16.12.2009 03:31:05
| 1dumbpcuser kirjutas: |
31% of Windows 7 Problems Are From Install
TomsGuide
1. Problems with installation: 31 percent
2. Missing applets or components: 26 percent
3. Aero theme is not running: 14 percent
4. DVD drive not found (this happens despite the drive being visible in the BIOS and the standard driver is working): 8 percent
5. Hidden extensions (Windows Explorer's default setting in all the versions of Windows is to hide file extensions, as well as system files and folders): 6 percent
6. Too many minidumps (By default Windows 7 keeps the last 50; minidumps are the memory images saved on the system when your PC crashes): 6 percent
7. Aero snap problems (Windows 7 has a handy new ability to move and resize windows, all in one movement, but sometimes it does not work as expected and can become annoying): 3 percent
8. iPhone won't sync with Windows 7 (usually with the 64-bit edition, the iPhone sometimes get recognized but then iTunes returns with the error 0xE8000065): 2 percent
9. Custom icons get changed with new theme (When a new Windows 7 theme is applied, custom icons can be lost): 2 percent
10. Taskbar problems (In Windows 7, it's difficult to tell at a glance whether an icon is a running application or a pinned shortcut): 1 percent |
Ainult Nr 5 käib pinda.Muid pole kohanud
16.12.2009 09:20:05
Nii. Jätkan siis oma "põnevate avastuste" teemat seoses kopeerimisega (ja aina jaburamaks see läheb):
Selgub, et junctioneid ei kopeeri tegelikult mitte miski Windowsi enda vahenditest, sealhulgas ka W7 enda backup utiliit. Nii et kes loodab oma kasutajaprofiili sellega varundada ja hiljem taastada, saab "meeldiva" üllatuse osaliseks.
Mis siis veel Microsofti vahenditest ei suuda selle tööga hakkama saada:
Easy Transfer (loomulikult)
SyncToy 2.1 (ja vanemad)
Samuti sai proovitud arhivaatoreid:
WinRAR (pakkimine koos security ja striimidega) - ei paki ega taasta junctioneid
7-Zip - pakib ja taastab junctionid tühjade kaustadena
Jääb veel üle proovida Acronist.
16.12.2009 10:27:33
| Dogbert kirjutas: |
Jääb veel üle proovida Acronist. |
Macrium Reflect Free
viimati muutis Etz 16.12.2009 10:47:44, muudetud 1 kord |
16.12.2009 10:46:34
Jah, ainus võimalus taastada ka junctionid on teha partitsioonist tõmmis ja taastada terve partitsioon. Tõmmisest eraldi kaustade taastamisel või kasutadest eraldi backupi tegemisel asi jällegi ebaõnnestub. No ma ei tea. Op-süsteem, mis iseendaga hakkama ei saa?! Uhke loss ehitati valmis, aga vundamendisegusse unustati tsement lisamata, eks ole. Väike näpukas.
Järjekordne eyecandy ja half-ass op-süsteem siis Microsoftilt. Õnnitleme!
Ja tänud Macriumile viitamise eest (kuigi CNeti linke pole kunagi mõtet kasutada, sest need ei tööta nagunii, aga nime järgi otsing juhatas kodulehele). Kindlasti saab vajaliku tööga hakkama ka Macrium.
viimati muutis Dogbert 16.12.2009 10:51:38, muudetud 1 kord |
16.12.2009 10:49:36
| Dogbert kirjutas: |
Ja tänud Macriumile viitamise eest (kuigi CNeti linke pole kunagi mõtet kasutada, sest need ei tööta nagunii, aga nime järgi otsing juhatas kodulehele). Kindlasti saab sellega hakkama ka Macrium. |
Viitasin kodulehele ringi, downloadi tõesti sealt ei proovinud
Ise siiani sellega edukalt igasugused backupid tehtud saanud...
Ikaldus ju veel selles, et Win7/Vista Home versioonid ise ei toeta backuppi võrguketastele...
Samas on suur mõte ju Backuppi samas masinas hoida (kui just Blue-Ray kirjutajat ei oma, on mujale paigutamisega kergeid raskusi)
16.12.2009 11:18:52
Ei, nojah. Seda ei oska enam kommenteerida ka mitte. Nuta või naera.
Timberg
ööKARU
16.12.2009 11:50:59
| Jäi kusagilt sil,a, et win 7'ga saab emuleerida rõõmsalt ka win xpd virtuaalse masinana? Kas saab ja kuidas?
