zest
| Kommentaarid: 182 loe/lisa |
157 |
29.08.2009 15:47:47
+2MP, MMC mälutüübi toetus, HDMI ja 20g kergem.
Sarivõte 2.3fps FZ28 2.5 vastu.
Muud asjad tunduvad pisiasjad olema.
| Kommentaarid: 85 loe/lisa |
29.08.2009 16:10:09
| AF kiiruse muutus kõlab küll hästi.
146 |
zest
29.08.2009 16:52:57
| mikk36 kirjutas: |
Muud asjad tunduvad pisiasjad olema. |
MMC tugi on ka Z28-l täitsa olemas
http://www.dpreview.com/reviews/specs/Panasonic/panasonic_dmcfz28.asp
_________________ If Jesus had been killed twenty years ago, Catholic school children would be wearing little electric chairs around their necks instead of crosses. |
157 |
29.08.2009 17:30:34
Neetud, tagurpidi vaatasin, uute specist on justkui välja jäetud see.
pruunkaru
| Kommentaarid: 10 loe/lisa |
10 |
28.09.2009 19:46:40
link :: Panasonic updates firmware for DMC-LX3
1. Improved auto white balance performance.
2. Auto Focus speed-up.
3. Recording function with an aspect ratio of 1:1 has been added.
4. A white balance (WB) bracket function has been added.
5. [HIGH DYNAMIC] has been added to scene mode.
6. [LENS RESUME] has been added to the [SETUP] menu.
7. [MENU RESUME] has been added to the [SETUP] menu.
8. The exposure compensation and the auto bracket compensation can now be set up to ±3EV.
9. Position of the guide line can now be set.
10. It is now possible to display the highlights in playback mode.
11. It is now possible to record the user’s name in the picture.
12. Digital red-eye removal has been modified.
13. Items saved in the custom set have changed.
146 |
MelesMeles
02.10.2009 15:49:52
Huvitav, kui palju see siis autofookust kiiremaks teeb?
_________________ Allkiri |
194 |
146 |
Trwind55
21.07.2010 20:31:20
DMC-FZ100 - uudis@dpreview
14,1MP MOS sensor
25 - 600mm (35mm ekv.)
11 fps sarivõte
3.0" vasakule välja pööratav LCD
välgutald
1920x1080 60i Full HD video
kaugjuhtimispuldi võimalus
DMC-FZ40 - uudis@dpreview
FZ38 edasiarendus põhimõtteliselt
DMC-FX700 - uudis@dpreview
_________________ möhhh.. |
| Kommentaarid: 22 loe/lisa |
21 |
Lemmy
21.07.2010 23:57:22
Hmm, sellise announcement'i peale tuleb järelikult veidi oodata..
Kaotasin nimelt oma armsa DMZ-FZ8 ära ning plaanisin just FZ38 selle asemele hankida. Kardetavasti saab FZ45 omale hinna 6K+ (siis jääb veits kalliks), aga loodetavasti langeb FZ38 oma uue mudeli välja tulekuga.
Eks siis kannatab veidi ja hoiab turul silma peal enne ostu tegemist.
_________________ Vähem möla, pikem samm! |
| Kommentaarid: 41 loe/lisa |
38 |
30.07.2010 12:30:50
link :: Panasonic updates firmware for DMC-LX3, DMC-TZ7 and DMC-TZ6
"Panasonic has released firmware updates for its DMC-LX3 premium compact, and the DMC-TZ7/ZS3 and DMC-TZ6/ZS1 compact superzooms. The company has not provided any information about the updates' actions beyond the slightly obscure 'Optimization of software processing. Change in software version has no effect on camera performance.' Firmware v2.2 for the LX3 and v1.3 for the TZ7 and TZ6 are available for immediate download from Panasonic's website."
Ehk siis kui keegi oskab täpsemalt ütelda, mida see uuendus parandab siis ütelge, ei hakka enne peale laskma.
146 |
aims
21.10.2011 12:51:41
Mida uutest Panasonicu 4/3 kaameratest arvatakse?
G3
GF3
GH2
| Kommentaarid: 32 loe/lisa |
31 |
High-Q
21.10.2011 15:42:20
esimene üldine probleem Eestis on see, et panasonic on väga kallis. põhjus on peaasjalikult maaletoomise probleemis ja sellest tingitud väga väikses turuosas ja väga piiratud müügipunktide arvus ning valikus. paar varianti on vitriini peal olemas aga muu on "ainult tellimusel" ja üsna suure lisahindlusega. kahju.
