P33K
02.12.2008 15:00:43
Service Pack 3 on nõuetes kirjas enamustel kindlasti jah SP2
Deadlock
02.12.2008 15:02:47
| xtream99 kirjutas: |
| Aga samas nii palju kui ma olen tähelepannud, siis enamus kes vinguvad on Vista SP1/Win SP2 kasutajad. Üks tüüp sealt ütles, et tal on SP3, viimased driverid ja windows frame network uuendatud ning tal ei ole ühtegi probleemi. Inimesed on vist lollid lihtsalt ja ei oska recommended settings lugeda. |
Kusjuures märkasin ka, et vingujatel oli Vista.
| Kommentaarid: 8 loe/lisa |
xtream99
02.12.2008 15:03:24
No järjest rohkem ma näen lambaid kes nutavad, et neil ei tööta, ise omavad SP2 või SP1. Pole ime siis, et ei tööta korralikult.
Ha. Got it playing flawlessly on my GTX280, bitches. You guys just don't know how to tweak.
I'm running on all settings max.
FOR NVIDIA OWNERS ONLY, I DONT HAVE AN ATI CARD.
Open the NVidia Control Panel.
Go to the manage 3d settings.
Go to "add application" or something.
Find GTAIV PC exe.
It should have settings like AA, LOD bias, Extended threading support, Gamma Antialiasing, Texture Filtering and Performance Mode.
Tweak it, then play. Hope this helps. |
viimati muutis xtream99 02.12.2008 15:04:18, muudetud 2 korda |
OskarR89
02.12.2008 15:03:44
| xtream99, loodan ise sama. Ei taha kuidagi uskuda, et selline jura kokku vorbiti, mis isegi high end kaartidega ei jookse normaalselt.
139 |
aare2
02.12.2008 15:05:33
http://forums.whirlpool.net.au/forum-replies.cfm?t=1028654&p=24
Worst install experience ever, and I'm seriously thinking of returning the freshly bought game and pirating, because consumers are being screwed over.
- Had to install Rockstar Social Club
- Had to install Games for Windows Live
- Had to install the Game and securom
- Be told I cant save the game without a Live account
- Get Windows Live Account
- Get Games Account
- Be told I don't have a Rockstar Social Club account every time the game is booted
- Sit through loading screen with no loading bar
- Instantly notice the major graphical glitches. Cannot see anything in opening scene. Just the ocean and a few jaggies
- Get to gameplay and framerate is 10-20 fps.
- Restart game but be told I don't have the original disk by securom
- Try for the third time and securom works
- Repeat the same issues
This is with:
4 GB RAM
3.2gHz Quad Core Intel
8800GT 1GB
Not happy at all. Downloading new display drivers now, so you can add that to the list. It's now nearly two hours since I started this circus.
| Kommentaarid: 30 loe/lisa |
29 |
monty11
02.12.2008 15:06:15
Mina loen ka seda GTA4Forums.com ja julgelt võib öelda, et suurem osa vingujaid pole mängu isegi veel mänginud.
_________________ Both the universe and stupidity are infinite. I'm not so sure about the former. - A. Einstein
Tule ja kiika minu fotomaailma. |
| Kommentaarid: 4 loe/lisa |
xtream99
02.12.2008 15:09:57
| aare2 kirjutas: |
- Get Games Account
This is with:
4 GB RAM
8800GT 1GB
Not happy at all. Downloading new display drivers now, so you can add that to the list. It's now nearly two hours since I started this circus. |
Küsi talt mis SP tal on. Kas SP3 XP'le või SP2 Vistale. Kui ta ütleb, et SP2/SP1 siis ma olen 100% kindel, et probleem on SP põhjustatud. Ei suuda uskuda, et R* sellise sita kokku keeraks.
