fgth
06.09.2007 21:35:06
Originally posted by [GA]Homey
America's Army: Special Forces (Overmatch) v2.8.2 released!
America's Army: Special Forces (Overmatch) v2.8.2 has been released today! This new patch contains the following new features:
- 2 New Multiplayer MissionsRummage and SF Hospital SE
- Enhanced Civilian AI
The civilian AI NPCs have been much improved
- Voice Activation Control
AC enables players to use the America's Army voice recognitions system to issue commands and initiate actions
- Improved TrackIR support
Support for the TrackIR Virtual Reality Headset has been improved
- Logitech G15 Keyboard Support
Added native Logitech G15 gaming keyboard support
- Bug fixes
Lots of bugs got fixed!
- And many more!
Release Notes: Download
The new version is currently available as a patch to update 2.8.1 to 2.8.2. Hurry and get the next version from one of these download locations:
Downloadlinks - Windows Patch (~879 MB):
» Official Bittorrent
» AAOTracker.com
» More Official Mirrors |
| Kommentaarid: 69 loe/lisa |
67 |
kalle78
07.09.2007 18:04:24
| imho see action delay suckib , quickswap ftw !
| Kommentaarid: 15 loe/lisa |
14 |
Sharky
09.09.2007 16:23:31
vaadake Eesti AA Portaali, lehel www.eestiaa.com .
| Kas Eesti serverit ka on |
ETC on tellinud honor serveri kuid see ei ole veel honoriks tehtud , hetkel on see ka vanemas versioonis kuna serverid.ee -l on väga aeglane tagasiside, ip on: 80.79.115.235:1719
| Kommentaarid: 21 loe/lisa |
20 |
-Kaivo-
09.09.2007 17:01:21
See Humemr on seal liiga tugev.
BTR 14.5 mm ei tee hummerile midagi, liiga tank.Uue versiooniga tuleb vähemalt kumm alt ära
| Kommentaarid: 16 loe/lisa |
15 |
-Liitlane-
11.09.2007 19:51:39
Selline probleem, et sain AA uusima versiooni ilusti peale. Nüüd kui tahan minna mängima, siis kõigepealt laseb serverisse ilusti sisse ära. Ütleb, et punkbuster on ilusti up tp date kuid siis mingi 15 sekundit hiljem kickib mind välja. Jõuan ainult lugeda, et ta ei leia mingit file "punkbstr.exe" vms.
Kasutan Vistat. Kas keegi oskab aidata?
RK:
_________________ www.kinnistuhaldus.ee kortermajade haldusteenuse terviklahendused (haldus-, hooldus- ja raamatupidamisteenus) Põlva- ja Võrumaal! |
| Kommentaarid: 231 loe/lisa |
195 |
Vananematu
12.09.2007 00:21:52
| Võib-olla blokeerib tulemüür pnkbstrA või pnkbstrB jooksmist. Kui ei ole nii, siis võib-olla et need teenused ei ole käivitunudki. Kui ei ole käivitunud, siis mõttekas käivitada win-key+R (run) - services.msc - käivitada vastav pnkbstr teenus.
| Kommentaarid: 31 loe/lisa |
28 |
-Liitlane-
12.09.2007 08:21:32
Saigi sinu õpetuse järgi. Firewallist tuli manuaalselt lisada see lubatud programmide hulka. Toimib. Tänud!
195 |
coolmode
12.09.2007 16:19:14
| Mul oli vistaga sama jama sain kicki pb pärast minule aitas mingi pb programm mis võttis kõik tulemüürid ja värgid maha mis blokkisid teda
14 |
-Liitlane-
14.09.2007 10:29:33
mis PB programm see oli? Ehk saad lingi anda?
195 |
coolmode
14 |
-Kaivo-
15.09.2007 11:16:01
Text to Voice on päris tore asi.
Miksrisse ütled selle sõna siis peaks nagu kõigile ütlema mängus, selle pole veel funkama saand.
15 |
Marduuhin
108 |
Velociraptor
15.09.2007 17:26:04
See ei ole nagu TS.
sa räägid , ja siis ta kirjutab mängus message "enemy central" või mis iganes sa ütled.
saab häälega reloadida ka.
offical foorumis ja tracker foorumis on juhised olemas , sa pead tirima softi ja siis control panelist treenima oma häält.
| Kommentaarid: 32 loe/lisa |
30 |
whitebread
16.09.2007 00:31:01
ohoh....kohe proovin seda reloadimis asja...
marex
16.09.2007 17:12:30
| Mul on mingi jama sellega, osadesse serveritesse kuhu ma connectn siis peale autoriseerimist kas vikab bunkbuster välja või saadab vanglasse...
| Kommentaarid: 22 loe/lisa |
20 |
coolmode
17.09.2007 15:47:51
| marex kirjutas: |
| Mul on mingi jama sellega, osadesse serveritesse kuhu ma connectn siis peale autoriseerimist kas vikab bunkbuster välja või saadab vanglasse... |
Vanglasse? Selline asi küll ei ole pb pärast
14 |
marex
17.09.2007 16:04:21
| coolmode kirjutas: |
| marex kirjutas: |
Vanglasse? Selline asi küll ei ole pb pärast  |
Ei vahepeal peksab bukbuster välja ja vahepeal peksab otse vanglasse...
20 |
Vananematu
17.09.2007 19:35:46
| marex kirjutas: |
| marex kirjutas: |
Ei vahepeal peksab bukbuster välja ja vahepeal peksab otse vanglasse... |
Ka endal oli mõni aasta tagasi selline tüütus väga paljudes serverites. Ei saanudki asjast aru. Ükskord kui pea igas teises nõnda tegi, siis kirjutasin kuhugi anti-cheat organisatsiooni või mis iganes lehekülg see oli, siis rääkisid et jah olin mingi arusaamatuse tõttu cheaterite nimekirjas. Hiljem kustutati listist ning probleem lahenes, mingiks ajaks. Nüüd enam pole sellist jama olnud.
28 |
kolakoll
18.09.2007 08:46:35
kas peab nüüd kõik versioonid 2.0-2.8 ära installima ,et mängida saaks?
võib piisab sellest , kui ma tõmban lihtsalt viimase?
| Kommentaarid: 10 loe/lisa |
9 |
kalle78
18.09.2007 12:49:44
| kõik versioonid või viimane full install
14 |
Sharky
18.09.2007 14:39:46
| Et mängida pead tõmbama ikkagi viimase versiooni, kuid kui sul vanem versioon olemas on saad lihtsalt uuendada.
20 |
Ernits
18.09.2007 15:29:53
| Sharky kirjutas: |
| Et mängida pead tõmbama ikkagi viimase versiooni, kuid kui sul vanem versioon olemas on saad lihtsalt uuendada. |
Peaaegu .. honor serverid on olemas versioonidele 2.5, 2.6, 2.7, 2.8, 2.8.1, 2.8.2; viimases versioonis on aga kõigem rohkem mängijaid.
| Kommentaarid: 99 loe/lisa |
86 |
whitebread
18.09.2007 17:34:08
osad mängivad ikka veel 2.6-s ja kas keegi teab miks?
Ernits
18.09.2007 19:56:56
| sellepärast et seda saab mängida ka 1.3ghz arvutil 512 mb ramiga, samal ajal saavutades mängitav fps ja ilus pilt?
86 |
paco
| Kommentaarid: 29 loe/lisa |
28 |
