AJ
d3t
apelsin16
02.02.2009 16:26:20
common kui sa mingit uudist kopid siis vähemalt too tähtsamad kohad välja ja tõlgi mingi osa.
02.02.2009 16:27:49
Ja MS vastus...
Microsoft response to UAC "issue"
Microsoft has sent me a statement about the UAC issue in Windows 7 that was raised by bloggers Rafael Rivera and Long Zheng. Long story short, its not a vulnerability. Heres the full statement:
* This is not a vulnerability. The intent of the default configuration of UAC is that users dont get prompted when making changes to Windows settings. This includes changing the UAC prompting level.
* Microsoft has received a great deal of usability feedback on UAC prompting behavior in UAC, and has made changes in accordance with user feedback.
* UAC is a feature designed to enable users to run software at user (non-admin) rights, something we refer to as Standard User. Running software as standard user improves security reduces TCO.
* The only way this could be changed without the users knowledge is by malicious code already running on the box.
* In order for malicious code to have gotten on to the box, something else has already been breached (or the user has explicitly consented). |
Allikas: http://community.winsupersite.com/blogs/paul/archive/2009/01/31/microsoft-response-to-uac-issue.aspx
AJ
02.02.2009 16:44:41
| apelsin16 kirjutas: |
common kui sa mingit uudist kopid siis vähemalt too tähtsamad kohad välja ja tõlgi mingi osa.  |
Ma ei viitsi. Kui tahad siis loe artiklit.
ramses21
02.02.2009 16:53:29
| Alguses, kui W7 peale lasin, oli IE8 vägagi kiire. Ühel päeval muutus IE8 aga imelikuks, käivitub aeglaselt, uusi aknaid ja tabeleid teeb lahti aeglaselt, enne tükk aega mõtleb ja siis alles avab. Kas on kellelgi veel selline probleem
apelsin16
02.02.2009 16:59:29
| AJ kirjutas: |
Ma ei viitsi. Kui tahad siis loe artiklit. |
mida sa kopid neid siis igasse teemasse neid "uudiseid"
võid ju oma postcounti e-p*enist mujal ka suurendada
CoiL
02.02.2009 18:06:28
| ot: |
apelsin16, hetkel tundud sina postikogujana kes iga asja üle vingub ja teemaväliseid postitusi teeb! Kõik inimesed ei loe kõiki teemasid ja vb. ei satu sellele uudisele peale.
AJ ei ole mingi tõlkija ja HV "ajalehe" toimetaja. Pigem võta mehe ees müts maha, et ta viitsib igasugu väljamaiseid lehti tuulata ja siia uudiseid postitada!
Kui sulle ei meeldi siin uudiseid lugeda ja ei viitsi uudise originaalallikat lugeda, siis mine loe kroonikat! Teine teeb head tööd ja sina vingud... no mida veel?  |
XYZ
02.02.2009 18:18:56
| CorsairX, just head tööd talt küsitigi, s.t. ainult inglisekeelse lingi asemele midagi sisuvalgustavat kah. Kui neid lühilinke oleks ütleme nädalas üks, siis ei nuriseks keegi vist. Aga pidev selline poolik jama...
02.02.2009 18:30:01
ramses21, ennustame, flash/skype/acrobat uuendus aitab?
_________________ - londiste
Donut
02.02.2009 18:54:02
Ega eriti ju vahet pole, dumbuserid klikivad nagunii "yes" ükskõik mille peale, pigem aitaks dumbuserite vastu filter, mis keelaks süsteemipartitsioonile kirjutamise (EWF), salvestab kõik muudatused rami - ja peale restarti on jälle puhas süsteem.
02.02.2009 19:33:06
| ramses21 kirjutas: |
| Alguses, kui W7 peale lasin, oli IE8 vägagi kiire. Ühel päeval muutus IE8 aga imelikuks, käivitub aeglaselt, uusi aknaid ja tabeleid teeb lahti aeglaselt, enne tükk aega mõtleb ja siis alles avab. Kas on kellelgi veel selline probleem |
mul oli ka alguses IE8 korras, eilsest hakkas selline jama, et uued tab-id avab mõnikord tühjana. algas peale Windows Live paketi uninstalli.