Edit:
| YES! Installing sp3 fixes it. Suggest be stickied or added to a faq somewhere, as the error message is far from informative. |
| yeah worked for me too, thanks all. |
Jah! Ongi SP probleem. Pagana lambad on inimesed noh . Ei osata System Requirement settings näha ning siis tulevad nutma, et "whaaaa booo what a shitty port."
viimati muutis xtream99 02.12.2008 15:16:34, muudetud 1 kord |
henri200
02.12.2008 15:12:54
| Vabalt võisid, ega eelmised GTA-d ka just ei säranud PC peal oma jooksmisega, igast bug-e jne ikka oli.
| Kommentaarid: 62 loe/lisa |
59 |
weasel
02.12.2008 15:13:26
Tundub, et Rockstar tegi M$-iga vale diili (xboxi exclusive DLC).
_________________ PSN: weaselEST |
| Kommentaarid: 38 loe/lisa |
henri200
02.12.2008 15:16:17
| weasel, mis suhtes?
59 |
-Kaivo-
02.12.2008 15:21:58
Steamis peab veel ootama 1 päev ja 14 tundi.Kuradima kaua
| Kommentaarid: 16 loe/lisa |
15 |
weasel
02.12.2008 15:28:20
Tegelikult kui mõtlema hakata, siis ei teinud ka. Arvatavasti oli teada, et PC versiooniga tekib Wini all hulga probleeme ja saamata jääv tulu kompenseeriti selle 50M diiliga.
TheDJ
02.12.2008 15:28:54
Huvitav diskass siin tekkinud ma vaatan
Deadlock
02.12.2008 15:33:57
Rockstari tüübid ise ei ole kuskil midagi kommenteerinud?
Krt ma vihkan seda GTA4 kodulehte, ei leia kunagi sealt vajalikku infot ülesse..
_________________ "Believe you can, believe you can't; either way, you're right." - Henry Ford |
TheDJ
02.12.2008 15:38:33
| Bluebull kirjutas: |
Krt ma vihkan seda GTA4 kodulehte, ei leia kunagi sealt vajalikku infot ülesse.. |
Vaatan et see on ikka üks jura küll. Aasta otsa oodatud asi ja nüüd sellise masendava kirumisega tuleb
Huvitav millal tehti viimati üks mäng, millega mängurid rahul olid ja töötas 100% iga arvuti peal....Quake II?
miqu
02.12.2008 15:46:53
Käisin siis küsimas Jõhvi klickis , alguses sain vastuseks müüa poolt "STO TAKOI GREND THEFT AVTO" siis näitasin reklaami pealt ning sain vastuseks , et tuleb lähipäevil.
_________________ Mis siis saab kui mitte midagi ei saa? |
| Kommentaarid: 25 loe/lisa |
23 |
TheDJ
02.12.2008 15:50:37
| miqu kirjutas: |
Ega jah, kõik teavad enamuses GTA nagu lühendina on...ausaltöeldes ma ei mäletagi millal ma ise ütlesin GTA kohta Grand Theft Auto...hmm, vist siis kui mängisin GTA Londonit
Celos
02.12.2008 15:51:55
Edit:
Jah! Ongi SP probleem. Pagana lambad on inimesed noh . Ei osata System Requirement settings näha ning siis tulevad nutma, et "whaaaa booo what a shitty port." |
Em .. on ikka Vistale SP2 väljas?
Minu teada on asja väljalase alles järgmise aasta algusesse planeeritud.
| Kommentaarid: 17 loe/lisa |
16 |
TheDJ
02.12.2008 15:53:43
| Celos kirjutas: |
Edit:
Minu teada on asja väljalase alles järgmise aasta algusesse planeeritud. |
Vistale on SP1
XP´le viimane on SP3 (valdav enamus kasutab siiski SP2 siiani)
villu70
02.12.2008 15:55:30
| Celos kirjutas: |
Edit:
Ja mina kõlupea läksin vista sp2-te kohe otsima Windowsi kodulehele.
122 |
Pihv
02.12.2008 15:56:32
| Siin on eksitavalt postitatud jah et Vista SP2, Vistale ikkagi SP1 väljas ja see ka system req. kirjas, ilma selleta äkki kalab?
94 |
Mihkel.
