uus teema   vasta Tarkvara »  Arvutimängude foorum »  Anno 1404 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, 4, 5  järgmine
Maailm
Maailm
sõnum 04.02.2010 22:17:50 vasta tsitaadiga
Videodriverid uusimad peal jah, patche pole sikutada viitsinud, kuna nett sakib :S
Kommentaarid: 38 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 35
pioneeros
pioneeros
sõnum 05.02.2010 00:20:17 Mangule tuleb lisaosa (MP-ga) vasta tsitaadiga
Anno 1404: Venice (Expansion Pack) PC
Release Date: 26 February 2010
Anno 1404 is unique and award-winning combination of construction, economy, discovery, diplomacy and combat. The game now offers multiplayer support, more adventures, new buildings, new quests and plenty of customisable content in order to go even further in gaming entertainment. Anno 1404: Venice is grandiose, improved, larger, innovative, living, and now allow you to share this experience with friends.
* Requries Anno 1404 to play
* Play Anno 1404 in multiplayer and online!
* Up to 4 players
* Challenge your friends by playing Versus Mode
* Choose Co-Op Mode and defeat the AI by merging your techniques
* A totally improved environement to be played: Venice!
* Embody a new venetian character: Giacomo Garibaldi
* Build an armada and reinvent your very own ships with custom builds
* Develop secret cabinets, infiltrate your enemies and sabotage their expansion
* Take control over a city thanks to your economical influence
* New challenges and quests!
* Up to 300 new quests with two new types: trading race and ship boarding
* 60 new items to increase your domination
* Discover, exploit a new type of islands, the Volcano Islands
* New islands to build giant cities
* New scenarios to face new challenges
* New achievements, medals and crests
Maailm
Maailm
sõnum 05.02.2010 00:34:21 vasta tsitaadiga
Pokkerit mängid aga rakeback ei saa? Liitu!
destiny12
destiny12
sõnum 05.02.2010 12:53:05 vasta tsitaadiga
Endal jookseb 30-40 fps.
4xAA,8xAF.
Mingi imelik nõksumine on ainult sees kui nooltega ringi liikuda.
Muidu täitsa tore mäng.
Ainult ei jaga asja eriti hästi veel.
Kommentaarid: 83 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 77
Lovvi
Lovvi
sõnum 05.02.2010 15:56:01 vasta tsitaadiga
Maailm kirjutas:
Ei pidanud kaua ootama? Ma lootsin, et multiplayer patch tuleb mingi 1-2 kuuga, aga noh..
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 58
Redikate
Redikate
sõnum 11.02.2010 04:46:02 vasta tsitaadiga
Tore, igaljuhul proovin MP ka ära.
Juba kujutan ette neid 20h mänge.
http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
Maailm
Maailm
sõnum 11.02.2010 11:11:10 vasta tsitaadiga
Hmm, panin 1.1 patchi peale, nüüd ikka maapinnad mustad kuid siin seal saarel on lõigud kus ilus roheline maapind... ons veel patche väljas või mis teha tuleb?
Lordlesta
sõnum 11.02.2010 19:00:55 vasta tsitaadiga
Maailm, mine "C:\Users\KASUTAJA\AppData\Roaming\Ubisoft\Anno1404\Config" ja ava fail nimega "Engine.ini", nüüd otsi üles rida "<DirectXVersion>0</DirectXVersion>" ning pane nulli asemel 9.
Kommentaarid: 31 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 27
Lovvi
Lovvi
sõnum 11.02.2010 19:07:16 vasta tsitaadiga
Lordlesta kirjutas:
Või pane vanemad draiverid peale (juhul kui ATI), ehk siis 9.7, kui ei taha dx10 kaotada.
Maailm
Maailm
sõnum 11.02.2010 19:57:22 vasta tsitaadiga
Mul ati jah, HD4870. Selge, proovin kõigepealt 9.7 ja kui ei aita siis katsetan seda dx9 varianti.
Edit: 9.7 catalyst peal ja voila, graafika oki icon_biggrin.gif Väga mõnus icon_smile.gif Aga arusaamatu miks uuemad driverid asja piixu keeravad... loodetavasti järgmine uuendus asja parandab.
Lovvi
Lovvi
sõnum 28.02.2010 14:00:29 vasta tsitaadiga
Kellelgi soovi koos mängida (LAN)?
Renq
Renq
sõnum 28.02.2010 14:51:06 vasta tsitaadiga
hetkel mitte, a muidu täitsa võimalik, läbi hamatsi siis?