16.12.2009 11:53:55
| Timberg kirjutas: |
| Jäi kusagilt sil,a, et win 7'ga saab emuleerida rõõmsalt ka win xpd virtuaalse masinana? Kas saab ja kuidas? |
http://www.microsoft.com/windows/virtual-pc/download.aspx
1dumbpcuser
16.12.2009 12:41:06
Xp-Mode  |
See nn "XP Mode" Windows 7 puhul koosnebki "Windows XP Mode" pakist, mis tuleb installida esimesena ja "vanast tuttavast" Virtual PC-st, mis tuleb installida teisena. Mõlemad on allalaetavad minu antud lingilt. Enne kilkamist paluks lugeda.
Q.
16.12.2009 12:44:25
| Keegi Supaplexi ei ole proovinud Win7 peale jooksutada? Üks õhtu oli igav kodus ja mõtlesin, et meenutaks vanu aegu, ent ei saanud asja jooksma. Ilmselt tuleb vist läbi Virtual PC tööle ajada.
Ertymo
16.12.2009 12:45:10
| HighEnd kirjutas: |
"Open file.." parema kliki menüüst puudu ja faili propertites ei näida "Details" tabi. Oskab keegi aidata? Arvan ise et midagi registris segi. |
Kunas, sa märkasid et see sealt kadunud?
Kui sa uue kasutaja teed, kas siis on sama probleem?
16.12.2009 12:45:33
| Dogbert kirjutas: |
Xp-Mode  |
See nn "XP Mode" Windows 7 puhul koosnebki "Windows XP Mode" pakist, mis tuleb installida esimesena ja "vanast tuttavast" Virtual PC-st, mis tuleb installida teisena. Mõlemad on allalaetavad minu antud lingilt. Enne kilkamist paluks lugeda. |
Ehk siis täpsustuseks, tegu on XP "virtuaalmasinaga"...
Pmst sama tulemuse saab, kui installida VirtualPC (või mõni muu Virtuaal masina rakendus) ja sinna sisse siis ise XP...
16.12.2009 13:32:16
Just. Nii et sama hästi võib kasutada seda mitte ainult W7 all vaid ka Vista ja XP enda all (ilma XP mode paketita muidugi) ning mitte ainult Windows XP jooksutamiseks vaid võid sinna ka Windows 98, 95 või kasvõi 3.1 peale panna, DOS-ist ja mitte-Microsofti süsteemidest rääkimata.
Nii et vanad DOS-i mängud, sh Supaplex tasub käima lükata virtuaalmasinas päris DOS-is (kui DOSBox üle jõu käib või mäng selle all töötamast keeldub).
DeTHiCa.
16.12.2009 13:43:26
| Q. kirjutas: |
| Keegi Supaplexi ei ole proovinud Win7 peale jooksutada? Üks õhtu oli igav kodus ja mõtlesin, et meenutaks vanu aegu, ent ei saanud asja jooksma. Ilmselt tuleb vist läbi Virtual PC tööle ajada. |
supaplex on porditud juba uutele OS'idele. google peaks aitama.
xp all mängisin, töötas tip top.
Q.
16.12.2009 15:14:06
| XP all sai mängitud jah, õhtul kodus uurin edasi, ehk leiab midagi 7 jaoks.
Equinox
16.12.2009 15:35:03
Tre,
| Q. kirjutas: |
| XP all sai mängitud jah, õhtul kodus uurin edasi, ehk leiab midagi 7 jaoks. |
Heh, eile just ise ka proovisin Vana Supaplex sisaldab 16-bit koodi ja seda niisama 7 peal käima ei saa. Ehk siis virtuaal masinat vaja või DOSBox-i. Või nagu juba öeldud siis uuemat porditud programmi.
Eile rohkem polnud aega, ei jõudnud DOSBoxi varianti proovida, et selles osas pead ei saa anda. XP all töötasid ka DOSBoxiga vanad mängud edukalt. Mul on sama probleem veel HOMM2-ga mida tahaks käima saada Win7 all.
Equ, ka abandonware mängude gurmaan
_________________ Live long and prosper!
RIP, Spock. Leonard Nimoy 1931-2015 |
mazdagti
16.12.2009 16:56:16
Selline küsimus et kas touchpad anomaaliad on seotud ka op süsteemiga? Omal lihtsalt asuse 1008HA ja Starteri puhul tekkinud selline jama et see tochpadiga lehe/akna alla kerimine kaob lihtsalt mingi hetk ära. Draiverid on Synapticu enda omad.
