RassK
22.05.2009 13:34:34
Uus iPhone saabub 17. juulil?? |
link :: Wired.com
A source closely connected to Apples hardware team claims to possess knowledge of the next-generation iPhones specifications and release date.
The source told iPhone fan blog Apple iPhone Apps that the new iPhone will launch July 17. Many of the provided specifications corroborate with past rumors that the device will introduce a digital compass and a video recorder, among other features. (The source did not provide a photo; the image to the right is from a past rumor report for the sake of comparison.) Heres the list:
32GB and 16GB storage (up from the current 16GB and 8GB models)
$199 and $299 price points to be maintained
3.2-megapixel camera (up from the current 2-megapixel camera)
Video-recording and editing capabilities
Ability to send a picture & video via MMS
Discontinuation of the metal band surrounding the edge of the device
OLED screen
1.5 times the battery life of the current models
Double the RAM and processing power
Built-in FM transmitter
Apple logo on back will glow
Rubber-tread backing
Sleeker design
Built-in compass
The camera, GPS, compass and Google map combined will identify photo and inform about photo locations
Turn-by-turn directions
Overall, if these claims are true, this is a relatively minor upgrade. The most notable new features would be the built-in compass (which appeared in earlier rumor reports), the video recorder and editor (the current iPhones dont support video recording unless you Jailbreak them), the built-in FM transmitter and the OLED screen (which would improve battery life).
One of the features that sticks out to me is the built-in FM transmitter. I see no compelling reason for Apple to put this in the iPhone, as it is not a feature that users have been demanding, and it hasnt appeared in other iPods.
Another specification I find strange is the OLED screen. That would be a welcome change because it would look nicer than the current LCD screen. But OLEDs are generally pricey, and if the current price points are maintained, Im not sure if I believe this one.
Otherwise, the rest of the specifications appear not too far-fetched. If the source is simply taking shots in the dark, then most of these specifications are very conservative guesses derived from previous rumor reports.
What do you think, readers? Im curious as to whether this list of purported specifications is enough to get you to upgrade from a current iPhone. Or if you dont own one, will you buy one if these rumored features turn out to be true? Let us know in the comments below.
I, for one, will be standing in line for Apples next iPhone this summer whether or not these rumors are true. After all, my iPhone is resting in rice. |
Tänud kasutajale raidomarek vihje eest.
101 |
excalibur
22.05.2009 13:38:07
| hinnad peaks siis vanematel kiirelt kukkuma hakkama
262 |
Mario.
22.05.2009 14:23:21
| Hakkab juba praktilisuse poole minema. Saaks vaba bluetoothi ja autofookuse kaamerale ning kõrgema ekraani resolutsiooni, hakkaks ise ka edeva mänguasja peale mõtlema.
6 :: |
217 |
d3t
24.05.2009 09:26:08
Care? Sellega ei saa ikka veel ju rohkem kui ühte rakendust korraga jooksutada ega akut vahetada
_________________ next.Insiders - koht mängijatele ja tehnikahuvilistele toredaks ajaveetmiseks.
| Kommentaarid: 85 loe/lisa |
72 |
Mario.
24.05.2009 09:33:38
Oot? Ainult üks rakendus korraga? Tähendab muusika taustaks ja netis sirvimine/mängimine ei käi iphone_i kohta?
6 :: |
217 |
d3t
24.05.2009 09:38:59
MarioA., see veel käib kuna see on Apple enda programm. Aga ära seda nalja küll looda teha et oled msnis ja siis vaatad korra mis sul mailides toimub. Või kui ilmateadet vaatad siis pead nt Safari kinni panema. Muusika võib tasutal mängida aga see on ka kõik.
72 |
Mario.
24.05.2009 09:39:51
No siis võtan sõnad tagasi
6 :: |
217 |
ufo56
24.05.2009 13:14:39
| d3t kirjutas: |
| MarioA., see veel käib kuna see on Apple enda programm. Aga ära seda nalja küll looda teha et oled msnis ja siis vaatad korra mis sul mailides toimub. Või kui ilmateadet vaatad siis pead nt Safari kinni panema. Muusika võib tasutal mängida aga see on ka kõik. |
Võlusõnaks Backgrounder. Pane msn tööle , samalajal vaata maili või gei porri
Lae pildid -> pilt.io |
| Kommentaarid: 78 loe/lisa |
67 |
rex
24.05.2009 14:24:48
| d3t kirjutas: |
Care? Sellega ei saa ikka veel ju rohkem kui ühte rakendust korraga jooksutada ega akut vahetada  |
Aga see, kuidas see üks rakendus jookseb, kaalub tihtipeale selle puuduse üles. Surfa üks tunnike netis WM IE/Opera või S60 brauseriga ja proovi siis Safarit, pärast seda tule räägi meile, mida sa neist edaspidi kasutada sooviks. BTW, millal sa viimati akut vahetasid? Ma ei tea oma tutvusringkonnas ühtki inimest, kes teine aku taskus ringi käiks.
3.0 IPSW on niikuinii varsti väljas, sellega parandatakse mitmed kiiksud ära. Näis, kas koos sellega tuleb ka uus device või ei...