Redikate
Redikate
sõnum 28.02.2010 15:38:55 vasta tsitaadiga
Läbi hamachi täiesti toimib. Ise olen juba ühe mängu teinud 3 inimesega.
http://nodejs.org/
Lovvi
Lovvi
sõnum 28.02.2010 16:01:29 vasta tsitaadiga
Kui kellelgi on soovi mängida siis saate PS.
Redikate
Redikate
sõnum 28.02.2010 21:36:14 vasta tsitaadiga
Sai üks mäng tehtud siis Lovvi ja ühe tuttavaga.
Winning conditioniks oli 150k goldi, mängisime umbkaudu 5-6h ning võitsin ise päris pika eduga.
http://nodejs.org/
Renq
Renq
sõnum 28.02.2010 22:53:39 vasta tsitaadiga
kui ma üldse mängiks, siis ma teeks ilma kindla sihtmärgita, lihtsalt et saaks mängida.
Redikate
Redikate
sõnum 28.02.2010 23:03:25 vasta tsitaadiga
Renq kirjutas:
Peale winning conditioni täitmist saab edasi mängida. Winning conditioneid saab ka mitu panna, niiet võib pärast vaadata kes enim ära tegi vms.
Meie mängu mängib veel mu tuttav edasi igatahes, ei ole uurind mis seis on tal.
Ma isiklikult ilma winning conditionita ei kannata mängida. Tundub kuidagi lihtsalt aja maha viskamisena, siis ikka mingi point ka.
http://nodejs.org/
Lovvi
Lovvi
sõnum 01.03.2010 16:24:00 vasta tsitaadiga
Redikate kirjutas:
Pro
Ma algul oli ehmatasin, kui küsisid ka 8h vaba aega on icon_eek.gif . Nüüd siis tean, et laupäeva hommikul tuleb pelama hakata thumbs_up.gif . Aga päris 5h välja tulnud, mingi 4.30 äkki.
RassK
RassK
sõnum 01.03.2010 19:35:19 vasta tsitaadiga
Kommentaarid: 118 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 103
Redikate
Redikate
sõnum 01.03.2010 19:49:18 vasta tsitaadiga
Paar pilti ka siis meie mängust, kuna frapsiga pildistatud siis kellaaega kenasti näha. Loodetavasti pole mängus osalenud osapooled piltide postimise vastu.
Lovvi baas kell 15:49. Mäng on just-just alanud.
Natuke üle 1h mängitud. Kerge ülevaade.
Mu enda baas kell 17:30. Natuke alla 2h mängitud.
18:34. Minu baas koos mõne ressursiga.
Kell on 20:15. Mängitud siis natuke alla 5h, seis minu nobelmanide housis.
12 minutit hiljem sai mul raha kokku. Teiste mängijate seisu ei oska kahjuks öelda.
http://nodejs.org/
lorch
sõnum 09.03.2010 16:20:39 vasta tsitaadiga
medium scenariot mängides peabki majad põlema minema?
Oldermann
sõnum 09.03.2010 16:59:41 vasta tsitaadiga
mingi lisa on ka vahpeal välja antud ANNO 1404: Venice
ei ole allkirja
toooomas
sõnum 10.03.2010 09:53:31 vasta tsitaadiga
lorch kirjutas:
Selle vastu aitavad tuletõrje majad. Eeldatavasti medium scenario'l on õnnetused lubatud.
ak47
sõnum 12.03.2010 19:05:58 vasta tsitaadiga
Siuke probleem siis, et üritame lanis venice teha, teised minu servu leiavad aga mina ei näe kellegi oma.Milles võib probleem olla ja kuidas seda ära parandada saaks?
Kommentaarid: 41 loe/lisa Kasutajad arvavad:  :: 3 :: 1 :: 33
RassK
RassK
sõnum 12.03.2010 19:09:49 vasta tsitaadiga
filtrid vms maas ikka?
ak47
sõnum 12.03.2010 19:12:49 vasta tsitaadiga
krusu70 kirjutas:
On küll
Redikate
Redikate
sõnum 12.03.2010 19:33:58 vasta tsitaadiga
ak47 kirjutas:
Oled W7 austaja ja hamachi kasutaja? Juhul kui jah, siis disable oma põhi nett ja siis mine mängu ning siis võid õige neti tagasi panna. Võimalik, et aitab, võimalik, et mitte.
