uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 (arutelu ja probleemid) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 182, 183, 184 ... 372, 373, 374  järgmine
sõnum 16.12.2009 03:31:05 vasta tsitaadiga
1dumbpcuser kirjutas:
31% of Windows 7 Problems Are From Install
TomsGuide
1. Problems with installation: 31 percent
2. Missing applets or components: 26 percent
3. Aero theme is not running: 14 percent
4. DVD drive not found (this happens despite the drive being visible in the BIOS and the standard driver is working): 8 percent
5. Hidden extensions (Windows Explorer's default setting in all the versions of Windows is to hide file extensions, as well as system files and folders): 6 percent
6. Too many minidumps (By default Windows 7 keeps the last 50; minidumps are the memory images saved on the system when your PC crashes): 6 percent
7. Aero snap problems (Windows 7 has a handy new ability to move and resize windows, all in one movement, but sometimes it does not work as expected and can become annoying): 3 percent
8. iPhone won't sync with Windows 7 (usually with the 64-bit edition, the iPhone sometimes get recognized but then iTunes returns with the error 0xE8000065): 2 percent
9. Custom icons get changed with new theme (When a new Windows 7 theme is applied, custom icons can be lost): 2 percent
10. Taskbar problems (In Windows 7, it's difficult to tell at a glance whether an icon is a running application or a pinned shortcut): 1 percent
sõnum 16.12.2009 09:20:05 vasta tsitaadiga
Nii. Jätkan siis oma "põnevate avastuste" teemat seoses kopeerimisega (ja aina jaburamaks see läheb):
Selgub, et junctioneid ei kopeeri tegelikult mitte miski Windowsi enda vahenditest, sealhulgas ka W7 enda backup utiliit. Nii et kes loodab oma kasutajaprofiili sellega varundada ja hiljem taastada, saab "meeldiva" üllatuse osaliseks.
Mis siis veel Microsofti vahenditest ei suuda selle tööga hakkama saada:
Easy Transfer (loomulikult)
SyncToy 2.1 (ja vanemad)
Samuti sai proovitud arhivaatoreid:
WinRAR (pakkimine koos security ja striimidega) - ei paki ega taasta junctioneid
7-Zip - pakib ja taastab junctionid tühjade kaustadena
Jääb veel üle proovida Acronist.
sõnum 16.12.2009 10:27:33 vasta tsitaadiga
Dogbert kirjutas:
viimati muutis Etz 16.12.2009 10:47:44, muudetud 1 kord
sõnum 16.12.2009 10:46:34 vasta tsitaadiga
Jah, ainus võimalus taastada ka junctionid on teha partitsioonist tõmmis ja taastada terve partitsioon. Tõmmisest eraldi kaustade taastamisel või kasutadest eraldi backupi tegemisel asi jällegi ebaõnnestub. No ma ei tea. Op-süsteem, mis iseendaga hakkama ei saa?! Uhke loss ehitati valmis, aga vundamendisegusse unustati tsement lisamata, eks ole. Väike näpukas.
thumbs_down.gif Järjekordne eyecandy ja half-ass op-süsteem siis Microsoftilt. Õnnitleme!
Ja tänud Macriumile viitamise eest (kuigi CNeti linke pole kunagi mõtet kasutada, sest need ei tööta nagunii, aga nime järgi otsing juhatas kodulehele). Kindlasti saab vajaliku tööga hakkama ka Macrium.
viimati muutis Dogbert 16.12.2009 10:51:38, muudetud 1 kord
sõnum 16.12.2009 10:49:36 vasta tsitaadiga
Dogbert kirjutas:
Ja tänud Macriumile viitamise eest (kuigi CNeti linke pole kunagi mõtet kasutada, sest need ei tööta nagunii, aga nime järgi otsing juhatas kodulehele). Kindlasti saab sellega hakkama ka Macrium.
Viitasin kodulehele ringi, downloadi tõesti sealt ei proovinud icon_wink.gif
Ise siiani sellega edukalt igasugused backupid tehtud saanud...
Ikaldus ju veel selles, et Win7/Vista Home versioonid ise ei toeta backuppi võrguketastele...
Samas on suur mõte ju Backuppi samas masinas hoida (kui just Blue-Ray kirjutajat ei oma, on mujale paigutamisega kergeid raskusi) icon_lol.gif
sõnum 16.12.2009 11:18:52 vasta tsitaadiga
Ei, nojah. Seda ei oska enam kommenteerida ka mitte. Nuta või naera.
