uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [X360] Left 4 Dead märgi kõik teemad loetuks
sõnum 11.11.2008 15:36:58 [X360] Left 4 Dead vasta tsitaadiga
Left 4 Dead
  • Ametlik leht: l4d.com
  • Publisher: Electronic Arts
  • Developer: Valve
  • Stiil: survival horror FPS
  • Väljalaske kuupäev: 20. november 2008
  • Kirjeldus:
    - Left 4 Dead is a First Person Shooter Co-operative Multiplayer game in which you can play as one of up to four people (called “Survivors”), luckily immune to a virus that’s sent most of the population mad. You, as a survivor, are pitched against an endless horde of people turned into deranged psychopaths as a result of the lost battle against the virus.
    - There are no character classes, every player starts off on an even footing in terms of skills and weaponry, meaning success requires teamwork and quick thinking.
    - At the start of each campaign of choice you begin with a basic pistol. Next to you are tables from which you can grab your choice of SMG or shotgun, and an explosive. Then you get into the action.
    - Friendly Fire is always on in all difficulty levels, and there is no way of turning it off.
    - Your goal...survive. Reach the rescue zone at the end of the campaign.
  • Multiplayer: 2-4 co-op | 2-8 deathmatch | 4 vs. 4 co-op versus
  • Uudised ja eelvaated: Gamespot
  • Ülevaade: Gamespot
  • Screenshotid: Gamespot
  • Videod: Gametrailers
viimati muutis SKG 09.04.2009 18:17:44, muudetud 1 kord
sõnum 11.11.2008 15:40:44 vasta tsitaadiga
Xbox 360 gameplay video: http://www.g4tv.com/trailers/videos/34798/Left_4_DirectFeed_Gameplay_Footage_Xbox_360.html
K3rT6699
K3rT6699
sõnum 13.11.2008 19:00:23 vasta tsitaadiga
Proovisin ka x360-ne ja PC demot, ülihea madin ikka minuarust. Huvitavam on siis kui kaaslastel on natuke aruraasu ka peas ja teamwork on mängus. Andricos ei paista PC versiooni (Võid üldse mingit versiooni) olevat veel, pre-orderit mõtlen.
sõnum 14.11.2008 21:55:11 vasta tsitaadiga
võiks proovida 4-kesi demo co-op teha. kas saame kokku 4 inimest? amddude tundis ka eile huvi, aga mul pold aega
Stabby
sõnum 14.11.2008 23:02:12 vasta tsitaadiga
PC peal proovitud ning väga kõva!
Kommentaarid: 35 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 35
Taaviup
Taaviup
sõnum 15.11.2008 00:20:57 vasta tsitaadiga
liituks ka.
Nuubkook
Nuubkook
sõnum 15.11.2008 01:00:24 vasta tsitaadiga
I'm in
Kewzors on gamertag
K3rT6699
K3rT6699
sõnum 15.11.2008 14:49:06 vasta tsitaadiga
Oleks küll huvi, mis ajal umbes?
GT: K3rT6699
Nuubkook
Nuubkook
sõnum 15.11.2008 16:03:34 vasta tsitaadiga
Pre-ordersin ära just game.co.uk-st
Naljakas oli see ,et ma ei teadnudki ,et sealt deebetkaardiga saab tellida panin tuimalt andmed sisse ja kõik võttis rahulikult vastu ja saatis confirmation emaili ka ära thumbs_up.gif
woo456
woo456
sõnum 15.11.2008 18:03:51 vasta tsitaadiga
Deebetkaardiga ei saa. Mingiaeg saad meili, et sinu tellimusega on midagi nihu (andmed valed) ja sulle ei saa pakki saata.