Mõte on siis selles, et w7 all ei oska / taha mäng kasutada hamachi adapterit.
Juhul kui ei kasuta hamachi, ega w7't, siis ei oska aidata.
http://nodejs.org/
Jaan700
sõnum 12.03.2010 20:06:51 vasta tsitaadiga
Mina leian tema mängu üles, samas kolmas sõber ei näe seda. Jällegi mitte keegi ei näe minu mängu ja mina näen kolmanda sõbra mängu icon_biggrin.gif
Imelik anomaalia, kõik firewallid jms filtrid on maas, ka hamachi on sätitud kõige 'esimeseks' ühenduseks..
Minul xp ja kolmandal sõbral Vista
Redikate
Redikate
sõnum 12.03.2010 22:31:23 vasta tsitaadiga
Jaan700 kirjutas:
Mnjah, seljuhul ei oska aidata kahjuks.
http://nodejs.org/
Pihlakas
Pihlakas
sõnum 13.03.2010 12:32:50 vasta tsitaadiga
Sõbraga teeme annot tunngles http://www.tunngle.de/
rainer9968
rainer9968
sõnum 20.03.2010 13:37:28 vasta tsitaadiga
Pöördun ka siis oma murega Anno 1404 mängijate poole. Probleem selles, et pärast ca 20-30 minutilist mängimist, jääb mäng seisma ja tuleb veateade: nv4 display drivers stopped work ning seejärel lööb monitoril reso ja värvid miinimumi kuigi mäng ise jääb tööle. Aitab ainult arvutile restardi tegemine. Olen proovinud erinevaid draivereid nii uusi kui ka vanu aga abi erilist ei ole. Kui Anno 1404 uuesti peale lasta siis saab mängida aga algab uuesti jama peale. Op. süsteemiks Win XP ja graafikakaardiks Geforce 7600 GS. icon_confused.gif
Kommentaarid: 44 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 38
K3ndu
K3ndu
sõnum 13.05.2010 18:55:53 vasta tsitaadiga
Mismoodi neid elanike linna juurde saab?
Mingi 3 tundi pelasin jutti ja oligi Citizenide arv sama, ehitasin maju juurde ja põhielanikud said kõik oma toitu ,aga need Araablased ei saanud oma datleid, kas sellepärast asi ei liikunud?
Kommentaarid: 131 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 121
Renq
Renq
sõnum 13.05.2010 19:02:29 vasta tsitaadiga
K3ndu kirjutas:
Butcher
Butcher
sõnum 13.05.2010 19:08:52 vasta tsitaadiga
K3ndu kirjutas:
tax rate peab madal olema, muidu rahvast ei tule juurde.
a rääkige parem mis moodi saab 10 000 noblemani, et viimane linna staatus saada.
Aix
Aix
sõnum 14.05.2010 08:56:11 vasta tsitaadiga
Butcher kirjutas:
Kommentaarid: 418 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 348
K3ndu
K3ndu
sõnum 15.05.2010 15:27:48 vasta tsitaadiga
Keegi nippe oskab öelda kuidas paremini raha teenida?
Mul raha läheb koguaeg miinustesse, see teenimine.
Redikate
Redikate
sõnum 15.05.2010 18:46:46 vasta tsitaadiga
K3ndu kirjutas:
Raha tuleb sisse peamiselt 2'st asjast. Kaubandusest ja inimestest. Katsu linnas inimeste arvu hoida koguaeg piisavalt kõrge, et neilt teenitu tooks tagasi majade upkeepi ja pealegi. Kui sa juhuslikult maju ei uuenda, siis võid maksud happy peal hoida.
Samuti alati pane oma ülejäägid müüki. NPC'd ostavad päris palju kaupa.
http://nodejs.org/
Éxxon
sõnum 15.05.2010 18:49:19 vasta tsitaadiga
Keegi mängida viitsib? Läbi Hamachi (või mõne muu sellise programmi), või kui on piisavalt hea ühendus, siis läbi avatud pordi.
Kommentaarid: 72 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 71
Redikate
Redikate
sõnum 15.05.2010 18:55:56 vasta tsitaadiga
Éxxon kirjutas:
Plaanis varsti hakata ühte pikemat mängu. Ilmselt sinna 10h juurde kuskile.