_________________ "a rental car, three cheeseburgers and a head start."
viimati muutis SKG 02.02.2009 19:35:08, muudetud 1 kord |
Steff.
02.02.2009 19:35:04
Imelik, Täheldasin täna muusikatkuulates et kui ma näiteks IEga hakkan alla kerima lehte siis tuleb kõlaritesse imelik sahin.
_________________ Kui sind ei ole siin...Siis sind ei ole olemaski! |
newarvuti
02.02.2009 19:38:11
Ma kasutan seda, töötab hästi, vahepeal oli interneti probleem, enam mitte.
Võti töötab 1. augustini.
Donut
02.02.2009 19:42:28
| Steff. kirjutas: |
Imelik, Täheldasin täna muusikatkuulates et kui ma näiteks IEga hakkan alla kerima lehte siis tuleb kõlaritesse imelik sahin.  |
See on integreeritud helikaardi probleem.
Steff.
02.02.2009 19:50:17
Donut, See tähendab et mul said kõrvad puhtaks alles nüüd ja ma hakkasin kuulma siis. Aga üldiselt saab seda kuidagi vältida?
2 trini
02.02.2009 19:53:33
| Skeptik kirjutas: |
| mul oli ka alguses IE8 korras, eilsest hakkas selline jama, et uued tab-id avab mõnikord tühjana. algas peale Windows Live paketi uninstalli. |
No selge nüüd siis mis seda minul ka põhjustas, sama asi, et lasin Live Essentials maha ja IE läks lolliks peale seda Tegin format...
Format oleks ma tegelt niikuinii teinud, et eemaldada vLite'ga Mediacenter. See sunnik startis ennast taustal igas asendis, killi protsessi maha niipalju kui tahad, varsti jälle Taskmanager'i all olemas, kuna kasutan Terratec'i Home Cinema siis pole seda jura vaja.
Donut
02.02.2009 20:11:42
| Steff. kirjutas: |
| Donut, See tähendab et mul said kõrvad puhtaks alles nüüd ja ma hakkasin kuulma siis. Aga üldiselt saab seda kuidagi vältida? |
Kui Line-in, microphone jne. ära mute-da siis peaks ka sahin kaduma, seitsmel peaks selleks olema sndvol.exe aga seal ma ei näe küll selliseid võimalusi(ma ei saa aru, on vaja koguaeg asju ringi tõsta, kui nad olid xp'l täiesti hästi kättesaadavad), võid proovida ka ASIO't või kernel streaming võibolla aitab.
02.02.2009 21:04:46
| taikonaut kirjutas: |
| Lan jah. Firewall ei tohiks segada. A Dx probleem võib küll olla. |
Ka Vegas 1'l oli täpselt sama piirang - pead dx9 forcema.
02.02.2009 22:17:06
http://web.zone.ee/indrekp6/desk/20090202.jpg?2
siit peaks selguma miks mina windowsi sisseehitatud programme kasutan, kahjuks ei suuda vlc, bullshit player ega ka winamp mulle puldi abil nii pilte, videot, muusikat korraga ega ka kordamööda kuvada/mängida.
tegelikult juhib kogu seda kama ainult üks harmony pult, teised näidiseks reas, palju mul harmonyta tegemist oleks.
teemasse siis 7 on windows mce puhul kõva edasiminek, nagu räägitud, h264 digitv tugi mis nüüd sees on ning hd videote tugi kaasaarvatud divx, xvid. üks puudus on mkv konteiner millele pole veel isegi korralikku 64bit splitterit ning mingil põhjusel sellest ei piisa, sealt ei oska ta h264 enam välja mängida ning coreavc tuleb lisaks peale panna. Ise panin siiski ka ffdshow kus eraldi DD ja DTS heli otse ressiiverisse lasen.
ühes arvutis siis kõikvõimas meediamängija ning mängumasin, peale selle saab netis käia ükskõik kas siis diivanil või laua taga.
