uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 (arutelu ja probleemid) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 52, 53, 54 ... 372, 373, 374  järgmine
AJ
AJ
sõnum 02.02.2009 15:59:07 vasta tsitaadiga
Windows 7 UAC Leaves Door Open for Attack
http://www.dailytech.com/Windows+7+UAC+Leaves+Door+Open+for+Attacks/article14127.htm
d3t
d3t
sõnum 02.02.2009 16:22:15 vasta tsitaadiga
AJ, http://battleit.eu/tag/windows-7-rajab-teed-pahavarale/
IsAiUseful.com - tee oma esimesed sammud kohaliku AI suunas
apelsin16
apelsin16
sõnum 02.02.2009 16:26:20 vasta tsitaadiga
AJ kirjutas:
common kui sa mingit uudist kopid siis vähemalt too tähtsamad kohad välja ja tõlgi mingi osa. icon_rolleyes.gif
sõnum 02.02.2009 16:27:49 vasta tsitaadiga
AJ kirjutas:
d3t kirjutas:
Ja MS vastus...
Microsoft response to UAC "issue"
Microsoft has sent me a statement about the UAC “issue” in Windows 7 that was raised by bloggers Rafael Rivera and Long Zheng. Long story short, it’s not a vulnerability. Here’s the full statement:
* This is not a vulnerability. The intent of the default configuration of UAC is that users don’t get prompted when making changes to Windows settings. This includes changing the UAC prompting level.
* Microsoft has received a great deal of usability feedback on UAC prompting behavior in UAC, and has made changes in accordance with user feedback.
* UAC is a feature designed to enable users to run software at user (non-admin) rights, something we refer to as Standard User. Running software as standard user improves security reduces TCO.
* The only way this could be changed without the user’s knowledge is by malicious code already running on the box.
* In order for malicious code to have gotten on to the box, something else has already been breached (or the user has explicitly consented).
Allikas: http://community.winsupersite.com/blogs/paul/archive/2009/01/31/microsoft-response-to-uac-issue.aspx
AJ
AJ
sõnum 02.02.2009 16:44:41 vasta tsitaadiga
apelsin16 kirjutas:
AJ kirjutas:
Ma ei viitsi. Kui tahad siis loe artiklit.
ramses21
sõnum 02.02.2009 16:53:29 vasta tsitaadiga
Alguses, kui W7 peale lasin, oli IE8 vägagi kiire. Ühel päeval muutus IE8 aga imelikuks, käivitub aeglaselt, uusi aknaid ja tabeleid teeb lahti aeglaselt, enne tükk aega mõtleb ja siis alles avab. Kas on kellelgi veel selline probleem
apelsin16
apelsin16
sõnum 02.02.2009 16:59:29 vasta tsitaadiga
AJ kirjutas:
apelsin16 kirjutas:
AJ kirjutas:
mida sa kopid neid siis igasse teemasse neid "uudiseid"
CoiL
CoiL
sõnum 02.02.2009 18:06:28 vasta tsitaadiga
ot:
apelsin16, hetkel tundud sina postikogujana kes iga asja üle vingub ja teemaväliseid postitusi teeb! Kõik inimesed ei loe kõiki teemasid ja vb. ei satu sellele uudisele peale.
AJ ei ole mingi tõlkija ja HV "ajalehe" toimetaja. Pigem võta mehe ees müts maha, et ta viitsib igasugu väljamaiseid lehti tuulata ja siia uudiseid postitada!
Kui sulle ei meeldi siin uudiseid lugeda ja ei viitsi uudise originaalallikat lugeda, siis mine loe kroonikat! Teine teeb head tööd ja sina vingud... no mida veel? icon_confused.gif
XYZ
XYZ
sõnum 02.02.2009 18:18:56 vasta tsitaadiga
CorsairX, just head tööd talt küsitigi, s.t. ainult inglisekeelse lingi asemele midagi sisuvalgustavat kah. Kui neid lühilinke oleks ütleme nädalas üks, siis ei nuriseks keegi vist. Aga pidev selline poolik jama...
