RassK
22.05.2009 14:34:34
Uus iPhone saabub 17. juulil?? |
link :: Wired.com
A source closely connected to Apples hardware team claims to possess knowledge of the next-generation iPhones specifications and release date.
The source told iPhone fan blog Apple iPhone Apps that the new iPhone will launch July 17. Many of the provided specifications corroborate with past rumors that the device will introduce a digital compass and a video recorder, among other features. (The source did not provide a photo; the image to the right is from a past rumor report for the sake of comparison.) Heres the list:
32GB and 16GB storage (up from the current 16GB and 8GB models)
$199 and $299 price points to be maintained
3.2-megapixel camera (up from the current 2-megapixel camera)
Video-recording and editing capabilities
Ability to send a picture & video via MMS
Discontinuation of the metal band surrounding the edge of the device
OLED screen
1.5 times the battery life of the current models
Double the RAM and processing power
Built-in FM transmitter
Apple logo on back will glow
Rubber-tread backing
Sleeker design
Built-in compass
The camera, GPS, compass and Google map combined will identify photo and inform about photo locations
Turn-by-turn directions
Overall, if these claims are true, this is a relatively minor upgrade. The most notable new features would be the built-in compass (which appeared in earlier rumor reports), the video recorder and editor (the current iPhones dont support video recording unless you Jailbreak them), the built-in FM transmitter and the OLED screen (which would improve battery life).
One of the features that sticks out to me is the built-in FM transmitter. I see no compelling reason for Apple to put this in the iPhone, as it is not a feature that users have been demanding, and it hasnt appeared in other iPods.
Another specification I find strange is the OLED screen. That would be a welcome change because it would look nicer than the current LCD screen. But OLEDs are generally pricey, and if the current price points are maintained, Im not sure if I believe this one.
Otherwise, the rest of the specifications appear not too far-fetched. If the source is simply taking shots in the dark, then most of these specifications are very conservative guesses derived from previous rumor reports.
What do you think, readers? Im curious as to whether this list of purported specifications is enough to get you to upgrade from a current iPhone. Or if you dont own one, will you buy one if these rumored features turn out to be true? Let us know in the comments below.
I, for one, will be standing in line for Apples next iPhone this summer whether or not these rumors are true. After all, my iPhone is resting in rice. |
Tänud kasutajale raidomarek vihje eest.
| Kommentaarid: 118 loe/lisa |
103 |
excalibur
22.05.2009 14:38:07
| hinnad peaks siis vanematel kiirelt kukkuma hakkama
262 |
Mario.
22.05.2009 15:23:21
| Hakkab juba praktilisuse poole minema. Saaks vaba bluetoothi ja autofookuse kaamerale ning kõrgema ekraani resolutsiooni, hakkaks ise ka edeva mänguasja peale mõtlema.
6 :: |
217 |
d3t
24.05.2009 10:26:08
Care? Sellega ei saa ikka veel ju rohkem kui ühte rakendust korraga jooksutada ega akut vahetada
_________________ IsAiUseful.com - tee oma esimesed sammud kohaliku AI suunas
| Kommentaarid: 85 loe/lisa |
72 |
Mario.
24.05.2009 10:33:38
Oot? Ainult üks rakendus korraga? Tähendab muusika taustaks ja netis sirvimine/mängimine ei käi iphone_i kohta?
6 :: |
217 |
d3t
24.05.2009 10:38:59
MarioA., see veel käib kuna see on Apple enda programm. Aga ära seda nalja küll looda teha et oled msnis ja siis vaatad korra mis sul mailides toimub. Või kui ilmateadet vaatad siis pead nt Safari kinni panema. Muusika võib tasutal mängida aga see on ka kõik.
72 |
Mario.
24.05.2009 10:39:51
No siis võtan sõnad tagasi
6 :: |
217 |
ufo56
24.05.2009 14:14:39
| d3t kirjutas: |
| MarioA., see veel käib kuna see on Apple enda programm. Aga ära seda nalja küll looda teha et oled msnis ja siis vaatad korra mis sul mailides toimub. Või kui ilmateadet vaatad siis pead nt Safari kinni panema. Muusika võib tasutal mängida aga see on ka kõik. |
Võlusõnaks Backgrounder. Pane msn tööle , samalajal vaata maili või gei porri
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
rex
24.05.2009 15:24:48
| d3t kirjutas: |
Care? Sellega ei saa ikka veel ju rohkem kui ühte rakendust korraga jooksutada ega akut vahetada  |
Aga see, kuidas see üks rakendus jookseb, kaalub tihtipeale selle puuduse üles. Surfa üks tunnike netis WM IE/Opera või S60 brauseriga ja proovi siis Safarit, pärast seda tule räägi meile, mida sa neist edaspidi kasutada sooviks. BTW, millal sa viimati akut vahetasid? Ma ei tea oma tutvusringkonnas ühtki inimest, kes teine aku taskus ringi käiks.
