Heins
03.08.2009 14:27:11
| tomorrow kirjutas: |
| Heins kirjutas: |
Oleks abi vaja windowsi installiga peidetud WinRE kettalt
Nimelt ei oska arvuti sealt bootida. Installisin Win7 RC vahepeal arvutile ja peale seda enam ei saa algsesse olekusse arvutit taastada.
Plaate arvutil kaasas polnud. Arvutiks Fujitsu siemens AMILO läpakas.
Oskab keegi aidata selle murega? |
Sellelt 100MB WinRE partitsioonilt saab ainult siis parandada ja taastada kui Win7 installitud.Kui pole installitud siis on see samahästi kui kasutu.
Kui sul miski Win7 või Vista installimeedia kuskil vedeleb siis boodi selle pealt ja kaota see WinRE part ära.Saad puhtalt lehelt alustades OS-i installida.Läpakal endal mingit tootjapoolset recovery parti polnud? |
Sa said nüüd valesti aru. Tootjapoolne recovery part ongi see WINRE part ja see on 11gb suur.
Ja see part ise on korras. Kui võtta vista plaadilt installi tehes repair computer vms siis näeb seda parti ja kõik failid on seal ka alles. Lihtsalt ei oska arvutit sealt bootima panna. Installitud win-i all on part peidetud.
03.08.2009 14:43:43
No näiteks: How to Boot Off the Recovery Partition of an HP
Step 1
Turn on your HP laptop or desktop computer.
Step2
Press the F11 key on your keyboard before the operating system loads. If you've made it to the logo for your operating system, you have gone past the point where you can boot into the recovery partition. You'll need to restart your computer and try again. As soon as you see something on your computer screen, press the F11 key.
Step3
Make any changes necessary to your computer. The F11 key will automatically boot into the recovery partition. This doesn't mean that you can use your computer as normal. What it will do is bring up the System Restore program built into Windows. From here, you can restore your computer to the way it was working at an earlier time, create a boot disk or put your operating system CDs in your CD drive to reinstall your operating system and start from scratch. |
Heins
03.08.2009 15:52:28
| jägaja kirjutas: |
Step 1
Step2
Step3
Ja FS-ga ei toimi see. Olen neid f8 f10 f11 jne variante juba terve eelmise nädala proovinud ja katsetanud.
Teine variant oleks laenata kelleltki Vista Home Premium plaati, aga kahjuks pole veel leidnud kedagi kellel see olemas oleks.
03.08.2009 17:20:38
Nojah, FuSil peaks F8 korduvalt toksima, kui see ei toimi mingil põhjusel, siis..
Re: FS Amilo Pi 1505 Recovery Disk Problem
by alan m » Mon Jan 19, 2009 4:23 pm
Hi,
I couldnt find the key presses to automate the recovery process from the hidden partition. So I booted from a windows 98 CD and went to FDISK.
I then made the Non-DOS (1st partition) active. Restarted the PC and it booted straight into the recovery process. Hurrah!!!
Presumably this alters the BOOT.INI file to boot from the hidden recovery partition which could probably be done within MSCONFIG -> BOOT.INI
alan m
Top
Abi saat ka siiT..http://bootdisk.com/
Pole vast vaja miskit parti aktiivseks muuta, vaid valid -start computer with cd-rom support, seejärel valid ketta, kus sul recovery part on jne.
Ramm
05.08.2009 10:17:27
Üks kala tekkis vistaga,nimelt kui tahan midagi salvestada teatud kausta siis ei lase ja lööb järgmise veateate:
Kuigi ma olen Admin jne. Äkki kellelgi on sama viga tekkinud?
tsihh
05.08.2009 11:10:14
| See ei ole viga, see on "featuur". Program Files kausta salvestamiseks on vaja rohkem õigusi ja salvestamise dialoogiaken ei oska seda küsida
SurfData
05.08.2009 11:10:37
| Ramm kirjutas: |
Kuigi ma olen Admin jne. Äkki kellelgi on sama viga tekkinud? |
otse program filedesse vist ei lasegi salvestada. Salvesta mujale ning siis tee kopi paste
Look Right
Anna vin
05.08.2009 22:18:00
No a need rohkemad õigused saab ju alati omale võtta?
