Maailm
04.02.2010 21:17:50
Videodriverid uusimad peal jah, patche pole sikutada viitsinud, kuna nett sakib :S
| Kommentaarid: 38 loe/lisa |
pioneeros
04.02.2010 23:20:17
Mangule tuleb lisaosa (MP-ga) |
Anno 1404: Venice (Expansion Pack) PC
Release Date: 26 February 2010
Anno 1404 is unique and award-winning combination of construction, economy, discovery, diplomacy and combat. The game now offers multiplayer support, more adventures, new buildings, new quests and plenty of customisable content in order to go even further in gaming entertainment. Anno 1404: Venice is grandiose, improved, larger, innovative, living, and now allow you to share this experience with friends.
* Requries Anno 1404 to play
* Play Anno 1404 in multiplayer and online!
* Up to 4 players
* Challenge your friends by playing Versus Mode
* Choose Co-Op Mode and defeat the AI by merging your techniques
* A totally improved environement to be played: Venice!
* Embody a new venetian character: Giacomo Garibaldi
* Build an armada and reinvent your very own ships with custom builds
* Develop secret cabinets, infiltrate your enemies and sabotage their expansion
* Take control over a city thanks to your economical influence
* New challenges and quests!
* Up to 300 new quests with two new types: trading race and ship boarding
* 60 new items to increase your domination
* Discover, exploit a new type of islands, the Volcano Islands
* New islands to build giant cities
* New scenarios to face new challenges
* New achievements, medals and crests
| Kommentaarid: 10 loe/lisa |
10 |
Maailm
destiny12
05.02.2010 11:53:05
Endal jookseb 30-40 fps.
4xAA,8xAF.
Mingi imelik nõksumine on ainult sees kui nooltega ringi liikuda.
Muidu täitsa tore mäng.
Ainult ei jaga asja eriti hästi veel.
| Kommentaarid: 83 loe/lisa |
77 |
Lovvi
05.02.2010 14:56:01
| Maailm kirjutas: |
Tore, arvata oligi , et MP-d ei tule kaua oodata  |
Ei pidanud kaua ootama? Ma lootsin, et multiplayer patch tuleb mingi 1-2 kuuga, aga noh..
| Kommentaarid: 60 loe/lisa |
57 |
Redikate
11.02.2010 03:46:02
Tore, igaljuhul proovin MP ka ära.
Juba kujutan ette neid 20h mänge.
_________________ http://nodejs.org/
"I'm also a person. Programming is just one thing I do." |
| Kommentaarid: 34 loe/lisa |
33 |
Maailm
11.02.2010 10:11:10
Hmm, panin 1.1 patchi peale, nüüd ikka maapinnad mustad kuid siin seal saarel on lõigud kus ilus roheline maapind... ons veel patche väljas või mis teha tuleb?
_________________ Pokkerit mängid aga rakeback ei saa? Liitu! |
Lordlesta
11.02.2010 18:00:55
| Maailm, mine "C:\Users\KASUTAJA\AppData\Roaming\Ubisoft\Anno1404\Config" ja ava fail nimega "Engine.ini", nüüd otsi üles rida "<DirectXVersion>0</DirectXVersion>" ning pane nulli asemel 9.
| Kommentaarid: 31 loe/lisa |
Lovvi
11.02.2010 18:07:16
| Lordlesta kirjutas: |
| Maailm, mine "C:\Users\KASUTAJA\AppData\Roaming\Ubisoft\Anno1404\Config" ja ava fail nimega "Engine.ini", nüüd otsi üles rida "<DirectXVersion>0</DirectXVersion>" ning pane nulli asemel 9. |
Või pane vanemad draiverid peale (juhul kui ATI), ehk siis 9.7, kui ei taha dx10 kaotada.
57 |
Maailm
11.02.2010 18:57:22
Mul ati jah, HD4870. Selge, proovin kõigepealt 9.7 ja kui ei aita siis katsetan seda dx9 varianti.
