_marek
15.12.2008 22:19:01
Tegu oli Zuumboxist tuleva 1080i HDMI upscalingu läbinud Kanal2 signaaliga (mingi film jooksis parajasti).
Kõrval seisev 7-seeria Philips/6-seeria Samsa olid ideaalselt sujuva pildiga, samas kui Sony W4500 värises täpselt sama moodi kui mõni odavam 3-seeria Samsung, kus mingit pilditöötlust ka paberil pole (kuigi Sony enda väitel on tal igasuguseid toredaid 24p programme)
118 |
Anti112
15.12.2008 22:50:33
| pealuu kirjutas: |
| see peaks olema clouding, mille üle nurisetakse (mitte ghosting) |
Ikka veel cloudingu probleemid Sonyl?
Krt mitu aastat juba nendest juttu olnud ja ikka nad ei suuda seda ära fixida?
114 |
pealuu
15.12.2008 22:59:14
samas sony "fix" on tõeliselt elegantne (mida nad soovitavad fotode järgi otsustades ka üsna ekstreemsete juhtumite korral ja ohvrite sõnul on sellest NULL abi):
Statement from Sony: Sony BRAVIA KDL-46W4500 TV Clouding (Uniformity)
To achieve a high level of performance and picture clarity, Sony
utilizes a very bright backlight setting. This helps deliver the
brightest picture possible, as well as exceptional picture clarity even
with the darkest image sources.
However, under certain dark viewing conditions, the setting may cause
the screens on some of these televisions to exhibit a slight uneven
uniformity, especially for a blank screen with no video source. This
condition is not normally visible under typical viewing situations, such
as watching movies or television programs, and should not affect viewing
experience.
Should customers find that this condition affects their viewing
enjoyment; we suggest adjusting the following settings to minimize this
condition:
1) Setup Menu - select - Light Sensor: ON
2) Setup Menu - select - Power Saving: Low or High
3) Picture Menu -- Reduce the Backlight Level eg 'Standard' or 'Cinema
mode' (Factory Setting = 'MAX')
SONY has its own criteria for uneven uniformity which was created from
past experience that satisfies a high majority of our customers.
SONY believes the level of uneven uniformity is not defective and does
not plan to recall any of its products.
| Kommentaarid: 211 loe/lisa |
170 |
a1
15.12.2008 23:03:03
| Anti112 kirjutas: |
Krt mitu aastat juba nendest juttu olnud ja ikka nad ei suuda seda ära fixida?  |
Fiximine pole probleem, hind on probleem.
PILT
ehk siis jälle 1+ plasmale
| Kommentaarid: 39 loe/lisa |
38 |
pealuu
15.12.2008 23:29:36
lihtsalt tuleb poes oma silmaga üle vaadata pilt. või siis leppida kindlalt kokku, et kui peaks esinema selliseid defekte, siis naaseb telekas kiiremas korras tagasi ja ringivahetamise või raha tagastamisega ei ole miskeid aga'sid. kui seda ei tee, siis tuleks olla valmis loteriiks.
plasmast: mõned kuud vana pana. omaniku sõnul on see jutt, et tänapäeva plasmadel pole pildi sissepõlemise probleemi või on see pea olematu, pigem sõnakõlks. 2 nädala jooksul pole tal paar varju kuskile kadunud. 2-3 tunnisest tv3 vaatamisest oli piisanud, et logo oleks mitmeteks päevadeks mõnusa varju tekitanud.
a muidu oli kena telekas. oma silmaga näinud.
170 |
mirko27
15.12.2008 23:38:56
| On tal uus pana plasma? Praegu võid ka mitu põlvkonda vana osta.
| Kommentaarid: 12 loe/lisa |
pealuu
15.12.2008 23:44:26
| mirko27 kirjutas: |
| On tal uus pana plasma? Praegu võid ka mitu põlvkonda vana osta. |
justkui ikka uus. hetkel ka panasonic.ee peal kirjas ja puha.
170 |
priitr
15.12.2008 23:54:50
| pealuu kirjutas: |
a muidu oli kena telekas. oma silmaga näinud. |
Vabandust, aga sellise sissepõlemise saavutamiseks peab ikka lausa pingutama. Ma arvan, et värskele ekraanile tunnike staatilist suure kontrastiga pilti on vast parasjagu. Ilmselt hakkas ta siis kohe telekat põhjakeeratud kontrasti ja heledusega vaatama. Mis teha, ega müüjad vist poes ka asjast räägi. Juhendis, tõsi küll, on vastavad hoiatused olemas.
Minu G11 Pana plasmal pole küll poole aasta jooksul midagi külge hakanud. TV + DVD+ Wii teevad pilti.
_________________ Tšudes ne bõvajet. |
| Kommentaarid: 27 loe/lisa |
pealuu
16.12.2008 00:08:14
| heleduse ja kontrasti koha pealt ei oska kindlalt öelda aga igasugu soovituste järgi olevat teinud - paarsada tundi miskit sissetöötamise aega.
170 |
Joos
priitr
17.12.2008 12:13:20
Eee... E-Marketist? 8)
A tõsiselt - kui head hinda sa siis loodad leida?
Edit: Heh, samas kohas 42PV80P ainult 340 krooni kallim.