OT. veel: VLC on küll hea universaalne mängija mis ei vaja lisakoodekeid kuid HD materjali ning DVDsid näitab ta küll kohutava kvaliteediga, ainuke milleks ma teda kasutan on DTV striimi vaatamiseks või striimi tekitamiseks.
Mutiq
03.02.2009 08:22:19
| Kas keegi build7025 on juba proovinud?
suur13
03.02.2009 10:33:26
| indrekp kirjutas: |
| teemasse siis 7 on windows mce puhul kõva edasiminek, nagu räägitud, h264 digitv tugi mis nüüd sees on ning hd videote tugi kaasaarvatud divx, xvid. üks puudus on mkv konteiner millele pole veel isegi korralikku 64bit splitterit ning mingil põhjusel sellest ei piisa, sealt ei oska ta h264 enam välja mängida ning coreavc tuleb lisaks peale panna. Ise panin siiski ka ffdshow kus eraldi DD ja DTS heli otse ressiiverisse lasen. |
Ot, kuidas selle subtiitrite näitamisega ikkagi on ?
Media Centris olemas ? Ka 64-bit ?
03.02.2009 13:18:50
| suur13 kirjutas: |
| indrekp kirjutas: |
Media Centris olemas ? Ka 64-bit ? |
MKV embedded subtiitreid näitab kenasti, aga eraldi SRT/SUB laiendiga teksti pole ma veel WMP/MC-s alla saanud
| 2 trini kirjutas: |
| Skeptik kirjutas: |
Format oleks ma tegelt niikuinii teinud, et eemaldada vLite'ga Mediacenter. See sunnik startis ennast taustal igas asendis, killi protsessi maha niipalju kui tahad, varsti jälle Taskmanager'i all olemas, kuna kasutan Terratec'i Home Cinema siis pole seda jura vaja. |
hee... ma sain korda omal. enne tegin Windows Live Essentials pakile repairi, aga see ei aidanud. tegin täieliku uninstalli ja reinstalli (Messenger+Mail+Movie Maker Beta+Photo Gallery) ning nüüd enam seda anomaaliat IE8-ga pole. ilmselt ei meeldinud talle see, et ma mingi komponendi sealt Essentials pakist maha lasin.
recent
03.02.2009 14:13:20
Krt, mul siuke kala et.. sätin Computer alt, Map Network driveks serveri "share" osa, peale restarti, aga ütleb et unable to connect, ja et a'la pane uuesti user name ja pw ! kuigi serveri sätetest authentimine maha võetud
Kui teen Desktopi shortcut otse share kausta, siis kõik toimib !
Lemmy
03.02.2009 14:41:43
| DeTHiCa. kirjutas: |
| .:RAITZ::. kirjutas: |
| Oskab keegi aidata? BS.Playeriga video käima pannes on pilt must aga subtiitrid on näha, mida teha? |
options - preferences - video - video rendering - rendering mode - internal rendering RGB overlay (seal valikuid mitu, üks nendest näitas veidi sakilist pilti, teine oli ilus. ise vali millist tahad) |
RGB overlay pole vast kõige parem variant. Esimene ja viimane tundusid OK'd, praegu peast nimetusi ei mäleta. Settingute muutmiseks tuli "run as administrator" käima lasta, muidu ei salvestanud muudatusi ära. Lisaks pidin veel ffdshow.ax uuesti registreerima, muidu ei osand vanemaid DIV3, DIV4 jne. asju mängida.
_________________ Vähem möla, pikem samm! |
recent
03.02.2009 18:32:11
Krt, päevläbi ainult probleemid..
natuke vara vist veel W7'me jaoks, eks ta Beta kah alles
ilus ja mugav on kasutada, aga kui mingeid imevidinaid tahad siis on kellad
Ma lähen veel Vista'le tagasi
Kuni mõni töökindlam versioon välja tuleb.
sandvik
03.02.2009 21:45:52
Huvitav jah et Build 6801 oli igati korralik ja paljulubav Aga avalik beta täitsa vigane
jnt
03.02.2009 21:49:04
sandvik, bug'id olid veel lisamata lihtsalt.
sakinaga
03.02.2009 21:51:30
Endal ka betaga olnud 2 probleemi.