_________________ No ikka täitsa kagu nukas!
FB Volvokodu, diagnostikaabi Võrumaal. |
CoiL
16.12.2009 17:23:53
| mazdagti, mul naisu läparis XPSP2-e all google Chrome`ga sama jama ning vahest mujal ka ei tööta.
16.12.2009 17:42:45
Kas ma kuidagi saan oma KEY ka teada kui on w7 installitud juba?
CoiL
16.12.2009 17:47:37
| Control Panel\System and Security\System ...product ID-d mõtled?
16.12.2009 17:50:55
Ei, ma mõtlen seda võtit millega ma installisin, kirjutaksin plaadi peale selle ära, vb kunagi läheb vaja üleinstallimiseks. Sain oma key'd msni teel ja millegipärast ei jäänud logisse tol päeval vestlusi päris mitu vajalikku keyd on nii kadunud hetkel, õnneks technetist saab vaadata, aga too inimene veidikene eemal on
Look Right
Anna vin
16.12.2009 17:51:44
product-id ei ole sama asi, mis key. Minu meelest ei näe kusagilt niisama lihtsalt seda. Vb registris kuskil kirjas.
_________________ Ehitusprojektid ja konstruktiivsed lahendused HV kasutajatele soodsamalt
M: Zafira A/Astra G põhjakaitse - 30€ |
XYZ
16.12.2009 18:05:39
| Etz kirjutas: |
| Dogbert kirjutas: |
Xp-Mode  |
Pmst sama tulemuse saab, kui installida VirtualPC (või mõni muu Virtuaal masina rakendus) ja sinna sisse siis ise XP... |
Mäletamisi ei ole päris sama. XP-modega kaasneb sulle virtuaalmasinasse legaalne koopia wxp-st ilma, et peaksid muret tundma aktiveerimise pärast ja uuenduste pärast, kõik on win7 võtme baasil olemas/legaalne. Kui aga installid vaid VMasina ja tahad sinna opsüssi panna, ükskõik millist, siis selle legaalsus on juba eraldi sinu mure.
16.12.2009 18:14:42
| XYZ kirjutas: |
| Etz kirjutas: |
| Dogbert kirjutas: |
Xp-Mode  |
Mäletamisi ei ole päris sama. XP-modega kaasneb sulle virtuaalmasinasse legaalne koopia wxp-st ilma, et peaksid muret tundma aktiveerimise pärast ja uuenduste pärast, kõik on win7 võtme baasil olemas/legaalne. Kui aga installid vaid VMasina ja tahad sinna opsüssi panna, ükskõik millist, siis selle legaalsus on juba eraldi sinu mure. |
Selle koha pealt on sul täiesti õigus...
Muusosas peaks ikkagist sama välja tulema...
Ertymo
16.12.2009 18:17:25
TuneUp Utilities 2010 on ka see võimalus olemas.
Q.
16.12.2009 19:33:48
| mazdagti kirjutas: |
| Selline küsimus et kas touchpad anomaaliad on seotud ka op süsteemiga? Omal lihtsalt asuse 1008HA ja Starteri puhul tekkinud selline jama et see tochpadiga lehe/akna alla kerimine kaob lihtsalt mingi hetk ära. Draiverid on Synapticu enda omad. |
OSi viga tõesti. Peale 7 panekut kadus ka enda 1008HA'l üles-alla scrollimine ära, kuigi zoom töötab ilusti. Sai draivereidki uuendatud, samuti Synapticu omad, ei aidanud. Ehk tuleb lihtsalt uuendusi oodata.
Timberg
ööKARU
16.12.2009 20:35:57
| win7 all selles "virtuaalses xp modes" saab mõne graafikakaarti rohkem kasutava mängu (world of warcraft) tööle ka panna?
16.12.2009 20:48:09
Kuna VirtualPC "videokaart" on samuti virtuaalne ja emuleeritud (niigi puudulikult) S3 Trio 32/64, millel ka reaalsena ja rauas isegi ajaloolises mõistes talutavat 3D kiirendust ei ole, siis on see suhteliselt kahtlane. Aga võid ju proovida ja katsetada...
Aga enne võiks proovida Windows 7 all seda otse installida ja käima panna. Isegi selline vana mäng läks Windows 7 all probleemideta käima nagu Tetris Adventure aastast 2001. Ilma igasuguste emulaatoriteta.
Timberg
ööKARU
16.12.2009 20:50:48
WIndows 7 jookseb wow normullilt, aga olen harjunud kasutama ühte addoni, mis millegi pärast paneb windows 7's wowi crashima ja ilma selle addonita mängida ei taha.
