uus teema   vasta Tarkvara »  Arvutimängude foorum »  Fallout 3 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 10, 11, 12 ... 49, 50, 51  järgmine
sõnum 16.07.2008 08:40:20 vasta tsitaadiga
http://www.gamesradar.com/pc/fallout-3/preview/fallout-3-hands-on/a-20080714133932662026/g-20070327151320531089
http://uk.gamespot.com/pc/rpg/fallout3/news.html?sid=6193739&mode=previews
http://pc.ign.com/articles/887/887729p1.html
http://www.shacknews.com/featuredarticle.x?id=921
- Melee VATS doesn’t let you target individual body parts, but it does increase your chance of scoring a critical hit and inflicting extra damage.
- Sims’ son presented me with the deed to a vacant Megaton home as a reward.
- Melee combat works very much as it does in Oblivion: one button strikes, another blocks. It’s a basic system, but it gets the job done.
- The slow-mo kills instantly became one of my favorite things ever, and I finished off my first victim's two friends in a similar fashion by closing to point-blank range before pausing and blowing off a chunk of raider.
- My action points, which you expend when using VATS, recharged at a rate that let me use the system pretty much as often as I wanted, although not for every shot.
- I found a new lock-picking minigame in which you twist a screwdriver in the lock while applying pressure with a bobby pin. If the pin is at the correct angle, the lock will pop open - if not, the lock will turn slightly, and will turn more the closer you get to the solution. The pin will snap after a couple of attempts, though, so you’ll need another one in order to try again.
- Oblivion's simple approach to dialogue trees would not suffice here, and as a result, I often had up to five or six options at any given time.
- The dialogue engine is indeed reminiscent of Oblivion, but after noticing this, I never gave it a second thought.
- A few mildly humorous moments were produced by said vulgarity. But none of the characters caught me off guard or engaged me in the same way that Fallout did, and the voice acting was sometimes rather wooden.
- But rather than a continuation of traditional Fallout combat, think of it more like tactical bullet-time.
- Though a lack of life or major landmarks is a classic sign of lazy video game design, Fallout 3's wasteland is appropriate in its barren nature. In fact, it's the first 3D post-apocalyptic game to really make me feel like I was in an area where a nuclear bomb had gone off.
- In short, this is not your father's Fallout. Some things are better, some things may not live up to expectations, and many things have stayed the same.
- londiste
madness
madness
sõnum 26.07.2008 10:41:28 vasta tsitaadiga
http://www.eurogamer.net/article.php?article_id=201105
But beyond that, there are simple questions of quality that it's impossible to avoid: characterless art, cold visuals, wonky animation, weak real-time combat, off-kilter writing. As it stands, Fallout 3 just doesn't feel right, and it will leave many players shivering for warmth in its nuclear winter.
corvette
sõnum 26.07.2008 12:12:14 vasta tsitaadiga
Fallout 1 ja 2 pole ma mänginud. Korraks kunagi sai küll uuritud, aga kuidagi imelik käimisstrateegia oli ning jätsin nad sinna paika icon_biggrin.gif
Aga Fallout Brothers Of Steel oli küll mäng millele ootaks järge.
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 48
Peltz
Peltz
sõnum 26.07.2008 13:53:59 vasta tsitaadiga
http://pc.ign.com/dor/objects/568806/fallout-3/videos/fallout3livewire_072308.html
Video näitab nats combatit ja mingi mees möliseb ka nats juurde. Mulle vähemalt meenutab gameplay esimest Deus Exi, aga see ei ole tingimata halb. Selge on see et eelmiste falloutidega on suht vähe ühist ja kindlasti ei suuda see hübriid täita Fallout2 susse. Sellegipoolest ootan rohkelt musta huumorit ja meeldejäävaid tegelasi.
See bloody mess perk vist ei ole hea mõte selles mängus. tüütab lõpuks ära kui koguaeg mingi slowmotion korjused ringi lendavad.
PS. ma ei viitsinud vaadata kas keegi oli juba postitanud selle, kui oli siis sorry.
"Do you know what the 'Chain of Command' is? It's the chain i'm going to beat You with untill You understand who is in command!"
"And you have the right to say, No!"
marcor1
marcor1
sõnum 27.07.2008 01:09:28 vasta tsitaadiga
Peltz kirjutas:
Kui Oblivioni seltskond, võtab selleks eraldi inimese tööle, siis võib ju loota...
