P33K
02.12.2008 15:00:43
Service Pack 3 on nõuetes kirjas enamustel kindlasti jah SP2
Deadlock
02.12.2008 15:02:47
| xtream99 kirjutas: |
| Aga samas nii palju kui ma olen tähelepannud, siis enamus kes vinguvad on Vista SP1/Win SP2 kasutajad. Üks tüüp sealt ütles, et tal on SP3, viimased driverid ja windows frame network uuendatud ning tal ei ole ühtegi probleemi. Inimesed on vist lollid lihtsalt ja ei oska recommended settings lugeda. |
Kusjuures märkasin ka, et vingujatel oli Vista.
| Kommentaarid: 8 loe/lisa |
xtream99
02.12.2008 15:03:24
No järjest rohkem ma näen lambaid kes nutavad, et neil ei tööta, ise omavad SP2 või SP1. Pole ime siis, et ei tööta korralikult.
Ha. Got it playing flawlessly on my GTX280, bitches. You guys just don't know how to tweak.
I'm running on all settings max.
FOR NVIDIA OWNERS ONLY, I DONT HAVE AN ATI CARD.
Open the NVidia Control Panel.
Go to the manage 3d settings.
Go to "add application" or something.
Find GTAIV PC exe.
It should have settings like AA, LOD bias, Extended threading support, Gamma Antialiasing, Texture Filtering and Performance Mode.
Tweak it, then play. Hope this helps. |
viimati muutis xtream99 02.12.2008 15:04:18, muudetud 2 korda |
OskarR89
02.12.2008 15:03:44
| xtream99, loodan ise sama. Ei taha kuidagi uskuda, et selline jura kokku vorbiti, mis isegi high end kaartidega ei jookse normaalselt.
139 |
aare2
02.12.2008 15:05:33
http://forums.whirlpool.net.au/forum-replies.cfm?t=1028654&p=24
Worst install experience ever, and I'm seriously thinking of returning the freshly bought game and pirating, because consumers are being screwed over.
- Had to install Rockstar Social Club
- Had to install Games for Windows Live
- Had to install the Game and securom
- Be told I cant save the game without a Live account
- Get Windows Live Account
- Get Games Account
- Be told I don't have a Rockstar Social Club account every time the game is booted
- Sit through loading screen with no loading bar
- Instantly notice the major graphical glitches. Cannot see anything in opening scene. Just the ocean and a few jaggies
- Get to gameplay and framerate is 10-20 fps.
- Restart game but be told I don't have the original disk by securom
- Try for the third time and securom works
- Repeat the same issues
This is with:
4 GB RAM
3.2gHz Quad Core Intel
8800GT 1GB
Not happy at all. Downloading new display drivers now, so you can add that to the list. It's now nearly two hours since I started this circus.
| Kommentaarid: 30 loe/lisa |
29 |
monty11
02.12.2008 15:06:15
Mina loen ka seda GTA4Forums.com ja julgelt võib öelda, et suurem osa vingujaid pole mängu isegi veel mänginud.
_________________ Both the universe and stupidity are infinite. I'm not so sure about the former. - A. Einstein
Tule ja kiika minu fotomaailma. |
| Kommentaarid: 4 loe/lisa |
xtream99
02.12.2008 15:09:57
| aare2 kirjutas: |
- Get Games Account
This is with:
4 GB RAM
8800GT 1GB
Not happy at all. Downloading new display drivers now, so you can add that to the list. It's now nearly two hours since I started this circus. |
Küsi talt mis SP tal on. Kas SP3 XP'le või SP2 Vistale. Kui ta ütleb, et SP2/SP1 siis ma olen 100% kindel, et probleem on SP põhjustatud. Ei suuda uskuda, et R* sellise sita kokku keeraks.
Edit:
| YES! Installing sp3 fixes it. Suggest be stickied or added to a faq somewhere, as the error message is far from informative. |
| yeah worked for me too, thanks all. |
Jah! Ongi SP probleem. Pagana lambad on inimesed noh . Ei osata System Requirement settings näha ning siis tulevad nutma, et "whaaaa booo what a shitty port."
viimati muutis xtream99 02.12.2008 15:16:34, muudetud 1 kord |
henri200
02.12.2008 15:12:54
| Vabalt võisid, ega eelmised GTA-d ka just ei säranud PC peal oma jooksmisega, igast bug-e jne ikka oli.
| Kommentaarid: 62 loe/lisa |
59 |
weasel
02.12.2008 15:13:26
Tundub, et Rockstar tegi M$-iga vale diili (xboxi exclusive DLC).