3.0 IPSW on niikuinii varsti väljas, sellega parandatakse mitmed kiiksud ära. Näis, kas koos sellega tuleb ka uus device või ei...
228 |
Ra*
24.05.2009 15:43:39
FM ...
eieiei.. siis peab kohe fake olema
| Kommentaarid: 135 loe/lisa |
123 |
d3t
24.05.2009 17:00:26
rex, sa mõtled seda Safarit mis mitu korda kokku jookseb keset browsimist? Akut praegusel telefonil ei peagi vahetama, peab vastu 2 päeva, iPod saab 4-5h kasutamisega tühjaks kahjuks. Oleks telefonil halvem aku, siis kasutaks küll mitut akut.
ufo56, jailbrake?`eiei, ilma selleta paluks
72 |
24.05.2009 17:51:59
| Aku vahetamisega on pigem see teema, et kui see lõpuks üles ütleb, siis ei ole võimalik ka uut asemele osta.
ufo56
67 |
Mario.
24.05.2009 18:11:07
| Üks asi on vast originaalsed võimalused, teine asi on see, kui sa pead midagi endale sobivamaks tegema.
6 :: |
217 |
rex
24.05.2009 18:13:04
| d3t kirjutas: |
| rex, sa mõtled seda Safarit mis mitu korda kokku jookseb keset browsimist? Akut praegusel telefonil ei peagi vahetama, peab vastu 2 päeva, iPod saab 4-5h kasutamisega tühjaks kahjuks. Oleks telefonil halvem aku, siis kasutaks küll mitut akut. |
Pole mul kordagi jooksnud 5 kuu jooksul. Aku kärab ka nii suure ekraaniga device'i kohta mõistlikult. Ainult telefonifunktsiooni kasutades näiteks vabalt 5 ööpäeva.
| mikk36 kirjutas: |
| Aku vahetamisega on pigem see teema, et kui see lõpuks üles ütleb, siis ei ole võimalik ka uut asemele osta. |
Ah, saab ju küll tegelikult, kui algne ükskord sureb. Teisel versioonil pole aku enam isegi külge joodetud. Telefoni esimene omanik aga vaevalt, et selle üle muret tundma peab.
228 |
| Kommentaarid: 755 loe/lisa |
567 |
rex
25.05.2009 15:48:48
On seni ilma EMT'i nuumamata hakkama saadud, saadakse ka edaspidi.
228 |
kami
26.05.2009 21:57:52
| d3t kirjutas: |
Halb näide. Just nimelt Seda suvel saabuv 3.0 Software Update võimaldabki - taustateateid, mis "pushitakse" telefoni. Ehk siis kasutaja võib väljuda (antud juhul) MSNi rakendusest, kuid suhtluskeskkonnast ta ei lahku. Juhul, kui keegi midagi kirjutab, jõuab see teade koheselt üle võrgu ka iPhone'i ning kasutaja võib siis rakenduse uuesti avada ning sõnumile vastata (sarnaneb väga SMS funktsioonile). Natuke lugemist kah: http://developer.apple.com/iphone/program/sdk/
| Kommentaarid: 12 loe/lisa |
12 |
ffw
29.05.2009 16:30:44
| ufo56 kirjutas: |
| d3t, ja miks "härrale" jailbreak ei sobi ? |
Sagedamad kokkujooksmised, osad asjad aeglasemad. Piisavalt mõjuv faktor miks ma eelistaks jeilbreikimatta telefoni.
| Kommentaarid: 60 loe/lisa |
52 |
ufo56
29.05.2009 16:50:04
| ffw kirjutas: |
| ufo56 kirjutas: |
Sagedamad kokkujooksmised, osad asjad aeglasemad. Piisavalt mõjuv faktor miks ma eelistaks jeilbreikimatta telefoni. |
Ei tea mul töötab küll probleemivabalt.
67 |
rex
29.05.2009 18:07:20
Jailbrake'imata iPhone on suht sama, nagu out-of-the-box WM device - dumbuser saab asjad enamvähem tehtud, poweruser vajab aga enamat.
Ei ole mina sellest küll ülearust uimamist või kokkujooksmisi täheldanud.
228 |
d3t
01.06.2009 22:31:04
| ufo56 kirjutas: |
| ffw kirjutas: |
| ufo56 kirjutas: |
Ei tea mul töötab küll probleemivabalt. |
Sul väidetavalt Safari ei crashi ka
72 |
ufo56
01.06.2009 23:28:20
Olen väitnud et ei crashi? Ära tule seletama.
