uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  ATi RV770 aka HD4K seeria märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 26, 27, 28 ... 210, 211, 212  järgmine
heikis
sõnum 29.06.2008 19:23:30 vasta tsitaadiga
aga pidi kõvasti konfima enne kui asja saab sellest.
Kommentaarid: 338 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 290
One
sõnum 29.06.2008 19:51:17 vasta tsitaadiga
link :: Diamond Releases Radeon HD 4870 XOC Unlocked Black Edition
The HD 4870 is a smoking gun dual slot card, PCIE 2.0, with 512MB of DDR5 memory and a clock speed of 800 MHz. The memory speed is 1100 MHz and is designed with 800 stream processors. The HD 4870 provides plug-and-play ATI CrossFireX™ upgradeability with up to quad-GPU support. Continuing with ATI’s Power Play and 55nm processing technology, this card is the fastest and efficient. “The Diamond Radeon HD 4870 XOC Black Edition was clocked to kick some ass”. We didn’t just want a fast card out in the market, we wanted the fastest card that could kick the living daylights and bust some performance records, say Mario Gastelum, Director of Product Development & Engineering. “we wanted a card that kicked the competitions teeth into the curb”, and that’s exactly what our engineers accomplished”. “The firmware was custom designed to enable end users to go beyond the normal over clocked speeds and allow them to push their cards for higher performance via the catalyst control center.” The GPU’s custom firmware has been unlocked to push cards to GPU settings of up to 950 MHz and Memory of up 1200 MHz
800MHz GPU ja 1100MHz(4400MHz) mälu.. ja seda by default.
Lisaks Overdrives lahti GPU oc kuni 950MHz ja Mem oc kuni 1200(4800MHz) thumbs_up.gif
esialgu müüakse antud kaarti vaid ühes kindlas poes.
aga see on suht poh sest, et ega see ainukeseks selliseks kaardiks jää
noonius
noonius
sõnum 29.06.2008 21:13:06 vasta tsitaadiga
assa jummel, aga tundub, et cooler on neil ikka stock. Ma ei leidnud nende saidilt sõnagi selle kohta, et too parema vastu oleks vahetatud.
Mingi paks pihv paugub siin
Heineken
sõnum 29.06.2008 21:24:14 vasta tsitaadiga
Sellised kellad icon_eek.gif icon_eek.gif icon_eek.gif . Kurat , stock cooleriga... aga loodab et see kaart üles ütlema ei hakka ja liiga kuumaks ei lähe .
Need Diamondi poisid ikka oskavad kellata neid kaarte beer_yum.gif thumbs_up.gif . Tahaks benche sellel näha .
ahtol
ahtol
sõnum 29.06.2008 21:41:27 vasta tsitaadiga
Kas pole võimalik, et 4870 kaartidel on umbes sama probleem nagu oli kunagi 7900gt-l? Sai kellata väga kaugele jne, kuid suri suht ruttu maha. Tundus samamoodi et mälud vms andsid üles, kuid tegelikult oli probleemiks toiteahel, mis oli liiga piiripeale tehtud ja ei pidanud def kelladest kõrgemal jooksutamist vastu. Ma võin ka eksida kuid maru tuttav tundub kogu see jutt mulle minevikust....
heretic666
heretic666
sõnum 29.06.2008 21:46:18 vasta tsitaadiga
ahtol, 7900GT-l oli nõrk toiteahel jah. Ei usu, et sama fataalne viga nüüd kordub.
noonius
noonius
sõnum 29.06.2008 21:56:27 vasta tsitaadiga
nah, eks nii paari kolme päeva pärast 8. juulit on teada, kas kaardid peavad vastu või mitte. Siis on massidel näpud kaartidele taha lükatud. Praegu on vist 4870. kaardid liiga vähestel, et mingeid järeldusi teha. Pealegi vägistavad nad neid viimase piirini, et esimestena suuremaid benchi punne foorumitesse postitada. Pole ka siis ime, et need otsad annavad
G80
G80
sõnum 29.06.2008 21:57:35 vasta tsitaadiga
Heineken kirjutas:
Kui korralik soff tulb 4800 seeriale siis 4870 peaks sinna 850+ lendama küll.
Kui muidugi pole mingit BIOS-i "lukku".