Timberg
ööKARU
Timberg
sõnum 16.12.2009 11:50:59 vasta tsitaadiga
Jäi kusagilt sil,a, et win 7'ga saab emuleerida rõõmsalt ka win xpd virtuaalse masinana? Kas saab ja kuidas?
sõnum 16.12.2009 11:53:55 vasta tsitaadiga
Timberg kirjutas:
http://www.microsoft.com/windows/virtual-pc/download.aspx
1dumbpcuser
sõnum 16.12.2009 12:08:18 vasta tsitaadiga
M: MSI B660M MORTAR
O: AM5 ITX emaplaat
sõnum 16.12.2009 12:41:06 vasta tsitaadiga
See nn "XP Mode" Windows 7 puhul koosnebki "Windows XP Mode" pakist, mis tuleb installida esimesena ja "vanast tuttavast" Virtual PC-st, mis tuleb installida teisena. Mõlemad on allalaetavad minu antud lingilt. Enne kilkamist paluks lugeda.
Q.
Q.
sõnum 16.12.2009 12:44:25 vasta tsitaadiga
Keegi Supaplexi ei ole proovinud Win7 peale jooksutada? Üks õhtu oli igav kodus ja mõtlesin, et meenutaks vanu aegu, ent ei saanud asja jooksma. Ilmselt tuleb vist läbi Virtual PC tööle ajada.
Ertymo
sõnum 16.12.2009 12:45:10 vasta tsitaadiga
HighEnd kirjutas:
"Open file.." parema kliki menüüst puudu ja faili propertites ei näida "Details" tabi. Oskab keegi aidata? Arvan ise et midagi registris segi.
Kunas, sa märkasid et see sealt kadunud?
Kui sa uue kasutaja teed, kas siis on sama probleem?
sõnum 16.12.2009 12:45:33 vasta tsitaadiga
Dogbert kirjutas:
Ehk siis täpsustuseks, tegu on XP "virtuaalmasinaga"...
Pmst sama tulemuse saab, kui installida VirtualPC (või mõni muu Virtuaal masina rakendus) ja sinna sisse siis ise XP...
sõnum 16.12.2009 13:32:16 vasta tsitaadiga
Just. Nii et sama hästi võib kasutada seda mitte ainult W7 all vaid ka Vista ja XP enda all (ilma XP mode paketita muidugi) ning mitte ainult Windows XP jooksutamiseks vaid võid sinna ka Windows 98, 95 või kasvõi 3.1 peale panna, DOS-ist ja mitte-Microsofti süsteemidest rääkimata.
Nii et vanad DOS-i mängud, sh Supaplex tasub käima lükata virtuaalmasinas päris DOS-is (kui DOSBox üle jõu käib või mäng selle all töötamast keeldub).
DeTHiCa.
DeTHiCa.
sõnum 16.12.2009 13:43:26 vasta tsitaadiga
Q. kirjutas:
supaplex on porditud juba uutele OS'idele. google peaks aitama.
xp all mängisin, töötas tip top.
Q.
Q.
sõnum 16.12.2009 15:14:06 vasta tsitaadiga
XP all sai mängitud jah, õhtul kodus uurin edasi, ehk leiab midagi 7 jaoks.
Equinox
Equinox
sõnum 16.12.2009 15:35:03 vasta tsitaadiga
Tre,
Q. kirjutas:
Heh, eile just ise ka proovisin icon_smile.gif Vana Supaplex sisaldab 16-bit koodi ja seda niisama 7 peal käima ei saa. Ehk siis virtuaal masinat vaja või DOSBox-i. Või nagu juba öeldud siis uuemat porditud programmi.
Eile rohkem polnud aega, ei jõudnud DOSBoxi varianti proovida, et selles osas pead ei saa anda. XP all töötasid ka DOSBoxiga vanad mängud edukalt. Mul on sama probleem veel HOMM2-ga mida tahaks käima saada Win7 all.
Live long and prosper!
mazdagti
mazdagti
sõnum 16.12.2009 16:56:16 vasta tsitaadiga
Selline küsimus et kas touchpad anomaaliad on seotud ka op süsteemiga? Omal lihtsalt asuse 1008HA ja Starteri puhul tekkinud selline jama et see tochpadiga lehe/akna alla kerimine kaob lihtsalt mingi hetk ära. Draiverid on Synapticu enda omad.
No ikka täitsa kagu nukas!
FB Volvokodu, diagnostikaabi Võrumaal.
CoiL
CoiL
sõnum 16.12.2009 17:23:53 vasta tsitaadiga
mazdagti, mul naisu läparis XPSP2-e all google Chrome`ga sama jama ning vahest mujal ka ei tööta.
sõnum 16.12.2009 17:42:45 vasta tsitaadiga
Kas ma kuidagi saan oma KEY ka teada kui on w7 installitud juba?