(kel FO hinges ja Planescape Torment mängimata siis thumbs_up.gif tõsiselt sügav ajaviide!)
War. War never changes.
Malkavian: [to a stop sign] No, you stop!
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 64
Scart
Scart
sõnum 30.07.2008 16:20:07 vasta tsitaadiga
link :: kae siit
Vähemalt on meeldiv näha, et mõni ajakirjanik pole end veel ära müünud.
Nagu võiski arvata, on Fallout 3 hale p**k.
sõnum 30.07.2008 16:33:00 vasta tsitaadiga
ai.
- londiste
Heineken
sõnum 30.07.2008 16:42:13 vasta tsitaadiga
Tegelikult kuidas kellele , mina ennem ei otsusta , kas on saast või mitte , kui ise proovin icon_smile.gif .
Paganarh
Paganarh
sõnum 30.07.2008 16:47:05 vasta tsitaadiga
Heineken kirjutas:
mhmh, sama siin.
siiber on juba sellest ininast icon_smile.gif mängib ära siis vaatab mis on. ega roosiline praegu välja ei näe aganoh, krt teab ju
Scart
Scart
sõnum 30.07.2008 17:11:52 vasta tsitaadiga
Heineken kirjutas:
Kas Falloutil demo üldse pidi tulema? Kui vastus on "ei", natuke kallis proovireis icon_razz1.gif
sõnum 30.07.2008 17:24:10 vasta tsitaadiga
ei tule demo.
- londiste
corvette
sõnum 30.07.2008 19:34:56 vasta tsitaadiga
Scart kirjutas:
Selle vastu on rohtu
MatchMaker
MatchMaker
sõnum 30.07.2008 22:17:49 vasta tsitaadiga
Scart kirjutas:
Lugesin terve selle teema seal läbi ja ega eriti aru ei saagi, et mille üle virisetakse, enamus neist - olid eelnevates Falloutites üsna iseloomulikud.
- the world feels empty (even on post-nuclear standards)
Oli täitsa tühi ka eelnevates, lihtsalt vahemaid läbiti läbi mapi.
- dialogs are more or less "Nice/Mean/Rumors/Bye"
Palju oli seda ka eelnevates...
- you can't enter buildings except through the front door (no sneaking through a broen window...)
Ei mäleta seda eelnevatest....
- weapons are not customizable and there's only one type of ammo for each weapon
Eelnevates oli enamus relvade jaoks 2ammot, ja välimuselt olid need üsna sarnased jne.,
- sneaking seems the only alternative to combat. Diplo characters are pretty much screwed.
Läbisin palju kordi F1 ja 2 ja hiilimist vist ei kasutanud pea kordagi, või polnud sellest suurt tolku, võitlus oli siiski primaarne
Kokkuvõttes on jah suht tulutu mängust mingit arvamust rajama hakata ennem kui asi väljas.
sõnum 30.07.2008 22:22:18 vasta tsitaadiga
dialooge oli/on ikka omajagu.
spetsialiseeritud ammo. _enamasti_ piirdus esimestes kahega, oli ka 1 ja 3 jms.
f1/2 sai läbi hiilida või läbi rääkida. läbi rääkimine on üks asjadest, mida sellisel tasemel muudes rpgdes pole põhimõtteliselt enam olnud (torment maybe).
majadesse sissesaamise ja tühjuse osas... no milleks siis uus vaatepunkt, kui 1st/3rd person vaatepunkti rpg jaoks suhteliselt tavalisi asju ei suudeta teha.
- londiste
Iceberg
sõnum 30.07.2008 22:46:01 vasta tsitaadiga
Nähtud gameplay videode puhul võib küll järeldada, et tuleb sama igav käkk nagu seda on oblivion thumbs_down.gif
marcor1
marcor1
sõnum 30.07.2008 22:50:53 vasta tsitaadiga
MatchMaker kirjutas:
Kirjas on ju, et diplo karakter on kasutu - ehk ei hakatud aega raiskama keerukamatele dialoogidele - "sloowmotion core" on see, mis müüb.
marko
marko
sõnum 30.07.2008 23:01:56 vasta tsitaadiga
Paganarh, inisemine on sõimusõna ja tüli pole mõtet tühjast kiskuma hakata.