Ebay hindu (kasvõi UK epoodide hindu, mitte mingeid pilukate omi) vaadates on hinnad konkurentidega võrreldes täitsa mõistlikud, aga kahjuks mitte meie mail. Eks see kriipsutab kogu kogemuse maha.
muidu minu arvamus (mul endal on GF-1, mis on üldiselt üsnagi rariteetne pill siin riigis)
GF3 läks eemale GF1 ideest olla entusiasti fotoaparaat ja hakkas püüdma kompaktiületulijaid. mõõdult on väga pisike, aga ka tehnoloogiliselt piiratud. mulle see ei meeldi. õtlen ausalt: IMHO on GF1 parem GF3.
G3 on tubli alternatiiv praegustele 500€ ringis (mitte eestis letihinnana kahjuks jällegi) olevatele kit dslridele (d3100, 1100d, k-r jms sägad). Uus 16mpix sensor on väga tubli (vast 1 EV jagu uuest nikon/sony sensorist maas, aga u samal tasemel mis ühe põlvkonna jagu vanemad aps-c sensorid), läätsed on kvaliteetsed, vaikse ja kiire autofookusega, soodsad ja väiksed/kerged. EVF vaateakna suurus (ja ka päevane eredus) on pea sama suur, mis täiskaadri oma (kõrguselt suurem kui 5D mark 2 ja laiuselt pisut kitsam, kuna on 4:3 küljesuhtega) ja on väärtus omaette. Eks optika vs lcd on harjumuse asi, aga üks eripära on WYSIWYG ehk lcd ekraanile või EVF-i kuvatakse reaalselt see, mis hiljem pildistamise tulemus ka tuleb (muutuv WB näiteks) ja seega on vähem ümberpildistamist.
paar asja nerfiti ära ja need mulle ei meeldi. esiteks oli GF-1 ja ka G2- olemas PASM mode diali küljes eraldi lisalüliti single-shot, continous, +/- bracket ja viiteajaga pildistamine. just see +/- on väga kasulik, sest põhimõtteliselt oli vaikimisi HDR jaoks väga kasulik dial mode valmis. ei pea menüüdesse ronima või midagi sättima. hopsti määrad +/- ära ja tulistad ja kui enam hdri käest ei tee, siis paned single peale tagasi. jube mugav oli. nüüd tuleb quickmenusse ronima. automaatne vaateakna switchine LCD ekraani ja EVF-i vahel kaotati ka ära, kusjuures on see väike kulu (enne oli silma läheduse sensor), aga tehti kasutamine kohe tublisti ebamugavaks.
inglismaalt tellides on G3 kit võimalik täitsa ~500€ eest saada ja IMHO on tegu kindlasti väga hea valikuga. Hea alternatiiv kindlasti, just mõõdu, väga hea EVF-i ja kaalu tõttu. kui kit-vs-kit võrrelda, siis on Pana kindlasti teravama pildiga (teravamate objektiivide tõttu) ja üks suur eelis m4/3-l on see, et põhimõtteliselt ühegi läätsega ei pea ava kinni keerama pildi teravamaks saamiseks. juba ava laialt lahti on läätsedel pea max teravus käes, seega igasugu "stopping down to F8" on unustatud. see on tegelikult väga oluline, sest minu arust on kaunis mõttetu osta kallist asp-c F2.8 (või parematki) klaasi, teades, et hea tulemuse saamiseks peab tagasi kitikate-tasemele ava kinni keerama. kus on point?
GH2 on tubli tööloom, kuid on liialt kallis. Aga väga hea kaamera on. minu rahakott sinna ei küündi.
97 |
Nganasan
25.10.2011 09:23:47
| Sai endale soetatud G3 komplekt koos lisaobjektiiviga 45-200mm ning mina olen just see P&S pealt üle kolinud (eelmine aparaat oli TZ1), kes alguses kindlasti eelistab iA nuppu ja eelseadistatud režiime. Praegu pole veel aega olnud, et aparaati rohkem proovida, aga esmamuljed kompakti pealt üle tulnuna on igatahes positiivsed.