_________________ Ehitusprojektid ja konstruktiivsed lahendused HV kasutajatele soodsamalt
M: Zafira A/Astra G põhjakaitse - 30€ |
Steff.
05.08.2009 23:09:04
Keegi oskab rääkida kuidas lubada mitme kasutaja sisselogimist üheaegselt vistale. XP oli selline asi olemas nüüd sooviks Vistal ka seda kasutada.
_________________ Kui sind ei ole siin...Siis sind ei ole olemaski! |
tsihh
05.08.2009 23:10:00
| taikonaut kirjutas: |
| No a need rohkemad õigused saab ju alati omale võtta? |
Ei ole proovinud aga kui UAC maha keerata, siis ehk saab
M00t
23.08.2009 07:18:51
Miks mu arvuti mälukasutus niimoodi jamab?
Asgate
23.08.2009 07:34:02
| lu1de, ilusad impulsid. Eeldan et pilt on ikka tehtud siis kui arvuti idles seisab?
M00t
23.08.2009 07:39:33
Asgate, jah. peale restarti. mingi 9 minutit ootasin niisama ja vaatasin ja ära ei lõppenud, arvuti teeb mingit veidrust lihtsalt loodan et see riistvarale (mäludele) halvasti ei mõju
kas format C on ainus võimalus?
23.08.2009 09:21:19
lu1de, mis seal keerulist... jälgid jooksvalt misasi see spike ajal mälu tarbib.
_________________ - londiste
23.08.2009 09:30:04
mul on 68, so what?
idle on defineerimata väärtus, reeglina mõistetakse selle all ka kogu taustal korraga lahti olevat kräppi. millega koos sul vaevalt et 33-34 on.
M00t
23.08.2009 09:54:58
| tundub et nüüd on rahulik. Peale RealPlayeri uninstalli jäi umbes poole vähemaks ja nüüd paar tundi hiljem on kõik täiesti ühtlane ja normaalne..
23.08.2009 10:35:47
| londiste kirjutas: |
| idle on defineerimata väärtus, reeglina mõistetakse selle all ka kogu taustal korraga lahti olevat kräppi. millega koos sul vaevalt et 33-34 on. |
Kui ma ütlen,et niipalju on siis niipalju ka on .Või arvad,et ma mõtlen peast suvalisi numbreid välja?
Palun väga.5 min idle.Taustal peale MS omade everest,utorrent,d3doverrider,setpoint,g-profiler ja sidebar koos 5 gadgetiga:
Protsesse: 33
Mängima hakkan siis panen enamuse 3rd party omadest veel kinni seega see langeb alla 30 ja mälukasutus kukub ~500MB peale mis on väga hea number 64bit OS kohta
teretalv
23.08.2009 11:24:02
windows vista on saast, mis siin enam arutada, praegused vista ostjad saavad tasuta win 7 kui se välja tuleb sest isegi ms arvates on vista läbikukkumine, proovisin kõik siin soovitatud tweakid läbi aga sitast pirukat ei tee, win7 lahendas kõik kiiruse probleemid ja muutis olematuks uue mälu juurde ostmise plaani
_________________ Ära usu kes kutsuvad kuskile raha investeerima. Suurt tootlust ei tule keegi kandikul kätte tooma! Head ja kindlat tootlust saab ainult siis, kui ise enda kontrolli all on kogu protsess või enamus sellest.