Kui eelpool mainitud virtualiseeritud XP masinas lasin wowi tööle, siis öeldi erroriks "ERROR #132 (0x85100084)". Oskab keegi soovitada misket?
Max Powers
16.12.2009 21:57:18
| ID.ee lehelt tuleb hetkel Vista asju kasutad?
olafsand
16.12.2009 23:09:43
| Max Powers kirjutas: |
| ID.ee lehelt tuleb hetkel Vista asju kasutad? |
jah
WäntWõll
make.believe
17.12.2009 00:42:30
Kuskohast ma leiaks nvidia 8400M gs jaoks draiverid (ei taha nvidia lehelt seda 140 mb varianti)
mazdagti
17.12.2009 06:42:47
Isegi Starteriga toimib sealt lehelt tõmmatud softiga ID-kaardi lugeja ideraalselt
rosin
17.12.2009 12:11:02
Mul on Windows 7 Pro x64 ja id kaardi lugeja installimisega polnud probleeme. Kaardilugeja (Cardman 1021) jaoks leidis
draiverid ise, id.ee lehelt laadisin alla toe firefoxi (ei ole ie sõber) jaoks ja töötab.
17.12.2009 12:20:11
Hehee, asi leidis vajalikud draiverid ise peale restarti
HP pavilion dv6000 seeria läpakal 1.45ghz pentium dual-core protsessoriga on W7 erksam kui Vista
olafsand
17.12.2009 13:32:41
Ta tegelt jah ei küsigi OS`i kohta midagi, aga kui esimese lingi pealt tirima panna, siis faili nimi sisaldab sõva "vista". Muud ei midagi, aga toimib ilusti
DVDRW
18.12.2009 10:27:16
Kas windows 7 ei olegi sisseehitatud veebikaamera programmi? XP all on nii, et võtad exploreri lahti ja seal klikid kaamera peale ja ongi plaks pilt ees.
olafsand
18.12.2009 10:50:42
| DVDRW, kui webcami driver õige on, siis peaks tekkima küll tegelikult exploreri alla kaamera ikoon.
DVDRW
18.12.2009 10:58:01
| Device manageri all näitab küll ilusti seda kaamerat ilma kollase hüüumärgita.
CoiL
18.12.2009 12:09:13
| DVDRW, mis versioon sul w7-st on? Home?
DVDRW
18.12.2009 12:13:13
Proffessional E4300 läpakaga kaasa tulnud.
Googeldades sain ka nii aru, et see funktsioon on windows 7st eemaldatud
Teil siin kellelgil töötab?
Ertymo
18.12.2009 13:57:37
| Ilma lisaprogrammita pole see windows 7 puhul võimalik..
linux
19.12.2009 03:09:48
chkdsk *: /r kohta oskate midagi öelda, nimelt tomorrow poolt pakutavad viimased updated peal, aga nii kui chkdsk tööle panna siis hakkab kohe mälu õgima?
teab keegi öelda, on seda yldse plaanis m$'l parandada või jätavadki selle sisse?
Win7 Ult 64bit.
19.12.2009 05:23:23
| linux kirjutas: |
Win7 Ult 64bit. |
Ju siis seda ei kavatsetagi parandada.Vähemalt mul masin ei crashinud selle mäluõgimise tõttu
mazdagti
20.12.2009 22:07:35
Nii, op on siis Starter ja kui hakkasin ühendama BT GPS seadet et hakata kasutama Ragioga ning ühildumise käigus peale koodi sisestamist on tulemuseks järgnev: The error code is:0x8007048f. Contact your device manufacture for assistance. Varem olen seadet kasutanud Qtek 9000 isendiga ja kõik toimis Seadmeks on GPS BT77
20.12.2009 22:17:50
Krt ma ei saa läpakal mälukaardilugejat tööle
peaks olema miski Texas Instruments PCIxx12 flashmedia controller või midagi sarnast. Installib ennast ilusti Vista draiveritega ära, ühtegi konflikti ega hüüumärki ei ole aga kui kaardi (SD) sisse lükkan, ei tee ta midagi. Draiverid tõmbasin Ordi lehelt, kuna Clevo lingid on surnud
http://dl.ordi.ee/draiverid/m52xn/m521n.rar
Proovin erinevaid draivereid hetkel. W7 32bit on mul
Edit: leidsin mingist väljamaa foorumi lingilt mingi Toshiba lehe suppordi alt Vista draiveri mis tööle läks
