16.07.2008 08:40:20
http://www.gamesradar.com/pc/fallout-3/preview/fallout-3-hands-on/a-20080714133932662026/g-20070327151320531089
http://uk.gamespot.com/pc/rpg/fallout3/news.html?sid=6193739&mode=previews
http://pc.ign.com/articles/887/887729p1.html
http://www.shacknews.com/featuredarticle.x?id=921
- Melee VATS doesnt let you target individual body parts, but it does increase your chance of scoring a critical hit and inflicting extra damage.
- Sims son presented me with the deed to a vacant Megaton home as a reward.
- Melee combat works very much as it does in Oblivion: one button strikes, another blocks. Its a basic system, but it gets the job done.
- The slow-mo kills instantly became one of my favorite things ever, and I finished off my first victim's two friends in a similar fashion by closing to point-blank range before pausing and blowing off a chunk of raider.
- My action points, which you expend when using VATS, recharged at a rate that let me use the system pretty much as often as I wanted, although not for every shot.
- I found a new lock-picking minigame in which you twist a screwdriver in the lock while applying pressure with a bobby pin. If the pin is at the correct angle, the lock will pop open - if not, the lock will turn slightly, and will turn more the closer you get to the solution. The pin will snap after a couple of attempts, though, so youll need another one in order to try again.
- Oblivion's simple approach to dialogue trees would not suffice here, and as a result, I often had up to five or six options at any given time.
- The dialogue engine is indeed reminiscent of Oblivion, but after noticing this, I never gave it a second thought.
- A few mildly humorous moments were produced by said vulgarity. But none of the characters caught me off guard or engaged me in the same way that Fallout did, and the voice acting was sometimes rather wooden.
- But rather than a continuation of traditional Fallout combat, think of it more like tactical bullet-time.
- Though a lack of life or major landmarks is a classic sign of lazy video game design, Fallout 3's wasteland is appropriate in its barren nature. In fact, it's the first 3D post-apocalyptic game to really make me feel like I was in an area where a nuclear bomb had gone off.
- In short, this is not your father's Fallout. Some things are better, some things may not live up to expectations, and many things have stayed the same.
_________________ - londiste
217 |
madness
26.07.2008 10:41:28
http://www.eurogamer.net/article.php?article_id=201105
| But beyond that, there are simple questions of quality that it's impossible to avoid: characterless art, cold visuals, wonky animation, weak real-time combat, off-kilter writing. As it stands, Fallout 3 just doesn't feel right, and it will leave many players shivering for warmth in its nuclear winter. |
| Kommentaarid: 13 loe/lisa |
corvette
26.07.2008 12:12:14
Fallout 1 ja 2 pole ma mänginud. Korraks kunagi sai küll uuritud, aga kuidagi imelik käimisstrateegia oli ning jätsin nad sinna paika
Aga Fallout Brothers Of Steel oli küll mäng millele ootaks järge.
Kahju et Fallout 3 nii käkiks muutus.
| Kommentaarid: 49 loe/lisa |
48 |
Peltz
26.07.2008 13:53:59
http://pc.ign.com/dor/objects/568806/fallout-3/videos/fallout3livewire_072308.html
Video näitab nats combatit ja mingi mees möliseb ka nats juurde. Mulle vähemalt meenutab gameplay esimest Deus Exi, aga see ei ole tingimata halb. Selge on see et eelmiste falloutidega on suht vähe ühist ja kindlasti ei suuda see hübriid täita Fallout2 susse. Sellegipoolest ootan rohkelt musta huumorit ja meeldejäävaid tegelasi.
See bloody mess perk vist ei ole hea mõte selles mängus. tüütab lõpuks ära kui koguaeg mingi slowmotion korjused ringi lendavad.
PS. ma ei viitsinud vaadata kas keegi oli juba postitanud selle, kui oli siis sorry.
_________________ "Do you know what the 'Chain of Command' is? It's the chain i'm going to beat You with untill You understand who is in command!"
"And you have the right to say, No!" |
| Kommentaarid: 23 loe/lisa |
22 |
marcor1
27.07.2008 01:09:28
| Peltz kirjutas: |
Kui Oblivioni seltskond, võtab selleks eraldi inimese tööle, siis võib ju loota...
(kel FO hinges ja Planescape Torment mängimata siis tõsiselt sügav ajaviide!)
_________________ War. War never changes.
Malkavian: [to a stop sign] No, you stop! |
65 |
Scart
30.07.2008 16:20:07
link :: kae siit
Vähemalt on meeldiv näha, et mõni ajakirjanik pole end veel ära müünud.
Nagu võiski arvata, on Fallout 3 hale p**k.
101 |
30.07.2008 16:33:00
ai.
