uus teema   vasta Tarkvara »  Arvutimängude foorum »  Flashpoint 2 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 16, 17, 18 ... 29, 30, 31  järgmine
-Kaivo-
sõnum 08.06.2009 07:51:44 vasta tsitaadiga
Päris huvitav post CM foorumist.
When Clive Lindop was the lead AI designer for Codemasters the game was being developed specifically for hardcore OFP fans. The long awaited sequel was originally intended to be hardcore across all platforms, no compromises regardless of platform.
Clive Lindop (long known to the veteran OFP community by the username Urban66) is a huge fan of the original OFP and understands exactly how vital it is that realism is the key objective.
Unfortunetaly Clive Lindop has left Codemasters, leaving the game in the hands of a bunch of asshats that original OFP community members had never even heard of until the infamous 'ego tech video'.
This new bunch of asshats have decided to take the game down the arcade route, and renamed the game from OFP2 to OFPDR.
These retards don't realise that there are many console gamers that crave hardcore realism, they are under the illusion that ALL console gamers must be noobs that like to run around the battlefield like peter pan blowing up pretty red barrels.
Heineken
sõnum 08.06.2009 15:21:31 vasta tsitaadiga
Nojah ... kahju icon_neutral.gif .
Pihv
Pihv
sõnum 08.06.2009 18:38:31 vasta tsitaadiga
Ongi siis kellad või? OFP:DR tuleb totaalne konsooli arcade ja Arma2 on testimise järgi .... , njah, eks te ise teate mis ta on.
Ootasin kahte head mängu, mis teineteisega konkureerivad kuid lõpptulemusena pole ühtegi. Tuleb DR ka ära ootada enne kui lõplikult käega lüüa.
Kommentaarid: 101 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 94
monty11
monty11
sõnum 08.06.2009 19:34:23 vasta tsitaadiga
Alati on ju Battlefield Heroes icon_biggrin.gificon_biggrin.gificon_biggrin.gif
Väljaarvatud praegusel hetkel ...
Both the universe and stupidity are infinite. I'm not so sure about the former. - A. Einstein
Tule ja kiika minu fotomaailma.
marexx
sõnum 08.06.2009 23:40:11 vasta tsitaadiga
mingi nupp võiks olla, nagu osades rallikates on, Simu ja arcade näiteks icon_biggrin.gif.
isegi kui simu ei ole võib mäng hea tulla.
xtream99
sõnum 09.06.2009 05:36:16 vasta tsitaadiga
Pihv kirjutas:
Testimise järgi on ta sul sitt ja pask, sest see mida sa mängisid oli probably piraatversioon Saksamaa reliisist.
"The crack isnt 100% working, you can run the game but it doesnt crack the FADE protection, its still there, even with beta patch 1.01 and the crack they did for it. Now final 1.01 patch is out and theres no crack at all, u can still run the game with genesis cracks but the game is all fk'd ~~ must be why no1 uploaded it here, its not even enjoyable to play it like this..This Fixed EXE does NOT work properly as the SecuROM Triggers kick in, degrading the the game & making the weapons very inaccurate."
Ning teiseks Saksa reliis oli niigi vigane alguses, sest see lasti välja nn "Beta testi" eesmärgil, et sakslased leiaks vead ja bugid ülesse ja annaksid nendest developeritele teada, et siis saaks patchid välja lasta ja Inglise keelse versiooni väljalaskmise ajaks vead ära parandada, et ei oleks järjekordset "GTA IV" jama, et mäng on kohe alguses vigasid täis.
Kommentaarid: 2 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 1
Pihv
Pihv
sõnum 09.06.2009 05:51:20 vasta tsitaadiga
monty11 kirjutas:
Tahtsid öelda BF1943?
Selle videosid vaadates ja seda Battlefieldi muusikat kuulates tuleb mõnus nostalgia hoog peale küll sest BF1942 oli ikka midagi erilist ja seda sai claniga taoutud nii et vähe pole icon_smile.gif
Arcade võib loomulikult olla väga hea mäng , ei kahtle selles üldse.
Ega see Arma II pole ka mingi "Realism simulation" , teoorias on kuid praktikas mitte, jube mikromajandus käib nende AI sõduritega seal mis teeb selle mängu liiga aeglaseks et oleks "reaalne". OFPDR command system (meenutab BiA seeriat) tundub vähemasti olevat kiire ja lihtne. Samas võib kogenud Arma mängija jaoks olla sealne ka väga kiire, kuid minu jaoks anda igale sõdurile käsklust et sina lase seda, ja sina lase toda, kolmas toogu Humvee siia (mida tuleb oodata terve igaviku sest sõidavad nad ühest tee servast teise, ei pane neile pahaks, endalgi raskusi seal auto kontrollimisega suurel kiirusel icon_smile.gif ) jne. on natukene liig.
