- Left 4 Dead is a First Person Shooter Co-operative Multiplayer game in which you can play as one of up to four people (called Survivors), luckily immune to a virus thats sent most of the population mad. You, as a survivor, are pitched against an endless horde of people turned into deranged psychopaths as a result of the lost battle against the virus.
- There are no character classes, every player starts off on an even footing in terms of skills and weaponry, meaning success requires teamwork and quick thinking.
- At the start of each campaign of choice you begin with a basic pistol. Next to you are tables from which you can grab your choice of SMG or shotgun, and an explosive. Then you get into the action.
- Friendly Fire is always on in all difficulty levels, and there is no way of turning it off.
- Your goal...survive. Reach the rescue zone at the end of the campaign.
Multiplayer: 2-4 co-op | 2-8 deathmatch | 4 vs. 4 co-op versus
Proovisin ka x360-ne ja PC demot, ülihea madin ikka minuarust. Huvitavam on siis kui kaaslastel on natuke aruraasu ka peas ja teamwork on mängus. Andricos ei paista PC versiooni (Võid üldse mingit versiooni) olevat veel, pre-orderit mõtlen.
Pre-ordersin ära just game.co.uk-st
Naljakas oli see ,et ma ei teadnudki ,et sealt deebetkaardiga saab tellida panin tuimalt andmed sisse ja kõik võttis rahulikult vastu ja saatis confirmation emaili ka ära
Ükskord kuidagi üritasin oma deebetiga (SEB). Siis nagu ei õnnestunud. Nii palju kui kuulnud olen, ei peaks nagu ka saama. Aga sellega seoses tekkis üks küsimus. Mis siis sinna turvakoodi reale sisestada tuleb?
-e-
AGa kas mitte SEB-s VISA-d krediitkaardid pole. Visa Electronid on deebetid.
No mul on näiteks Visa Electron panin lahtrisse Visa kuna Visa Electronit ta vastu ei võtnud ütles et kaardi tüüp ja number ei ühti siis muutsin Visaks ja võttis vastu
Turvakoodiks panin kolm viimast numbrit mis mul seal deebetkaardi peal oli
Mul swedbank btw
edit:
eks varsti saab teada
ma oleks tegelt eriti rõngas kui see töötaks
woo Ma ei tea, mul töötab, lithsalt sõltub deebeti tüübist, kui on relieefsed numbrid, siis on ok. Igasgugu noortekaartidel jms pole, või Visa electron kui on. _________________
I am delighted to let you know that your Preorder for Left 4 Dead is now being processed subject to successful payment being taken from your credit card when it is dispatched. The order will be despatched by your chosen delivery method in time to reach you for the day of release.
By using the GAME 1st To Play Preorder Service you have ensured that you will be among the first people to receive Left 4 Dead, and we are confident that you will be happy with the order, our service and our speedy delivery!
Your credit / debit card will be charged upon despatch of your order. Also, if you are a Reward Member your points will be added to your account at this time.