217 |
Heineken
30.07.2008 16:42:13
Tegelikult kuidas kellele , mina ennem ei otsusta , kas on saast või mitte , kui ise proovin .
| Kommentaarid: 24 loe/lisa |
23 |
Paganarh
30.07.2008 16:47:05
| Heineken kirjutas: |
Tegelikult kuidas kellele , mina ennem ei otsusta , kas on saast või mitte , kui ise proovin . |
mhmh, sama siin.
siiber on juba sellest ininast mängib ära siis vaatab mis on. ega roosiline praegu välja ei näe aganoh, krt teab ju
| Kommentaarid: 15 loe/lisa |
Scart
30.07.2008 17:11:52
Kas Falloutil demo üldse pidi tulema? Kui vastus on "ei", natuke kallis proovireis
101 |
30.07.2008 17:24:10
ei tule demo.
217 |
corvette
30.07.2008 19:34:56
| Scart kirjutas: |
Kas Falloutil demo üldse pidi tulema? Kui vastus on "ei", natuke kallis proovireis  |
Selle vastu on rohtu
48 |
MatchMaker
30.07.2008 22:17:49
| Scart kirjutas: |
Nagu võiski arvata, on Fallout 3 hale p**k. |
Lugesin terve selle teema seal läbi ja ega eriti aru ei saagi, et mille üle virisetakse, enamus neist - olid eelnevates Falloutites üsna iseloomulikud.
- the world feels empty (even on post-nuclear standards)
Oli täitsa tühi ka eelnevates, lihtsalt vahemaid läbiti läbi mapi.
- dialogs are more or less "Nice/Mean/Rumors/Bye"
Palju oli seda ka eelnevates...
- you can't enter buildings except through the front door (no sneaking through a broen window...)
Ei mäleta seda eelnevatest....
- weapons are not customizable and there's only one type of ammo for each weapon
Eelnevates oli enamus relvade jaoks 2ammot, ja välimuselt olid need üsna sarnased jne.,
- sneaking seems the only alternative to combat. Diplo characters are pretty much screwed.
Läbisin palju kordi F1 ja 2 ja hiilimist vist ei kasutanud pea kordagi, või polnud sellest suurt tolku, võitlus oli siiski primaarne
Kokkuvõttes on jah suht tulutu mängust mingit arvamust rajama hakata ennem kui asi väljas.
30.07.2008 22:22:18
dialooge oli/on ikka omajagu.
spetsialiseeritud ammo. _enamasti_ piirdus esimestes kahega, oli ka 1 ja 3 jms.
f1/2 sai läbi hiilida või läbi rääkida. läbi rääkimine on üks asjadest, mida sellisel tasemel muudes rpgdes pole põhimõtteliselt enam olnud (torment maybe).
majadesse sissesaamise ja tühjuse osas... no milleks siis uus vaatepunkt, kui 1st/3rd person vaatepunkti rpg jaoks suhteliselt tavalisi asju ei suudeta teha.
217 |
Iceberg
30.07.2008 22:46:01
Nähtud gameplay videode puhul võib küll järeldada, et tuleb sama igav käkk nagu seda on oblivion
| Kommentaarid: 6 loe/lisa |
marcor1
30.07.2008 22:50:53
| MatchMaker kirjutas: |
Kirjas on ju, et diplo karakter on kasutu - ehk ei hakatud aega raiskama keerukamatele dialoogidele - "sloowmotion core" on see, mis müüb.
65 |
marko
30.07.2008 23:01:56
Paganarh, inisemine on sõimusõna ja tüli pole mõtet tühjast kiskuma hakata.
Mängu demomisega/presenteerimisega ja mingi versiooni ajakirjanikele mängida andmisega tahetakse ikka parimad palad ette näidata, või vähemalt midagi head... mina ei ole siiani näinud ei ühte ega teist.
Kokkuvõtvalt, siin ei ole tegu õige Fallout seeria mänguga (nagu me juba teame), kahjuks ei ole see isegi lihtsalt mõnus FPS... huvitav mis lõplikud review'd ja müüginumbrid ütlevad?
| Kommentaarid: 178 loe/lisa |
161 |
Scart
30.07.2008 23:14:34
| marko kirjutas: |
huvitav mis lõplikud review'd ja müüginumbrid ütlevad?  |
Gamespot, Gamespy annavad aasta mängu tiitli, müüb Ikskastil 10 miljonit koopiat, PC peal 500 tuhat, sest shitti ei osteta sellel platformil ja kuuleme aasta pärast, kuidas "piraatlus tapab PC".
Tavaline ju. Revüünädalal on mõlema saidid muidugi ka maast laeni Fallouti reklaami täis ja Gamespot jooksutab nädal enne release'i "kuidas tehti legendi nimega Fallout 3".