Kes on tuttav Project Reality modifikatsiooniga, BF2 jaoks, siis lubati sellel aastal juba alpha versioon enda retail mängust välja lasta ja full game 2011. Eks näis mis välja tuleb. Mod on küll super ja lubadused tunduvad esialgu väga suursugused. Looks like COD4, size of an Arma II and plays like Project Reality.
EDIT: xtream99 eks ootame siis õige väljalaske ära, ma olen 99% kindel et täpselt samasugune. Peamine, kuid kaugeltki mitte ainuke probleem, on väga kehv fps.
Mina mängisin jah torrentiga tõmmatud versiooni, millel 1.01 patch peal + crack. Mingit FADE mul ei olnud, natuke uurida siis leiab mooduse kuidas seda mängu proovida nii nagu need kes selle ostnud, ja meie kes me seda koos testisime täname küll hetkel kõigevõimsamat, et selle peale raha ei raisanud. Aga see selleks.
-Kaivo-
sõnum 09.06.2009 08:08:14 vasta tsitaadiga
Mängu kiirus on suht hästi paika saadud. Arvad tõesti, et päris elus käib asi kiiremini, veel aeglasemalt käib icon_biggrin.gif
Aga OFP:DR kohta kiidaks seda, et nüüd tuleb Battlefield korralik SP-ga icon_biggrin.gif
Aah
Aah
sõnum 12.07.2009 19:29:05 vasta tsitaadiga
Natuke parem juba icon_razz1.gif Fear and Anticipation Trailer HD
Pihv
Pihv
sõnum 18.07.2009 11:05:56 vasta tsitaadiga
EU release on siis "October 9th"
North America "October 6th"
Mõned kuud ikka oodata veel.
Üks uus video ka lisatud 17.07.09
http://www.codemasters.co.uk/flashpoint/index.php?territory=EnglishUK#/video/
Ja mõned uued screenid.
http://www.flickr.com/photos/29306805@N08/
Aah
Aah
sõnum 12.08.2009 08:54:37 vasta tsitaadiga
Tüübid üritavad Hardcore modega mett mokale määrida.
-Kaivo-
sõnum 14.08.2009 08:55:55 vasta tsitaadiga
Operation Flashpoint: Dragon Rising Vehicles Trailer
Lõpuks üks video, mis tekitab isu mängida.
Cb4
Cb4
sõnum 14.08.2009 09:10:38 vasta tsitaadiga
Täitsa asjalik tundub, loodame et treiler vastab mängule ka.
Aah kirjutas:
enamus mängude suur miinus on see krdi ristike keset ekraani. Mina igati päri et igasugu abivahendid ära võtta thumbs_up.gif
Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Kommentaarid: 113 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 95
Aah
Aah
sõnum 14.08.2009 10:19:20 vasta tsitaadiga
Cb4 kirjutas:
Aah kirjutas:
See on jah hea et igast värvilised vidinad eest ära. Kuid kompass ja map peaks ikka olema.
Goon
Goon
sõnum 15.08.2009 09:57:43 vasta tsitaadiga
-Kaivo- kirjutas:
Näeb välja nagu Battlefield 2
Aah
Aah
sõnum 15.08.2009 10:36:09 vasta tsitaadiga
Goon kirjutas:
-Kaivo- kirjutas:
Mis seal DR Vehicles siis nii mõttetut on? Kas enam ei tohi mängus mitte millegagi sõita/lennata ja möllu teha? 1 osas sai ju kõike seda sama teha siis BF 2 veel polnud.
KuriVaiM1
KuriVaiM1
sõnum 15.08.2009 11:53:13 vasta tsitaadiga
CM pole milleski süüdi, need sõidukid kuuluvad reaalaja arsenali, vaevalt et nad BF2 pealt kloonisid
icon_arrow.gif "Mõtle kriitiliselt"
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 66
Aah
Aah
sõnum 16.08.2009 01:32:45 vasta tsitaadiga
Ja soundi poolest tundub et tüübid, kes selle Vehicles Traileri valmis treisid, on liiga palju Terminaatorit vaadanud icon_lol.gif
Cb4
Cb4
sõnum 16.08.2009 09:19:08 vasta tsitaadiga
Minu meelest oli just sound hea. Viimase aja püssimängude sound on nii niru et juba. Lased püssiga, kuid heli on nagu õhupüssill. Sellised asjad segavad jubedalt. Plahvatus(mürsud) ei tee ka lihtsalt plõxu, vaid teevad ikka väga kõva ja sumeda matsu.