Mängu demomisega/presenteerimisega ja mingi versiooni ajakirjanikele mängida andmisega tahetakse ikka parimad palad ette näidata, või vähemalt midagi head... mina ei ole siiani näinud ei ühte ega teist.
Kokkuvõtvalt, siin ei ole tegu õige Fallout seeria mänguga (nagu me juba teame), kahjuks ei ole see isegi lihtsalt mõnus FPS... huvitav mis lõplikud review'd ja müüginumbrid ütlevad? icon_neutral.gif
Kommentaarid: 178 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 161
Scart
Scart
sõnum 30.07.2008 23:14:34 vasta tsitaadiga
marko kirjutas:
Gamespot, Gamespy annavad aasta mängu tiitli, müüb Ikskastil 10 miljonit koopiat, PC peal 500 tuhat, sest shitti ei osteta sellel platformil ja kuuleme aasta pärast, kuidas "piraatlus tapab PC".
Tavaline ju. Revüünädalal on mõlema saidid muidugi ka maast laeni Fallouti reklaami täis ja Gamespot jooksutab nädal enne release'i "kuidas tehti legendi nimega Fallout 3".
Ho Ho
Ho Ho
sõnum 30.07.2008 23:15:22 vasta tsitaadiga
Vähemalt F2's oli ammo vägagi suure tähtsusega ja võis väga palju muuta. Oli ikka suur vahe kas toksida robotit/aliene 5+ käiku või nad ühe lasuga ribadeks lasta
marko
marko
sõnum 30.07.2008 23:23:54 vasta tsitaadiga
Scart kirjutas:
dstar
dstar
sõnum 30.07.2008 23:29:58 vasta tsitaadiga
See, et 3rd person view's ei saa kaamerat ümber tegelase pöörata, on ikka täielik BS. Oblivionis sai vähemalt vaadata, mis riietus või armor sul seljas on, aga selle RE4 stiilis fikseeritud kaameranurgaga ei näe enam mitte midagi. Arvan, et sellest tuleb sama unine, igav ja huumorivaene mäng nagu Obliviongi, mida alguses ülistatakse ja hiljem vihatakse.
Elof
Elof
sõnum 30.07.2008 23:39:23 vasta tsitaadiga
Kõige õigem lähenemine sellele mängule on see, et tegemist täieliku p*saga, mis võibolla hiljem siiski millekski muuks võib osutuda.
Olla
Olla
sõnum 30.07.2008 23:55:35 vasta tsitaadiga
Mul meenus üks Yahtzee ütlus. "If I put balls in my mouth I´m a prostitute or possibly a Gamespot employee". See pole täpne tsitaat aga käis umbes nii. 8)
Juttu mõtte on siis see, et Fallout 3 saab raudselt 9-10 skoori Gamespotilt ning kiidavad seda taevani väites, et see on the best game ever.
viimati muutis Olla 30.07.2008 23:56:08, muudetud 1 kord
Peltz
Peltz
sõnum 31.07.2008 01:13:59 vasta tsitaadiga
Ega ta hullem ju olla ei saa kui see eelmine konsooliüritus.
sõnum 06.08.2008 12:28:18 vasta tsitaadiga
http://www.strategyinformer.com/pc/fallout3/interview.html
- londiste
connor
sõnum 06.08.2008 13:30:55 vasta tsitaadiga
Eelmisest lingist:
Strategy Informer: kirjutas:
Talking about the game world, obviously it’s massive, you can do anything you want, go anywhere you please. Do you think there’s a danger you went too far?
Mis kuradi küsimus see on? a'la "Paistab et mäng on lahe. Mehed miks te nii laheda mängu tegite?"
Lisaks veel:
Pete Hines: kirjutas:
I think it’s probably fair to say that we don’t feel compelled to beat people over the head with the letters RPG and to insist that they acknowledge they are playing a role playing game
Would it be fair to label Fallout 3, “Oblivion with guns”? It seems as if the dialogue seems to be the same, the wide open spaces and there are a lot of similarities.
...You know, the dialogue is exactly like the dialogue from Fallout so it may feel similar to Oblivion and I guess in terms of how it’s structured, but ...