02.12.2008 15:57:04
Ei näe küll põhjust miks ei peaks SP3 peale laskma. ( käib siis nende inimeste kohta kes ikka veel sp2'te kasutavad ja kiruvad kui pask ikka sp3 on, ise pole seda proovinudki )
| Kommentaarid: 92 loe/lisa |
Bensiin
02.12.2008 15:58:02
| kui mul on SP1 ja tahan 3 siis kas pean 2 ka tõmbama ja mida see 3 üldse muudab?
| Kommentaarid: 12 loe/lisa |
12 |
XNDR
02.12.2008 15:58:50
Mul on XP 64bit ja minuteada sellele pole SP3 (SP2 praegu peal), ma loodan, et mul mingit jebimist ei tule ette
viimati muutis XNDR 02.12.2008 16:01:20, muudetud 1 kord |
| Kommentaarid: 19 loe/lisa |
19 |
Deadlock
02.12.2008 15:58:55
Minul juba installib SP3.
Game.co.uk saatis kirja, et nüüd võetakse varsti krediiti maha ja võin olla esimeste seas, kes GTAIV mängib
apelsin16
02.12.2008 16:00:32
canyourunit.com saab testida kuda veab. mul tuli kõvasti üle keskmise
| Kommentaarid: 63 loe/lisa |
57 |
weasel
02.12.2008 16:03:36
GTA tellijad on game.co.uk nii umbe tõmmanud, et mu PS3 wireless keyboard jääbki tulema...
roop
02.12.2008 16:19:29
| XNDR kirjutas: |
Mul on XP 64bit ja minuteada sellele pole SP3 (SP2 praegu peal), ma loodan, et mul mingit jebimist ei tule ette  |
Huvitab samuti, kas ja kuidas 64 bitiste xp peal uue GTA võlusi katsuda saab.
02.12.2008 16:19:36
| Celos kirjutas: |
Edit:
Ei ole jah.Nõuetesse ei panta ka seda mis veel väljas pole .RC tuleb Veebruaris ja RTM Aprillis .Seega vistale on nõuded:SP1.Punkt.
villu70
02.12.2008 16:21:32
Pljääd, nibin-nabin veab välja.
Olen küllalt kaua upgreatimist edasi lükanud, nüüd pole vist pääsu.
122 |
Deadlock
02.12.2008 16:22:15
No igaljuhul seisneb probleem lihtsalt selles, et tüübid ei oska õigesti mängu ära konfida või pole viimaseid draivereid tõmmanud, sest see pole normaalne, et praeguste parimate kaartidega fps kuskil 30 juures on
Syncmahv
02.12.2008 16:29:11
Pagana jama isegi minimumile ei vasta mu süsteem, prose veab alt. Peab vist jõuluvanale kirja saatma
aga eks näis kuidas see GTA IV tegelikult välja kukub, enamus GTA'si suhteliselt sellised bugised olnud, vast ikka sama populaarne nagu kõik eelmisedki
viimati muutis Syncmahv 02.12.2008 16:29:55, muudetud 1 kord |
102 |
devilman
02.12.2008 16:29:49
| Mis ajast peavad high-end kaartide omanikud ise mängu meeletult tweakima, et see neil talutavalt jookseks? Ja sedagi ehku peale. Valmis produkt küll selline ei tohiks olla.
19 |
lightbluefox
02.12.2008 16:30:15
| Kas keegi oskab öelda kui palju on GTA IV kaart väiksem San andrease omast?
| Kommentaarid: 45 loe/lisa |
44 |
raul.
02.12.2008 16:32:09
| Raidomarek kirjutas: |
| Kas keegi oskab öelda kui palju on GTA IV kaart väiksem San andrease omast? |
no ma nii nuh pakun, et mingi ümaralt 5 ruut kilomeetrit ikka väiksem 8) täpsemat mõõtmist pole veel teind.
| Kommentaarid: 97 loe/lisa |
83 |
One
02.12.2008 16:34:30
| Syncmahv kirjutas: |
Pagana jama isegi minimumile ei vasta mu süsteem, prose veab alt. Peab vist jõuluvanale kirja saatma  |
kloki proset. 2.4GHz ikka teeb
728 |
Pihv
02.12.2008 16:37:32
| Winterwind kirjutas: |
kloki proset. 2.4GHz ikka teeb |
pole vast kasu kui video on ikka suht "juust" , vabandan Syncmahvi ees siinkohal. 2400pro pole just teab mis kaart mängimiseks.
