-Kaivo-
08.06.2009 07:51:44
Päris huvitav post CM foorumist.
tsitaat: |
When Clive Lindop was the lead AI designer for Codemasters the game was being developed specifically for hardcore OFP fans. The long awaited sequel was originally intended to be hardcore across all platforms, no compromises regardless of platform.
Clive Lindop (long known to the veteran OFP community by the username Urban66) is a huge fan of the original OFP and understands exactly how vital it is that realism is the key objective.
Unfortunetaly Clive Lindop has left Codemasters, leaving the game in the hands of a bunch of asshats that original OFP community members had never even heard of until the infamous 'ego tech video'.
This new bunch of asshats have decided to take the game down the arcade route, and renamed the game from OFP2 to OFPDR.
These retards don't realise that there are many console gamers that crave hardcore realism, they are under the illusion that ALL console gamers must be noobs that like to run around the battlefield like peter pan blowing up pretty red barrels. |
Kommentaarid: 16 loe/lisa |
15 |
Heineken
08.06.2009 15:21:31
Nojah ... kahju .
Kommentaarid: 24 loe/lisa |
23 |
Pihv
08.06.2009 18:38:31
Ongi siis kellad või? OFP:DR tuleb totaalne konsooli arcade ja Arma2 on testimise järgi .... , njah, eks te ise teate mis ta on.
Ootasin kahte head mängu, mis teineteisega konkureerivad kuid lõpptulemusena pole ühtegi. Tuleb DR ka ära ootada enne kui lõplikult käega lüüa.
Kommentaarid: 101 loe/lisa |
94 |
monty11
08.06.2009 19:34:23
Alati on ju Battlefield Heroes
Väljaarvatud praegusel hetkel ...
_________________ Both the universe and stupidity are infinite. I'm not so sure about the former. - A. Einstein
Tule ja kiika minu fotomaailma. |
Kommentaarid: 4 loe/lisa |
marexx
08.06.2009 23:40:11
mingi nupp võiks olla, nagu osades rallikates on, Simu ja arcade näiteks .
isegi kui simu ei ole võib mäng hea tulla.
xtream99
09.06.2009 05:36:16
Pihv kirjutas: |
Ootasin kahte head mängu, mis teineteisega konkureerivad kuid lõpptulemusena pole ühtegi. Tuleb DR ka ära ootada enne kui lõplikult käega lüüa. |
Testimise järgi on ta sul sitt ja pask, sest see mida sa mängisid oli probably piraatversioon Saksamaa reliisist.
tsitaat: |
"The crack isnt 100% working, you can run the game but it doesnt crack the FADE protection, its still there, even with beta patch 1.01 and the crack they did for it. Now final 1.01 patch is out and theres no crack at all, u can still run the game with genesis cracks but the game is all fk'd ~~ must be why no1 uploaded it here, its not even enjoyable to play it like this..This Fixed EXE does NOT work properly as the SecuROM Triggers kick in, degrading the the game & making the weapons very inaccurate." |
Ning teiseks Saksa reliis oli niigi vigane alguses, sest see lasti välja nn "Beta testi" eesmärgil, et sakslased leiaks vead ja bugid ülesse ja annaksid nendest developeritele teada, et siis saaks patchid välja lasta ja Inglise keelse versiooni väljalaskmise ajaks vead ära parandada, et ei oleks järjekordset "GTA IV" jama, et mäng on kohe alguses vigasid täis.
Kommentaarid: 2 loe/lisa |
Pihv
09.06.2009 05:51:20
monty11 kirjutas: |
Väljaarvatud praegusel hetkel ... |
Tahtsid öelda BF1943?
Selle videosid vaadates ja seda Battlefieldi muusikat kuulates tuleb mõnus nostalgia hoog peale küll sest BF1942 oli ikka midagi erilist ja seda sai claniga taoutud nii et vähe pole
Arcade võib loomulikult olla väga hea mäng , ei kahtle selles üldse.
Ega see Arma II pole ka mingi "Realism simulation" , teoorias on kuid praktikas mitte, jube mikromajandus käib nende AI sõduritega seal mis teeb selle mängu liiga aeglaseks et oleks "reaalne". OFPDR command system (meenutab BiA seeriat) tundub vähemasti olevat kiire ja lihtne. Samas võib kogenud Arma mängija jaoks olla sealne ka väga kiire, kuid minu jaoks anda igale sõdurile käsklust et sina lase seda, ja sina lase toda, kolmas toogu Humvee siia (mida tuleb oodata terve igaviku sest sõidavad nad ühest tee servast teise, ei pane neile pahaks, endalgi raskusi seal auto kontrollimisega suurel kiirusel ) jne. on natukene liig.
Kes on tuttav Project Reality modifikatsiooniga, BF2 jaoks, siis lubati sellel aastal juba alpha versioon enda retail mängust välja lasta ja full game 2011. Eks näis mis välja tuleb. Mod on küll super ja lubadused tunduvad esialgu väga suursugused. Looks like COD4, size of an Arma II and plays like Project Reality.
EDIT: xtream99 eks ootame siis õige väljalaske ära, ma olen 99% kindel et täpselt samasugune. Peamine, kuid kaugeltki mitte ainuke probleem, on väga kehv fps.
Mina mängisin jah torrentiga tõmmatud versiooni, millel 1.01 patch peal + crack. Mingit FADE mul ei olnud, natuke uurida siis leiab mooduse kuidas seda mängu proovida nii nagu need kes selle ostnud, ja meie kes me seda koos testisime täname küll hetkel kõigevõimsamat, et selle peale raha ei raisanud. Aga see selleks.