sõnum 02.02.2009 18:30:01 vasta tsitaadiga
ramses21, ennustame, flash/skype/acrobat uuendus aitab? icon_smile.gif
- londiste
Donut
Donut
sõnum 02.02.2009 18:54:02 vasta tsitaadiga
AJ kirjutas:
Ega eriti ju vahet pole, dumbuserid klikivad nagunii "yes" ükskõik mille peale, pigem aitaks dumbuserite vastu filter, mis keelaks süsteemipartitsioonile kirjutamise (EWF), salvestab kõik muudatused rami - ja peale restarti on jälle puhas süsteem.
sõnum 02.02.2009 19:33:06 vasta tsitaadiga
ramses21 kirjutas:
mul oli ka alguses IE8 korras, eilsest hakkas selline jama, et uued tab-id avab mõnikord tühjana. algas peale Windows Live paketi uninstalli.
viimati muutis SKG 02.02.2009 19:35:08, muudetud 1 kord
Steff.
Steff.
sõnum 02.02.2009 19:35:04 vasta tsitaadiga
Imelik, Täheldasin täna muusikatkuulates et kui ma näiteks IEga hakkan alla kerima lehte siis tuleb kõlaritesse imelik sahin. icon_rolleyes.gif
Kui sind ei ole siin...Siis sind ei ole olemaski!
newarvuti
sõnum 02.02.2009 19:38:11 vasta tsitaadiga
Ma kasutan seda, töötab hästi, vahepeal oli interneti probleem, enam mitte.
Võti töötab 1. augustini.
Donut
Donut
sõnum 02.02.2009 19:42:28 vasta tsitaadiga
Steff. kirjutas:
See on integreeritud helikaardi probleem.
Steff.
Steff.
sõnum 02.02.2009 19:50:17 vasta tsitaadiga
Donut, See tähendab et mul said kõrvad puhtaks alles nüüd ja ma hakkasin kuulma siis. Aga üldiselt saab seda kuidagi vältida?
2 trini
2 trini
sõnum 02.02.2009 19:53:33 vasta tsitaadiga
Skeptik kirjutas:
No selge nüüd siis mis seda minul ka põhjustas, sama asi, et lasin Live Essentials maha ja IE läks lolliks peale seda icon_neutral.gif Tegin format...
Format oleks ma tegelt niikuinii teinud, et eemaldada vLite'ga Mediacenter. See sunnik startis ennast taustal igas asendis, killi protsessi maha niipalju kui tahad, varsti jälle Taskmanager'i all olemas, kuna kasutan Terratec'i Home Cinema siis pole seda jura vaja.
Donut
Donut
sõnum 02.02.2009 20:11:42 vasta tsitaadiga
Steff. kirjutas:
Kui Line-in, microphone jne. ära mute-da siis peaks ka sahin kaduma, seitsmel peaks selleks olema sndvol.exe aga seal ma ei näe küll selliseid võimalusi(ma ei saa aru, on vaja koguaeg asju ringi tõsta, kui nad olid xp'l täiesti hästi kättesaadavad), võid proovida ka ASIO't või kernel streaming võibolla aitab.
sõnum 02.02.2009 21:04:46 vasta tsitaadiga
taikonaut kirjutas:
Lan jah. Firewall ei tohiks segada. A Dx probleem võib küll olla.
Ka Vegas 1'l oli täpselt sama piirang - pead dx9 forcema.
sõnum 02.02.2009 22:17:06 vasta tsitaadiga
http://web.zone.ee/indrekp6/desk/20090202.jpg?2
siit peaks selguma miks mina windowsi sisseehitatud programme kasutan, kahjuks ei suuda vlc, bullshit player ega ka winamp mulle puldi abil nii pilte, videot, muusikat korraga ega ka kordamööda kuvada/mängida.
tegelikult juhib kogu seda kama ainult üks harmony pult, teised näidiseks reas, palju mul harmonyta tegemist oleks.
teemasse siis 7 on windows mce puhul kõva edasiminek, nagu räägitud, h264 digitv tugi mis nüüd sees on ning hd videote tugi kaasaarvatud divx, xvid. üks puudus on mkv konteiner millele pole veel isegi korralikku 64bit splitterit ning mingil põhjusel sellest ei piisa, sealt ei oska ta h264 enam välja mängida ning coreavc tuleb lisaks peale panna. Ise panin siiski ka ffdshow kus eraldi DD ja DTS heli otse ressiiverisse lasen.
ühes arvutis siis kõikvõimas meediamängija ning mängumasin, peale selle saab netis käia ükskõik kas siis diivanil või laua taga.