_________________ PSN: weaselEST |
| Kommentaarid: 38 loe/lisa |
henri200
02.12.2008 15:16:17
| weasel, mis suhtes?
59 |
-Kaivo-
02.12.2008 15:21:58
Steamis peab veel ootama 1 päev ja 14 tundi.Kuradima kaua
| Kommentaarid: 16 loe/lisa |
15 |
weasel
02.12.2008 15:28:20
Tegelikult kui mõtlema hakata, siis ei teinud ka. Arvatavasti oli teada, et PC versiooniga tekib Wini all hulga probleeme ja saamata jääv tulu kompenseeriti selle 50M diiliga.
TheDJ
02.12.2008 15:28:54
Huvitav diskass siin tekkinud ma vaatan
Deadlock
02.12.2008 15:33:57
Rockstari tüübid ise ei ole kuskil midagi kommenteerinud?
Krt ma vihkan seda GTA4 kodulehte, ei leia kunagi sealt vajalikku infot ülesse..
_________________ "Believe you can, believe you can't; either way, you're right." - Henry Ford |
TheDJ
02.12.2008 15:38:33
| Bluebull kirjutas: |
Krt ma vihkan seda GTA4 kodulehte, ei leia kunagi sealt vajalikku infot ülesse.. |
Vaatan et see on ikka üks jura küll. Aasta otsa oodatud asi ja nüüd sellise masendava kirumisega tuleb
Huvitav millal tehti viimati üks mäng, millega mängurid rahul olid ja töötas 100% iga arvuti peal....Quake II?
miqu
02.12.2008 15:46:53
Käisin siis küsimas Jõhvi klickis , alguses sain vastuseks müüa poolt "STO TAKOI GREND THEFT AVTO" siis näitasin reklaami pealt ning sain vastuseks , et tuleb lähipäevil.
_________________ Mis siis saab kui mitte midagi ei saa? |
| Kommentaarid: 25 loe/lisa |
23 |
TheDJ
02.12.2008 15:50:37
| miqu kirjutas: |
Ega jah, kõik teavad enamuses GTA nagu lühendina on...ausaltöeldes ma ei mäletagi millal ma ise ütlesin GTA kohta Grand Theft Auto...hmm, vist siis kui mängisin GTA Londonit
Celos
02.12.2008 15:51:55
Edit:
Jah! Ongi SP probleem. Pagana lambad on inimesed noh . Ei osata System Requirement settings näha ning siis tulevad nutma, et "whaaaa booo what a shitty port." |
Em .. on ikka Vistale SP2 väljas?
Minu teada on asja väljalase alles järgmise aasta algusesse planeeritud.
| Kommentaarid: 17 loe/lisa |
16 |
TheDJ
02.12.2008 15:53:43
| Celos kirjutas: |
Edit:
Minu teada on asja väljalase alles järgmise aasta algusesse planeeritud. |
Vistale on SP1
XP´le viimane on SP3 (valdav enamus kasutab siiski SP2 siiani)
villu70
02.12.2008 15:55:30
| Celos kirjutas: |
Edit:
Ja mina kõlupea läksin vista sp2-te kohe otsima Windowsi kodulehele.
122 |
Pihv
02.12.2008 15:56:32
| Siin on eksitavalt postitatud jah et Vista SP2, Vistale ikkagi SP1 väljas ja see ka system req. kirjas, ilma selleta äkki kalab?
94 |
Mihkel.
02.12.2008 15:57:04
Ei näe küll põhjust miks ei peaks SP3 peale laskma. ( käib siis nende inimeste kohta kes ikka veel sp2'te kasutavad ja kiruvad kui pask ikka sp3 on, ise pole seda proovinudki )
| Kommentaarid: 92 loe/lisa |
Bensiin
02.12.2008 15:58:02
| kui mul on SP1 ja tahan 3 siis kas pean 2 ka tõmbama ja mida see 3 üldse muudab?
| Kommentaarid: 12 loe/lisa |
12 |
XNDR
02.12.2008 15:58:50
Mul on XP 64bit ja minuteada sellele pole SP3 (SP2 praegu peal), ma loodan, et mul mingit jebimist ei tule ette
viimati muutis XNDR 02.12.2008 16:01:20, muudetud 1 kord |
| Kommentaarid: 19 loe/lisa |
19 |
Deadlock
02.12.2008 15:58:55
Minul juba installib SP3.
Game.co.uk saatis kirja, et nüüd võetakse varsti krediiti maha ja võin olla esimeste seas, kes GTAIV mängib