CoiL
CoiL
sõnum 16.12.2009 17:47:37 vasta tsitaadiga
Control Panel\System and Security\System ...product ID-d mõtled?
sõnum 16.12.2009 17:50:55 vasta tsitaadiga
Ei, ma mõtlen seda võtit millega ma installisin, kirjutaksin plaadi peale selle ära, vb kunagi läheb vaja üleinstallimiseks. Sain oma key'd msni teel ja millegipärast ei jäänud logisse tol päeval vestlusi thumbs_down.gif päris mitu vajalikku keyd on nii kadunud hetkel, õnneks technetist saab vaadata, aga too inimene veidikene eemal on
Look Right
Anna vin
Look Right
sõnum 16.12.2009 17:51:44 vasta tsitaadiga
product-id ei ole sama asi, mis key. Minu meelest ei näe kusagilt niisama lihtsalt seda. Vb registris kuskil kirjas.
sõnum 16.12.2009 18:01:52 vasta tsitaadiga
http://magicaljellybean.com/keyfinder/
XYZ
XYZ
sõnum 16.12.2009 18:05:39 vasta tsitaadiga
Etz kirjutas:
Dogbert kirjutas:
Mäletamisi ei ole päris sama. XP-modega kaasneb sulle virtuaalmasinasse legaalne koopia wxp-st ilma, et peaksid muret tundma aktiveerimise pärast ja uuenduste pärast, kõik on win7 võtme baasil olemas/legaalne. Kui aga installid vaid VMasina ja tahad sinna opsüssi panna, ükskõik millist, siis selle legaalsus on juba eraldi sinu mure.
sõnum 16.12.2009 18:14:42 vasta tsitaadiga
XYZ kirjutas:
Etz kirjutas:
Dogbert kirjutas:
Selle koha pealt on sul täiesti õigus...
Ertymo
sõnum 16.12.2009 18:17:25 vasta tsitaadiga
TuneUp Utilities 2010 on ka see võimalus olemas.
Q.
Q.
sõnum 16.12.2009 19:33:48 vasta tsitaadiga
mazdagti kirjutas:
OSi viga tõesti. Peale 7 panekut kadus ka enda 1008HA'l üles-alla scrollimine ära, kuigi zoom töötab ilusti. Sai draivereidki uuendatud, samuti Synapticu omad, ei aidanud. Ehk tuleb lihtsalt uuendusi oodata.
Timberg
ööKARU
Timberg
sõnum 16.12.2009 20:35:57 vasta tsitaadiga
win7 all selles "virtuaalses xp modes" saab mõne graafikakaarti rohkem kasutava mängu (world of warcraft) tööle ka panna?
sõnum 16.12.2009 20:48:09 vasta tsitaadiga
Kuna VirtualPC "videokaart" on samuti virtuaalne ja emuleeritud (niigi puudulikult) S3 Trio 32/64, millel ka reaalsena ja rauas isegi ajaloolises mõistes talutavat 3D kiirendust ei ole, siis on see suhteliselt kahtlane. Aga võid ju proovida ja katsetada...
Aga enne võiks proovida Windows 7 all seda otse installida ja käima panna. Isegi selline vana mäng läks Windows 7 all probleemideta käima nagu Tetris Adventure aastast 2001. Ilma igasuguste emulaatoriteta.
Timberg
ööKARU
Timberg
sõnum 16.12.2009 20:50:48 vasta tsitaadiga
WIndows 7 jookseb wow normullilt, aga olen harjunud kasutama ühte addoni, mis millegi pärast paneb windows 7's wowi crashima ja ilma selle addonita mängida ei taha.
Kui eelpool mainitud virtualiseeritud XP masinas lasin wowi tööle, siis öeldi erroriks "ERROR #132 (0x85100084)". Oskab keegi soovitada misket?
Max Powers
sõnum 16.12.2009 21:57:18 vasta tsitaadiga
ID.ee lehelt tuleb hetkel Vista asju kasutad?
olafsand
olafsand
sõnum 16.12.2009 23:09:43 vasta tsitaadiga
Max Powers kirjutas:
jah
WäntWõll
make.believe
WäntWõll
sõnum 17.12.2009 00:09:39 vasta tsitaadiga
https://installer.id.ee/
ei tea mul küll ei küsi OS-i kohta midagi.
Mis vahet on XP Vista W7?