| Kommentaarid: 25 loe/lisa |
23 |
Puuriit
22.12.2011 09:34:23
Astusin samuti Panasonicu leeri, sedapuhku küll Bridge tüüpi kaameraga - Lumix FZ150 kui korrekte olla. Olles varem läbi kasutanud kolm D-SLRi ning tüdinedes kogu tarvikutemajandusest ning üldisest kohmakusest oli see esmapilgul ainuõige otsus, kuid kartus tagasiminekul oli suur peaasjalikult pildikvaliteedi osas. Olles nüüd FZ150 mõnda aega kasutanud ei jagu minu sõnavaras piisavalt kiidusõnu kaamera iseloomustamiseks. Ehk on see tingitud asjaolust, et minu ootused polnud suured, kuid investeeritud sai maksimum ning hankisin selles kategoorias parima saadaoleva aparaadi (pärast ohtraid reviewde ja võrdluste läbivaatamist). Esmalt mis on minu jaoks kõige tähtsam on komaktsus ja komplektsus. Suurepärane funktsionaalsus küllaltki tagasihoidlikus kestas. Lühiülevaade nendele, kes on sarnase kaameraklassi radadel ning ei suuda valida:
Kere - FZ150 on hämmastavalt käepärase kerega kaamera ning mis kõige olulisem - see on kerge. Väliselt paistab igati kvaliteetne ning kere lõppviimistlusele on põhjalikult rõhku pööratud (mitte ainult). Kaameral on sarnaselt peeglitele korralik grip mis tagab normaalse käsitlemishaarde ka suuremat sorti labidaga meesterahvastele. Nuppude hulgaga pole õle priisatud ning nende asetus on loogiline ja igal ühel on oma kindel funktsioon. Lisaks on kindlasti kvaliteetset videot salvestama kaamera puhul esmalt kiirfilmimise nupp mis alustab sekundiga eelnevalt paika määratud režiimis videopildi salvestamist (nt. 1080p 60fps AVCHD). Teiseks maasikaks on objektiivi küljel asuv videokaameratelt päris zoom nupp mis võimaldab videokaamera haardes hoides sujuvalt zoomida. Kerel on peal ka "hotshoe" kuhu saab kinnitada Lumixi/Olympuse välke ning välist mikrofoni - justnimelt välist mikrofoni, mille tarbeks on ka eraldi sisend olemas, et piltilusale FHD videole ka vääriline heli juurde salvestada.
Ekraan/EVF - Ekraan on 3" 16:9 formaadis LCD mis on piisava lahutusvõimega andmaks võttetulemustest vahetut muljet. Ekraan on pööratav mis tuleb jällegi kasuks keerulistes pildistamisoludes ja filmimisel. EVF on minujaoks mänguasi ja DSL-Ri pealt tulnuna tundub naljateona, kuid töötab ja pilti näitab.
Menüü - küllaltki lihtsa ülesehitusega ning ei aja segadusse inimest, kes on varasemalt digiaparaatide ning nende hingeeluga tutvust teinud. Erinevate pildistus/videorežiimide valikuid on mehiselt ning igale maitsele leiab midagi.
Optika - hämmastavalt valgusküllane, kuid samas ei võistle peegelkaameratel kasutatavaga. Ütlus "mis kõlbab kõigeks, ei kõlba millekski" siinkohal siiski paika ei pea ja hindeks saab 5 palli süsteemis 4. Peamine miinus on distortsioon laias nurgas, kuid jällegi pole see nii hull kui mõnel teisel Bridge kaameral mida näppinud olen. Panasonic pole õnneks zoomi võimuvõitlusega kaasa läinud ning on säilinud eelmisel põlvkonnal nähtud 24x zoom millele lisandub -30x inteligentne zoom (digitaalne ). Tegelikult on see 99% olukordadel täiesti piisav ja suurem ulatuse järele vajadust pole. Zoomida on võimalik kahest nupust - päästiku ees asuvast ning varem mainitud objektiivil asuvast. Kaamera tervustab küllaltki kirielt ning täpselt. Erinevalt teistest Birdge kaameratest on FZ150-l olemas manuaalne teravustamine mis kõll tegelikuses pole pooltki selle õigest tähendusest - objektiivi küljel on nupp mida tuleb vajutada kui oled objektiivi suunanud objektile mille järgi soovid kaadrit teravustada (ekraanil on roheline kastike keskpunktis). Kaameraga on kaasas ka varjuk ning ette on võimalik keerata filtreid. Minimaalne fokusseerimiskaugus on ca 5cm... Mega OIS optiline pildistabilisaator teeb oma tööd eeskujulikult.
