Smoking
18.08.2009 18:20:46
G80, Mul võibolla silmad pahupidi, aga tundub, et suurem.
Aga eks aeg näitab.
298 |
Flavius
18.08.2009 19:31:52
tundub pikem jah
natuke shoppatud, kuskil ~1.5cm pikem
118 |
G80
18.08.2009 22:01:43
AMD RV870: P18000 in 3DMark Vantage?
It looks like AMD's upcomming performance chip, call it RV870 or Cypress, will run between P16000 and P18000 scores in 3DMark Vantage. This would mean a performance around of HD 4870 X2.
RV840/Juniper shall score P95xx, RV830/Redwood P46xx. |
Et siis R800 kuskil 30kilo+
http://www.hardware-infos.com/news.php?news=3148&sprache=1
210 |
Gap
| Kommentaarid: 21 loe/lisa |
17 |
G80
19.08.2009 00:22:21
So here is what I learned so far (from these guys - hehehe :p :
Radeon "7" Family (Evergreen) is 6 parts:
Trillian = "R800" + either multiple montior or 3-way GPU
Hemlock = "R800" Dual GPU
Cypress = "RV870" Single GPU
Juniper = "RV840"
Redwood = "RV830"
Cedar = "RV810"
Press date: Sept 10th, 2009 Event loc. San Fran, USA?
Hard release: Sept 24th. --> mid Nov. 2009
Price range: $500 (high-end) --> $50 (low-end Cedar)
Cypress (rv870) single gpu "HD5870" is:
HD2900XT PCB size
40nm
353mm^2 die size
19mm x 19mm at cost of $34 per die
2x 6pin PCI_E power connectors
DX11
1600SP
256bit bus
80TMU
32ROP
1024/2048mb mem configs
SIMD : 20
Shader Clock : 850 ???
Memory Clock : 1200 ???
Bandwidth : 153Gbps ???
~$350 MSRP
3dmark vantage performance:
Cypress ~P16xxx - P17xxx - P18xxx
aka ~HD4870X2 performance level
potentially an ~30% performance improvement in the same power profile vs. rv770
Hemlock (R800) dual gpu "HD5870x2" is:
larger than 4870x2 single PCB
40nm 353mm^2 die x 2
1 6pin + 1 8pin PCI_E power connectors
DX11
3200SP
256bit bus x 2
80TMU x 2
32ROP x 2
1024/2048mb x 2 mem configs ???
~$500 MSRP
(2x Cypress) theoretical P34xxx ???
Juniper/Redwood HD5850, HD5830, HD5770?
Partial shroud HSF design
40nm
181mm^2 die size
14mm x 14mm die
1 6pin PCI_E power connector
DX11
800SP on Redwood
640SP on Juniper
128bit bus
40TMU
16ROP
512/1024mb mem configs???
~$199/$149 MSRP
Juniper XT ~P95xx
Redwood ~P46xx
About the speed of a HD4870 & HD3870
All lesser end models (Juniper, Redwood, Cedar) will be limited by loss of memory bus width, shader count, TMU & ROP count, memory size, HSF design, ports & features according to their market placement of either performance, mainstream, or entry-level. Not much solid info on these AFAIK, and many of the reports have Juniper/Redwood with mismatched info (like 640/800 SP, but p95xx/p46xx Vantage scores). Also no definite info found about MCM... |
http://www.xtremesystems.org/forums/showthread.php?t=226623&page=7
210 |
One
19.08.2009 08:07:59
| 353mm^2 die size |
vaevalt küll, et see die nii suur tuleb..
728 |
G80
19.08.2009 11:35:10
| Winterwind kirjutas: |
| 353mm^2 die size |
vaevalt küll, et see die nii suur tuleb.. |
Aga võiks ju.
210 |
One
19.08.2009 11:42:03
mida väiksem seda parem
728 |
G80
19.08.2009 11:47:45
mida väiksem seda parem  |
Minu jaoks oluline, et SP-sid oleks ikka kuhjaga.
1600SP on soliidne.
210 |
tsurka155
19.08.2009 12:09:16
Need kaardid on ikka p2ris koledad minu vaatenurgast (cypress ja helmlock) naq mingid kummi jublakad, loodan et ikka l6pp tulemus on parem. Videokaardid paistavad ikka v6imsad, aga kuidas naad tegelikult m2nge veavad, vot seda ei tea.
Paistab, et ei tulegi 320 bitiseid, odavamad kaardid on isegi 128 bitiga?
SOS, et ma siis vahepeal Crappy suust v2lja ajasin kuna sain natuke vihaseks k6igi peale (kaasa arvatud enda)
| Kommentaarid: 9 loe/lisa |
9 |
G80
19.08.2009 12:38:59
| tsurka155 kirjutas: |
SOS, et ma siis vahepeal Crappy suust v2lja ajasin kuna sain natuke vihaseks k6igi peale (kaasa arvatud enda) |
XS-is ka mingi vana ajas, et tuleks 512-bit oleks nvidia surnud aga nüüd jälle fail ATI.