Oled käsi? Ei pea tervet mänguaeg kohal olema, saame aru küll kui uni õhtul murrab icon_wink.gif
http://nodejs.org/
K3ndu
K3ndu
sõnum 15.05.2010 19:06:26 vasta tsitaadiga
Redikate kirjutas:
K3ndu kirjutas:
Teen kõik nii, aga kuidagi vastasel nii palju linnasi ja suured linnad ,et midagi hullu ja kõige kergema raskusastmega mängin.
Redikate
Redikate
sõnum 15.05.2010 19:20:51 vasta tsitaadiga
K3ndu kirjutas:
Üritad päästa mingit pooleli olevat mängu või...?
Kui juba pooleli olev on miinuses siis pole väga midagi teha. Võib proovida ülejääkide käsitsi müümist ning oma tooteliinide läbisõelmust ning ebavajaliku eemaldamist.
Kui uut alustad siis ära alguses tootmisega üle pinguta. Tooda niipalju kui vaja on. Hoia piisavalt elanikke, et sissetulek koguaeg plussis oleks ning võta asja rahulikult. Mõtle kuidas ja kuhu ehitada ning kui palju.
Ehk tahad meiega tulla MP'd mängima? Ei oska küll öelda praegu kellaaega millal alustaks, kuid eks ta millalgil õhtu ole.
http://nodejs.org/
Éxxon
sõnum 15.05.2010 20:00:04 vasta tsitaadiga
Mina oleks käsi.
Räägi asjast lähemalt.
Redikate
Redikate
sõnum 16.05.2010 04:33:25 vasta tsitaadiga
Saatsin PSi. Mäng täis nüüd thumbs_up.gif.
E: Mäng läbi... kokku sai siis mängitud peaaegu 7 tundi koos mõne pausiga kuna mäng crashis.
Tegime neljakesi, winning conditioniteks olid: 5k nobels or 5k envoys or 10k population
Keegi nii kaugele ei jõudnud, uni murdis enne.
Niipalju oskan kommenteerida et päris tasavägine mäng oli. Vastased olid head ning puhata polnud hetkegi aega.
4 kesi on HUGE map tegelikult siiski liiga pisike. Vaja oleks umbes 2x samasuur kaarti, et korralikult mängima mahuks. Lõpus kisuvad numbridki juba ulmeks kätte ära... woodi, toolse ja ore tootis nii tohutult, et lõpus kui kaks venda lahkunud olid, suutsin põhisaarel toodetuga ehitada ülesse 4 täismahus linna koos basic production line'ga.
Täna enam pilte uppida ei viitsi, eks homme vast.
http://nodejs.org/
K3ndu
K3ndu
sõnum 16.05.2010 11:45:32 vasta tsitaadiga
Miinusesse mul ei lähe ,aga kõigub +100 ja -200 vahel pidevalt.
Olen kahe saare peal, üks põhjas üks lõunas.
Redikate
Redikate
sõnum 17.05.2010 20:28:26 vasta tsitaadiga
Täna plaanis teha jälle üks mäng. Arvestama peab sellega et võib hommikuni ulatuda. Võtke ühendust PSi või MSNi kaudu kui soovi liituda.
Kasutame Venti ning hamachit ja mängime Venice expansionit.
1 koht vaba.
E: Asendasime 4'na AI'ga icon_neutral.gif
http://nodejs.org/
viimati muutis Redikate 17.05.2010 20:55:56, muudetud 1 kord
Éxxon
sõnum 17.05.2010 20:38:42 vasta tsitaadiga
Butcher
Butcher
sõnum 20.05.2010 10:25:20 vasta tsitaadiga
No mina ei saa viimast linna tärni kuidagi. Võtsin huge maailma ja kõige suuremad saared, kogu tootmine põhisaarelt ära viidud... maju lihtsalt ei mahu nii palju et saaks 7500 noblemani?
Redikate
Redikate
sõnum 20.05.2010 15:38:48 vasta tsitaadiga
Butcher kirjutas:
Koli ka elanikud mitmele saarele siis ju?
Kui sa mängid üksi HUGE worldi, siis ei ole see üldse raske.
http://nodejs.org/
Butcher
Butcher
sõnum 20.05.2010 19:10:23 vasta tsitaadiga
Pidasin silmas linna statust. Viimane tärn on cosmopolitan city. Hetlel on metropolis.
sõnum 20.05.2010 19:11:04 vasta tsitaadiga
anno 1404 + venice (gamestar)
neile, kellel veel ei ole.
hetkel väga hea hinnaga.
- londiste
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Anno 1404 mine lehele eelmine  1, 2, 3, 4, 5  järgmine