Pihv
Pihv
sõnum 17.08.2009 03:28:04 vasta tsitaadiga
Minimum requirement
Operating system: Windows XP SP2 or later
GPU/Video Card: Shader 3.0 (GeForce 7900 GT / 256 MB VRAM or higher), DirectX 9.0c
Sound Card: DirectX Compatible
Memory: 1 GB
Hard disk: 8 GB
Dual Core CPU 2 x 2.4 GHz
DVD drive: Dual Layer DVD-ROM
Recommended System
GPU/Video Card: Shader 3.0 (GeForce 8800 GT / 512 MB VRAM or higher), DirectX 9.0c
Memory: 2 GB
Hard disk: 8 GB
CPU: Quad Core CPU
Dual Layer DVD-ROM DVD drive: Dual Layer DVD-ROM
Loodame, et siis Quad Core annab ka mingi eelise, mitte pole moe pärast "recommended" nagu enamus mängudel mis siiani välja lastud. icon_wink.gif
Reviewd on päris head mida saab lugeda www.ofp2.info
“Yeehaa, all in all everything is working very well so far. Operation Flashpoint: Dragon Rising’s first two missions commence astonishingly smooth. I am curious, whether this is also true for the rest of the game. Although the visuals are not as good as the first screenshots made us believe, but that doesn’t make any difference to me. After all I can play that game fluently on my Laptop with nothing more than 1 GB RAM and a 7600 GT and even then is a good looking game.”
Ja lugedes seda tundub, et vähemalt performance probleeme sellel mängul pole erinevalt mõnest teisest, aga eks siis näeb kui asi käes icon_razz1.gif
Kuigi viimaseid videosid vaadates märkasin ka ise, et graafika pole enam nii hea kui algul tundus. Vist on ühtteist maha keeratud.
Aah
Aah
sõnum 27.08.2009 10:15:17 vasta tsitaadiga
The Sounds of War
http://www.gametrailers.com/video/the-sounds-operation-flashpoint/55001
Release Date: October 6, 2009
-Kaivo-
sõnum 28.08.2009 11:24:35 vasta tsitaadiga
Operation Flashpoint: DR Cooperative Trailer
Veel mingi video
Keskkond on ikka täiesti elutu.
Vastab see tõele, te kui co-op -s kaugemale 200 m lähed tiimi liikmest siis kööga selle vennaga ?
Aah
Aah
sõnum 29.08.2009 03:13:05 vasta tsitaadiga
-Kaivo- kirjutas:
Mida sa täpsemalt silmas pead? Tuul puhub , rohi-puud liiguvad, linnud laulavad, CM on heli poolest alati tasemel?
Pihv
Pihv
sõnum 04.09.2009 04:51:01 vasta tsitaadiga
Huvitav kuidas on lahendatud see, et kui mul on grass view distance nt. 200m ja mingi vend roomab 300m kaugusel kõrges rohus, et mina teda siis ei näeks. Siiani pole keegi peale Joint Operationsi (seal polnud rohtu näha aga meest ka mitte, väga õrnalt oli näha siluett kui hoolega vaadata, parim lahendus siiani, mis ei koorma lahjasid arvuteid) seda probleemi suutnud lahendada. BF2: PR mod tegi lihtsalt static rohu mis on igal kaugusel seal olemas. kuid see pole just hea lahendus.
www.flashpointgame.com
Leht on ka uue välimuse ja sisu saanud.
Story
http://www.youtube.com/watch?v=x0DuPGxdw3A&feature=related
konsooli ingame footage kah. (teise osa leiate vast ise üles)
http://www.youtube.com/watch?v=wSd3HdM0drA&feature=channel
Hardcore "Blinding the dragon"
http://www.youtube.com/watch?v=QBxPGRBOxJA&NR=1
Aah
Aah
sõnum 04.09.2009 11:11:43 vasta tsitaadiga
Lõpuks ometi näeb korralikke gameplay videosi icon_cool.gif Hetkel ei oskagi millegi üle nuriseda.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Flashpoint 2 mine lehele eelmine  1, 2, 3 ... 16, 17, 18 ... 29, 30, 31  järgmine