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
WäntWõll
make.believe
WäntWõll
sõnum 29.06.2008 21:58:43 vasta tsitaadiga
G80
G80
sõnum 29.06.2008 22:03:53 vasta tsitaadiga
wanawoll kirjutas:
With a bios flash you can get the 4850 to 750mhz, and with some pencil modding you can really clock it. Mine is 940/1200 core/mem under water
No ma ei tea selle kohapealt palju aga oleks tore, kui poleks mingit lukku. 8)
Eks varsti saab teada.
Ära siia kliki
WäntWõll
make.believe
WäntWõll
sõnum 29.06.2008 22:13:07 vasta tsitaadiga
Usun et erinevalt 38xx seeriast pole lukku aga sarnaselt vcore ja vmem on teise voldiga lihtsalt,et sa ei saavutaks umbkaudset 4870 kiirust icon_wink.gif
Heineken
sõnum 29.06.2008 22:18:14 vasta tsitaadiga
G80 kirjutas:
Heineken kirjutas:
Ma mõtlesin mälude kellasid , kuna seal XS foorumites olid paljudel kaardid ära surnud sellistel kelladel icon_redface.gif .
G80
G80
sõnum 29.06.2008 22:33:28 vasta tsitaadiga
ox.ee nüüd ka 4870 kaardid listis:
GigaByte RADEON HD 4870 512MB DDR5 - 3 985 EEK
http://www.ox.ee/est/product/109363
PowerColor RADEON HD 4870 512M DDR5 - 4 120 EEK
http://www.ox.ee/est/product/109383
GeCube RADEON HD4870 512MB DDR5 - 4 160 EEK
http://www.ox.ee/est/product/109393
Need siis kolm odavamat aga jah lao seis hetkel veel 0.
Ära siia kliki
Heineken
sõnum 29.06.2008 22:34:28 vasta tsitaadiga
No kuu-paari pärast peaks kusagil 3,5 kilo kandis olema , kuna ega selle kiibi tootmine kuigi kallis ikkagist ei ole .
libe
kvaliteetne mees
libe
sõnum 29.06.2008 22:35:33 vasta tsitaadiga
WäntWõll
make.believe
WäntWõll
sõnum 29.06.2008 22:44:33 vasta tsitaadiga
Ma juba fikseerisin ASUSE oma ära,seal karbis World Exclusive Hottest Game Bundle – Alone in the Dark thumbs_up.gif
Väike lisaväärtus kindlasti kui hinnavahed 100 eeku ,missest et ma ei ole lugenud mis mäng see on icon_wink.gif
JA muidugi Up to 7ºC Cooler with Exclusive Glaciator Fansink
http://www.asus.com/news_show.aspx?id=11871
:twisted:
enx
sõnum 29.06.2008 22:44:50 vasta tsitaadiga
G80 kirjutas:
njah arvasin ka et mingi 3,5 kilo kanti.... jääb loota et teised pakuvad paremat hinda:D
Kommentaarid: 31 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 26
WäntWõll
make.believe
WäntWõll
sõnum 29.06.2008 22:47:57 vasta tsitaadiga
ATF fiktiivselt kindlasti HV hinnakirjas okse
olc
olc
sõnum 29.06.2008 22:49:06 vasta tsitaadiga
enx kirjutas:
G80 kirjutas:
uusi tooteid ei müü sul keegi võileiva eest, ikka küsitakse tubli summa.
Kommentaarid: 142 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 130
libe
kvaliteetne mees
libe
sõnum 29.06.2008 22:49:15 vasta tsitaadiga
kusagil on nimekiri, mis erinevatel versioonidel bundle on icon_question.gif
WäntWõll
make.believe
WäntWõll
sõnum 29.06.2008 22:51:29 vasta tsitaadiga
libe, Enne 8 juuli ple midagi,kuna müütada ametlikult ei saa icon_neutral.gif
KzxTc
KzxTc
sõnum 29.06.2008 23:06:43 vasta tsitaadiga
G80
G80
sõnum 29.06.2008 23:08:15 vasta tsitaadiga
wanawoll kirjutas:
:twisted:
Seal on kaks 4870, ühel on kaasa mäng ja teisel pole.
Huvitav jah mis teistel kaasa saab, AOC tahaks.
KzxTc kirjutas:
Ära siia kliki
KzxTc
KzxTc
sõnum 29.06.2008 23:09:38 vasta tsitaadiga
Kle need kus näidatud prose, ja single gpu crysis run
WäntWõll
make.believe
WäntWõll
sõnum 29.06.2008 23:13:17 vasta tsitaadiga
G80
G80
sõnum 29.06.2008 23:17:09 vasta tsitaadiga
wanawoll kirjutas:
Samas on vaid aja küsimus, kui 4870 1GB tulevad. 8)
KzxTc kirjutas:
Ei tea.
