15. Mängitud siis natuke alla 5h, seis minu nobelmanide housis.
12 minutit hiljem sai mul raha kokku. Teiste mängijate seisu ei oska kahjuks öelda.
http://nodejs.org/
lorch
sõnum 09.03.2010 15:20:39 vasta tsitaadiga
medium scenariot mängides peabki majad põlema minema?
Oldermann
sõnum 09.03.2010 15:59:41 vasta tsitaadiga
mingi lisa on ka vahpeal välja antud ANNO 1404: Venice
ei ole allkirja
toooomas
sõnum 10.03.2010 08:53:31 vasta tsitaadiga
lorch kirjutas:
Selle vastu aitavad tuletõrje majad. Eeldatavasti medium scenario'l on õnnetused lubatud.
ak47
sõnum 12.03.2010 18:05:58 vasta tsitaadiga
Siuke probleem siis, et üritame lanis venice teha, teised minu servu leiavad aga mina ei näe kellegi oma.Milles võib probleem olla ja kuidas seda ära parandada saaks?
Kommentaarid: 41 loe/lisa Kasutajad arvavad:  :: 3 :: 1 :: 33
RassK
RassK
sõnum 12.03.2010 18:09:49 vasta tsitaadiga
filtrid vms maas ikka?
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Anno 1404 mine lehele eelmine  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  järgmine