Einoh täis ulme, kui ülakorrus ei oska mõelda.
Aga see välimus on hetkel ju teisejärguline, kuna engineering sample.
Eks pärast tulevad ikka ilusad naiste pildid.
210 |
One
19.08.2009 13:45:17
tolle xsi tüübi mõtlemine on fail.
iga firma eesmärk on ikkagi võimalikult suurt kasumit teenida.
RV770 täitis seda eesmärki igati hästi, vahet pole, et nvidial mingid tiba kiiremad
kaardid omajagu kallimalt müügil on.
728 |
ossa
19.08.2009 13:59:13
Ei no mis mõttes koledad Ostad välimuse järgi kaarti või
See on umbes sama, et näe autol jube kole mootor, seda ei osta
Tänapäeval võid ju kogu elamise kleepse, reklaami ja tilulilu täis kleepida...KAS SEE ON ILUS
| Kommentaarid: 20 loe/lisa |
20 |
CoiL
| Kommentaarid: 95 loe/lisa |
83 |
Evil
Hull
19.08.2009 14:06:32
| ossa kirjutas: |
See on umbes sama, et näe autol jube kole mootor, seda ei osta  |
Kas sa ei osta siis või?
Selleks tulebki alati ilusa mootoriga auto osta et pärast ei peaks teistele oma koledat mootorit näitama.
Aga RV870 võiks veel suurem olla ja veel kummisem cooler, cooler võiks tegelt isegi 2x sama suur olla kui kaart ja põhiline koostismaterjal võiks olla kumm.
202 |
CoiL
19.08.2009 14:13:20
võtame!
83 |
tsurka155
19.08.2009 15:09:09
Ei ma ei osta v2limuse j2rgi, ostan perfi ja hinna j2rgi, aga kui kaart maksab 500$ siis naq tahaks mingit paremat v2limust kui mingi kummi jublakas. aga naq oeldud disain on praegu teisejarguline ehk eks ta muutub ka, ning ei sa kindel ollagi et need on just t2psed koopiad kaarditest
Cypress ja Juniperi vahele v6iks tulla mingi kaart, umbes sama v6imuga mis 4890, muidu oleks vahe ju natukene suur nii rahas kui perfis 350$ vs 199$ ja Vantage punktides 17000 vs 9000, mingi ~275$ ja ~14000
Arge mind siis mahalooge jalle.
9 |
heff
19.08.2009 16:26:17
Oh, tahaks ka seda artiklit lugeda, kus kirjas, et uute kaartide jahutid kummist tehakse.
Tõesti, pisut võiks mõtlemist ka rakendada. Kui kaardi väljastamiseni veel palju aega on ja hetkel testimine jms toimub, siis miks oleks vaja ilusat välimust kaardile?
Tihti ju on kaardid, mis veel müügilettidele pole jõudnud, mittemidagiütleva jahutiga. Eriti rohelistel mehikestel, neil tuleb pidevalt uute kaartide kohta pilte, millel tüüpiline tühi disain.
Küll hakatakse joonistama erinevaid pildikesi jms kaartidele peale.
Endale küll meeldiks, kui sellised coolerid ka müügile tulevatel kaartidel on, nagu XFX-i kaartidel tihtipeale kipub olema. Imo väga šeff näeb nii välja.
94 |
G80
19.08.2009 16:28:13
| CorsairX kirjutas: |
võtame!  |
Imo võiks uued ATI kaardid olla varusatud rohkete led-dega, mis vilguksid kiiresti ja värve võiks palju olla ka.
210 |
heff
19.08.2009 17:06:22
LED-d vilguksid vastavalt loadile, kui loadi pole, põlevad niisama, kui suur load, vilguvad väga kiiresti jne. Kaardi ja jahuti vahelt võiks sinakas neoon ka välja paista ning paar spoilerit võiks ka juurde kruvida
94 |
tsurka155
19.08.2009 17:37:35
Ega ma ei tahtnud mingit led ja mida veel, et kaart oleks naq j6ulukuusk, ma lihtsalt ytlesin, et minu jaatenurgast kaardid naevad valja naq oleks need kummist tehtud, mitte et ma oleks oelnud, et need peavad olema j6ulukuused.
9 |
Otto E.
19.08.2009 18:01:52
Ega ma ei tahtnud mingit led ja mida veel, et kaart oleks naq j6ulukuusk, ma lihtsalt ytlesin, et minu jaatenurgast kaardid naevad valja naq oleks need kummist tehtud, mitte et ma oleks oelnud, et need peavad olema j6ulukuused.  |
kummist kaardid.
201 |
tsurka155
19.08.2009 18:10:40
OH.... kurat mina ei saa aru kelles on viga minus v6i teistes aga noh savi.
Kuidas ma seletan, videokaardi korpus - varv ja valimus oleks naq kummist aga noh ma lahen vist lolliks.... Peaks magama minema.
9 |
CoiL
19.08.2009 18:18:01
Ja võtame veelkord!
83 |
G80
19.08.2009 18:31:20
Ja võtame veelkord!  |
Ma enam ei jaksa.
210 |