Ära siia kliki
KzxTc
KzxTc
sõnum 29.06.2008 23:20:52 vasta tsitaadiga
G80 kirjutas:
Kus sa selle "skriini" said ???
WäntWõll
make.believe
WäntWõll
sõnum 29.06.2008 23:21:57 vasta tsitaadiga
Rahune maha ja loe uuesti.
Sul vist ikka on juba liigse RV770 teema sündroom,hammust näppu ja proovi kaks päeva olla siia postitamata thumbs_up.gif
G80
G80
sõnum 29.06.2008 23:26:31 vasta tsitaadiga
KzxTc kirjutas:
G80 kirjutas:
http://www.xtremesystems.org/forums/showthread.php?t=192859
4870 dying thread
Vaadake küsitlust ka.
http://www.xtremesystems.org/forums/showthread.php?t=192937
Heh ma mõtlesin tegelt Assassin's Creed-i, et maksaks 100kr rohkem 4870 eest, kui saaks selle mängu kaasa.
Ära siia kliki
WäntWõll
make.believe
WäntWõll
sõnum 29.06.2008 23:29:29 vasta tsitaadiga
Värske pressikas siis,kaarte saavad valitud müüjad müüma hakata 1. juuli
“The firmware was custom designed to enable end users to go beyond the normal over clocked speeds and allow them to push their cards for higher performance via the catalyst control center.” The GPU’s custom firmware has been unlocked to push cards to GPU settings of up to 950 MHz and Memory of up 1200 MHz.
See oleks küll hea,ei pea igasuguste Riva ja AtiTooli arendajate taga thumbs_up.gif
G80
G80
sõnum 29.06.2008 23:37:45 vasta tsitaadiga
wanawoll, selge, sul on RV770 üledoos, winterwind juba postitas selle, vaata ülesse. icon_biggrin.gif
Radeon HD 4870X2 in the nude, 15% better than 4870 CrossFire?
The card has two 512MB GDDR5 memory buffers, most likely the same 3.6GHz chips found with Radeon HD 4870. We suspect these won't be shared as so many were hoping.
Some performance indications have also been posted and they state that Radeon HD 4870X2 will outperform Radeon HD 4870 CrossFire with around 15% with a decent system in general. We should know more as we approach the launch in late August.
Kokku siis ikka 1GB mälu.
http://www.nordichardware.com/news,7900.html
Ära siia kliki
noonius
noonius
sõnum 29.06.2008 23:46:52 vasta tsitaadiga
hmmm, see et nad mälu ei jaga omavahel (vist) on jama. 15% rohkem kui CF on hea.
Ei tea, kui palju ta powerit kulistab?
virx
sõnum 29.06.2008 23:54:25 vasta tsitaadiga
Soomes esialgu tuleb soodsaim Sapphire 4870.. 3750.- Saadavus : mitte kohe aga varsti peale launchi.
Kommentaarid: 363 loe/lisa Kasutajad arvavad:  :: 5 :: 1 :: 308
WäntWõll
make.believe
WäntWõll
sõnum 29.06.2008 23:54:44 vasta tsitaadiga
Erinevalt sinust ei ole ma 18h foorumis 24-st ja midagi jääb ikka kahe silma vahele thumbs_up.gif
Lisaks erinevalt sinus on mul RV770 masinas ka,niiet mul nati võib-olla icon_razz.gif
vutt
sõnum 29.06.2008 23:55:32 vasta tsitaadiga
Oskab mõni omanik siin kommenteerida - Kas ma saan õigest aru, et 'reference' 4850 propelleri kinnitus on identne 3850-ga. St. teisisõnu, kas Zalmani eelmisele seeriale mõeldud ZM-GWB3850/3870 waterblock istub valutult 4850-le selga?
Kommentaarid: 7 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 6
Heineken
sõnum 29.06.2008 23:57:07 vasta tsitaadiga
Rohkem , kui GTX280 . Ma pakuks 250W või rohkem .
Kahju et 1GB lihtsalt ei jaga omavahel thumbs_down.gif .
Aga see , et 15% kiirem , kui HD 4870 CF , see on küll beer_yum.gif thumbs_up.gif . St. GTX 280 55nm peal jääb sellele alla ilmselt .
