uus teema   vasta Uudised »  Mobiiltelefonid ja fototehnika »  Uus iPhone saabub 17. juulil?? märgi kõik teemad loetuks
mine lehele 1, 2  järgmine
RassK
RassK
sõnum 22.05.2009 14:34:34 Uus iPhone saabub 17. juulil?? vasta tsitaadiga
link :: Wired.com
A source closely connected to Apple’s hardware team claims to possess knowledge of the next-generation iPhone’s specifications and release date.
The source told iPhone fan blog Apple iPhone Apps that the new iPhone will launch July 17. Many of the provided specifications corroborate with past rumors that the device will introduce a digital compass and a video recorder, among other features. (The source did not provide a photo; the image to the right is from a past rumor report for the sake of comparison.) Here’s the list:
32GB and 16GB storage (up from the current 16GB and 8GB models)
$199 and $299 price points to be maintained
3.2-megapixel camera (up from the current 2-megapixel camera)
Video-recording and editing capabilities
Ability to send a picture & video via MMS
Discontinuation of the metal band surrounding the edge of the device
OLED screen
1.5 times the battery life of the current models
Double the RAM and processing power
Built-in FM transmitter
Apple logo on back will glow
Rubber-tread backing
Sleeker design
Built-in compass
The camera, GPS, compass and Google map combined will identify photo and inform about photo locations
Turn-by-turn directions
Overall, if these claims are true, this is a relatively minor upgrade. The most notable new features would be the built-in compass (which appeared in earlier rumor reports), the video recorder and editor (the current iPhones don’t support video recording unless you Jailbreak them), the built-in FM transmitter and the OLED screen (which would improve battery life).
One of the features that sticks out to me is the built-in FM transmitter. I see no compelling reason for Apple to put this in the iPhone, as it is not a feature that users have been demanding, and it hasn’t appeared in other iPods.
Another specification I find strange is the OLED screen. That would be a welcome change because it would look nicer than the current LCD screen. But OLEDs are generally pricey, and if the current price points are maintained, I’m not sure if I believe this one.
Otherwise, the rest of the specifications appear not too far-fetched. If the source is simply taking shots in the dark, then most of these specifications are very conservative guesses derived from previous rumor reports.
What do you think, readers? I’m curious as to whether this list of purported specifications is enough to get you to upgrade from a current iPhone. Or if you don’t own one, will you buy one if these rumored features turn out to be true? Let us know in the comments below.
I, for one, will be standing in line for Apple’s next iPhone this summer whether or not these rumors are true. After all, my iPhone is resting in rice.
Tänud kasutajale raidomarek vihje eest.
Kommentaarid: 116 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 101
excalibur
sõnum 22.05.2009 14:38:07 vasta tsitaadiga
hinnad peaks siis vanematel kiirelt kukkuma hakkama
Kommentaarid: 316 loe/lisa Kasutajad arvavad:  :: 5 :: 4 :: 262
Mario.
sõnum 22.05.2009 15:23:21 vasta tsitaadiga
Hakkab juba praktilisuse poole minema. Saaks vaba bluetoothi ja autofookuse kaamerale ning kõrgema ekraani resolutsiooni, hakkaks ise ka edeva mänguasja peale mõtlema.
d3t
d3t
sõnum 24.05.2009 10:26:08 vasta tsitaadiga
Care? Sellega ei saa ikka veel ju rohkem kui ühte rakendust korraga jooksutada ega akut vahetada icon_lol.gif
Kommentaarid: 85 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 72
Mario.
sõnum 24.05.2009 10:33:38 vasta tsitaadiga
Oot? Ainult üks rakendus korraga? Tähendab muusika taustaks ja netis sirvimine/mängimine ei käi iphone_i kohta? icon_lol.gif thumbs_down.gif
d3t
d3t
sõnum 24.05.2009 10:38:59 vasta tsitaadiga
MarioA., see veel käib kuna see on Apple enda programm. Aga ära seda nalja küll looda teha et oled msnis ja siis vaatad korra mis sul mailides toimub. Või kui ilmateadet vaatad siis pead nt Safari kinni panema. Muusika võib tasutal mängida aga see on ka kõik.
Mario.
sõnum 24.05.2009 10:39:51 vasta tsitaadiga
ufo56
ufo56
sõnum 24.05.2009 14:14:39 vasta tsitaadiga
d3t kirjutas:
Võlusõnaks Backgrounder. Pane msn tööle , samalajal vaata maili või gei porri
 Lae pildid -> pilt.io
rex
rex
sõnum 24.05.2009 15:24:48 vasta tsitaadiga
d3t kirjutas:
Aga see, kuidas see üks rakendus jookseb, kaalub tihtipeale selle puuduse üles. Surfa üks tunnike netis WM IE/Opera või S60 brauseriga ja proovi siis Safarit, pärast seda tule räägi meile, mida sa neist edaspidi kasutada sooviks. icon_wink.gif BTW, millal sa viimati akut vahetasid? Ma ei tea oma tutvusringkonnas ühtki inimest, kes teine aku taskus ringi käiks.
