heikis
29.06.2008 19:23:30
| aga pidi kõvasti konfima enne kui asja saab sellest.
| Kommentaarid: 339 loe/lisa |
291 |
One
29.06.2008 19:51:17
link :: Diamond Releases Radeon HD 4870 XOC Unlocked Black Edition
| The HD 4870 is a smoking gun dual slot card, PCIE 2.0, with 512MB of DDR5 memory and a clock speed of 800 MHz. The memory speed is 1100 MHz and is designed with 800 stream processors. The HD 4870 provides plug-and-play ATI CrossFireX upgradeability with up to quad-GPU support. Continuing with ATIs Power Play and 55nm processing technology, this card is the fastest and efficient. The Diamond Radeon HD 4870 XOC Black Edition was clocked to kick some ass. We didnt just want a fast card out in the market, we wanted the fastest card that could kick the living daylights and bust some performance records, say Mario Gastelum, Director of Product Development & Engineering. we wanted a card that kicked the competitions teeth into the curb, and thats exactly what our engineers accomplished. The firmware was custom designed to enable end users to go beyond the normal over clocked speeds and allow them to push their cards for higher performance via the catalyst control center. The GPUs custom firmware has been unlocked to push cards to GPU settings of up to 950 MHz and Memory of up 1200 MHz |
800MHz GPU ja 1100MHz(4400MHz) mälu.. ja seda by default.
Lisaks Overdrives lahti GPU oc kuni 950MHz ja Mem oc kuni 1200(4800MHz)
esialgu müüakse antud kaarti vaid ühes kindlas poes.
aga see on suht poh sest, et ega see ainukeseks selliseks kaardiks jää
728 |
noonius
29.06.2008 21:13:06
assa jummel, aga tundub, et cooler on neil ikka stock. Ma ei leidnud nende saidilt sõnagi selle kohta, et too parema vastu oleks vahetatud.
Mingi paks pihv paugub siin
| Kommentaarid: 8 loe/lisa |
Heineken
29.06.2008 21:24:14
Sellised kellad . Kurat , stock cooleriga... aga loodab et see kaart üles ütlema ei hakka ja liiga kuumaks ei lähe .
Need Diamondi poisid ikka oskavad kellata neid kaarte . Tahaks benche sellel näha .
| Kommentaarid: 24 loe/lisa |
23 |
ahtol
29.06.2008 21:41:27
| Kas pole võimalik, et 4870 kaartidel on umbes sama probleem nagu oli kunagi 7900gt-l? Sai kellata väga kaugele jne, kuid suri suht ruttu maha. Tundus samamoodi et mälud vms andsid üles, kuid tegelikult oli probleemiks toiteahel, mis oli liiga piiripeale tehtud ja ei pidanud def kelladest kõrgemal jooksutamist vastu. Ma võin ka eksida kuid maru tuttav tundub kogu see jutt mulle minevikust....
| Kommentaarid: 6 loe/lisa |
heretic666
29.06.2008 21:46:18
| ahtol, 7900GT-l oli nõrk toiteahel jah. Ei usu, et sama fataalne viga nüüd kordub.
| Kommentaarid: 73 loe/lisa |
noonius
29.06.2008 21:56:27
nah, eks nii paari kolme päeva pärast 8. juulit on teada, kas kaardid peavad vastu või mitte. Siis on massidel näpud kaartidele taha lükatud. Praegu on vist 4870. kaardid liiga vähestel, et mingeid järeldusi teha. Pealegi vägistavad nad neid viimase piirini, et esimestena suuremaid benchi punne foorumitesse postitada. Pole ka siis ime, et need otsad annavad
G80
29.06.2008 21:57:35
| Heineken kirjutas: |
Need Diamondi poisid ikka oskavad kellata neid kaarte . Tahaks benche sellel näha . |
50MHz corele pole küll väga hull.
Kui näeks 850-900MHz kaarte siis oleks juba.
Kui korralik soff tulb 4800 seeriale siis 4870 peaks sinna 850+ lendama küll.
Kui muidugi pole mingit BIOS-i "lukku".
210 |
WäntWõll
make.believe
29.06.2008 21:58:43
G80, Bios lukust ei saa ju juttu olla kui 4850 lendab 900+
300 |
G80
29.06.2008 22:03:53
| wanawoll kirjutas: |
G80, Bios lukust ei saa ju juttu olla kui 4850 lendab 900+  |
| With a bios flash you can get the 4850 to 750mhz, and with some pencil modding you can really clock it. Mine is 940/1200 core/mem under water |
No ma ei tea selle kohapealt palju aga oleks tore, kui poleks mingit lukku. 8)
Eks varsti saab teada.
