11.11.2008 14:36:58
[X360] Left 4 Dead |
Left 4 Dead
- Ametlik leht: l4d.com
- Publisher: Electronic Arts
- Developer: Valve
- Stiil: survival horror FPS
- Väljalaske kuupäev: 20. november 2008
- Kirjeldus:
- Left 4 Dead is a First Person Shooter Co-operative Multiplayer game in which you can play as one of up to four people (called Survivors), luckily immune to a virus thats sent most of the population mad. You, as a survivor, are pitched against an endless horde of people turned into deranged psychopaths as a result of the lost battle against the virus.
- There are no character classes, every player starts off on an even footing in terms of skills and weaponry, meaning success requires teamwork and quick thinking.
- At the start of each campaign of choice you begin with a basic pistol. Next to you are tables from which you can grab your choice of SMG or shotgun, and an explosive. Then you get into the action.
- Friendly Fire is always on in all difficulty levels, and there is no way of turning it off.
- Your goal...survive. Reach the rescue zone at the end of the campaign. |
Multiplayer: 2-4 co-op | 2-8 deathmatch | 4 vs. 4 co-op versus
Uudised ja eelvaated: Gamespot
Ülevaade: Gamespot
Screenshotid: Gamespot
Videod: Gametrailers
_________________ MÜÜA: Xbox 360 E 250GB (UUS)
viimati muutis SKG 09.04.2009 17:17:44, muudetud 1 kord |
313 |
313 |
K3rT6699
13.11.2008 18:00:23
| Proovisin ka x360-ne ja PC demot, ülihea madin ikka minuarust. Huvitavam on siis kui kaaslastel on natuke aruraasu ka peas ja teamwork on mängus. Andricos ei paista PC versiooni (Võid üldse mingit versiooni) olevat veel, pre-orderit mõtlen.
14.11.2008 20:55:11
võiks proovida 4-kesi demo co-op teha. kas saame kokku 4 inimest? amddude tundis ka eile huvi, aga mul pold aega
_________________ MÜÜA: Xbox 360 E 250GB (UUS) |
313 |
Stabby
14.11.2008 22:02:12
Minul suur huvi!
PC peal proovitud ning väga kõva!
| Kommentaarid: 34 loe/lisa |
34 |
Taaviup
14.11.2008 23:20:57
| liituks ka.
| Kommentaarid: 11 loe/lisa |
Nuubkook
15.11.2008 00:00:24
I'm in
Kewzors on gamertag
| Kommentaarid: 16 loe/lisa |
16 |
K3rT6699
15.11.2008 13:49:06
Oleks küll huvi, mis ajal umbes?
GT: K3rT6699
Nuubkook
15.11.2008 15:03:34
Pre-ordersin ära just game.co.uk-st
Naljakas oli see ,et ma ei teadnudki ,et sealt deebetkaardiga saab tellida panin tuimalt andmed sisse ja kõik võttis rahulikult vastu ja saatis confirmation emaili ka ära
16 |
woo456
15.11.2008 17:03:51
| Deebetkaardiga ei saa. Mingiaeg saad meili, et sinu tellimusega on midagi nihu (andmed valed) ja sulle ei saa pakki saata.
| Kommentaarid: 8 loe/lisa |
Nuubkook
15.11.2008 17:09:54
| woo456 kirjutas: |
| Deebetkaardiga ei saa. Mingiaeg saad meili, et sinu tellimusega on midagi nihu (andmed valed) ja sulle ei saa pakki saata. |
Kuradi lame
16 |
PeZ
15.11.2008 20:43:53
woo, saab küll ,kui Visa deebet, nt kõik SEB deebetid.
| Kommentaarid: 12 loe/lisa |
woo456
15.11.2008 20:48:54
Ükskord kuidagi üritasin oma deebetiga (SEB). Siis nagu ei õnnestunud. Nii palju kui kuulnud olen, ei peaks nagu ka saama. Aga sellega seoses tekkis üks küsimus. Mis siis sinna turvakoodi reale sisestada tuleb?
-e-
AGa kas mitte SEB-s VISA-d krediitkaardid pole. Visa Electronid on deebetid.
Nuubkook
15.11.2008 20:59:27
No mul on näiteks Visa Electron panin lahtrisse Visa kuna Visa Electronit ta vastu ei võtnud ütles et kaardi tüüp ja number ei ühti siis muutsin Visaks ja võttis vastu
Turvakoodiks panin kolm viimast numbrit mis mul seal deebetkaardi peal oli
Mul swedbank btw
edit:
eks varsti saab teada
ma oleks tegelt eriti rõngas kui see töötaks
16 |
PeZ
15.11.2008 21:11:26
woo Ma ei tea, mul töötab, lithsalt sõltub deebeti tüübist, kui on relieefsed numbrid, siis on ok. Igasgugu noortekaartidel jms pole, või Visa electron kui on.
kukkurkurat8
17.11.2008 19:17:06
Keegi täna Demot ei viitsiks? (GT:Est275)
| Kommentaarid: 4 loe/lisa |
ertr2
19.11.2008 18:54:41
| mulle sobib
| Kommentaarid: 67 loe/lisa |
65 |
kukkurkurat8
19.11.2008 20:00:42
| ertr2 kirjutas: |
| mulle sobib |
Eeh... see postitus oli juba paar oli juba paar päeva tagasi postitatud aga ok umbes 20:30 sobib mulle.
ertr2
19.11.2008 20:16:40
| kukkurkurat8 kirjutas: |
| ertr2 kirjutas: |
| mulle sobib |
Eeh... see postitus oli juba paar oli juba paar päeva tagasi postitatud aga ok umbes 20:30 sobib mulle. |
sry...kahjuks ei saa,mida imeliku juhtus...
65 |
K3rT6699
19.11.2008 20:20:55
"A problem with your order"
deem
r3dd3vil
20.11.2008 12:48:31
| See algusvideo oli ülikõvv. mäng suht hea, aga ostma ei hakka.
| Kommentaarid: 35 loe/lisa |
Arbuus
20.11.2008 14:46:43
4'Kesi mängimine tõesti väga huvitav =)Jään ootama
Edit:Täna peaks välja tulema
Nuubkook
16 |
313 |
RasmusJ
26.11.2008 20:40:34
| kust seda pc demot saab
| Kommentaarid: 6 loe/lisa |
