uus teema   vasta Tarkvara »  Arvutimängude foorum »  Crysis märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 195, 196, 197 ... 350, 351, 352  järgmine
G80
G80
sõnum 13.01.2008 15:50:53 vasta tsitaadiga
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
sõnum 13.01.2008 16:10:49 vasta tsitaadiga
G80 kirjutas:
Demole polegi patchi ju icon_razz.gif icon_lol.gif .
BTW: hevi.gif thumbs_up.gif
Kui keegi tahab veel omale crysise fonti siis selle saab siit icon_smile.gif : http://rapidshare.com/files/83461067/CRYSISB.ttf.html (installimiseks:paremklõps-install)
G80
G80
sõnum 13.01.2008 16:46:28 vasta tsitaadiga
Njah,ma mõtlesin,et äkki saab peale panna.
Ära siia kliki
sõnum 13.01.2008 17:34:49 vasta tsitaadiga
tomorrow 12.01.2008 kirjutas:
CPU TimeDemo:
    Play Time: 69.35s, Average FPS: 21.63
    Min FPS: 8.19 at frame 232, Max FPS: 31.54 at frame 109
    Average Tri/Sec: 26714226, Tri/Frame: 1235056
    Recorded/Played Tris ratio: -0.68
TimeDemo Play Ended, (4 Runs Performed)
GPU TimeDemo:
    Play Time: 64.21s, Average FPS: 31.15
    Min FPS: 18.13 at frame 1946, Max FPS: 41.03 at frame 1001
    Average Tri/Sec: 28578162, Tri/Frame: 917466
    Recorded/Played Tris ratio: 1.00
CPU 2 TimeDemo:
    Play Time: 51.79s, Average FPS: 28.96
    Min FPS: 14.61 at frame 198, Max FPS: 36.83 at frame 1376
    Average Tri/Sec: 26889704, Tri/Frame: 928492
    Recorded/Played Tris ratio: 0.77
Crysis v.1.1 Stock Settings/SLI off/1280x1024/Custom-Medium-High/0xAA/DX10/Vista 32bit SP1 v.668(RC0)/FW 169.28
Testisin nüüd ,et palju vahet on Vista SP1 RC(v.668) ja SP1 Beta(v.744) vahel Crysises icon_wink.gif :
tomorrow 13.01.2008 kirjutas:
CPU TimeDemo:
    Play Time: 72.94s, Average FPS: 20.56
    Min FPS: 8.87 at frame 1464, Max FPS: 31.27 at frame 109
    Average Tri/Sec: 25409716, Tri/Frame: 1235597
GPU TimeDemo:
    Play Time: 63.50s, Average FPS: 31.50
    Min FPS: 18.65 at frame 1948, Max FPS: 41.08 at frame 984
    Average Tri/Sec: 28912764, Tri/Frame: 917975
CPU 2 TimeDemo:
    Play Time: 51.70s, Average FPS: 29.01
    Min FPS: 12.19 at frame 196, Max FPS: 36.71 at frame 1377
    Average Tri/Sec: 26911660, Tri/Frame: 927618
    Recorded/Played Tris ratio: 0.78
Crysis v.1.1 Stock Settings/SLI off/1280x1024/Custom-Medium-High/0xAA/DX10/Vista 32bit SP1 v.744(Beta)/FW 169.28
corvette
sõnum 14.01.2008 18:28:21 vasta tsitaadiga
Vajan veidi kellegi abi.
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 48
Cheetah
Cheetah
sõnum 14.01.2008 18:46:02 vasta tsitaadiga
Kommentaarid: 91 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 84
corvette
sõnum 14.01.2008 18:51:34 vasta tsitaadiga
d3t
d3t
sõnum 14.01.2008 20:10:05 vasta tsitaadiga
corvette, doh, proovi uuesti, teed ehk midagi valesti?
Kommentaarid: 85 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 72
tumbuser
sõnum 14.01.2008 20:39:46 vasta tsitaadiga
Mul on hakanud multipleieris tegema seda jama, et teatab ühenduse katkemisest. Ja pea iga kolmas-neljas mäng juba. Ja ei oskagi täpselt öelda, kas peale patch 1.1 või nvidia driverite installi. Kas kellelgi veel sellist jama tuleb ette ja mis võib viga olla?
Seda tahtsin veel küsida, et kes multiplayeris mängib siin veel teist ja mis nimede all ja serverite all? Äkki saaks koos pelada, teha nö tiimitööd. Kui keegi nõus on siis saadaks talle oma mobla nr, msn ja skype, et täpsemalt kokku leppida icon_smile.gif.
"The computer says I need to upgrade my brain to be compatible with the new software."
AFFmees
AFFmees
sõnum 15.01.2008 02:01:19 vasta tsitaadiga
Kas keegi oskaks öelda kust kohast ma saan muuta Multiplayer-is (LAN ainult) SUIT-i? (sama asi nagu diff_hard.cfg;diff_normal.cfg;diff_easy.cfg;diff_bauer.cfg). Ma tegin selle ülilahedaks ja nüüd tahaks lan-is sõpradega pelada (selle "NN" minu MOD-iga). (mitte ülepakutud vaid lihtsalt paremaks)
Inimene on kui peata kana, kes ei oska ega taha, kahe toiduhunniku vahel valida.
Kommentaarid: 132 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 117
Sylar
Sylar
sõnum 15.01.2008 18:13:37 vasta tsitaadiga
No aga muuda siis sõpradel ka cfg-d ära, see ei aitaks?