210 |
WäntWõll
make.believe
29.06.2008 22:13:07
Usun et erinevalt 38xx seeriast pole lukku aga sarnaselt vcore ja vmem on teise voldiga lihtsalt,et sa ei saavutaks umbkaudset 4870 kiirust
300 |
Heineken
29.06.2008 22:18:14
| G80 kirjutas: |
Kui muidugi pole mingit BIOS-i "lukku". |
Ma mõtlesin mälude kellasid , kuna seal XS foorumites olid paljudel kaardid ära surnud sellistel kelladel .
23 |
G80
210 |
Heineken
29.06.2008 22:34:28
| No kuu-paari pärast peaks kusagil 3,5 kilo kandis olema , kuna ega selle kiibi tootmine kuigi kallis ikkagist ei ole .
23 |
libe
kvaliteetne mees
29.06.2008 22:35:33
krt kontojäägi üle vaatama
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
WäntWõll
make.believe
29.06.2008 22:44:33
Ma juba fikseerisin ASUSE oma ära,seal karbis World Exclusive Hottest Game Bundle Alone in the Dark
Väike lisaväärtus kindlasti kui hinnavahed 100 eeku ,missest et ma ei ole lugenud mis mäng see on
JA muidugi Up to 7ºC Cooler with Exclusive Glaciator Fansink
http://www.asus.com/news_show.aspx?id=11871
:twisted:
300 |
enx
29.06.2008 22:44:50
njah arvasin ka et mingi 3,5 kilo kanti.... jääb loota et teised pakuvad paremat hinda:D
| Kommentaarid: 31 loe/lisa |
26 |
WäntWõll
make.believe
29.06.2008 22:47:57
ATF fiktiivselt kindlasti HV hinnakirjas okse
300 |
olc
29.06.2008 22:49:06
| enx kirjutas: |
njah arvasin ka et mingi 3,5 kilo kanti.... jääb loota et teised pakuvad paremat hinda:D |
uusi tooteid ei müü sul keegi võileiva eest, ikka küsitakse tubli summa.
samas müüa club3d 3870 OC edition
130 |
libe
kvaliteetne mees
29.06.2008 22:49:15
kusagil on nimekiri, mis erinevatel versioonidel bundle on
WäntWõll
make.believe
29.06.2008 22:51:29
libe, Enne 8 juuli ple midagi,kuna müütada ametlikult ei saa
Siis saavad ka kodulehed info üles
300 |
KzxTc
29.06.2008 23:06:43
G80, kle kus need tabelid üleval on
G80
29.06.2008 23:08:15
:twisted: |
Seal on kaks 4870, ühel on kaasa mäng ja teisel pole.
Huvitav jah mis teistel kaasa saab, AOC tahaks.
| KzxTc kirjutas: |
G80, kle kus need tabelid üleval on  |
Mis tabelid?
210 |
KzxTc
29.06.2008 23:09:38
| Kle need kus näidatud prose, ja single gpu crysis run
WäntWõll
make.believe
29.06.2008 23:13:17
Parem cuuler väidetavalt ja 1G rammu
300 |
G80
29.06.2008 23:17:09
Parem cuuler väidetavalt ja 1G rammu  |
See käis 4850 kohta.
Rahune maha ja loe uuesti.
Samas on vaid aja küsimus, kui 4870 1GB tulevad. 8)
| KzxTc kirjutas: |
| Kle need kus näidatud prose, ja single gpu crysis run |
Ei tea.
210 |
KzxTc
29.06.2008 23:20:52
| G80 kirjutas: |
Kellates lähevad ikka eriti loomaks kätte.  |
Kus sa selle "skriini" said ???
WäntWõll
make.believe
29.06.2008 23:21:57
Mis puhul kus mina tean mis AOC sa ajad
Sul vist ikka on juba liigse RV770 teema sündroom,hammust näppu ja proovi kaks päeva olla siia postitamata
300 |
G80
210 |
WäntWõll
make.believe
29.06.2008 23:29:29
Värske pressikas siis,kaarte saavad valitud müüjad müüma hakata 1. juuli
The firmware was custom designed to enable end users to go beyond the normal over clocked speeds and allow them to push their cards for higher performance via the catalyst control center. The GPUs custom firmware has been unlocked to push cards to GPU settings of up to 950 MHz and Memory of up 1200 MHz.
See oleks küll hea,ei pea igasuguste Riva ja AtiTooli arendajate taga
300 |
G80
29.06.2008 23:37:45
wanawoll, selge, sul on RV770 üledoos, winterwind juba postitas selle, vaata ülesse.
Radeon HD 4870X2 in the nude, 15% better than 4870 CrossFire?
The card has two 512MB GDDR5 memory buffers, most likely the same 3.6GHz chips found with Radeon HD 4870. We suspect these won't be shared as so many were hoping.