101 |
Ho Ho
30.07.2008 23:15:22
Vähemalt F2's oli ammo vägagi suure tähtsusega ja võis väga palju muuta. Oli ikka suur vahe kas toksida robotit/aliene 5+ käiku või nad ühe lasuga ribadeks lasta
87 |
marko
30.07.2008 23:23:54
| Scart kirjutas: |
| marko kirjutas: |
see oli retooriline küsimus... ma isegi ei kahtle selles
161 |
dstar
30.07.2008 23:29:58
| See, et 3rd person view's ei saa kaamerat ümber tegelase pöörata, on ikka täielik BS. Oblivionis sai vähemalt vaadata, mis riietus või armor sul seljas on, aga selle RE4 stiilis fikseeritud kaameranurgaga ei näe enam mitte midagi. Arvan, et sellest tuleb sama unine, igav ja huumorivaene mäng nagu Obliviongi, mida alguses ülistatakse ja hiljem vihatakse.
Elof
30.07.2008 23:39:23
Kõige õigem lähenemine sellele mängule on see, et tegemist täieliku p*saga, mis võibolla hiljem siiski millekski muuks võib osutuda.
See plaan on lollikindel
175 |
Olla
30.07.2008 23:55:35
Mul meenus üks Yahtzee ütlus. "If I put balls in my mouth I´m a prostitute or possibly a Gamespot employee". See pole täpne tsitaat aga käis umbes nii. 8)
Juttu mõtte on siis see, et Fallout 3 saab raudselt 9-10 skoori Gamespotilt ning kiidavad seda taevani väites, et see on the best game ever.
viimati muutis Olla 30.07.2008 23:56:08, muudetud 1 kord |
| Kommentaarid: 18 loe/lisa |
17 |
Peltz
31.07.2008 01:13:59
Ega ta hullem ju olla ei saa kui see eelmine konsooliüritus.
22 |
217 |
connor
06.08.2008 13:30:55
Eelmisest lingist:
| Strategy Informer: kirjutas: |
| Talking about the game world, obviously its massive, you can do anything you want, go anywhere you please. Do you think theres a danger you went too far? |
Mis kuradi küsimus see on? a'la "Paistab et mäng on lahe. Mehed miks te nii laheda mängu tegite?"
Lisaks veel:
| Pete Hines: kirjutas: |
| I think its probably fair to say that we dont feel compelled to beat people over the head with the letters RPG and to insist that they acknowledge they are playing a role playing game |
Would it be fair to label Fallout 3, Oblivion with guns? It seems as if the dialogue seems to be the same, the wide open spaces and there are a lot of similarities.
...You know, the dialogue is exactly like the dialogue from Fallout so it may feel similar to Oblivion and I guess in terms of how its structured, but ...
| Kommentaarid: 31 loe/lisa |
28 |
06.08.2008 14:06:10
| With Oblivion and with Fallout we like to have it be such that if you are hardcore and you want to get in to power gaming and the numbers and how youre levelling up, what youre putting skills in, what perks your picking and really sort of power game that... you totally can and if you want to spend most your time doing dialogue or whatever the hell it is, you can. |
217 |
marcor1
65 |
System
06.08.2008 19:05:16
| connor kirjutas: |
Eelmisest lingist:
Äkki ta mõtles selle all seda, et mängu maailm on mängurite riistvara jaoks liiga massiivne ?
_________________ Tuli vaikselt, tuli tasa. Varjud jättis seintele ja maha. |
| Kommentaarid: 14 loe/lisa |
Heineken
06.08.2008 19:32:19
| Ega arvuti kogu maailma korraga ei streami ... ikka jupphaaval loadib , aga mitte load screenidega , ma arvan . Nagu Oblivionis(vähemalt väljas ringi rännates) , Crysises (editoris võtsin piirid maha ja sõitsin hõljukiga saarele ringi peale , mingit load screeni ei tulnud ) , TDUs , jne .
23 |
20.08.2008 22:41:03
| tuleb 31. oktoobril 2008
313 |
Delta
134 |
minake
21.08.2008 17:20:13
| njah, mulle igatahes videod meeldisid, n2is kas ja kuidas see pausiga combat on, fallout 1-2-te nad nagunii ei suuda yletada, a loodame, et on hea ja m6nus fps/rpg, igatahes sai collectors edition tellitud, survival edition on m6eldud paraku ameeriklastele ja seda vist euroopasse ei tulegi...
| Kommentaarid: 164 loe/lisa |
137 |
marko
21.08.2008 17:37:14
2saja taalaga ju ebays täitsa olemas survival edition pakkumised
161 |
minake
22.08.2008 10:25:26
muig, nu kui n6udmine suurem kui pakkumine siis saab alati ulmelisi hindu kysida ju
137 |
Taaviup
| Kommentaarid: 11 loe/lisa |
Delta
134 |
Mario153
| Kommentaarid: 56 loe/lisa |
50 |
andres1221
30.08.2008 14:00:16
| Tundub huvitav, aga paitab, ikka nii oblivion with guns kui olla saab. Mis võib-olla ei olegi kõige hullem, aga loodetavasti ei kisu nii igavaks ära...