94 |
xtriz
02.12.2008 16:38:12
Sitaks väiksem. Õhus helikopteriga võib terve kaardi korraga ära näha.
Ühest kaardi otsast teise ei pea helikopteriga kaua lendama. San Andreases aga hoopis teine lugu.
viimati muutis xtriz 02.12.2008 16:38:32, muudetud 1 kord |
| Kommentaarid: 9 loe/lisa |
9 |
strohher
02.12.2008 16:38:21
Minu puhul ei aita see ka enam
_________________ Tunguusia tundraahv |
30 |
Syncmahv
02.12.2008 16:38:43
teeks ka 2.6 aga vaevalt see mäng isegi siis jooksma hakkab korralikult minu süsteemil aga noh eks näis.
102 |
Nu
02.12.2008 17:02:09
cpu poolest on paljudel FAIL kuna sys req lab arust c2d ei kvalifitseeru ju. 2,1ghz Phenom X3 on recommended
_________________ DO you want it.. And if you had it would you flaunt it...
ss
viimati muutis Nu 02.12.2008 17:13:05, muudetud 4 korda |
157 |
Oliverk
02.12.2008 17:03:40
| Niipalju kui muljeid lugenud siis ikka epic fail. Graafika kehva ja ei jookse mitte kellelgi. Suht jama aasta oodatuima mängu kohta.
| Kommentaarid: 27 loe/lisa |
26 |
sessa
02.12.2008 17:08:21
''I have the same problem. It's pathetic. I have a 4870, 3.0GHz dual core and 4 gig ram on Vista 32bit.
It will only let me do medium textures and I can only get the view distance up to 65/100
I did a benchmark and not only did the game look about as good as GTA III but it only ran at an FPS of about 35. Same deal when I started a new game...before it crashed like usual. ''
''Hey guys. I have some news for you. I've just called a friend of mine who got the game. His specs are: E8400- 3GB ram- GTX 280. He said that at 1920x1200 he had to turn down the draw distance a little and texture to medium in order to make the game running above 30 FPS. He said that the game looks terrible and is very jaggy (0 AA). F*ck that.''
nii räägivad siis kutid kelle orginaal käes ja juba "naudivad"
| Kommentaarid: 75 loe/lisa |
63 |
Syncmahv
02.12.2008 17:11:44
| sellest oli juba jutt eespool, SP3 pidavat XP peal paremaks tegema(kuna see recomended) vista kohta ei tea midagi.
102 |
weasel
02.12.2008 17:12:22
Võiks ju install keelatud olla kui õiget SP-d peal pole. Siis vähemalt kasutajad teavad, mida teha.
henri200
02.12.2008 17:13:39
| Irw, mitte keelata sellepärast, pigem hoiatada
59 |
weasel
02.12.2008 17:14:15
Ma pigem keelaks, kellele seda hala pärast vaja on kui teada, et nagunii jooksma ei saa.
DeTHiCa.
02.12.2008 17:14:45
| huvitav mis maagilist tarkvara see SP3 sisaldab et ta gta paremini jooksma peaks panema? mitte ühelgi teisel mängul ei ole olnud põhjust plõksida mingi sp3 puudumise pärast, ja nüüd rockstar tegi ühe sellise?
140 |
henri200
02.12.2008 17:15:34
| weasel kirjutas: |
| Ma pigem keelaks, kellele seda hala pärast vaja on kui teada, et nagunii jooksma ei saa. |
no R* saaks selle laimu sellepeale kui mängu ei saa installida. Ostad poest ~500kr eest mängu, mida mõned installida ei saa.
59 |
omgwtf
02.12.2008 17:15:51
Mingi loll iba see SP3 asi
137 |