1) siiamaani lahendamata: rFactor jookseb kokku aeg-ajalt ja kogu arvuti koos temaga, aitab restart..
2) videokaardi driver hakkas näkku panema. Selle sain kiiresti korda.
trebla
03.02.2009 21:56:22
Toetan tomorrow arvamust.
olen kõik käima saanud, ka vana IrDA junni, Polar Powertraineri, Nokia softid, Tomtom home, tootjapolse draiveritoeta plate draiverid käima jne.
_________________ Having a smoking section in a restaurant is like having a peeing section in a swimming pool.
velo.clubbers.ee |
sandvik
03.02.2009 22:04:48
| tomorrow kirjutas: |
| sandvik kirjutas: |
Huvitav jah et Build 6801 oli igati korralik ja paljulubav Aga avalik beta täitsa vigane  |
Viga pigem ekraani ja tooli vahel võis siis mingi veider raua mitteühilduvus .Endal siiani korras.Pmst kõikidele vigadele mis olen leidnud on ka fixid juba olemas(v.a mõned väiksemad asjad) |
Nii loll ma nüüd ka ei ole aga eks niisama targutajaid on siin foorumis ennegi ette tulnud Aga eks minu viga et ma ei väljendanud ennas õigesti "Tahtsin öelda ,et Pre Beta 6801 töötas kohe üllatavalt hästi aga beta 7000 ei tööta "Muidugi
kõike saab siluda.Mõni on lihtsalt liiga kaua seal TOOLI JA ARVUTI VAHEL OLNUD
Look Right
Anna vin
03.02.2009 22:13:39
Krt ma 6801 peal olin üsna vähe a kõik töötas küll. 7000 on ka hästi töötanud, ainukesed pangestumised on tulnud vaid enda näppimiste tõttu
_________________ Ehitusprojektid ja konstruktiivsed lahendused HV kasutajatele soodsamalt
M: Zafira A/Astra G põhjakaitse - 30€ |
G80
04.02.2009 01:06:14
Kui reaalselt ostma hakkaks siis vajaduste poolest:
Windows 7 Professional (superset of Home)
Market: Mainstream retail market
Key features: Domain join, Remote Desktop host, location aware printing, EFS, Mobility Center, Presentation Mode, Offline Folders, Media Center
What's missing: BitLocker, BitLocker To Go, AppLocker, Direct Access, Branche Cache, MUI language packs, boot from VHD |
Kui on muud võimalused(mis mul on - mitte piraatlus) siis:
Windows 7 Ultimate
Market: Retail market, limited availability
Key features: BitLocker, BitLocker To Go, AppLocker, Direct Access, Branche Cache, MUI language packs, boot from VHD
What's missing: Volume licensing |
etk
04.02.2009 01:21:07
endal ka ei ole suuremaid probleeme 7000-ga olnud, kui pangestus siis oma vea tõttu või omalt poolt installitud programmi mitteühilduvuse tõttu(torrent programmid ei olnud võimelised eelnevalt tekitatud poolikuid torrent faile jätkama ja pangestas arvuti(lahendus- muutsin vastavate failide/folderite share optionseid))
ainus jama mis viimasel ajal on tekkinud, aga ka ilmselt mingit omategevusest on see, et OS muutub väga aeglaseks ja jõnksuvaks peale pikemat käimashoidmist või hibernate panekut. Ise kahtlustan Visual Studiot peale mille käivitamist/sulgemist on märgatavalt näha jõnksumist.
mats198
04.02.2009 15:12:40
Probleem siis järgmine.
Ei lase Adobe Illustraatoris töid ära salvestada kas sellele on ka mignit fixi või peaks lihtsalt reinstalli vms proovima?