Allkirja pole hetkel
Kommentaarid: 58 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 52
aX
aX
sõnum 15.01.2008 18:21:13 vasta tsitaadiga
Teemakohane OT:
http://bash.org/?835178
Kommentaarid: 108 loe/lisa Kasutajad arvavad:  :: 3 :: 2 :: 84
softis
softis
sõnum 16.01.2008 20:49:13 vasta tsitaadiga
Suht lol: http://www.escapistmagazine.com/articles/view/editorials/zeropunctuation/2808-Zero-Punctuation-Crysis
fredd
sõnum 16.01.2008 21:05:50 vasta tsitaadiga
softis kirjutas:
Kommentaarid: 33 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 29
omgwtf
omgwtf
sõnum 16.01.2008 21:11:47 vasta tsitaadiga
softis kirjutas:
Hehehe päris hea thumbs_up.gif icon_lol.gif icon_lol.gif Üks korralik a aus reviw icon_smile.gif
Cb4
Cb4
sõnum 16.01.2008 21:51:29 vasta tsitaadiga
No jah icon_biggrin.gif Sippa ülepingutatud see ülevaade, aga eks ta peakski selline humoorikas vist olema.
Kuid ma ei tea, minu meelest on crysis thumbs_up.gif thumbs_up.gif thumbs_up.gif thumbs_up.gif icon_biggrin.gif
Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Kommentaarid: 113 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 95
Asgate
sõnum 16.01.2008 21:54:11 vasta tsitaadiga
Cb4 kirjutas:
Kommentaarid: 17 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 14
Noname
Noname
sõnum 17.01.2008 11:02:09 vasta tsitaadiga
#835178 +(343)- [X]
DHS : Could god make a game so powerful, that even his computer couldn't run it at full settings?
PoorLeno : It's called Crysis.
Kommentaarid: 372 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 321
sõnum 17.01.2008 18:51:58 vasta tsitaadiga
CPU TimeDemo:
GPU TimeDemo:
CPU 2 TimeDemo:
Nvidia ForceWare v.171.16 Beta Driver Update Benchmark Results:
tomorrow 17.01.2008 kirjutas:
CPU TimeDemo:
    Play Time: 51.98s, Average FPS: 28.86
    Min FPS: 5.86 at frame 197, Max FPS: 40.12 at frame 178
    Average Tri/Sec: 26164232, Tri/Frame: 906721
    Recorded/Played Tris ratio: 0.79
GPU TimeDemo:
    Play Time: 58.83s, Average FPS: 33.99
    Min FPS: 22.16 at frame 1941, Max FPS: 41.93 at frame 1770
    Average Tri/Sec: 30534710, Tri/Frame: 898225
    Recorded/Played Tris ratio: 1.02
CPU 2 TimeDemo:
    Play Time: 75.14s, Average FPS: 19.96
    Min FPS: 12.55 at frame 989, Max FPS: 30.82 at frame 109
    Average Tri/Sec: 23451984, Tri/Frame: 1174782
    Recorded/Played Tris ratio: -0.71
Crysis v.1.1 Stock Settings/SLI off/1280x1024/Custom-Medium-High/0xAA/DX10/Vista 32bit SP1 v.744(Beta)/FW 171.16
Väga kenad tulemused eks ole? icon_smile.gif (arvestades,et ainult uus driver).Mis puutub CPU bencmarki siis üks seade läks valesti ja seega on tulemus ~10fps halvem.Parandasin selle ära ja lasen uuesti.Uuendan seda posti uue tulemusega peatselt thumbs_up.gif
G80
G80
sõnum 17.01.2008 18:54:27 vasta tsitaadiga
thumbs_up.gif thumbs_up.gif thumbs_up.gif beer_yum.gif beer_yum.gif beer_yum.gif
See on ulme!
Ära siia kliki
sõnum 17.01.2008 19:07:56 vasta tsitaadiga
tomorrow kirjutas:
CPU TimeDemo:
GPU TimeDemo:
CPU 2 TimeDemo:
CPU TimeDemo:
GPU TimeDemo:
CPU 2 TimeDemo:
EDIT:NB!.Eelnevas postis oli siiski viga icon_exclaim.gif .Nimelt olid CPU tulemused kogemata vahetusse läinud.Vabandan icon_redface.gif .Tsiteeritud lõigu lõpus on viga parandatud.
Btw:Miks ma oma eelnevaid poste muuta ei saa? @ HV icon_eek.gif
symmi
sõnum 17.01.2008 19:11:34 vasta tsitaadiga
oot kust ma neid drivusi saaks? 64bit...
sõnum 17.01.2008 19:13:49 vasta tsitaadiga
symmi kirjutas:
64bit pole märganud veel.Hetkel ainult 32bit icon_neutral.gif .Kui näen 64bit või XP versioone siis karjun seal icon_wink.gif : https://foorum.hinnavaatlus.ee/viewtopic.php?p=4156257#4156257
symmi
sõnum 17.01.2008 23:36:53 vasta tsitaadiga
Kas Q6600@ 3.6ghz annaks suure jõudluse kasvu cryises?? Praegu sees E4300@3ghz.. Oleks vahe suur?
G80
G80
sõnum 18.01.2008 00:19:44 vasta tsitaadiga
symmi kirjutas:
Kahjuks mitte,kuna Crysis ei toeta quad-i,vahe tuleks taktist ja vahemälu suurusest. icon_wink.gif
Ära siia kliki
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Crysis mine lehele eelmine  1, 2, 3 ... 195, 196, 197 ... 350, 351, 352  järgmine