Kommentaarid: 31 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 28
sõnum 06.08.2008 14:06:10 vasta tsitaadiga
With Oblivion and with Fallout we like to have it be such that if you are hardcore and you want to get in to power gaming and the numbers and how you’re levelling up, what you’re putting skills in, what perks your picking and really sort of power game that... you totally can and if you want to spend most your time doing dialogue or whatever the hell it is, you can.
- londiste
marcor1
marcor1
sõnum 06.08.2008 15:12:13 vasta tsitaadiga
...You know, the dialogue is exactly like the dialogue from Fallout so it may feel similar to Oblivion ...
... tundub, et kõik läheb siiski hästi:
http://www.fanmadefallout.com/IMG/news/fallout_3_by_bethesda_admiral_jimbob_rpgcodex.gif
edit:
kui hea soundtrack tuleb, siis võib päris tore shooter tulla:
http://www.strategyinformer.com/pc/fallout3/movie/25190.html
(mulle, näiteks see retroklipp ei mõjunud... ja võrdluseks fo2 oma http://au.youtube.com/watch?v=e3PXiV95kwA )
System
sõnum 06.08.2008 19:05:16 vasta tsitaadiga
connor kirjutas:
Eelmisest lingist:
Äkki ta mõtles selle all seda, et mängu maailm on mängurite riistvara jaoks liiga massiivne ?
Tuli vaikselt, tuli tasa. Varjud jättis seintele ja maha.
Heineken
sõnum 06.08.2008 19:32:19 vasta tsitaadiga
Ega arvuti kogu maailma korraga ei streami ... ikka jupphaaval loadib , aga mitte load screenidega , ma arvan . Nagu Oblivionis(vähemalt väljas ringi rännates) , Crysises (editoris võtsin piirid maha ja sõitsin hõljukiga saarele ringi peale , mingit load screeni ei tulnud ) , TDUs , jne .
sõnum 20.08.2008 22:41:03 vasta tsitaadiga
tuleb 31. oktoobril 2008
Delta
Delta
sõnum 20.08.2008 23:47:53 vasta tsitaadiga
Pole viitsinud vahepeal uurida, kas min spec on juba avaldatud. Siis selgub ka, kas pean oma rondi välja vahetama või veab veel seekord välja 8)
airgun.planet.ee - õhkrelvad ja taskulambid
Salva kindlustus = probleemid
M: EDC nuga
Kommentaarid: 141 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 133
minake
minake
sõnum 21.08.2008 17:20:13 vasta tsitaadiga
njah, mulle igatahes videod meeldisid, n2is kas ja kuidas see pausiga combat on, fallout 1-2-te nad nagunii ei suuda yletada, a loodame, et on hea ja m6nus fps/rpg, igatahes sai collectors edition tellitud, survival edition on m6eldud paraku ameeriklastele ja seda vist euroopasse ei tulegi...
Kommentaarid: 164 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 137
marko
marko
sõnum 21.08.2008 17:37:14 vasta tsitaadiga
icon_lol.gif 2saja taalaga ju ebays täitsa olemas survival edition pakkumised
minake
minake
sõnum 22.08.2008 10:25:26 vasta tsitaadiga
muig, nu kui n6udmine suurem kui pakkumine siis saab alati ulmelisi hindu kysida ju icon_wink.gif
Taaviup
Taaviup
sõnum 29.08.2008 23:47:33 vasta tsitaadiga
OMG !!!
Fallout 3 on must have !!!
Tšekkige seda...
Part1 : http://www.gametrailers.com/player/39283.html
Part2 : http://www.gametrailers.com/player/39285.html
Part3 : http://www.gametrailers.com/player/39287.html
Part4 : http://www.gametrailers.com/player/39289.html
Part5 : http://www.gametrailers.com/player/39291.html
Ei osanud nagu ette kujutada ,et seal sellised võimalused on...
Delta
Delta
sõnum 30.08.2008 00:38:09 vasta tsitaadiga
Njah, vana oli ikka parem :twisted: :twisted: :twisted:
M: EDC nuga
Mario153
Mario153
sõnum 30.08.2008 11:47:20 vasta tsitaadiga
Videode järgi on ikka päris kobe asi......atmosfäär ja heli on ikka päris korralik.