Andykas
Andykas
sõnum 30.06.2008 00:14:51 vasta tsitaadiga
Pixmanias 3688.- +150eek post
Kommentaarid: 25 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 22
G80
G80
sõnum 30.06.2008 00:20:40 vasta tsitaadiga
Heineken kirjutas:
Kõlakas rääkis 275W midagi aga eks näis, kuum kaart ta tuleb igatahes ja võimas ka. 8)
Ära siia kliki
HDTanel
Overclocker
HDTanel
sõnum 30.06.2008 00:30:03 vasta tsitaadiga
Noh, kus arvutikeskuse töötajad on icon_razz1.gif tahan nende hindasi icon_smile.gif varsti läheb ostuks thumbs_up.gif
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
Heineken
sõnum 30.06.2008 00:32:26 vasta tsitaadiga
Läks meelest , et vahepeal 275W räägiti icon_redface.gif .
G80
G80
sõnum 30.06.2008 00:32:42 vasta tsitaadiga
PlatoonSgtElias kirjutas:
Arvata on, et seal samad hinnad, ox.ee on viimasel ajal odavam isegi, kui AK.
Ära siia kliki
libe
kvaliteetne mees
libe
sõnum 30.06.2008 00:36:28 vasta tsitaadiga
krt ühtegi pela pole veel, mida viitsikski väga mängida, aga seda kaarti vajan icon_lol.gif
sõnum 30.06.2008 00:40:06 vasta tsitaadiga
Heineken kirjutas:
mind huvitab, kuidas see 15% kiirusevõitu saavutatakse. sisemise pci-e bridge arvelt?
4870 on reviewdes voolutarbelt kuskile sinna performance järgi õigesse kohta jäänud. gtx260 kõrvale või veidi ülespoole. järeldused võib ise teha.
- londiste
Heineken
sõnum 30.06.2008 00:46:52 vasta tsitaadiga
Ma arvan , et selle X2 mõlemad tuumad on natuke kõrgematel kelladel , ja sealt see 15% perfi kasv .
G80
G80
sõnum 30.06.2008 00:49:06 vasta tsitaadiga
londiste kirjutas:
Heineken kirjutas:
Võib olla 4870X2 efektiivsem kuidagi, ühe skriini järgi peaks 4870X2 jooksma täpselt samadel kelladel nagu 4870.
Muidu oleks võinud arvata, et panevad natuke kella juurde aga järelikult on midagi muud.
Samas see pole kindel, kas GPU-Z ikka "tundis" ära korralikult. icon_neutral.gif
Ära siia kliki
WäntWõll
make.believe
WäntWõll
sõnum 30.06.2008 01:00:37 vasta tsitaadiga
G80 kirjutas:
Kõik õige,OX on viimasel ajal hakanud kõvasti konkureerima ja kui hind on samas augus siis sealt nagu saab asju varem kätte icon_rolleyes.gif
libe
kvaliteetne mees
libe
sõnum 30.06.2008 01:09:22 vasta tsitaadiga
x2 puhul ei ole seda probleemi, mis px5 plaatide puhul, kus ei ole cf korral PCIE siin sama
WäntWõll
make.believe
WäntWõll
sõnum 30.06.2008 01:18:28 vasta tsitaadiga
sõnum 30.06.2008 11:06:14 vasta tsitaadiga
[lauri] kirjutas:
ZAndlamb kirjutas:
Mario153 kirjutas:
Jutu järgi kasutab 2/3 rami ja on umbes 10-20% kiirem kui vista.
OT:Pidid modulaarne ka olema. St saad kõik ebavajaliku välja visata.
heikis kirjutas:
Siin teemas paslik juttu jätkata: https://foorum.hinnavaatlus.ee/viewtopic.php?p=4484635#4484635
EDIT:
How to recover ATI Radeon HD 4870 from bad BIOS flash
Seega pole mingeid surevaid kaarte.Ainult paar programmi errorit icon_rolleyes.gif
EDIT2:
ATI HD4850/HD4870 Fan speed hack thumbs_up.gif
One
sõnum 30.06.2008 11:37:17 vasta tsitaadiga
link :: Sapphire HD4850 Review
Väike OC annab kohati ikka väga palju juurde..
ja noh, kaart astub otseses mõttes 280GTX jälgedes..
edit:
Hd 4850 1000/1100
http://www.xtremesystems.org/forums/showthread.php?t=192955
Killer kaart, igasugune G80/G92 baasil vanaraud selle vastu ei saa
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  ATi RV770 aka HD4K seeria mine lehele eelmine  1, 2, 3 ... 26, 27, 28 ... 210, 211, 212  järgmine