30.08.2008 22:26:31
oblivion with guns?
gears of war with pause.
217 |
andres1221
30.08.2008 22:41:42
| londiste kirjutas: |
oblivion with guns?
gears of war with pause. |
Njah, ka võimalik : D
dstar
30.08.2008 23:35:39
Täielik Elder Scrolls: Fallout. Tuleb samasugune unine ja igav soigumine nagu Oblivion. Tõenäeoliselt loevad hääli sisse täpselt samad 3 meest ja üks naine, mis tähendab, et kõik hakkab jälle korduma. Paar tundi võib ju tolmu maitse suus ringi lonkida ja kolle retsida, aga sellest tüdineb väga kiiresti ära. Ja kaua sa seda tuumaseent ikka imetled?
Visuaalselt ei paku mäng midagi huvitavat, ainult üks hallides toonides varemete hunnik. Peategelane on järjekordselt mingisugune isikupäratu tummahammas, kes rääkida ei oska. Pärast Mass Effecti mõjub selline vaikus ikka väga haledalt... Animatsioonid on Bethesdale omaselt puised. Võiks juba motion capture peale mõtlema hakata, liikumine on jätkuvalt aastast 2005... Tüüpilist FPS combatit püütakse varjata ajuvaba VATS süsteemiga. Nii et igati tore mänguke jälle tulemas.
andres1221
30.08.2008 23:40:20
| dstar kirjutas: |
Visuaalselt ei paku mäng midagi huvitavat, ainult üks hallides toonides varemete hunnik. Peategelane on järjekordselt mingisugune isikupäratu tummahammas, kes rääkida ei oska. Pärast Mass Effecti mõjub selline vaikus ikka väga haledalt... Animatsioonid on Bethesdale omaselt puised. Võiks juba motion capture peale mõtlema hakata, liikumine on jätkuvalt aastast 2005... Tüüpilist FPS combatit püütakse varjata ajuvaba VATS süsteemiga. Nii et igati tore mänguke jälle tulemas.  |
Kardan, et pean enam jaolt sinuga nõustuma, aga loodan ikkagi midagi head.
A ja paistab, et ühes gameplay videos oli kuulda, et üks voice actor oli sama, kes Oblivionis või oligi isegi 2 sama. (Kui seal jälle ainult 4 inimest, siis kisub vähe igavaks jah.)
Iceberg
30.08.2008 23:45:49
Dialoogid tunduvad sama tuimad ja igavad nagu nad olid oblivionis
Heineken
31.08.2008 00:20:58
Ma loodan , et seda pausiasja saab maha kuidagi keerata , kasvõi nii et peab muutma mängufaile vms.
Mäng ise tundub norm tulevat , aga see pausi asi on jah ajuvaba .
23 |
Scart
31.08.2008 00:40:07
| VATSi ei pea kasutama, mängi kas sellega või ilma aga mingit kohustuslikku pausitamist ei ole.
101 |
Thing
31.08.2008 01:21:52
huoh, näeb välja täpselt nii sitt nagu ma kartsingi.
WTF, lased mingit autoromu ja see lendab õhku? Mehike tehtud ise kah vist terasest, sitta kanti talub piitsutamist ja vastased tunduvad küll paberist olevad. Ammot tundub kah lõpmatuseni olevat. Masendav kuidas võib hea asja ära sittuda
| Kommentaarid: 20 loe/lisa |
20 |
andres1221
31.08.2008 02:50:31
| Thing kirjutas: |
Mehike tehtud ise kah vist terasest, sitta kanti talub piitsutamist ja vastased tunduvad küll paberist olevad. Ammot tundub kah lõpmatuseni olevat. Masendav kuidas võib hea asja ära sittuda  |
No ma arvan, et tal oli miski god mode peal. Mõni kord devid kasutavad seda, kui mängu demonstreerivad.
nolifer
31.08.2008 08:10:07
| Thing kirjutas: |
WTF, lased mingit autoromu ja see lendab õhku? Mehike tehtud ise kah vist terasest, sitta kanti talub piitsutamist ja vastased tunduvad küll paberist olevad. Ammot tundub kah lõpmatuseni olevat. Masendav kuidas võib hea asja ära sittuda  |
oota ära kuni mäng välja tuleb ja siis hakka halvustama
| Kommentaarid: 8 loe/lisa |
Timberg
ööKARU
272 |