Part3 : http://www.gametrailers.com/player/39287.html thumbs_up.gif
Part4 : http://www.gametrailers.com/player/39289.html thumbs_up.gif
Kommentaarid: 56 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 50
andres1221
sõnum 30.08.2008 14:00:16 vasta tsitaadiga
Tundub huvitav, aga paitab, ikka nii oblivion with guns kui olla saab. Mis võib-olla ei olegi kõige hullem, aga loodetavasti ei kisu nii igavaks ära...
sõnum 30.08.2008 22:26:31 vasta tsitaadiga
oblivion with guns?
gears of war with pause.
- londiste
andres1221
sõnum 30.08.2008 22:41:42 vasta tsitaadiga
londiste kirjutas:
oblivion with guns?
Njah, ka võimalik : D
dstar
dstar
sõnum 30.08.2008 23:35:39 vasta tsitaadiga
Täielik Elder Scrolls: Fallout. Tuleb samasugune unine ja igav soigumine nagu Oblivion. Tõenäeoliselt loevad hääli sisse täpselt samad 3 meest ja üks naine, mis tähendab, et kõik hakkab jälle korduma. Paar tundi võib ju tolmu maitse suus ringi lonkida ja kolle retsida, aga sellest tüdineb väga kiiresti ära. Ja kaua sa seda tuumaseent ikka imetled?
Visuaalselt ei paku mäng midagi huvitavat, ainult üks hallides toonides varemete hunnik. Peategelane on järjekordselt mingisugune isikupäratu tummahammas, kes rääkida ei oska. Pärast Mass Effecti mõjub selline vaikus ikka väga haledalt... Animatsioonid on Bethesdale omaselt puised. Võiks juba motion capture peale mõtlema hakata, liikumine on jätkuvalt aastast 2005... Tüüpilist FPS combatit püütakse varjata ajuvaba VATS süsteemiga. Nii et igati tore mänguke jälle tulemas. thumbs_up.gif
andres1221
sõnum 30.08.2008 23:40:20 vasta tsitaadiga
dstar kirjutas:
Kardan, et pean enam jaolt sinuga nõustuma, aga loodan ikkagi midagi head.
A ja paistab, et ühes gameplay videos oli kuulda, et üks voice actor oli sama, kes Oblivionis või oligi isegi 2 sama. (Kui seal jälle ainult 4 inimest, siis kisub vähe igavaks jah.)
Iceberg
sõnum 30.08.2008 23:45:49 vasta tsitaadiga
Dialoogid tunduvad sama tuimad ja igavad nagu nad olid oblivionis thumbs_down.gif
Heineken
sõnum 31.08.2008 00:20:58 vasta tsitaadiga
Ma loodan , et seda pausiasja saab maha kuidagi keerata , kasvõi nii et peab muutma mängufaile vms.
Mäng ise tundub norm tulevat , aga see pausi asi on jah ajuvaba .
Scart
Scart
sõnum 31.08.2008 00:40:07 vasta tsitaadiga
VATSi ei pea kasutama, mängi kas sellega või ilma aga mingit kohustuslikku pausitamist ei ole.
Thing
Thing
sõnum 31.08.2008 01:21:52 vasta tsitaadiga
huoh, näeb välja täpselt nii sitt nagu ma kartsingi.
WTF, lased mingit autoromu ja see lendab õhku? Mehike tehtud ise kah vist terasest, sitta kanti talub piitsutamist ja vastased tunduvad küll paberist olevad. Ammot tundub kah lõpmatuseni olevat. Masendav kuidas võib hea asja ära sittuda icon_sad.gif
andres1221
sõnum 31.08.2008 02:50:31 vasta tsitaadiga
Thing kirjutas:
No ma arvan, et tal oli miski god mode peal. Mõni kord devid kasutavad seda, kui mängu demonstreerivad.
nolifer
sõnum 31.08.2008 08:10:07 vasta tsitaadiga
Thing kirjutas:
oota ära kuni mäng välja tuleb ja siis hakka halvustama
Timberg
ööKARU
Timberg
sõnum 31.08.2008 11:34:16 vasta tsitaadiga
http://www.winamp.com/skins/details/221699
friiki
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Fallout 3 mine lehele eelmine  1, 2, 3 ... 10, 11, 12 ... 49, 50, 51  järgmine