Look Right
Anna vin
04.02.2009 15:23:04
A kui jookseb comp. mode'is?
mats198
04.02.2009 16:00:18
| comp. mode ka ei teinud asja paremaks
Look Right
Anna vin
04.02.2009 17:14:17
No sa võid ju reinstali proovida. A mingit veateadet ei anna? Event Viewer ka ei anna midagi teada?
trebla
04.02.2009 17:32:52
just. milles see "ei lase salvestada" avaldub?
velo.clubbers.ee |
Syncmahv
05.02.2009 00:04:20
| Kuidas selle windows 7ga siis on, väga hullus beta staatuses hetkel? või kui uuele arvutile (Core i7 jms) hetkel OSi vaatama hakata siis kas vaadata mingi vista poole(mida väga üldse kohe ei tahaks) või õnnestuks juba selle praeguse saadaval win 7 peale lasta, mingi driverite toetus asjale olemas jms? mängud töötavad jms? lihtsalt uurin hetkel. kuna uus arvuti kohe järgminenädal tulemas ja kuna win xp otseselt kasu pole DX10 ning 6gb mälu kasutamiseks siis on vaja vaadata nende kahe võimaluse poole....
DeTHiCa.
05.02.2009 00:13:20
Syncmahv, kui meeldib pidevalt millegagi jännata siis võibolla win7 isegi kõlbab.
100% töötamist ei saa keegi garanteerida, mingisuguseid jamasid tuleb nagunii. kui on uus riistvara siis sellele võib puudulik support kaa olla.
Look Right
Anna vin
05.02.2009 00:38:23
Kindluse mõttes võid ju Vista peale lasta, kuna 7'ga või tekkida draiveriprobleeme ja kahtlasi pangestumisi. Progedega (sh mängudega) on nii ja naa. Üks räägib, et temal mingi proge ei lähe tööle, teisel jälle läheb.
recent
05.02.2009 23:57:06
| Kindluse mõttes võid ju Vista peale lasta, kuna 7'ga või tekkida draiveriprobleeme ja kahtlasi pangestumisi. Progedega (sh mängudega) on nii ja naa. Üks räägib, et temal mingi proge ei lähe tööle, teisel jälle läheb. |
See on jah miskipärast nii individuaalne, mul ei läind pooled asjad käima korralikult,
isegi winamp pangestus..
ja teistel on kõik
Aga kihvt on W7, võiks juba esimene sats välja tulla, sutsu parandatud versioon.
AJ
06.02.2009 10:50:54
Windows 7 -me hinnad
* Windows 7 Starter - $ 199,95
* Windows 7 Home Premium - $ 259,95
* Windows 7 Professional - $ 299.95
* Windows 7 Ultimate-$ 319,95
* Windows 7 Ettevõtlus - teadmata veel |
Pricing of Windows 7 Detailed
http://en.expreview.com/2009/02/06/pricing-of-windows-7-detailed.html
Google tõlge > link
XYZ
06.02.2009 11:35:54
MS-le see meeldib, sest turustuskulud on samad aga suure koguse pealt tuleb raha ikkagi rohkem.
Ahjaa, äsja vaatasin ühte võrdlust:
"Professional tuleb müügile üle maailma. Parem võrguõhenduste haldur, andmekaitsefunktsioonid koos üle võrgu tagavarakoopia tegemiste võimalusega ja failisüsteemi krüpteerimisega ja täiustatud printimisfunktsioonid.
Ultimate tuleb müügile üle maailma. Kohandatud ettevõtete vajaduste järgi, sealhulgas igakülgne tugi erinevatele võrgufunktsioonidele ja piirangud volitusteta tarkvara kasutamisele."
Ultimate puhul jutt piirangutest volitusteta tarkvarale ja prof. versioonil see puudu ---- võib juhtuda, et mitmed ei soovi seda piirangut automaatselt tööle ja valivad sel põhjusel siiski prof. versiooni. Saab näha.
G80
07.02.2009 10:13:55
Prof ja Ultimate hinnavahe nii väike on, siis keegi ei võta Prof .Kõik selle hinnaklassi ostjad võtavad siis juba Ultimate  |
Eks mõned "profid" ikka ostavad. Aga pigem võtta juba Ultimate.