Nuubkook
Nuubkook
sõnum 15.11.2008 18:09:54 vasta tsitaadiga
woo456 kirjutas:
PeZ
sõnum 15.11.2008 21:43:53 vasta tsitaadiga
woo, saab küll ,kui Visa deebet, nt kõik SEB deebetid.
woo456
woo456
sõnum 15.11.2008 21:48:54 vasta tsitaadiga
Ükskord kuidagi üritasin oma deebetiga (SEB). Siis nagu ei õnnestunud. Nii palju kui kuulnud olen, ei peaks nagu ka saama. eusa_think.gif Aga sellega seoses tekkis üks küsimus. Mis siis sinna turvakoodi reale sisestada tuleb?
-e-
AGa kas mitte SEB-s VISA-d krediitkaardid pole. Visa Electronid on deebetid. icon_question.gif
Nuubkook
Nuubkook
sõnum 15.11.2008 21:59:27 vasta tsitaadiga
No mul on näiteks Visa Electron panin lahtrisse Visa kuna Visa Electronit ta vastu ei võtnud ütles et kaardi tüüp ja number ei ühti siis muutsin Visaks ja võttis vastu
Turvakoodiks panin kolm viimast numbrit mis mul seal deebetkaardi peal oli
Mul swedbank btw
edit:
ma oleks tegelt eriti rõngas kui see töötaks
PeZ
sõnum 15.11.2008 22:11:26 vasta tsitaadiga
woo Ma ei tea, mul töötab, lithsalt sõltub deebeti tüübist, kui on relieefsed numbrid, siis on ok. Igasgugu noortekaartidel jms pole, või Visa electron kui on.
kukkurkurat8
sõnum 17.11.2008 20:17:06 vasta tsitaadiga
Keegi täna Demot ei viitsiks? (GT:Est275) icon_rolleyes.gif
Kommentaarid: 4 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 2
ertr2
ertr2
sõnum 19.11.2008 19:54:41 vasta tsitaadiga
mulle sobib
Kommentaarid: 67 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 65
kukkurkurat8
sõnum 19.11.2008 21:00:42 vasta tsitaadiga
ertr2 kirjutas:
mulle sobib
Eeh... see postitus oli juba paar oli juba paar päeva tagasi postitatud aga ok umbes 20:30 sobib mulle.
ertr2
ertr2
sõnum 19.11.2008 21:16:40 vasta tsitaadiga
kukkurkurat8 kirjutas:
ertr2 kirjutas:
mulle sobib
sry...kahjuks ei saa,mida imeliku juhtus...
K3rT6699
K3rT6699
sõnum 19.11.2008 21:20:55 vasta tsitaadiga
"A problem with your order"
r3dd3vil
r3dd3vil
sõnum 20.11.2008 13:48:31 vasta tsitaadiga
See algusvideo oli ülikõvv. mäng suht hea, aga ostma ei hakka.
Arbuus
Arbuus
sõnum 20.11.2008 15:46:43 vasta tsitaadiga
Edit:Täna peaks välja tulema
Nuubkook
Nuubkook
sõnum 20.11.2008 16:17:13 vasta tsitaadiga
sõnum 24.11.2008 09:25:37 vasta tsitaadiga
Link
Y'all used me like a pipe bomb!
RasmusJ
sõnum 26.11.2008 21:40:34 vasta tsitaadiga
kust seda pc demot saab
Angryhead
Angryhead
sõnum 26.11.2008 22:00:53 vasta tsitaadiga
RasmusJ, ei saagi enam.
akira
sõnum 30.03.2009 19:48:31 vasta tsitaadiga
Paljudel teist Left 4 dead xbox360le üldse olemas on? PC peal proovisin asja ja hullult meeldib. Kui teaks, et eestlastest oleks konsooli versioonile ka potentsiaalseid kaasmängijaid kellega co-op mänge teha, siis soetaksin endale lähiajal xbox360 versiooni.
sõnum 30.03.2009 20:10:06 vasta tsitaadiga
akira, http://www.mygamercard.net/clboard.php?id=s1MiEbQU&gt=&g=666&z=&c=&x=93&y=12 icon_wink.gif
Ramones
Ramones
sõnum 27.04.2009 12:11:49 vasta tsitaadiga
Kas keegi näiteks täna õhtul ei viitsi expert tasemel mängida?