Edit: 9.7 catalyst peal ja voila, graafika oki Väga mõnus Aga arusaamatu miks uuemad driverid asja piixu keeravad... loodetavasti järgmine uuendus asja parandab.
Tänud nõuande eest
Lovvi
28.02.2010 13:00:29
| Kellelgi soovi koos mängida (LAN)?
57 |
Renq
28.02.2010 13:51:06
| hetkel mitte, a muidu täitsa võimalik, läbi hamatsi siis?
Redikate
28.02.2010 14:38:55
Läbi hamachi täiesti toimib. Ise olen juba ühe mängu teinud 3 inimesega.
33 |
Lovvi
28.02.2010 15:01:29
| Kui kellelgi on soovi mängida siis saate PS.
57 |
Redikate
28.02.2010 20:36:14
Sai üks mäng tehtud siis Lovvi ja ühe tuttavaga.
Winning conditioniks oli 150k goldi, mängisime umbkaudu 5-6h ning võitsin ise päris pika eduga.
GD
33 |
Renq
28.02.2010 21:53:39
kui ma üldse mängiks, siis ma teeks ilma kindla sihtmärgita, lihtsalt et saaks mängida.
Redikate
28.02.2010 22:03:25
| Renq kirjutas: |
| kui ma üldse mängiks, siis ma teeks ilma kindla sihtmärgita, lihtsalt et saaks mängida. |
Peale winning conditioni täitmist saab edasi mängida. Winning conditioneid saab ka mitu panna, niiet võib pärast vaadata kes enim ära tegi vms.
Meie mängu mängib veel mu tuttav edasi igatahes, ei ole uurind mis seis on tal.
Ma isiklikult ilma winning conditionita ei kannata mängida. Tundub kuidagi lihtsalt aja maha viskamisena, siis ikka mingi point ka.
33 |
Lovvi
01.03.2010 15:24:00
| Redikate kirjutas: |
GD  |
Pro
Ma algul oli ehmatasin, kui küsisid ka 8h vaba aega on . Nüüd siis tean, et laupäeva hommikul tuleb pelama hakata . Aga päris 5h välja tulnud, mingi 4.30 äkki.
57 |
RassK
01.03.2010 18:35:19
krt kuidas te 8h nii kiirelt arenete et juba sõjaväge saate
102 |
Redikate
01.03.2010 18:49:18
Paar pilti ka siis meie mängust, kuna frapsiga pildistatud siis kellaaega kenasti näha. Loodetavasti pole mängus osalenud osapooled piltide postimise vastu.
Lovvi baas kell 15:49. Mäng on just-just alanud.
Natuke üle 1h mängitud. Kerge ülevaade.
Mu enda baas kell 17:30. Natuke alla 2h mängitud.
18:34. Minu baas koos mõne ressursiga.
Kell on 20:15. Mängitud siis natuke alla 5h, seis minu nobelmanide housis.
12 minutit hiljem sai mul raha kokku. Teiste mängijate seisu ei oska kahjuks öelda.
33 |
lorch
09.03.2010 15:20:39
| medium scenariot mängides peabki majad põlema minema?
Oldermann
09.03.2010 15:59:41
mingi lisa on ka vahpeal välja antud ANNO 1404: Venice
_________________ ei ole allkirja |
| Kommentaarid: 7 loe/lisa |
toooomas
10.03.2010 08:53:31
| lorch kirjutas: |
| medium scenariot mängides peabki majad põlema minema? |
Selle vastu aitavad tuletõrje majad. Eeldatavasti medium scenario'l on õnnetused lubatud.
| Kommentaarid: 16 loe/lisa |
16 |
ak47
12.03.2010 18:05:58
| Siuke probleem siis, et üritame lanis venice teha, teised minu servu leiavad aga mina ei näe kellegi oma.Milles võib probleem olla ja kuidas seda ära parandada saaks?
| Kommentaarid: 41 loe/lisa |
33 |
RassK
12.03.2010 18:09:49
| filtrid vms maas ikka?
102 |