Teen Hobikorras Audio, Video, Foto ja Trükiettevalmistust/Kujundust ja Python Scripte |
Asgate
23.08.2009 11:25:26
tomorrow-l hästi ära twiigitud süsteem (tegemist on ka win 7-ga), ilma modimata süsteemi puhul kipub number vägisi 50 peale liikuma.
flake
25.08.2009 12:14:00
selline jama, et õde pani oma iPodi laadima. Peale 30 minutit laadimist tegi Windows Update ja iPod läks lolliks. Õde vist võttis selle tagant ära, arvuti tegi peale updatede lõpetamist restarti ja siis on selline jama, et update jõuab punkti,kus näitab et finishing updates 3/3, do not turn off the computer ja siis teeb ise restardi ning kogu protsess hakkab uuesti. Wini kasutada ei saa ja kogu see update/restardi värk on loopis. Tegmist on Dell D630 masinaga, kus peal Vista Business. Kuna masin asub füüsiliselt Portugalis, on väga keeruline siit midagi teha, kuid ehk oskate öelda mis valesti võis minna?
_________________ ..||.. |
mattu
25.08.2009 12:21:12
| oli sama jama sp2 peale laskmisega, kustutasin registryst paar keyd ära ja jäi sp1 peale. googlist leidisn mis vaja kustutada oli.
25.08.2009 12:22:00
| flake kirjutas: |
| selline jama, et õde pani oma iPodi laadima. Peale 30 minutit laadimist tegi Windows Update ja iPod läks lolliks. Õde vist võttis selle tagant ära, arvuti tegi peale updatede lõpetamist restarti ja siis on selline jama, et update jõuab punkti,kus näitab et finishing updates 3/3, do not turn off the computer ja siis teeb ise restardi ning kogu protsess hakkab uuesti. Wini kasutada ei saa ja kogu see update/restardi värk on loopis. Tegmist on Dell D630 masinaga, kus peal Vista Business. Kuna masin asub füüsiliselt Portugalis, on väga keeruline siit midagi teha, kuid ehk oskate öelda mis valesti võis minna? |
F8(vms klahvi) kasutades safe mode saab bootida?
Kui saab ja eelnevalt oli System Restore-ga tehtud taastepunkt, siis saab eelnevasse seisu taastada
dzombe
25.08.2009 13:02:28
Windows Automate update service seisata (või panna startup manual seadete peale, My Computer menüüst võtta Manage ->services), \WINDOWS\SoftwareDistribution kaust tühjaks ja siis, kas käsuga wuauct /detectnow abil proovida või kasutada IEga Windows Update teenust, kus valida, mida paigaldada. Samas, äkki on logis ka näha, millise uuenduse paigaldamisel automaatne restart tuleb.
_________________ -- |
mildseven
30.08.2009 22:27:50
Kui mu arvutil on : My Documents, Pictures jne. asukoht teisel partitsioonil nt: D: ja Vista on C: kettal ja kui ma Format C: teen, kas ta ikka jätab need Win. My Documentsid jms. kaustad nendele partitsioonidele alles naq näiteks D:.
Igaksjuhuks küsin, ei taha, et pärast oleks mingeid ebameeldivaid üllatusi...!
XYZ
31.08.2009 08:22:49
| sõltub tihendist
ErkiT
31.08.2009 10:56:36
| mildseven kirjutas: |
Igaksjuhuks küsin, ei taha, et pärast oleks mingeid ebameeldivaid üllatusi...! |
Jäävad alles küll kui ainult C: kettale formati teed.
mildseven
31.08.2009 23:36:48
Okei, tänud!
Järgmine küsimus, kasutan Windows Mail'i ja tahaks, et meilid alles peale Formatimist jääks, kus kohast ma neid kuhugi ära saa Importida?
E: Ja see ka, kui ml mängud ja jms. porgammid on installitud teistele partitsioonidele ja kõvakatele, kas siis pärast Format C: tegemist nood ka käima lähevad?
centraaL
06.09.2009 23:22:21
Okei, tänud!
E: Ja see ka, kui ml mängud ja jms. porgammid on installitud teistele partitsioonidele ja kõvakatele, kas siis pärast Format C: tegemist nood ka käima lähevad? |
Mängude folderid ja failid jäävad sul alles täpselt samamoodi, aga suure tõenäosusega ei käivitu enne reinstalli. Kui My Documents failid ka tagasi kopid default asukohta, jääksid isegi savegamed alles. Aga et neid kasutada, pead reinstalli tegema, tänu registryle, kus su mängude väärtusi ei ole.