OT. veel: VLC on küll hea universaalne mängija mis ei vaja lisakoodekeid kuid HD materjali ning DVDsid näitab ta küll kohutava kvaliteediga, ainuke milleks ma teda kasutan on DTV striimi vaatamiseks või striimi tekitamiseks.
Mutiq
sõnum 03.02.2009 08:22:19 vasta tsitaadiga
Kas keegi build7025 on juba proovinud?
sõnum 03.02.2009 08:24:52 vasta tsitaadiga
Mutiq kirjutas:
Siin vaevalt,et keegi on.Ise ootan vist RC ära.Ehk aprillis saab näppida juba icon_razz1.gif .Beta 7000 töötab juba üle kuu aja eeskujulikult Dualboodis Vistaga 8) thumbs_up.gif
suur13
suur13
sõnum 03.02.2009 10:33:26 vasta tsitaadiga
indrekp kirjutas:
Ot, kuidas selle subtiitrite näitamisega ikkagi on ?
Media Centris olemas ? Ka 64-bit ?
sõnum 03.02.2009 13:18:50 vasta tsitaadiga
suur13 kirjutas:
indrekp kirjutas:
MKV embedded subtiitreid näitab kenasti, aga eraldi SRT/SUB laiendiga teksti pole ma veel WMP/MC-s alla saanud
2 trini kirjutas:
Skeptik kirjutas:
hee... ma sain korda omal. enne tegin Windows Live Essentials pakile repairi, aga see ei aidanud. tegin täieliku uninstalli ja reinstalli (Messenger+Mail+Movie Maker Beta+Photo Gallery) ning nüüd enam seda anomaaliat IE8-ga pole. thumbs_up.gif ilmselt ei meeldinud talle see, et ma mingi komponendi sealt Essentials pakist maha lasin. icon_rolleyes.gif
recent
recent
sõnum 03.02.2009 14:13:20 vasta tsitaadiga
Krt, mul siuke kala et.. sätin Computer alt, Map Network driveks serveri "share" osa, peale restarti, aga ütleb et unable to connect, ja et a'la pane uuesti user name ja pw ! icon_razz.gif kuigi serveri sätetest authentimine maha võetud icon_neutral.gif
Kui teen Desktopi shortcut otse share kausta, siis kõik toimib !
Lemmy
sõnum 03.02.2009 14:41:43 vasta tsitaadiga
DeTHiCa. kirjutas:
.:RAITZ::. kirjutas:
Oskab keegi aidata? BS.Playeriga video käima pannes on pilt must aga subtiitrid on näha, mida teha?
options - preferences - video - video rendering - rendering mode - internal rendering RGB overlay (seal valikuid mitu, üks nendest näitas veidi sakilist pilti, teine oli ilus. ise vali millist tahad)
RGB overlay pole vast kõige parem variant. Esimene ja viimane tundusid OK'd, praegu peast nimetusi ei mäleta. Settingute muutmiseks tuli "run as administrator" käima lasta, muidu ei salvestanud muudatusi ära. Lisaks pidin veel ffdshow.ax uuesti registreerima, muidu ei osand vanemaid DIV3, DIV4 jne. asju mängida.
Vähem möla, pikem samm!
recent
recent
sõnum 03.02.2009 18:32:11 vasta tsitaadiga
ilus ja mugav on kasutada, aga kui mingeid imevidinaid tahad siis on kellad icon_neutral.gif
Kuni mõni töökindlam versioon välja tuleb.
sandvik
sandvik
sõnum 03.02.2009 21:45:52 vasta tsitaadiga
Huvitav jah et Build 6801 oli igati korralik ja paljulubav Aga avalik beta täitsa vigane icon_eek.gif
jnt
jnt
sõnum 03.02.2009 21:49:04 vasta tsitaadiga
sõnum 03.02.2009 21:50:30 vasta tsitaadiga
sandvik kirjutas:
Viga pigem ekraani ja tooli vahel võis siis mingi veider raua mitteühilduvus icon_rolleyes.gif .Endal siiani korras.Pmst kõikidele vigadele mis olen leidnud on ka fixid juba olemas(v.a mõned väiksemad asjad)
sakinaga
sõnum 03.02.2009 21:51:30 vasta tsitaadiga
Endal ka betaga olnud 2 probleemi.