Crashib küll ja mitte harva
67 |
2III7
| Kommentaarid: 170 loe/lisa |
152 |
miga
02.06.2009 18:26:46
Vaevalt. Samsung võib teha telefone väga võimsate omadustega, kuid kui telefon ise töötab nagu replay, siis on see rohkem suicide kui headshot. iPhone'i kasutusmugavus ja menüü sujuvus ületab kõiki seniseid "iphone-killer" telefone mäekõrguselt.
| Kommentaarid: 34 loe/lisa |
Vici
03.06.2009 11:14:26
seda võib kohe kindlalt öelda et iphone on üle mäekõrguselt teistest mobiilidest mis seni väljas ja tulemas neti surfamise poolest parimat vist nii pea loota pole,hea ekraan kasutajamugavus on ikka nii palju üle sellistest telefonidest nagu samsung omnia LG puutetundlike telefonidega netis surfamine on ikka paras käkk iphonega võrreldes,olen paljusi teisigi veel proovinud millega netis surfata aga ikka kui aus olla paras n...s.Nokia pole ka kahjuks veel lasknud head mobiili välja millega netis nii mugavalt saaks surfata kui iphone,aga eks aeg näitab ehk tuleb aeg kui tuleb iphonele kokurent,killereid on nagu välja hõisatud aga seni ükski pole kahjuks õnnestunud killeriks saada
03.06.2009 11:49:27
| Vici, oled juba proovinud seda Samsung Omniat?
313 |
heretic666
03.06.2009 15:19:41
| Vici, Nokia Xpress Music 5800 ..
| Kommentaarid: 73 loe/lisa |
miga
03.06.2009 15:50:42
| heretic666 kirjutas: |
| Vici, Nokia Xpress Music 5800 .. |
5800 ei küündi oma kasutusmugavuselt ja internetis surfamisel iPhone'i lähedale ka mitte. Ma ei ole omanud 5800, kuid olen kasutanud ja ei meeldinud. Oman iPhone'i ja tagasiminek oli tuntav! Samas asi on maitses. Kes kasutab, see kiidab. Olen kasutaja Vici'ga nõus, et turul olevad ja lähiajal tulevad "iphone killer" telefonid on kaugel killimisest. Jah, nad on võimsamate omadustega, kuid kasutusmugavuses jäävad ikka tuntavalt f66nile alla.
ffw
03.06.2009 18:37:04
Kahjuks ei saa seda nimetada puutetundliku ekraaniga telefoniks. Pigem vajutustundlik. Kahjuks. Lootsin Nokialt mingit konkurentsi pakkuvat sedaet sellest aga tutkit.
52 |
2III7
03.06.2009 18:45:36
nokial tulevad capactive ekraaniga telefonid alles aasta kolmandas pooles loodetavasti need on OLED ka. isegi n97 pole puutetundliku ekraaniga, kuigi peaks nagu olema nokia nö. lipulaev
152 |
Vici
03.06.2009 20:58:23
Omasin vahepeal ka Samsung Omnia i900 no see oli ikka iphone kõrval kräpp ruudus isegi pulgaga jõnksutas,uut omnia HD pole veel müüki jõudnud muidu näpiks selle kohe poes ära,asi selles et kõik uuemad saab poes ära näpitud tutvuse kaudu lihtsalt huvi pärast,olen ka nokia 5800 päris põgusalt näppinud aga noh võrdlust ei kannata raudselt kasutaja mugavuse poolest iphonega hoopis kaks erinevat asja mida võrrelda,Esiteks iphonil on ekraan sujuv kõik saab näpuga ikka väga mõnusalt aetud,teisteh'ga ma pole seda veel suutnud teha,no vähemalt 10 ne telefoniga võrrelnud iphoni aga veel konkurenti mugavuse poolest iphonele vastu panna pole,kes on näppinud ja võrrelnud saaks asja kohe selgeks
TT
11.06.2009 10:52:39
| 2III7 kirjutas: |
nokial tulevad capactive ekraaniga telefonid alles aasta kolmandas pooles loodetavasti need on OLED ka. isegi n97 pole puutetundliku ekraaniga, kuigi peaks nagu olema nokia nö. lipulaev |
Kus sa selle välja lugesid, et N97 pole puutetundlik?
Iphone 3mas raud hakkab juba lubama
Kuni korralik multitasking ja hea kaamera puudub kasutan N82.te edasi.
_________________ Things ThaT You own end up Owning you! |
| Kommentaarid: 313 loe/lisa |
275 |
woo456
14.06.2009 22:16:58
TT, selle all, et pole puutetundlik, mõtleb ta seda, et tegu on resistive tüüpi touchscreeniga, mitte capacitive nagu on iPhone'il ja tollel Omnial.
Need erinevad siis selle poolest, et resistive reageerib kergele vajutusele, capacitive aga puudutusele. Täpsemalt võid wikist uurida.
| Kommentaarid: 8 loe/lisa |
Misfits
22.06.2009 21:36:47
Kuna see iPod Touch ja iPhone on iTunesiga seotud on need vidinad absoluutselt mõttetud arvutiga ühendades.