M00t
07.09.2009 00:30:40
| lu1de kirjutas: |
uus windows aga vana probleem tagasi:
ma sain teada et seda põhjustas vist searchprotocolhost.exe
ja sain teada tänu Reliability and Performance Monitorile, mis Vistas on.
pwnage
07.09.2009 22:52:47
Mul jamab prügikast nii, et mõnikord, kui on täis, on desktopil tühja prükkari ikoon ja teinekord peale tühjendamist on ikka täis prükkari ikoon
Vista Ultimate 64-bit SP2
08.09.2009 16:40:18
Ajalooline päev siis täna:
Windows 7 teemas on mul samapalju poste kui Vista teemas.Ja seda veel enne kui Windows 7 ametlikult väljaski on.Vista on juba ligi 3 aastat väljas olnud teatavasti(tundub palju vähem aga tõesti )
Veidi statistikat kah(see mulle meeldib ):
Vista
Teema algus - 23 August 2004(enam kui 5.a tagasi )
Minu esimene post teemas - 10 Juuli 2006(ligi 2.a peale teema algust ).Esimesest postist möödunud 3.1 aastat tänaseks
Windows 7
Teema algus - 4 Aprill 2008(õnneks mitte esimene aprill )
Minu esimene post teemas - 8 Aprill 2008(kõigest 4 päeva jäin hiljaks 2.a asemel ).Esimesest postist möödunud 1.4 aastat tänaseks
Järeldus on see,et olen poole aktiivsem olnud Windows 7 teemas
Max Powers
08.09.2009 16:42:06
| tomorrow, mida sinu kasvanud aktiivsusest võime järeldada?
Mucrop3
09.09.2009 11:12:40
| Vista tahab peaaegu iga kord enne printimist printeri eemaldamist ja uuesti võrgust üles otsimist ja välja jagamist. Kuidas korda saada asi?
2III7
ik2
10.09.2009 10:48:25
[quote="mcaff"]oleks vaja vista teha eesti keelseks et kuidas ma saaks ? Läppar läheb emale ja tal oli soov et teeksin win eesti keelseks :roll:[/quote]
ostad eesti keelne vista poest
sulomile
10.09.2009 12:57:32
| mcaff kirjutas: |
oleks vaja vista teha eesti keelseks et kuidas ma saaks ? Läppar läheb emale ja tal oli soov et teeksin win eesti keelseks  |
Kui Ultimate versiooni pole, siis legaalselt ei saagi.
_________________ Oleks mina näinud, kuis sind tehti, oleks öelnud: ärge tehke. |
Psych0
10.09.2009 16:59:36
| flake kirjutas: |
Mul probleem samasugune, safe mode'ga ei saa bootida (with networking ja command promptiga teeb restarte ning tavalise sade mode'ga jääb "Please wait..." peal laadima) ning vista plaati pole.
Mucrop3
10.09.2009 18:39:30
| Psych0 kirjutas: |
| flake kirjutas: |
Mul probleem samasugune, safe mode'ga ei saa bootida (with networking ja command promptiga teeb restarte ning tavalise sade mode'ga jääb "Please wait..." peal laadima) ning vista plaati pole. |
Vaata see update, ise olin ka sellega hädas.
Sellega on nii:
Kui Vista paigaldad ja jõuad updatimisele, siis mingil hetkel tuleb ja selline karm laadung update mida installib isegi 7 tundi kui sa ei mõika arvutile restarti teha kui hd aktiivsus minuteid puudub.
Ilmselt mingi vista sisseehitatud viga, et ei oska ise restarti teha (jooksis kinni). Ja need staadiumid 1-2-3 iga eraldi numbri all teeb ta mitmeid kordi restarti (ehk isegi 10 rohkemat korda).
Millalgi ta jõuab need updatid peale pandud, ja kui seisma jääb siis suru manuaalselt restarti. Need updatid võtavad minimaalselt 1,5h või isegi 3 aeglase masina puhul.