Foto - FZ150 toodab biridge kaamera kohta suhteliselt korralike kaadreid. Pildimüra on hämmastavalt vähe ka kehvades valgustingimustes. ISO 800 ja üles minnes muutub olukord muidugi hüppeliselt ja nii kuini ISO 3200-ni välja. Kaameral on olemas nii kunstifiltrid (nt. pinhole) kui ka eelseadistatud režiimid (ca. 52tk - number ei vasta tegelikkusele, kuid tabab suurusjärku). Lisaks sellele on olemas P, A, S ja M täismanuaalne režiim. Makro, sportvõte ja portreerežiim on iseenesest mõistetavad. Mis on Lumixi puhul eriskummaline on automaatne võtteeziim (Intelligent Auto) - see mitte ei säti otse parameetreid lähtuvalt oludest vaid valib parima eelseadistatud režiimi misjärel mängib omakorda parameetrite peenhäälestusega. usjuures kaamera näitab ära ka sobiliku režiimivaliku kasutajale. Näotuvastus jms. modru on samuti sisse topitud. Huvitav on veel sarivõtte režiim mis suudab manada kuni 60 kaadrit sekundis - müstiline...muidugi tähendab see madalama kvaliteediga pilte. Kuni 12 kaadrit sekundis suudab teha maksimaalse resolutsiooniga. PS - teeb ka 3D fotosid.
Video - see on osa mis oli minupuhul põhiraskuseks kaalukausil. Video kvaliteet on bridge kaamera kohta hämmastav. Formaatideks AVCHD/MP4 ning alikus on 1080p 60fps, 1080i 60fps/30fps ja 720p. Siin üks näidisklipp koos miniature effektiga - http://vimeo.com/29303667 . Kaameral on j'llegi valikus erinevad videoeffektid millest on lemmikud miniature ja high speed ( http://vimeo.com/29364843 ) . FZ150 on võimeline tegema 220fps kaadrisagedusega video mille kvaliteet on küll VGA, kuid slo-mo siiski. OIS teeb jällegi oma tööd korrektselt ning käevärinaid kaadris märgata pole. ZOOMimine on objektiivi kõrval asuva nupuga käepärane ja sujuv ning AF töötab kiirelt ja täpselt ning kaader püsib pidevalt fookuses. Heli lindistamise tarbeks on kaameral peal küll stereo mikker, kuid nagu ikka pole sisseehitatud mikrofonid parima võimekusega (siiski parem kui enamikul konkurentidest). See pole aga takistuseks, sest ainukesena omas klassis omab see välise mikrofoni sisendit (2,5mm) kuhu saab ühendada näiteks Lumixi suundmikri või mõne teise konkurendi toodangu mis paigaldub kaameral asuvasse hotshoe kinnitusse. Ise pole veel suundmikrit hankinud, kuid plaan on suur.
Muu - kaamera on väga hea videovõimekusega, kuid sellel puudub välise toite võimalus - vähemalt ametlikult ei tooda Lumix sobivat adapterit, KUID.... Kaamerale on olemas demoeesmärgil poes kasutatavad püsitoitevahendid - aku kujuga DC-coupler + adapter aitavad hädast välja.
Kokkuvõtteks võib tõdeda, et kuigi tegu on küllaltki kalli Birdge klassi kaameraga on see oma hinna vääriline - algne skeptilisus oli asjata ning aparaat on igati aus. Inimesele kes on tüdinenud peeglitega seonduvast kohmakusest ja kõrgest hinnast on konkreetne kaamera heaks alternatiiviks. Muidugi otsust vastu võttes pole mõtet kohalikelt kaupmeestelt seda soetada (momendil polegi veel müügis) vaid valida mõni usaldusväärsem EU-s asuv elektronkaupmees (ise soetasin Pixmaniast hinnaga 465€). Millegipärast on Lumixi toodangu hind meil arusaamatult kõrge.
Jutt sai pikem kui plaanisin ning vabandan ette kirjavigade pärast, sest silme eest läks kirjuks ja kontrollimiseks pole enam mahti.
| Kommentaarid: 90 loe/lisa |
88 |
Jack
23.03.2012 14:24:13
Jõudsin Priidust sõltumatult järeldusele et seda kaamerat ma tahangi.
Otsisin siis Panasonicu teemat fotoblogist ja kõige viimane postitus vastas kõikidele küsimustele mis veel vastamata olid
Nüüd jahh veel vaja leida normaalne ostukoht.
| Kommentaarid: 11 loe/lisa |
Puuriit
23.03.2012 15:47:13
| Jack kirjutas: |
Nüüd jahh veel vaja leida normaalne ostukoht.  |
Olen teda nüüd mõnda aega kasutanud ja kohati võib mõne asja üle nuriseda. Kui tahad näha/proovida siis võid traati tõmmata - oma silm on kuningas.
88 |
