Lotharius
rallisibul
11.12.2008 15:42:57
Mul ka see stock punane raam kasutuses. angel, mis sa seal veel modisid selle juures ?
117 |
angel
11.12.2008 15:52:56
S1 + 120mm vent + punane radikas oligi kogu mu "mode" Ainuke asi et punase radika vrm vms osa valge tatt lagunes ära kui selle maha võtsin. Seega pidin 4850 jahutuses kasutatavaid mäludel olevaid lärakaid kasutama.
157 |
rycyve
11.12.2008 20:29:41
Endal pole üheski mängus 35% vent üle 75`C läinud.Kuigi enda jaoks see % lärmakus suur võrreldes vanemate graffidega.Ei tea kas uued Nvidia kaardid(GTX260 216 SP) ka sama lärmakad või
Revüüdest eriti sotti ei saa.
_________________ CH341A EEPROM Flash BIOS teenus. |
83 |
Karel.
11.12.2008 21:55:39
| Ei saa aru mida te põete nende temperatuuride pärast, ju siis ongi ned kaardid ongi mõeldud selliste temperatuuride jaoks, pole nagu eriti kuulnud kah, et neid oleks väga palju temperatuuri tõttu surnud.
CoiL
11.12.2008 22:20:25
Rivatuner 2.21
Version 2.21:
Minor bugfixes:
FOURCC INTZ and RAWZ formats are no longer forcibly disabled on GeForce 6 and newer display adapters when closing the 'Textures' tab in Direct3D tweaks dialog. Please take a note that these formats are required for proper GTA IV functionality, so if you experience problems with missing textures in this game on NVIDIA GeForce 6 and newer display adapters then please try to open the 'Textures' tab and press the 'Defaults' button.
Fixed 'Restore after suspended mode' option in low-level fan control tab, corrupted in the previous release due to multi-GPU related core changes.
What's new:
Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 180.60, 180.70 and 180.84.
Added Catalyst 8.12 driver family detection.
Added 'Enable FOURCC INTZ surfaces' and 'Enable FOURCC RAWZ surfaces' options to the 'Textures' tab of the Direct3D tweaks dialog.
'Restore after suspended mode' option in low-level fan control tab is multi-GPU oriented now. Now the option affects all display adapters in the system instead of currently selected display adapter only.
'Allow separate 2D/3D clock frequency adjustment' option is no longer provided when enabling driver-level hardware overclocking. The option is now hidden to reduce the amount of false bugreports posted by the beginners trying to disable 2D/3D clock frequncy then claiming that the hardware stays at extremely low boot clocks. Power users can still control this option via AllowMaxPerf registry entry.
Extended list of detectable supported FOURCC formats in 'IDirect3D9 HAL adapter formats' diagnostic report category. |
| Kommentaarid: 95 loe/lisa |
83 |
| Kommentaarid: 92 loe/lisa |
AJ
| Kommentaarid: 37 loe/lisa |
36 |
caarel123
12.12.2008 11:08:44
mis progrega saaksin ma kogu aeg(isegi kui mängin) tempe jälgida?
| Kommentaarid: 83 loe/lisa |
74 |
G80
12.12.2008 12:25:30
See RV775XT või RV790 on kahtlane, igast kõlakaid on olnud, et teevad nii öelda 4890X2, millel on eriti kiired mälu ja core 850-900MHz, mis vaja ka korraliku jahutust, mitte vase käkke aga kas sel pointi oleks.
210 |
AJ
36 |
chulo
12.12.2008 15:32:43
| AJ, suht kõvv asi tundub olevat. Tea millal Eestisse jõuab?! Mingi paar kuud tagasi minuarust jõudsid juba esimesed pildid netti, siis tundus juba suht ahvatlev. Hinda on muidugi ka raisal vägevalt...
| Kommentaarid: 20 loe/lisa |
18 |
G80
12.12.2008 16:07:51
| G80 kirjutas: |
See RV775XT või RV790 on kahtlane, igast kõlakaid on olnud, et teevad nii öelda 4890X2, millel on eriti kiired mälu ja core 850-900MHz, mis vaja ka korraliku jahutust, mitte vase käkke aga kas sel pointi oleks. |
Leidsin veel sellise asja:
http://forums.techpowerup.com/showthread.php?p=1101925#post1101925
March, AMD will release more of the low-level RV775 Pro, based on 40nm As for the RV870 the time to market in October of 2009, AMD did not disclose any information that would once again cooked up one of the new dual-core card, but why Not take action?
http://translate.google.com/translate?hl=en&u=http%3A%2F%2Fwww.expreview.com%2Fnews%2Fhard%2F2008-12-12%2F1229072147d10842.html&sl=auto&tl=en
Huvitav.
viimati muutis G80 12.12.2008 16:12:51, muudetud 1 kord |
210 |
AJ
36 |
12.12.2008 18:41:39
Üks väga loll küsimus vahele...
Mis kaarti hetkel eelistada?
HD4870 1GB/HD4850x2/GTX260 ?
Tahaks nagu taas paar aastat ühe kaardiga läbi saada...
196 |
G80
12.12.2008 18:54:03
Mul ka inglise keelne ju, tänu tõlkele.
Etz,
Oota 55nm-sed nvidia kaardid ära aga kui viitsi siis 4870 1GB.
210 |
3GHZ
12.12.2008 19:22:45
See on tõesti üllatav uudis.
_________________ Eesti vanarahvatarkus: S*tu ruttu, karu tuleb! Kui ei s*tu, karu pureb! |
| Kommentaarid: 6 loe/lisa |
G80
12.12.2008 19:34:42
| 3GHZ kirjutas: |
See on tõesti üllatav uudis.  |
Ma ütleks, et hea uudis.
