uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 (arutelu ja probleemid) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 364, 365, 366 ... 746, 747, 748  järgmine
sõnum 16.12.2009 04:31:05 vasta tsitaadiga
1dumbpcuser kirjutas:
31% of Windows 7 Problems Are From Install
TomsGuide
1. Problems with installation: 31 percent
2. Missing applets or components: 26 percent
3. Aero theme is not running: 14 percent
4. DVD drive not found (this happens despite the drive being visible in the BIOS and the standard driver is working): 8 percent
5. Hidden extensions (Windows Explorer's default setting in all the versions of Windows is to hide file extensions, as well as system files and folders): 6 percent
6. Too many minidumps (By default Windows 7 keeps the last 50; minidumps are the memory images saved on the system when your PC crashes): 6 percent
7. Aero snap problems (Windows 7 has a handy new ability to move and resize windows, all in one movement, but sometimes it does not work as expected and can become annoying): 3 percent
8. iPhone won't sync with Windows 7 (usually with the 64-bit edition, the iPhone sometimes get recognized but then iTunes returns with the error 0xE8000065): 2 percent
9. Custom icons get changed with new theme (When a new Windows 7 theme is applied, custom icons can be lost): 2 percent
10. Taskbar problems (In Windows 7, it's difficult to tell at a glance whether an icon is a running application or a pinned shortcut): 1 percent
sõnum 16.12.2009 10:20:05 vasta tsitaadiga
Nii. Jätkan siis oma "põnevate avastuste" teemat seoses kopeerimisega (ja aina jaburamaks see läheb):
Selgub, et junctioneid ei kopeeri tegelikult mitte miski Windowsi enda vahenditest, sealhulgas ka W7 enda backup utiliit. Nii et kes loodab oma kasutajaprofiili sellega varundada ja hiljem taastada, saab "meeldiva" üllatuse osaliseks.
Mis siis veel Microsofti vahenditest ei suuda selle tööga hakkama saada:
Easy Transfer (loomulikult)
SyncToy 2.1 (ja vanemad)
Samuti sai proovitud arhivaatoreid:
WinRAR (pakkimine koos security ja striimidega) - ei paki ega taasta junctioneid
7-Zip - pakib ja taastab junctionid tühjade kaustadena
Jääb veel üle proovida Acronist.
sõnum 16.12.2009 11:27:33 vasta tsitaadiga
Dogbert kirjutas:
viimati muutis Etz 16.12.2009 11:47:44, muudetud 1 kord
sõnum 16.12.2009 11:46:34 vasta tsitaadiga
Jah, ainus võimalus taastada ka junctionid on teha partitsioonist tõmmis ja taastada terve partitsioon. Tõmmisest eraldi kaustade taastamisel või kasutadest eraldi backupi tegemisel asi jällegi ebaõnnestub. No ma ei tea. Op-süsteem, mis iseendaga hakkama ei saa?! Uhke loss ehitati valmis, aga vundamendisegusse unustati tsement lisamata, eks ole. Väike näpukas.
thumbs_down.gif Järjekordne eyecandy ja half-ass op-süsteem siis Microsoftilt. Õnnitleme!
Ja tänud Macriumile viitamise eest (kuigi CNeti linke pole kunagi mõtet kasutada, sest need ei tööta nagunii, aga nime järgi otsing juhatas kodulehele). Kindlasti saab vajaliku tööga hakkama ka Macrium.
viimati muutis Dogbert 16.12.2009 11:51:38, muudetud 1 kord
sõnum 16.12.2009 11:49:36 vasta tsitaadiga
Dogbert kirjutas:
Ja tänud Macriumile viitamise eest (kuigi CNeti linke pole kunagi mõtet kasutada, sest need ei tööta nagunii, aga nime järgi otsing juhatas kodulehele). Kindlasti saab sellega hakkama ka Macrium.
Viitasin kodulehele ringi, downloadi tõesti sealt ei proovinud icon_wink.gif
Ise siiani sellega edukalt igasugused backupid tehtud saanud...
Ikaldus ju veel selles, et Win7/Vista Home versioonid ise ei toeta backuppi võrguketastele...
Samas on suur mõte ju Backuppi samas masinas hoida (kui just Blue-Ray kirjutajat ei oma, on mujale paigutamisega kergeid raskusi) icon_lol.gif
sõnum 16.12.2009 12:18:52 vasta tsitaadiga
Ei, nojah. Seda ei oska enam kommenteerida ka mitte. Nuta või naera.
Timberg
ööKARU
Timberg
sõnum 16.12.2009 12:50:59 vasta tsitaadiga
Jäi kusagilt sil,a, et win 7'ga saab emuleerida rõõmsalt ka win xpd virtuaalse masinana? Kas saab ja kuidas?
sõnum 16.12.2009 12:53:55 vasta tsitaadiga
Timberg kirjutas:
http://www.microsoft.com/windows/virtual-pc/download.aspx
1dumbpcuser
sõnum 16.12.2009 13:08:18 vasta tsitaadiga
M: MSI B660M MORTAR
sõnum 16.12.2009 13:41:06 vasta tsitaadiga
See nn "XP Mode" Windows 7 puhul koosnebki "Windows XP Mode" pakist, mis tuleb installida esimesena ja "vanast tuttavast" Virtual PC-st, mis tuleb installida teisena. Mõlemad on allalaetavad minu antud lingilt. Enne kilkamist paluks lugeda.
Q.