Some performance indications have also been posted and they state that Radeon HD 4870X2 will outperform Radeon HD 4870 CrossFire with around 15% with a decent system in general. We should know more as we approach the launch in late August. |
Kokku siis ikka 1GB mälu.
http://www.nordichardware.com/news,7900.html
210 |
noonius
29.06.2008 23:46:52
hmmm, see et nad mälu ei jaga omavahel (vist) on jama. 15% rohkem kui CF on hea.
Ei tea, kui palju ta powerit kulistab?
virx
29.06.2008 23:54:25
| Soomes esialgu tuleb soodsaim Sapphire 4870.. 3750.- Saadavus : mitte kohe aga varsti peale launchi.
309 |
WäntWõll
make.believe
29.06.2008 23:54:44
Erinevalt sinust ei ole ma 18h foorumis 24-st ja midagi jääb ikka kahe silma vahele
Lisaks erinevalt sinus on mul RV770 masinas ka,niiet mul nati võib-olla
300 |
vutt
29.06.2008 23:55:32
| Oskab mõni omanik siin kommenteerida - Kas ma saan õigest aru, et 'reference' 4850 propelleri kinnitus on identne 3850-ga. St. teisisõnu, kas Zalmani eelmisele seeriale mõeldud ZM-GWB3850/3870 waterblock istub valutult 4850-le selga?
| Kommentaarid: 7 loe/lisa |
Heineken
29.06.2008 23:57:07
Rohkem , kui GTX280 . Ma pakuks 250W või rohkem .
Kahju et 1GB lihtsalt ei jaga omavahel .
Aga see , et 15% kiirem , kui HD 4870 CF , see on küll . St. GTX 280 55nm peal jääb sellele alla ilmselt .
23 |
Andykas
30.06.2008 00:14:51
| Pixmanias 3688.- +150eek post
| Kommentaarid: 25 loe/lisa |
22 |
G80
30.06.2008 00:20:40
Aga see , et 15% kiirem , kui HD 4870 CF , see on küll . St. GTX 280 55nm peal jääb sellele alla ilmselt . |
Kõlakas rääkis 275W midagi aga eks näis, kuum kaart ta tuleb igatahes ja võimas ka. 8)
210 |
HDTanel
Overclocker
30.06.2008 00:30:03
Noh, kus arvutikeskuse töötajad on tahan nende hindasi varsti läheb ostuks
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
Heineken
30.06.2008 00:32:26
Pixmanias suht korralik hind .
Läks meelest , et vahepeal 275W räägiti .
23 |
G80
30.06.2008 00:32:42
| PlatoonSgtElias kirjutas: |
Noh, kus arvutikeskuse töötajad on tahan nende hindasi varsti läheb ostuks  |
Arvata on, et seal samad hinnad, ox.ee on viimasel ajal odavam isegi, kui AK.
210 |
libe
kvaliteetne mees
30.06.2008 00:36:28
krt ühtegi pela pole veel, mida viitsikski väga mängida, aga seda kaarti vajan
30.06.2008 00:40:06
mind huvitab, kuidas see 15% kiirusevõitu saavutatakse. sisemise pci-e bridge arvelt?
4870 on reviewdes voolutarbelt kuskile sinna performance järgi õigesse kohta jäänud. gtx260 kõrvale või veidi ülespoole. järeldused võib ise teha.
_________________ - londiste
217 |
Heineken
30.06.2008 00:46:52
| Ma arvan , et selle X2 mõlemad tuumad on natuke kõrgematel kelladel , ja sealt see 15% perfi kasv .
23 |
G80
30.06.2008 00:49:06
| londiste kirjutas: |
4870 on reviewdes voolutarbelt kuskile sinna performance järgi õigesse kohta jäänud. gtx260 kõrvale või veidi ülespoole. järeldused võib ise teha. |
Võib olla 4870X2 efektiivsem kuidagi, ühe skriini järgi peaks 4870X2 jooksma täpselt samadel kelladel nagu 4870.
Muidu oleks võinud arvata, et panevad natuke kella juurde aga järelikult on midagi muud.
Samas see pole kindel, kas GPU-Z ikka "tundis" ära korralikult.
210 |
WäntWõll
make.believe
30.06.2008 01:00:37
| G80 kirjutas: |
Arvata on, et seal samad hinnad, ox.ee on viimasel ajal odavam isegi, kui AK. |
Kõik õige,OX on viimasel ajal hakanud kõvasti konkureerima ja kui hind on samas augus siis sealt nagu saab asju varem kätte
300 |
libe
kvaliteetne mees
30.06.2008 01:09:22
x2 puhul ei ole seda probleemi, mis px5 plaatide puhul, kus ei ole cf korral PCIE siin sama
WäntWõll
make.believe
30.06.2008 01:18:28
libe, Ei X2 töötab ühes pilus täis kiirusel
300 |
| Kommentaarid: 92 loe/lisa |
One
728 |