94 |
-Kaivo-
09.06.2009 08:08:14
tsitaat: |
mis teeb selle mängu liiga aeglaseks et oleks "reaalne" |
Mängu kiirus on suht hästi paika saadud. Arvad tõesti, et päris elus käib asi kiiremini, veel aeglasemalt käib
Aga OFP:DR kohta kiidaks seda, et nüüd tuleb Battlefield korralik SP-ga
15 |
Aah
Kommentaarid: 21 loe/lisa |
21 |
Pihv
94 |
Aah
12.08.2009 08:54:37
Tüübid üritavad Hardcore modega mett mokale määrida.
21 |
-Kaivo-
15 |
Cb4
14.08.2009 09:10:38
Täitsa asjalik tundub, loodame et treiler vastab mängule ka.
Aah kirjutas: |
Tüübid üritavad Hardcore modega mett mokale määrida. |
enamus mängude suur miinus on see krdi ristike keset ekraani. Mina igati päri et igasugu abivahendid ära võtta
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
Kommentaarid: 113 loe/lisa |
95 |
Aah
14.08.2009 10:19:20
Cb4 kirjutas: |
Aah kirjutas: |
enamus mängude suur miinus on see krdi ristike keset ekraani. Mina igati päri et igasugu abivahendid ära võtta  |
See on jah hea et igast värvilised vidinad eest ära. Kuid kompass ja map peaks ikka olema.
21 |
Goon
15.08.2009 09:57:43
Suht mõttetu minu meelest
Näeb välja nagu Battlefield 2
Aah
15.08.2009 10:36:09
Goon kirjutas: |
Näeb välja nagu Battlefield 2 |
Mis seal DR Vehicles siis nii mõttetut on? Kas enam ei tohi mängus mitte millegagi sõita/lennata ja möllu teha? 1 osas sai ju kõike seda sama teha siis BF 2 veel polnud.
21 |
KuriVaiM1
15.08.2009 11:53:13
CM pole milleski süüdi, need sõidukid kuuluvad reaalaja arsenali, vaevalt et nad BF2 pealt kloonisid
"Mõtle kriitiliselt" |
Kommentaarid: 68 loe/lisa |
63 |
Aah
16.08.2009 01:32:45
Ja soundi poolest tundub et tüübid, kes selle Vehicles Traileri valmis treisid, on liiga palju Terminaatorit vaadanud
21 |
Cb4
16.08.2009 09:19:08
Minu meelest oli just sound hea. Viimase aja püssimängude sound on nii niru et juba. Lased püssiga, kuid heli on nagu õhupüssill. Sellised asjad segavad jubedalt. Plahvatus(mürsud) ei tee ka lihtsalt plõxu, vaid teevad ikka väga kõva ja sumeda matsu.
95 |
Pihv
17.08.2009 03:28:04
tsitaat: |
Minimum requirement
Operating system: Windows XP SP2 or later
GPU/Video Card: Shader 3.0 (GeForce 7900 GT / 256 MB VRAM or higher), DirectX 9.0c
Sound Card: DirectX Compatible
Memory: 1 GB
Hard disk: 8 GB
Dual Core CPU 2 x 2.4 GHz
DVD drive: Dual Layer DVD-ROM
Recommended System
GPU/Video Card: Shader 3.0 (GeForce 8800 GT / 512 MB VRAM or higher), DirectX 9.0c
Memory: 2 GB
Hard disk: 8 GB
CPU: Quad Core CPU
Dual Layer DVD-ROM DVD drive: Dual Layer DVD-ROM
Loodame, et siis Quad Core annab ka mingi eelise, mitte pole moe pärast "recommended" nagu enamus mängudel mis siiani välja lastud.
Reviewd on päris head mida saab lugeda www.ofp2.info
tsitaat: |
“Yeehaa, all in all everything is working very well so far. Operation Flashpoint: Dragon Rising’s first two missions commence astonishingly smooth. I am curious, whether this is also true for the rest of the game. Although the visuals are not as good as the first screenshots made us believe, but that doesn’t make any difference to me. After all I can play that game fluently on my Laptop with nothing more than 1 GB RAM and a 7600 GT and even then is a good looking game.”
Ja lugedes seda tundub, et vähemalt performance probleeme sellel mängul pole erinevalt mõnest teisest, aga eks siis näeb kui asi käes
Kuigi viimaseid videosid vaadates märkasin ka ise, et graafika pole enam nii hea kui algul tundus. Vist on ühtteist maha keeratud.
94 |
Aah
21 |
-Kaivo-
28.08.2009 11:24:35
Operation Flashpoint: DR Cooperative Trailer
Veel mingi video
Keskkond on ikka täiesti elutu.
Vastab see tõele, te kui co-op -s kaugemale 200 m lähed tiimi liikmest siis kööga selle vennaga ?
15 |
Aah
29.08.2009 03:13:05
-Kaivo- kirjutas: |
Keskkond on ikka täiesti elutu. |
Mida sa täpsemalt silmas pead? Tuul puhub , rohi-puud liiguvad, linnud laulavad, CM on heli poolest alati tasemel?
21 |
Pihv
94 |
Aah
04.09.2009 11:11:43
Lõpuks ometi näeb korralikke gameplay videosi Hetkel ei oskagi millegi üle nuriseda.
21 |