sõnum 17.12.2009 00:42:30 vasta tsitaadiga
Kuskohast ma leiaks nvidia 8400M gs jaoks draiverid (ei taha nvidia lehelt seda 140 mb varianti)
sõnum 17.12.2009 03:16:15 vasta tsitaadiga
carlking kirjutas:
http://www.laptopvideo2go.com/drivers
Või siis viimane Beta:
http://forums.laptopvideo2go.com/topic/25843-v19581-windows-7vista-32bit-nvidia-oem/
http://forums.laptopvideo2go.com/topic/25844-v19581-windows-7vista-64bit-nvidia-oem/
mazdagti
mazdagti
sõnum 17.12.2009 06:42:47 vasta tsitaadiga
wanawoll kirjutas:
Isegi Starteriga toimib sealt lehelt tõmmatud softiga ID-kaardi lugeja ideraalselt thumbs_up.gif
rosin
rosin
sõnum 17.12.2009 12:11:02 vasta tsitaadiga
Mul on Windows 7 Pro x64 ja id kaardi lugeja installimisega polnud probleeme. Kaardilugeja (Cardman 1021) jaoks leidis
draiverid ise, id.ee lehelt laadisin alla toe firefoxi (ei ole ie sõber) jaoks ja töötab. thumbs_up.gif
sõnum 17.12.2009 12:20:11 vasta tsitaadiga
tomorrow kirjutas:
carlking kirjutas:
HP pavilion dv6000 seeria läpakal 1.45ghz pentium dual-core protsessoriga on W7 erksam kui Vista thumbs_up.gif
olafsand
olafsand
sõnum 17.12.2009 13:32:41 vasta tsitaadiga
wanawoll kirjutas:
Ta tegelt jah ei küsigi OS`i kohta midagi, aga kui esimese lingi pealt tirima panna, siis faili nimi sisaldab sõva "vista". Muud ei midagi, aga toimib ilusti icon_smile.gif
DVDRW
DVDRW
sõnum 18.12.2009 10:27:16 vasta tsitaadiga
Kas windows 7 ei olegi sisseehitatud veebikaamera programmi? icon_neutral.gif XP all on nii, et võtad exploreri lahti ja seal klikid kaamera peale ja ongi plaks pilt ees.
olafsand
olafsand
sõnum 18.12.2009 10:50:42 vasta tsitaadiga
DVDRW, kui webcami driver õige on, siis peaks tekkima küll tegelikult exploreri alla kaamera ikoon.
DVDRW
DVDRW
sõnum 18.12.2009 10:58:01 vasta tsitaadiga
Device manageri all näitab küll ilusti seda kaamerat ilma kollase hüüumärgita.
CoiL
CoiL
sõnum 18.12.2009 12:09:13 vasta tsitaadiga
DVDRW, mis versioon sul w7-st on? Home?
DVDRW
DVDRW
sõnum 18.12.2009 12:13:13 vasta tsitaadiga
Proffessional E4300 läpakaga kaasa tulnud.
Googeldades sain ka nii aru, et see funktsioon on windows 7st eemaldatud icon_eek.gif
Teil siin kellelgil töötab?
Ertymo
sõnum 18.12.2009 13:57:37 vasta tsitaadiga
Ilma lisaprogrammita pole see windows 7 puhul võimalik..
linux
linux
sõnum 19.12.2009 03:09:48 vasta tsitaadiga
chkdsk *: /r kohta oskate midagi öelda, nimelt tomorrow poolt pakutavad viimased updated peal, aga nii kui chkdsk tööle panna siis hakkab kohe mälu õgima?
teab keegi öelda, on seda yldse plaanis m$'l parandada või jätavadki selle sisse?
Win7 Ult 64bit.
sõnum 19.12.2009 05:23:23 vasta tsitaadiga
linux kirjutas:
Win7 Ult 64bit.
Ju siis seda ei kavatsetagi parandada.Vähemalt mul masin ei crashinud selle mäluõgimise tõttu icon_rolleyes.gif
mazdagti
mazdagti
sõnum 20.12.2009 22:07:35 vasta tsitaadiga
Nii, op on siis Starter ja kui hakkasin ühendama BT GPS seadet et hakata kasutama Ragioga ning ühildumise käigus peale koodi sisestamist on tulemuseks järgnev: The error code is:0x8007048f. Contact your device manufacture for assistance. Varem olen seadet kasutanud Qtek 9000 isendiga ja kõik toimis icon_confused.gif Seadmeks on GPS BT77
sõnum 20.12.2009 22:17:50 vasta tsitaadiga
Krt ma ei saa läpakal mälukaardilugejat tööle
peaks olema miski Texas Instruments PCIxx12 flashmedia controller või midagi sarnast. Installib ennast ilusti Vista draiveritega ära, ühtegi konflikti ega hüüumärki ei ole aga kui kaardi (SD) sisse lükkan, ei tee ta midagi. Draiverid tõmbasin Ordi lehelt, kuna Clevo lingid on surnud
http://dl.ordi.ee/draiverid/m52xn/m521n.rar
Proovin erinevaid draivereid hetkel. W7 32bit on mul
Edit: leidsin mingist väljamaa foorumi lingilt mingi Toshiba lehe suppordi alt Vista draiveri mis tööle läks thumbs_up.gif
uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 (arutelu ja probleemid) mine lehele eelmine  1, 2, 3 ... 182, 183, 184 ... 372, 373, 374  järgmine