Aga kui 1-2-3, 1-2-3, 1-2-3 siis ma ei tea. Proovi clear c-mos, ja vool tagant ära ja hoia power nuppu all. Ehk biosi update vaja.
Psych0
10.09.2009 18:46:57
| Mucrop3 kirjutas: |
| Psych0 kirjutas: |
| flake kirjutas: |
Sellega on nii:
Aga kui 1-2-3, 1-2-3, 1-2-3 siis ma ei tea. Proovi clear c-mos, ja vool tagant ära ja hoia power nuppu all. Ehk biosi update vaja. |
Ta näitab jah 3 of 3 koguaeg, do not turn off computer, shutting down ja uuesti. Eks ma panen ta hiljemalt 22'ni jändama ja vaatab, mis saab..
Mucrop3
10.09.2009 19:41:48
7 Tundi?.Wtf? .Mul pole kunagi üle 30min läinud selle peale ja seegi oli SP
Individuaalsed updated siis peab olema küll kõikvõimalik kraam ja aeglane masin veel,et tunde võtaks.Restardi tegemisega sai ka vista alati eduliselt hakkama  |
Mul oli ka see 3 - 3est ees 7 tundi, siis vaatasin hd led vilgub harva ja hd on vaikne. Surusin resa ja updatimine jätkus edukalt.
Aga tõesti 1,5h-3H läheb min c2d e4500 2.2GHz ära kõik updatid peale värsket installi (seda juhul kui pisipehme server on kiire).
CPU-d tahab ja näiteks Q9550 on umbes 4x kiirem / i7 920 veel sellele 20-30% otsa.
See manuaalse resa vajadus on aegade algusest püsiv nähtus erinevate mobodega.
Psych0
10.09.2009 19:59:53
| Mucrop3 kirjutas: |
See manuaalse resa vajadus on aegade algusest püsiv nähtus erinevate mobodega. |
Mul on vista olnud talvest saati..
Mucrop3
10.09.2009 20:06:34
Ma ostsin esimese vista 2008 algul.
Teise plaadi 2009 algul.
Psych0
10.09.2009 20:10:15
| Mucrop3 kirjutas: |
Teise plaadi 2009 algul. |
Juhin tähelepanu sellele, et pole siin mingit värsket installi Hetkel on ikka veel stage 3 of 3 ja 0%.. vahel jõuab öelda "Welcome" ja siis tuleb "Shutting Down".
Mucrop3
10.09.2009 20:33:46
| Psych0 kirjutas: |
| Mucrop3 kirjutas: |
Juhin tähelepanu sellele, et pole siin mingit värsket installi Hetkel on ikka veel stage 3 of 3 ja 0%.. vahel jõuab öelda "Welcome" ja siis tuleb "Shutting Down". |
Aaa ok. Jälle mõni selline update siis. Minul autoupdate maas.
Ja seda % ära vahi.
Teinekord istub nullis tund aega siis hüppab 60% peale või koguni 100% peale, teeb restarti ja on jälle vahepeal 20% peal.
See tavapärane asi.
Mitu giga rami muidu?
dvd vader
12.09.2009 22:12:38
olen nüüdseks viiendat päeva esmakordne vista kasutaja, ostsin esmaspäeval uue sülearvuti, vistat pole enne kunagi kasutanud.
esimesed kolm päeva olid normaalsed - tundus normaalne, sai väga hästi kohandada igasuguseid seadeid.
neljandal päeval tekkis kerge hämming mõningate funktsioonide käitumise või funktsioonide puudumise üle.
viiendal päeval, täna, olen juba põhjalikult ärritunud. täna nimelt tõin oma eelmisest arvutist üle kõik failid. ja sain sellest ühe k*radi peavalu. märksõnaks on "windows explorer". up-nupu kasutamise võimaluse likvideerimine on vist sajandi mõttetuim uuendus. päeva lõpuks on hetkel väga tugev tunne, et tahaks XP-d tagasi.