1) siiamaani lahendamata: rFactor jookseb kokku aeg-ajalt ja kogu arvuti koos temaga, aitab restart..
2) videokaardi driver hakkas näkku panema. Selle sain kiiresti korda.
trebla
trebla
sõnum 03.02.2009 21:56:22 vasta tsitaadiga
Toetan tomorrow arvamust.
olen kõik käima saanud, ka vana IrDA junni, Polar Powertraineri, Nokia softid, Tomtom home, tootjapolse draiveritoeta plate draiverid käima jne.
Having a smoking section in a restaurant is like having a peeing section in a swimming pool.
velo.clubbers.ee
sandvik
sandvik
sõnum 03.02.2009 22:04:48 vasta tsitaadiga
tomorrow kirjutas:
sandvik kirjutas:
Nii loll ma nüüd ka ei ole aga eks niisama targutajaid on siin foorumis ennegi ette tulnud icon_biggrin.gif Aga eks minu viga et ma ei väljendanud ennas õigesti "Tahtsin öelda ,et Pre Beta 6801 töötas kohe üllatavalt hästi aga beta 7000 ei tööta "Muidugi
kõike saab siluda.Mõni on lihtsalt liiga kaua seal TOOLI JA ARVUTI VAHEL OLNUD icon_biggrin.gif
Look Right
Anna vin
Look Right
sõnum 03.02.2009 22:13:39 vasta tsitaadiga
Krt ma 6801 peal olin üsna vähe a kõik töötas küll. 7000 on ka hästi töötanud, ainukesed pangestumised on tulnud vaid enda näppimiste tõttu icon_biggrin.gif
G80
G80
sõnum 04.02.2009 00:46:29 vasta tsitaadiga
Windows 7 SKUs Made Official
http://www.techpowerup.com/84046/Windows_7_SKUs_Made_Official.html
Ära siia kliki
sõnum 04.02.2009 01:06:14 vasta tsitaadiga
G80 kirjutas:
Kui reaalselt ostma hakkaks siis vajaduste poolest:
Windows 7 Professional (superset of Home)
Market: Mainstream retail market
Key features: Domain join, Remote Desktop host, location aware printing, EFS, Mobility Center, Presentation Mode, Offline Folders, Media Center
What's missing: BitLocker, BitLocker To Go, AppLocker, Direct Access, Branche Cache, MUI language packs, boot from VHD
Kui on muud võimalused(mis mul on - mitte piraatlus) siis:
Windows 7 Ultimate
Market: Retail market, limited availability
Key features: BitLocker, BitLocker To Go, AppLocker, Direct Access, Branche Cache, MUI language packs, boot from VHD
What's missing: Volume licensing
etk
etk
sõnum 04.02.2009 01:21:07 vasta tsitaadiga
endal ka ei ole suuremaid probleeme 7000-ga olnud, kui pangestus siis oma vea tõttu või omalt poolt installitud programmi mitteühilduvuse tõttu(torrent programmid ei olnud võimelised eelnevalt tekitatud poolikuid torrent faile jätkama ja pangestas arvuti(lahendus- muutsin vastavate failide/folderite share optionseid))
ainus jama mis viimasel ajal on tekkinud, aga ka ilmselt mingit omategevusest on see, et OS muutub väga aeglaseks ja jõnksuvaks peale pikemat käimashoidmist või hibernate panekut. Ise kahtlustan Visual Studiot peale mille käivitamist/sulgemist on märgatavalt näha jõnksumist.
mats198
sõnum 04.02.2009 15:12:40 vasta tsitaadiga
Probleem siis järgmine.
Ei lase Adobe Illustraatoris töid ära salvestada kas sellele on ka mignit fixi või peaks lihtsalt reinstalli vms proovima?