Joos
17.12.2008 13:19:57
| priitr kirjutas: |
Edit: Heh, samas kohas 42PV80P ainult 340 krooni kallim. |
Expert-is alla 11tuh.
maxtor1
17.12.2008 21:57:07
| raix kirjutas: |
Ma ostsin ka SHARP LC-37DH65E ära. Karbi peal on tal jah HD Ready 1080p. Kui seda linki vaadata, siis seal määratletakse ta 'HD TV 1080p'-ks.
lcd-compare.com lehel on need erinevad mõisted ka lahti seletatud. Leht on küll prantsuse keeles aga kerige lehekülje lõppu ja vaadake seda tabelit. Selle tabeli järgi liigitub see SHARP FULL HD TV 1080p alla. |
Mis signaali otsa ta sul kasutusele läheb ? Kaablidigiga see hakkama ei saa ilmselt või kuidas ?
91 |
likoor
| Kommentaarid: 46 loe/lisa |
43 |
korsten
17.12.2008 22:22:12
| maxtor1 kirjutas: |
| raix kirjutas: |
Mis signaali otsa ta sul kasutusele läheb ? Kaablidigiga see hakkama ei saa ilmselt või kuidas ? |
MPEG-4 dekooder on tal olemas kui see kuidagi kaablidigiga hakkama saamisele kaasa aitab.
_________________ Ma ei kuuluta jumalikku tõde vaid avaldan oma isiklikku subjektiivset arvamust.
God Hates Us All |
| Kommentaarid: 62 loe/lisa |
58 |
pealuu
17.12.2008 22:56:51
kaasa aitaks dvb-c tuuneri olemasolu.
täna sattusin ühes poes nägema samsungi vist 50" plasmat, millel oli parajasti küljes ps2 mis miskit abba laulude mängu mängitas. oli parajasti miski valge taustaga väheste kirjadega pilt ees ning täitsa tõetruu etv logo ilusti nurgas. kui ei teaks, et seda seal olema ei peaks, siis petaks ilusti ära.
170 |
korsten
17.12.2008 23:04:04
Krt, eelmine Sharpi mudel mida piilusin oli DVB tuuneriga (kas DVB-C s.o DVB CABLE ka lahti muugib, seda ei tea) aga pakuti seda 65E-d 12 k-ga , et samaväärne ja blaa-blaa ainult, et odavam Mul ei tulnud kõik asjad enam paugust meelde, mis telkul küljes peavad olema ja nii ma ta siis ära ostsingi. Sihteliselt pohh on ka hetkel kuna digiboxi taga vist sellest tuunerist kasu ei ole.
God Hates Us All |
58 |
maxtor1
18.12.2008 09:08:13
| korsten kirjutas: |
Krt, eelmine Sharpi mudel mida piilusin oli DVB tuuneriga (kas DVB-C s.o DVB CABLE ka lahti muugib, seda ei tea) aga pakuti seda 65E-d 12 k-ga , et samaväärne ja blaa-blaa ainult, et odavam Mul ei tulnud kõik asjad enam paugust meelde, mis telkul küljes peavad olema ja nii ma ta siis ära ostsingi. Sihteliselt pohh on ka hetkel kuna digiboxi taga vist sellest tuunerist kasu ei ole. |
Boxi taga ei ole tõesti tuunerist tolku aga ise olen pähe võtnud et telekas peab ilma boxita hakkama saama. Kellel on silma jäänud DVB-C tuuneriga 37'' isendeid võiks teada anda.
91 |
raix
18.12.2008 10:17:21
| maxtor1 kirjutas: |
| raix kirjutas: |
See on jah DVB-T tüüneriga, nii et kaabeldigi tuleb ikka läbi digiboksi. Ja kuna mul on salvestav digiboks, siis sellest loobuda ei tahagi.
Laazy
| Kommentaarid: 30 loe/lisa |
korsten
18.12.2008 22:14:32
Laazy, alati ei pruugi odavaim lahendus parim olla. 6k hinnaklassis on raske midagi muud leida (kui tingimuseks on 32+ diagonaal) aga ära kindlasti põrsast kotis osta, mine poodi ja vaata nende telerite pilti ja võrdle teiste telerite piltidega. Demodest ära ennast petta lase vaid küsi julgelt näha nt TV3-e kui sind nähtu rahuldab ja liidesed ka sobivad (misiganes sul ka vaja läheb: SCART, HDMI, S-VHS, VGA jne) siis osta ära. Kui midagi vihasemat tahad siis pead veel raha koguma/ootama.
Lugupidamisega
God Hates Us All |
58 |
vieko
Tbit
18.12.2008 23:04:41
Hakkasin ka vaatama siis seda imevigurit ja tekkis paar küsimust, et kas 100hz on väga oluline, kas odavas klassis ~12-13k mõistlik osta hdready või fullhd ning mis numbrid veel olulised võik spec olla mida silmas pidada ?
|OSTAN|-> T43 pikk jahutus |
230 |
korsten
18.12.2008 23:14:01
Tbit, kõik sõltub sellest mille jaoks sa seda telerit vajad (vabad kanalid, digi tv, arvutist filmid, dvd mängija või mängimine nt ps3-l).
God Hates Us All |
58 |
_marek
19.12.2008 10:15:05
| Tbit kirjutas: |
| Hakkasin ka vaatama siis seda imevigurit ja tekkis paar küsimust, et kas 100hz on väga oluline, kas odavas klassis ~12-13k mõistlik osta hdready või fullhd ning mis numbrid veel olulised võik spec olla mida silmas pidada ? |
Arvestades keskmisest kõrgema usaldusväärsusega naisedsaunas juttudega, peaks mõne kuu perspektiivis meie maale esimesed vaadatava sisuga HD-kanalid jõudma...
Seega soovitaks kindlasti FullHD telekas võtta.
100Hz Samsa puhul nii väga oluline pole, aga 100Hz-ga kaasatulev MotionPlus on imo suht vajalik.
118 |