3.0 IPSW on niikuinii varsti väljas, sellega parandatakse mitmed kiiksud ära. Näis, kas koos sellega tuleb ka uus device või ei...
Ra*
Ra*
sõnum 24.05.2009 15:43:39 vasta tsitaadiga
FM ...
Kommentaarid: 135 loe/lisa Kasutajad arvavad:  :: 1 :: 2 :: 123
d3t
d3t
sõnum 24.05.2009 17:00:26 vasta tsitaadiga
rex, sa mõtled seda Safarit mis mitu korda kokku jookseb keset browsimist? Akut praegusel telefonil ei peagi vahetama, peab vastu 2 päeva, iPod saab 4-5h kasutamisega tühjaks kahjuks. Oleks telefonil halvem aku, siis kasutaks küll mitut akut.
sõnum 24.05.2009 17:51:59 vasta tsitaadiga
Aku vahetamisega on pigem see teema, et kui see lõpuks üles ütleb, siis ei ole võimalik ka uut asemele osta.
ufo56
ufo56
sõnum 24.05.2009 18:03:19 vasta tsitaadiga
d3t, ja miks "härrale" jailbreak ei sobi ?
Mario.
sõnum 24.05.2009 18:11:07 vasta tsitaadiga
Üks asi on vast originaalsed võimalused, teine asi on see, kui sa pead midagi endale sobivamaks tegema.
rex
rex
sõnum 24.05.2009 18:13:04 vasta tsitaadiga
d3t kirjutas:
Pole mul kordagi jooksnud 5 kuu jooksul. Aku kärab ka nii suure ekraaniga device'i kohta mõistlikult. Ainult telefonifunktsiooni kasutades näiteks vabalt 5 ööpäeva.
mikk36 kirjutas:
Ah, saab ju küll tegelikult, kui algne ükskord sureb. Teisel versioonil pole aku enam isegi külge joodetud. Telefoni esimene omanik aga vaevalt, et selle üle muret tundma peab.
sõnum 25.05.2009 15:12:35 vasta tsitaadiga
Eestis tulevad jälle nagunii kirvete hindadega ja haigete liitumistingimustega need iPhone'id müüki. Ja EMT-iga küll sellepärast liituma ei hakka thumbs_down.gif
Kommentaarid: 733 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 554
rex
rex
sõnum 25.05.2009 15:48:48 vasta tsitaadiga
On seni ilma EMT'i nuumamata hakkama saadud, saadakse ka edaspidi. icon_wink.gif
kami
sõnum 26.05.2009 21:57:52 vasta tsitaadiga
d3t kirjutas:
Halb näide. Just nimelt Seda suvel saabuv 3.0 Software Update võimaldabki - taustateateid, mis "pushitakse" telefoni. Ehk siis kasutaja võib väljuda (antud juhul) MSNi rakendusest, kuid suhtluskeskkonnast ta ei lahku. Juhul, kui keegi midagi kirjutab, jõuab see teade koheselt üle võrgu ka iPhone'i ning kasutaja võib siis rakenduse uuesti avada ning sõnumile vastata (sarnaneb väga SMS funktsioonile). Natuke lugemist kah: http://developer.apple.com/iphone/program/sdk/
ffw
sõnum 29.05.2009 16:30:44 vasta tsitaadiga
ufo56 kirjutas:
Sagedamad kokkujooksmised, osad asjad aeglasemad. Piisavalt mõjuv faktor miks ma eelistaks jeilbreikimatta telefoni.
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 52
ufo56
ufo56
sõnum 29.05.2009 16:50:04 vasta tsitaadiga
ffw kirjutas:
ufo56 kirjutas:
Ei tea mul töötab küll probleemivabalt.
rex
rex
sõnum 29.05.2009 18:07:20 vasta tsitaadiga
Jailbrake'imata iPhone on suht sama, nagu out-of-the-box WM device - dumbuser saab asjad enamvähem tehtud, poweruser vajab aga enamat. icon_wink.gif
Ei ole mina sellest küll ülearust uimamist või kokkujooksmisi täheldanud.
d3t
d3t
sõnum 01.06.2009 22:31:04 vasta tsitaadiga
ufo56 kirjutas:
ffw kirjutas:
ufo56 kirjutas:
ufo56
ufo56
sõnum 01.06.2009 23:28:20 vasta tsitaadiga
Olen väitnud et ei crashi? Ära tule seletama.
Crashib küll ja mitte harva
2III7
2III7
sõnum 02.06.2009 15:34:14 vasta tsitaadiga
http://omniahd.samsungmobile.com/
iphone sai headshoti
Kommentaarid: 159 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 144
miga
miga
sõnum 02.06.2009 18:26:46 vasta tsitaadiga
2III7 kirjutas:
Vaevalt. Samsung võib teha telefone väga võimsate omadustega, kuid kui telefon ise töötab nagu replay, siis on see rohkem suicide kui headshot. iPhone'i kasutusmugavus ja menüü sujuvus ületab kõiki seniseid "iphone-killer" telefone mäekõrguselt.
uus teema   vasta Uudised »  Mobiiltelefonid ja fototehnika »  Uus iPhone saabub 17. juulil?? mine lehele 1, 2  järgmine