See iTunes on mega keeruliseks tehtud ning telefoist piltide või videote laadimine ning syncimine võtab pool päeva.
Ostsin Nokia 5800XMi ning kõik väga lihtne. Pealekauba mahub kätte kah ära ning kõik võimalused on samad kui iPhonel. Puuteekraaniks jääb selle Nokia oma vähe väikseks aga saab hakkama. Igati kiire telefon. IPod Touch jääb igastahes vahest toppama. IPhone kohta ei oska ütelda aga peaksid enamvöhem sama softiga olema. IPod Touch seisab siiani sahtlis. Sain selle kingiks aga ei viitsi kasutada. Oleks võimalus otse arvutiga ühendada - võibolla isegi kasutaksin. Helikvaliteet jätab ka soovida.
Väääga üleshaibitud tooted
175 |
rex
23.06.2009 00:00:19
Haibist hoolimata mõnusad kasutada.
228 |
d3t
23.06.2009 00:03:25
woo456, tegelt ma eelistan ise resistive tüüpi ekraane. Saab vähemalt kõne vastu võtta kui kindad käes. Lisaks muidugi handwritingu tugi.
miga, kui sulle Flash ei meeldi (noh tead, küll et Youtube ja muid selliseid lehti vaadata) siis võid võtta Opera Mini. Tulemus on mitu korda kiirem netibrowsimine kui iPhonel ever.
ffw, puutetundlik ekraan on puutetundlik erkaan. Pole olemas vajutustundliku ekraani.
72 |
rex
23.06.2009 01:23:24
Sul, d3t, pole vist capactive ekraaniga device'i kunagi olnud? Kindaga kõne vastu võtmine on paraku ainuke vajutustundliku ekraani pluss.
228 |
d3t
23.06.2009 10:36:38
rex, iphone ja ipod mõlemad olemas olnud. Jätkuvalt, mulle meeldib stiilust kasutada ja ilma stiiluseta handwritingu tuvastus on naljaasi.
72 |
RassK
24.06.2009 14:11:46
link :: Tarbija24
Apple müüs kolme päevaga üle miljoni uue iPhonei
Apple'i teatel oli eilse päeva seisuga vaid kolme päevaga alates uue iPhone'i mudeli 3G S turuletoomisest müüdud üle miljoni nutitelefoni eksemplari.
103 |
rex
24.06.2009 15:51:27
| d3t kirjutas: |
| Jätkuvalt, mulle meeldib stiilust kasutada ja ilma stiiluseta handwritingu tuvastus on naljaasi. |
BTW, vajutustundliku puhul meeldib mulle ka stylusega torkimine rohkem (olen omanud Asus P535 ja SE P1i-d). Ilma selleta on alla 5x5 mm objektidega opereerimine juba maru ebatäpne. iPhone'iga seda muret ei ole ja stylust lihtsalt ei lähe vaja. Ruutmillimeetrised objektid on sõrmega tabatavad. Ja sellele vaatamata on Apple disaininud kogu UI sellisena, et igasugused nupud ja sliderid on tabamiseks rohkem kui küllaldaselt suured. WM all on osadele checkboxidele isegi pulgaga raske pihta saada, samas kõrval laiutab kasutamata eikellegimaa.
Handwriting? Misasi see on? Miks ma peaks seda tänapäeval veel mujal kui pastakaga pabermärkmikku sodides kasutama? Pisut sai seda katsetatud, kui mul oli kunagi Palm IIIx ja Vx, ei leidnud, et see tähtede toksimisest kiirem oleks olnud. iPhone'i juures sellest küll puudust tunda ei oska. Joonistada ma mobiilse seadmega ka üldjuhul ei taha.
Pärast OS 3.0 pealepanekut olen ma igatahes oma ifööniga rohkem rahul kui eales varem ühegi varasema mobiilse seadmega.
228 |
d3t
25.06.2009 12:35:07
rex, mulle meeldib tablet pc kah, märkmeid imo mugavam stiilusega teha. Muide, mind ajab iPhonel närvi see helislaider. Ma ei saa kunagi sellele pihta, alati peab nuppe kasutama.
72 |
rex
228 |
M00t
25.06.2009 23:38:39
haha, mis ajupesu?
| Kommentaarid: 77 loe/lisa |
73 |
d3t
25.06.2009 23:39:47
iPhone on kergem maha müüa kui tipklassi äritelefoni
72 |
rex
26.06.2009 09:38:11
| lu1de kirjutas: |
| haha, mis ajupesu? |
Ei olnud sulle mõeldud. Sinust ma juba tean niigi, et müüd selleks, et Sport-varianti osta.
228 |
gen
26.06.2009 10:43:33
| jälle üks mängasu juures
| Kommentaarid: 22 loe/lisa |
21 |
