G80
13.01.2008 15:50:53
Demole ei saagi patchi peale panna?
Kommentaarid: 256 loe/lisa |
210 |
Kommentaarid: 92 loe/lisa |
G80
13.01.2008 16:46:28
tsitaat: |
Demole polegi patchi ju . |
Njah,ma mõtlesin,et äkki saab peale panna.
210 |
13.01.2008 17:34:49
tomorrow 12.01.2008 kirjutas: |
CPU TimeDemo:
Play Time: 69.35s, Average FPS: 21.63
Min FPS: 8.19 at frame 232, Max FPS: 31.54 at frame 109
Average Tri/Sec: 26714226, Tri/Frame: 1235056
Recorded/Played Tris ratio: -0.68
TimeDemo Play Ended, (4 Runs Performed) |
GPU TimeDemo:
Play Time: 64.21s, Average FPS: 31.15
Min FPS: 18.13 at frame 1946, Max FPS: 41.03 at frame 1001
Average Tri/Sec: 28578162, Tri/Frame: 917466
Recorded/Played Tris ratio: 1.00
CPU 2 TimeDemo:
Play Time: 51.79s, Average FPS: 28.96
Min FPS: 14.61 at frame 198, Max FPS: 36.83 at frame 1376
Average Tri/Sec: 26889704, Tri/Frame: 928492
Recorded/Played Tris ratio: 0.77
Crysis v.1.1 Stock Settings/SLI off/1280x1024/Custom-Medium-High/0xAA/DX10/Vista 32bit SP1 v.668(RC0)/FW 169.28
Testisin nüüd ,et palju vahet on Vista SP1 RC(v.668) ja SP1 Beta(v.744) vahel Crysises :
tomorrow 13.01.2008 kirjutas: |
CPU TimeDemo:
Play Time: 72.94s, Average FPS: 20.56
Min FPS: 8.87 at frame 1464, Max FPS: 31.27 at frame 109
Average Tri/Sec: 25409716, Tri/Frame: 1235597
GPU TimeDemo:
Play Time: 63.50s, Average FPS: 31.50
Min FPS: 18.65 at frame 1948, Max FPS: 41.08 at frame 984
Average Tri/Sec: 28912764, Tri/Frame: 917975
CPU 2 TimeDemo:
Play Time: 51.70s, Average FPS: 29.01
Min FPS: 12.19 at frame 196, Max FPS: 36.71 at frame 1377
Average Tri/Sec: 26911660, Tri/Frame: 927618
Recorded/Played Tris ratio: 0.78
Crysis v.1.1 Stock Settings/SLI off/1280x1024/Custom-Medium-High/0xAA/DX10/Vista 32bit SP1 v.744(Beta)/FW 169.28 |
corvette
Kommentaarid: 49 loe/lisa |
48 |
Cheetah
Kommentaarid: 91 loe/lisa |
84 |
corvette
48 |
d3t
14.01.2008 20:10:05
corvette, doh, proovi uuesti, teed ehk midagi valesti?
_________________ next.Insiders - koht mängijatele ja tehnikahuvilistele toredaks ajaveetmiseks.
Kommentaarid: 85 loe/lisa |
72 |
tumbuser
14.01.2008 20:39:46
Mul on hakanud multipleieris tegema seda jama, et teatab ühenduse katkemisest. Ja pea iga kolmas-neljas mäng juba. Ja ei oskagi täpselt öelda, kas peale patch 1.1 või nvidia driverite installi. Kas kellelgi veel sellist jama tuleb ette ja mis võib viga olla?
Seda tahtsin veel küsida, et kes multiplayeris mängib siin veel teist ja mis nimede all ja serverite all? Äkki saaks koos pelada, teha nö tiimitööd. Kui keegi nõus on siis saadaks talle oma mobla nr, msn ja skype, et täpsemalt kokku leppida .
_________________ "The computer says I need to upgrade my brain to be compatible with the new software."
Kommentaarid: 4 loe/lisa |
AFFmees
15.01.2008 02:01:19
Kas keegi oskaks öelda kust kohast ma saan muuta Multiplayer-is (LAN ainult) SUIT-i? (sama asi nagu diff_hard.cfg;diff_normal.cfg;diff_easy.cfg;diff_bauer.cfg). Ma tegin selle ülilahedaks ja nüüd tahaks lan-is sõpradega pelada (selle "NN" minu MOD-iga). (mitte ülepakutud vaid lihtsalt paremaks)
_________________ Inimene on kui peata kana, kes ei oska ega taha, kahe toiduhunniku vahel valida. |
Kommentaarid: 132 loe/lisa |
117 |
Sylar
15.01.2008 18:13:37
No aga muuda siis sõpradel ka cfg-d ära, see ei aitaks?