Q.
sõnum 16.12.2009 13:44:25 vasta tsitaadiga
Keegi Supaplexi ei ole proovinud Win7 peale jooksutada? Üks õhtu oli igav kodus ja mõtlesin, et meenutaks vanu aegu, ent ei saanud asja jooksma. Ilmselt tuleb vist läbi Virtual PC tööle ajada.
Ertymo
sõnum 16.12.2009 13:45:10 vasta tsitaadiga
HighEnd kirjutas:
"Open file.." parema kliki menüüst puudu ja faili propertites ei näida "Details" tabi. Oskab keegi aidata? Arvan ise et midagi registris segi.
Kunas, sa märkasid et see sealt kadunud?
Kui sa uue kasutaja teed, kas siis on sama probleem?
sõnum 16.12.2009 13:45:33 vasta tsitaadiga
Dogbert kirjutas:
Ehk siis täpsustuseks, tegu on XP "virtuaalmasinaga"...
Pmst sama tulemuse saab, kui installida VirtualPC (või mõni muu Virtuaal masina rakendus) ja sinna sisse siis ise XP...
sõnum 16.12.2009 14:32:16 vasta tsitaadiga
Just. Nii et sama hästi võib kasutada seda mitte ainult W7 all vaid ka Vista ja XP enda all (ilma XP mode paketita muidugi) ning mitte ainult Windows XP jooksutamiseks vaid võid sinna ka Windows 98, 95 või kasvõi 3.1 peale panna, DOS-ist ja mitte-Microsofti süsteemidest rääkimata.
Nii et vanad DOS-i mängud, sh Supaplex tasub käima lükata virtuaalmasinas päris DOS-is (kui DOSBox üle jõu käib või mäng selle all töötamast keeldub).
DeTHiCa.
DeTHiCa.
sõnum 16.12.2009 14:43:26 vasta tsitaadiga
Q. kirjutas:
supaplex on porditud juba uutele OS'idele. google peaks aitama.
xp all mängisin, töötas tip top.
Q.
Q.
sõnum 16.12.2009 16:14:06 vasta tsitaadiga
XP all sai mängitud jah, õhtul kodus uurin edasi, ehk leiab midagi 7 jaoks.
Equinox
Equinox
sõnum 16.12.2009 16:35:03 vasta tsitaadiga
Tre,
Q. kirjutas:
Heh, eile just ise ka proovisin icon_smile.gif Vana Supaplex sisaldab 16-bit koodi ja seda niisama 7 peal käima ei saa. Ehk siis virtuaal masinat vaja või DOSBox-i. Või nagu juba öeldud siis uuemat porditud programmi.
Eile rohkem polnud aega, ei jõudnud DOSBoxi varianti proovida, et selles osas pead ei saa anda. XP all töötasid ka DOSBoxiga vanad mängud edukalt. Mul on sama probleem veel HOMM2-ga mida tahaks käima saada Win7 all.
Live long and prosper!
mazdagti
mazdagti
sõnum 16.12.2009 17:56:16 vasta tsitaadiga
Selline küsimus et kas touchpad anomaaliad on seotud ka op süsteemiga? Omal lihtsalt asuse 1008HA ja Starteri puhul tekkinud selline jama et see tochpadiga lehe/akna alla kerimine kaob lihtsalt mingi hetk ära. Draiverid on Synapticu enda omad.
No ikka täitsa kagu nukas!
FB Volvokodu, diagnostikaabi Võrumaal.
CoiL
CoiL
sõnum 16.12.2009 18:23:53 vasta tsitaadiga
mazdagti, mul naisu läparis XPSP2-e all google Chrome`ga sama jama ning vahest mujal ka ei tööta.
sõnum 16.12.2009 18:42:45 vasta tsitaadiga
Kas ma kuidagi saan oma KEY ka teada kui on w7 installitud juba?
CoiL
CoiL
sõnum 16.12.2009 18:47:37 vasta tsitaadiga
Control Panel\System and Security\System ...product ID-d mõtled?
sõnum 16.12.2009 18:50:55 vasta tsitaadiga
Ei, ma mõtlen seda võtit millega ma installisin, kirjutaksin plaadi peale selle ära, vb kunagi läheb vaja üleinstallimiseks. Sain oma key'd msni teel ja millegipärast ei jäänud logisse tol päeval vestlusi thumbs_down.gif päris mitu vajalikku keyd on nii kadunud hetkel, õnneks technetist saab vaadata, aga too inimene veidikene eemal on
Look Right
Anna vin
Look Right
sõnum 16.12.2009 18:51:44 vasta tsitaadiga
product-id ei ole sama asi, mis key. Minu meelest ei näe kusagilt niisama lihtsalt seda. Vb registris kuskil kirjas.
sõnum 16.12.2009 19:01:52 vasta tsitaadiga
http://magicaljellybean.com/keyfinder/
XYZ
XYZ
sõnum 16.12.2009 19:05:39 vasta tsitaadiga
Etz kirjutas:
Dogbert kirjutas:
Mäletamisi ei ole päris sama. XP-modega kaasneb sulle virtuaalmasinasse legaalne koopia wxp-st ilma, et peaksid muret tundma aktiveerimise pärast ja uuenduste pärast, kõik on win7 võtme baasil olemas/legaalne. Kui aga installid vaid VMasina ja tahad sinna opsüssi panna, ükskõik millist, siis selle legaalsus on juba eraldi sinu mure.
uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 (arutelu ja probleemid) mine lehele eelmine  1, 2, 3 ... 364, 365, 366 ... 746, 747, 748  järgmine