226 |
Ra*
24.05.2009 14:43:39
FM ...
eieiei.. siis peab kohe fake olema
| Kommentaarid: 135 loe/lisa |
123 |
d3t
24.05.2009 16:00:26
rex, sa mõtled seda Safarit mis mitu korda kokku jookseb keset browsimist? Akut praegusel telefonil ei peagi vahetama, peab vastu 2 päeva, iPod saab 4-5h kasutamisega tühjaks kahjuks. Oleks telefonil halvem aku, siis kasutaks küll mitut akut.
ufo56, jailbrake?`eiei, ilma selleta paluks
72 |
24.05.2009 16:51:59
| Aku vahetamisega on pigem see teema, et kui see lõpuks üles ütleb, siis ei ole võimalik ka uut asemele osta.
ufo56
67 |
Mario.
24.05.2009 17:11:07
| Üks asi on vast originaalsed võimalused, teine asi on see, kui sa pead midagi endale sobivamaks tegema.
6 :: |
217 |
rex
24.05.2009 17:13:04
| d3t kirjutas: |
| rex, sa mõtled seda Safarit mis mitu korda kokku jookseb keset browsimist? Akut praegusel telefonil ei peagi vahetama, peab vastu 2 päeva, iPod saab 4-5h kasutamisega tühjaks kahjuks. Oleks telefonil halvem aku, siis kasutaks küll mitut akut. |
Pole mul kordagi jooksnud 5 kuu jooksul. Aku kärab ka nii suure ekraaniga device'i kohta mõistlikult. Ainult telefonifunktsiooni kasutades näiteks vabalt 5 ööpäeva.
| mikk36 kirjutas: |
| Aku vahetamisega on pigem see teema, et kui see lõpuks üles ütleb, siis ei ole võimalik ka uut asemele osta. |
Ah, saab ju küll tegelikult, kui algne ükskord sureb. Teisel versioonil pole aku enam isegi külge joodetud. Telefoni esimene omanik aga vaevalt, et selle üle muret tundma peab.
226 |
25.05.2009 14:12:35
Eestis tulevad jälle nagunii kirvete hindadega ja haigete liitumistingimustega need iPhone'id müüki. Ja EMT-iga küll sellepärast liituma ei hakka
| Kommentaarid: 742 loe/lisa |
560 |
rex
25.05.2009 14:48:48
On seni ilma EMT'i nuumamata hakkama saadud, saadakse ka edaspidi.
226 |
kami
26.05.2009 20:57:52
| d3t kirjutas: |
Halb näide. Just nimelt Seda suvel saabuv 3.0 Software Update võimaldabki - taustateateid, mis "pushitakse" telefoni. Ehk siis kasutaja võib väljuda (antud juhul) MSNi rakendusest, kuid suhtluskeskkonnast ta ei lahku. Juhul, kui keegi midagi kirjutab, jõuab see teade koheselt üle võrgu ka iPhone'i ning kasutaja võib siis rakenduse uuesti avada ning sõnumile vastata (sarnaneb väga SMS funktsioonile). Natuke lugemist kah: http://developer.apple.com/iphone/program/sdk/
| Kommentaarid: 12 loe/lisa |
12 |
ffw
29.05.2009 15:30:44
| ufo56 kirjutas: |
| d3t, ja miks "härrale" jailbreak ei sobi ? |
Sagedamad kokkujooksmised, osad asjad aeglasemad. Piisavalt mõjuv faktor miks ma eelistaks jeilbreikimatta telefoni.
| Kommentaarid: 60 loe/lisa |
52 |
ufo56
29.05.2009 15:50:04
| ffw kirjutas: |
| ufo56 kirjutas: |
Sagedamad kokkujooksmised, osad asjad aeglasemad. Piisavalt mõjuv faktor miks ma eelistaks jeilbreikimatta telefoni. |
Ei tea mul töötab küll probleemivabalt.
67 |
rex
29.05.2009 17:07:20
Jailbrake'imata iPhone on suht sama, nagu out-of-the-box WM device - dumbuser saab asjad enamvähem tehtud, poweruser vajab aga enamat.
Ei ole mina sellest küll ülearust uimamist või kokkujooksmisi täheldanud.
226 |
d3t
01.06.2009 21:31:04
| ufo56 kirjutas: |
| ffw kirjutas: |
| ufo56 kirjutas: |
Ei tea mul töötab küll probleemivabalt. |
Sul väidetavalt Safari ei crashi ka
72 |
ufo56
01.06.2009 22:28:20
Olen väitnud et ei crashi? Ära tule seletama.
Crashib küll ja mitte harva
67 |
2III7
| Kommentaarid: 161 loe/lisa |
145 |
miga
02.06.2009 17:26:46
Vaevalt. Samsung võib teha telefone väga võimsate omadustega, kuid kui telefon ise töötab nagu replay, siis on see rohkem suicide kui headshot. iPhone'i kasutusmugavus ja menüü sujuvus ületab kõiki seniseid "iphone-killer" telefone mäekõrguselt.
| Kommentaarid: 34 loe/lisa |