_________________ Allkirja pole hetkel |
Kommentaarid: 58 loe/lisa |
52 |
aX
Kommentaarid: 108 loe/lisa |
84 |
softis
Kommentaarid: 21 loe/lisa |
21 |
fredd
16.01.2008 21:05:50
ootasingi, millal yahtzee crysis't reviewib
Kommentaarid: 31 loe/lisa |
omgwtf
16.01.2008 21:11:47
Hehehe päris hea Üks korralik a aus reviw
Kommentaarid: 155 loe/lisa |
137 |
Cb4
16.01.2008 21:51:29
No jah Sippa ülepingutatud see ülevaade, aga eks ta peakski selline humoorikas vist olema.
Kuid ma ei tea, minu meelest on crysis
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
Kommentaarid: 113 loe/lisa |
95 |
Asgate
16.01.2008 21:54:11
Cb4 kirjutas: |
Kuid ma ei tea, minu meelest on crysis  |
ülevaade veel parem
Kommentaarid: 16 loe/lisa |
Noname
17.01.2008 11:02:09
#835178 +(343)- [X]
DHS : Could god make a game so powerful, that even his computer couldn't run it at full settings?
PoorLeno : It's called Crysis.
_________________ "Olukord on sitt, aga see on meie tuleviku väetis." - Lennart Meri
"Edu on kehv õpetaja. See ahvatleb tarku inimesi mõtlema, et nad ei saagi kaotada" - B. Gates |
Kommentaarid: 370 loe/lisa |
320 |
17.01.2008 18:51:58
CPU TimeDemo:
GPU TimeDemo:
CPU 2 TimeDemo:
Nvidia ForceWare v.171.16 Beta Driver Update Benchmark Results:
tomorrow 17.01.2008 kirjutas: |
CPU TimeDemo:
Play Time: 51.98s, Average FPS: 28.86
Min FPS: 5.86 at frame 197, Max FPS: 40.12 at frame 178
Average Tri/Sec: 26164232, Tri/Frame: 906721
Recorded/Played Tris ratio: 0.79
GPU TimeDemo:
Play Time: 58.83s, Average FPS: 33.99
Min FPS: 22.16 at frame 1941, Max FPS: 41.93 at frame 1770
Average Tri/Sec: 30534710, Tri/Frame: 898225
Recorded/Played Tris ratio: 1.02
CPU 2 TimeDemo:
Play Time: 75.14s, Average FPS: 19.96
Min FPS: 12.55 at frame 989, Max FPS: 30.82 at frame 109
Average Tri/Sec: 23451984, Tri/Frame: 1174782
Recorded/Played Tris ratio: -0.71
Crysis v.1.1 Stock Settings/SLI off/1280x1024/Custom-Medium-High/0xAA/DX10/Vista 32bit SP1 v.744(Beta)/FW 171.16 |
Väga kenad tulemused eks ole? (arvestades,et ainult uus driver).Mis puutub CPU bencmarki siis üks seade läks valesti ja seega on tulemus ~10fps halvem.Parandasin selle ära ja lasen uuesti.Uuendan seda posti uue tulemusega peatselt
G80
17.01.2008 18:54:27
20-ne pealt 28 peale FPS.
See on ulme!
210 |
17.01.2008 19:07:56
tomorrow kirjutas: |
CPU TimeDemo:
GPU TimeDemo:
CPU 2 TimeDemo:
CPU TimeDemo:
GPU TimeDemo:
CPU 2 TimeDemo:
Väga kenad tulemused eks ole? (arvestades,et ainult uus driver).Mis puutub CPU bencmarki siis üks seade läks valesti ja seega on tulemus ~10fps halvem.Parandasin selle ära ja lasen uuesti.Uuendan seda posti uue tulemusega peatselt  |
EDIT:NB!.Eelnevas postis oli siiski viga .Nimelt olid CPU tulemused kogemata vahetusse läinud.Vabandan .Tsiteeritud lõigu lõpus on viga parandatud.
Btw:Miks ma oma eelnevaid poste muuta ei saa? @ HV
symmi
17.01.2008 19:11:34
oot kust ma neid drivusi saaks? 64bit...
Kommentaarid: 27 loe/lisa |
25 |
symmi
17.01.2008 23:36:53
Kas Q6600@ 3.6ghz annaks suure jõudluse kasvu cryises?? Praegu sees E4300@3ghz.. Oleks vahe suur?
25 |
G80
18.01.2008 00:19:44
symmi kirjutas: |
Kas Q6600@ 3.6ghz annaks suure jõudluse kasvu cryises?? Praegu sees E4300@3ghz.. Oleks vahe suur? |
Kahjuks mitte,kuna Crysis ei toeta quad-i,vahe tuleks taktist ja vahemälu suurusest.
210 |