210 |
Heineken
12.12.2008 20:02:17
Seda tahaks küll näha . Loodame , et see ei ole BS muidugi .
Sellest , et XFX hakkab ATi kaarte müüma , oli juba mõni aeg tagasi juttu .
| Kommentaarid: 24 loe/lisa |
23 |
G80
12.12.2008 21:55:05
Heineken, Peale seda tabelit tundub, et tegu pole BS-iga ATI plaanib tõesti RV770 sterod peale lükata.Samas see on hetkel enam, kui mõistlik.
210 |
One
728 |
heretic666
13.12.2008 11:54:07
| Oh jumal, lausa mingi kohver.
| Kommentaarid: 73 loe/lisa |
G80
13.12.2008 12:09:30
| Winterwind kirjutas: |
Core clock speed for this model is 800MHz, there are 2x800 stream processors,
the memory clock speed is 1000MHz with 512-bit memory interface |
Eliit  |
Kusjuures hind polegi mingi väga hull, mõtlesin ,et 1000doltsi tuleb ära aga "ainult" $649.
210 |
jnt
13.12.2008 12:33:41
Eliit  |
Ohsa p... ongi 512bit'i lai mälusiin ve?
108 |
13.12.2008 13:08:53
2x256 nkn
_________________ - londiste
217 |
jnt
13.12.2008 13:13:15
londiste, krt jah, küllap vist... Ma juba mõtsin, et mis asja? Eile või millalgi tuli ju ka uudis, et amd laseb nüüd täielikult oma kaartide disainiga möllata... ma juba lootsin, et midagi eriti hullu tuleb nüüd... krt, miks nad ei võiks siis 2x256bit kirjutada ka... :S
108 |
denis28
13.12.2008 13:59:09
| ju siis ei ole seda nii kerge muuta ...
| Kommentaarid: 67 loe/lisa |
13.12.2008 14:15:22
esiteks on neil kontroller ilmselgelt 256bit. teiseks teeb laiem siin pcb kõvasti keerulisemaks. ja 2xgpu ühel platel ei ole kardetavasti juba iseenesest eriti lihtne.
217 |
Heineken
13.12.2008 14:18:51
Eliit  |
Muidu müüakse kaarte karpides , aga seda müüakse kohvris .
23 |
heretic666
13.12.2008 14:55:58
| Pigem pokkerikomplekti kohver.
G80
210 |
Azatris
| Kommentaarid: 40 loe/lisa |
36 |
G80
13.12.2008 22:39:59
Suht ühte auku kaardid aga kuna too 216SP corega siis GTX veits kiirem.
210 |
angel
13.12.2008 22:48:45
4870 1GB hind päris soolane. Ise sain asja mõned kuud tagasi isegi odavamalt kätte Sama kehtib ka 216 kohta. Kord üks kiirem kord teine on kohati testides silma jäänud.
157 |
G80
14.12.2008 00:39:45
| angel kirjutas: |
4870 1GB hind päris soolane. Ise sain asja mõned kuud tagasi isegi odavamalt kätte Sama kehtib ka 216 kohta. Kord üks kiirem kord teine on kohati testides silma jäänud. |
Tihti oleneb ka mis sait testi teeb, mõned on nvidia kallakuga ja mõned ATI jne.
Õige pildi saad, kui mõlemad masinas olnud.
210 |
CoiL
14.12.2008 15:40:01
| angel kirjutas: |
Hind on jah päris jõhker sellel HD4870 1GB Ise sain õnneks MSI 1GB OC variandi 3,9K eest
83 |
Azatris
14.12.2008 15:46:57
| Kust siis odavama HD4870 saab? Kasvõi OC variant.
36 |
aap14
14.12.2008 15:47:49
Nagu ma aru saan, siis mängud ei saa 4870X2-he puhul üle 1GB videomälu kasutamisega hakkama (crossfire ei luba seda).
Kas ülejäänud 1GB läheks kasutusse aga näiteks teise monitori ühendamisel arvutiga?
Kui ei, siis milleks see ekstra 1GB seal on?
_________________ Slow is smooth and smooth is fast |
| Kommentaarid: 41 loe/lisa |
38 |
jnt
14.12.2008 15:50:52
aap14, 4870x2 puhul hoitakse ju mõlema prose jaoks asju eraldi, ehk kokkuvõttes on kõike topelt... nii lihtne see asi ongi... mälu on 2x1GB mitte 2GB
108 |
angel
14.12.2008 15:52:19
| aap14 kirjutas: |
Kui ei, siis milleks see ekstra 1GB seal on?  |
googeldades leidsin sellise vastuse -> mõlematel kaartidel peab olema videomälus sama info mis teisel. Ehk siis kui üks hoiab X infot videomälus peab samal ajal ka teine kaart seda videomälus hoidma.
157 |
aap14
14.12.2008 16:35:03
Seega see 2GB ongi tegelikult 1GB, kuna mälu on nagu safe RAID-is.
Vähemalt peaks 2 GPU-d rohkem jõudlust andma kui 1.
38 |
angel
14.12.2008 16:46:58
annavad kui mäng oskab neid ära kasutada kui ei siis on ainult ühe kaardi jõudlus.
157 |
Heineken
14.12.2008 16:49:52
| Või alla selle mõnikord .
23 |
14.12.2008 16:52:03
| aap14 kirjutas: |
Vähemalt peaks 2 GPU-d rohkem jõudlust andma kui 1. |
Pigem sellepärast on 2X1GB,et nt üks kaart renderdab pool raami ja teine kaart teise poole siis on kriitiline,et mõlematel oleks mälus sama asi mille kallal nad saavad töötada.Muidu ühine 2GB siis üks GPU parajasti õngitseb ja teine peab ootama kuni esimene lõpetab ja vastupidi