Look Right
Anna vin
Look Right
sõnum 04.02.2009 15:23:04 vasta tsitaadiga
A kui jookseb comp. mode'is?
mats198
sõnum 04.02.2009 16:00:18 vasta tsitaadiga
comp. mode ka ei teinud asja paremaks
Look Right
Anna vin
Look Right
sõnum 04.02.2009 17:14:17 vasta tsitaadiga
No sa võid ju reinstali proovida. A mingit veateadet ei anna? Event Viewer ka ei anna midagi teada?
trebla
trebla
sõnum 04.02.2009 17:32:52 vasta tsitaadiga
just. milles see "ei lase salvestada" avaldub?
velo.clubbers.ee
Syncmahv
Syncmahv
sõnum 05.02.2009 00:04:20 vasta tsitaadiga
Kuidas selle windows 7ga siis on, väga hullus beta staatuses hetkel? või kui uuele arvutile (Core i7 jms) hetkel OSi vaatama hakata siis kas vaadata mingi vista poole(mida väga üldse kohe ei tahaks) või õnnestuks juba selle praeguse saadaval win 7 peale lasta, mingi driverite toetus asjale olemas jms? mängud töötavad jms? lihtsalt uurin hetkel. kuna uus arvuti kohe järgminenädal tulemas ja kuna win xp otseselt kasu pole DX10 ning 6gb mälu kasutamiseks siis on vaja vaadata nende kahe võimaluse poole....
DeTHiCa.
DeTHiCa.
sõnum 05.02.2009 00:13:20 vasta tsitaadiga
Syncmahv, kui meeldib pidevalt millegagi jännata siis võibolla win7 isegi kõlbab.
100% töötamist ei saa keegi garanteerida, mingisuguseid jamasid tuleb nagunii. kui on uus riistvara siis sellele võib puudulik support kaa olla.
Look Right
Anna vin
Look Right
sõnum 05.02.2009 00:38:23 vasta tsitaadiga
Kindluse mõttes võid ju Vista peale lasta, kuna 7'ga või tekkida draiveriprobleeme ja kahtlasi pangestumisi. Progedega (sh mängudega) on nii ja naa. Üks räägib, et temal mingi proge ei lähe tööle, teisel jälle läheb.
recent
recent
sõnum 05.02.2009 23:57:06 vasta tsitaadiga
taikonaut kirjutas:
See on jah miskipärast nii individuaalne, mul ei läind pooled asjad käima korralikult,
Aga kihvt on W7, võiks juba esimene sats välja tulla, sutsu parandatud versioon.
AJ
AJ
sõnum 06.02.2009 10:50:54 vasta tsitaadiga
Windows 7 -me hinnad
* Windows 7 Starter - $ 199,95
* Windows 7 Home Premium - $ 259,95
* Windows 7 Professional - $ 299.95
* Windows 7 Ultimate-$ 319,95
* Windows 7 Ettevõtlus - teadmata veel
Pricing of Windows 7 Detailed
http://en.expreview.com/2009/02/06/pricing-of-windows-7-detailed.html
Google tõlge > link
sõnum 06.02.2009 10:52:37 vasta tsitaadiga
AJ kirjutas:
Google tõlge > link
Prof ja Ultimate hinnavahe nii väike on, siis keegi ei võta Prof icon_rolleyes.gif .Kõik selle hinnaklassi ostjad võtavad siis juba Ultimate icon_lol.gif
XYZ
XYZ
sõnum 06.02.2009 11:35:54 vasta tsitaadiga
MS-le see meeldib, sest turustuskulud on samad aga suure koguse pealt tuleb raha ikkagi rohkem.
Ahjaa, äsja vaatasin ühte võrdlust:
"Professional tuleb müügile üle maailma. Parem võrguõhenduste haldur, andmekaitsefunktsioonid koos üle võrgu tagavarakoopia tegemiste võimalusega ja failisüsteemi krüpteerimisega ja täiustatud printimisfunktsioonid.
Ultimate tuleb müügile üle maailma. Kohandatud ettevõtete vajaduste järgi, sealhulgas igakülgne tugi erinevatele võrgufunktsioonidele ja piirangud volitusteta tarkvara kasutamisele."
Ultimate puhul jutt piirangutest volitusteta tarkvarale ja prof. versioonil see puudu ---- võib juhtuda, et mitmed ei soovi seda piirangut automaatselt tööle ja valivad sel põhjusel siiski prof. versiooni. Saab näha.
G80
G80
sõnum 07.02.2009 10:13:55 vasta tsitaadiga
tomorrow kirjutas:
AJ kirjutas:
Google tõlge > link
Eks mõned "profid" ikka ostavad. icon_lol.gif Aga pigem võtta juba Ultimate. thumbs_up.gif
Ära siia kliki
uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 (arutelu ja probleemid) mine lehele eelmine  1, 2, 3 ... 52, 53, 54 ... 372, 373, 374  järgmine
