Lotharius
rallisibul
11.12.2008 14:42:57
Mul ka see stock punane raam kasutuses. angel, mis sa seal veel modisid selle juures ?
117 |
angel
11.12.2008 14:52:56
S1 + 120mm vent + punane radikas oligi kogu mu "mode" Ainuke asi et punase radika vrm vms osa valge tatt lagunes ära kui selle maha võtsin. Seega pidin 4850 jahutuses kasutatavaid mäludel olevaid lärakaid kasutama.
157 |
rycyve
11.12.2008 19:29:41
Endal pole üheski mängus 35% vent üle 75`C läinud.Kuigi enda jaoks see % lärmakus suur võrreldes vanemate graffidega.Ei tea kas uued Nvidia kaardid(GTX260 216 SP) ka sama lärmakad või
Revüüdest eriti sotti ei saa.
_________________ CH341A EEPROM Flash BIOS teenus. |
| Kommentaarid: 99 loe/lisa |
Karel.
11.12.2008 20:55:39
| Ei saa aru mida te põete nende temperatuuride pärast, ju siis ongi ned kaardid ongi mõeldud selliste temperatuuride jaoks, pole nagu eriti kuulnud kah, et neid oleks väga palju temperatuuri tõttu surnud.
CoiL
11.12.2008 21:20:25
Rivatuner 2.21
Version 2.21:
Minor bugfixes:
FOURCC INTZ and RAWZ formats are no longer forcibly disabled on GeForce 6 and newer display adapters when closing the 'Textures' tab in Direct3D tweaks dialog. Please take a note that these formats are required for proper GTA IV functionality, so if you experience problems with missing textures in this game on NVIDIA GeForce 6 and newer display adapters then please try to open the 'Textures' tab and press the 'Defaults' button.
Fixed 'Restore after suspended mode' option in low-level fan control tab, corrupted in the previous release due to multi-GPU related core changes.
What's new:
Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 180.60, 180.70 and 180.84.
Added Catalyst 8.12 driver family detection.
Added 'Enable FOURCC INTZ surfaces' and 'Enable FOURCC RAWZ surfaces' options to the 'Textures' tab of the Direct3D tweaks dialog.
'Restore after suspended mode' option in low-level fan control tab is multi-GPU oriented now. Now the option affects all display adapters in the system instead of currently selected display adapter only.
'Allow separate 2D/3D clock frequency adjustment' option is no longer provided when enabling driver-level hardware overclocking. The option is now hidden to reduce the amount of false bugreports posted by the beginners trying to disable 2D/3D clock frequncy then claiming that the hardware stays at extremely low boot clocks. Power users can still control this option via AllowMaxPerf registry entry.
Extended list of detectable supported FOURCC formats in 'IDirect3D9 HAL adapter formats' diagnostic report category. |
| Kommentaarid: 95 loe/lisa |
83 |
| Kommentaarid: 92 loe/lisa |
AJ
| Kommentaarid: 37 loe/lisa |
36 |
caarel123
12.12.2008 10:08:44
mis progrega saaksin ma kogu aeg(isegi kui mängin) tempe jälgida?
| Kommentaarid: 83 loe/lisa |
74 |
G80
12.12.2008 11:25:30
See RV775XT või RV790 on kahtlane, igast kõlakaid on olnud, et teevad nii öelda 4890X2, millel on eriti kiired mälu ja core 850-900MHz, mis vaja ka korraliku jahutust, mitte vase käkke aga kas sel pointi oleks.
210 |
AJ
36 |
chulo
12.12.2008 14:32:43
| AJ, suht kõvv asi tundub olevat. Tea millal Eestisse jõuab?! Mingi paar kuud tagasi minuarust jõudsid juba esimesed pildid netti, siis tundus juba suht ahvatlev. Hinda on muidugi ka raisal vägevalt...
| Kommentaarid: 20 loe/lisa |
18 |
G80
12.12.2008 15:07:51
| G80 kirjutas: |
See RV775XT või RV790 on kahtlane, igast kõlakaid on olnud, et teevad nii öelda 4890X2, millel on eriti kiired mälu ja core 850-900MHz, mis vaja ka korraliku jahutust, mitte vase käkke aga kas sel pointi oleks. |
Leidsin veel sellise asja:
http://forums.techpowerup.com/showthread.php?p=1101925#post1101925
March, AMD will release more of the low-level RV775 Pro, based on 40nm As for the RV870 the time to market in October of 2009, AMD did not disclose any information that would once again cooked up one of the new dual-core card, but why Not take action?
http://translate.google.com/translate?hl=en&u=http%3A%2F%2Fwww.expreview.com%2Fnews%2Fhard%2F2008-12-12%2F1229072147d10842.html&sl=auto&tl=en
Huvitav.
viimati muutis G80 12.12.2008 15:12:51, muudetud 1 kord |
210 |
AJ
36 |
12.12.2008 17:41:39
Üks väga loll küsimus vahele...
Mis kaarti hetkel eelistada?
HD4870 1GB/HD4850x2/GTX260 ?
Tahaks nagu taas paar aastat ühe kaardiga läbi saada...
196 |
G80
12.12.2008 17:54:03
Mul ka inglise keelne ju, tänu tõlkele.
Etz,
Oota 55nm-sed nvidia kaardid ära aga kui viitsi siis 4870 1GB.
210 |
3GHZ
12.12.2008 18:22:45
See on tõesti üllatav uudis.
_________________ Eesti vanarahvatarkus: S*tu ruttu, karu tuleb! Kui ei s*tu, karu pureb! |
| Kommentaarid: 6 loe/lisa |
G80
12.12.2008 18:34:42
| 3GHZ kirjutas: |
See on tõesti üllatav uudis.  |
Ma ütleks, et hea uudis.
210 |
Heineken
12.12.2008 19:02:17
Seda tahaks küll näha . Loodame , et see ei ole BS muidugi .
Sellest , et XFX hakkab ATi kaarte müüma , oli juba mõni aeg tagasi juttu .
| Kommentaarid: 24 loe/lisa |
23 |
G80
12.12.2008 20:55:05
Heineken, Peale seda tabelit tundub, et tegu pole BS-iga ATI plaanib tõesti RV770 sterod peale lükata.Samas see on hetkel enam, kui mõistlik.
210 |
One
728 |
