fgth
06.09.2007 22:35:06
Originally posted by [GA]Homey
America's Army: Special Forces (Overmatch) v2.8.2 released!
America's Army: Special Forces (Overmatch) v2.8.2 has been released today! This new patch contains the following new features:
- 2 New Multiplayer MissionsRummage and SF Hospital SE
- Enhanced Civilian AI
The civilian AI NPCs have been much improved
- Voice Activation Control
AC enables players to use the America's Army voice recognitions system to issue commands and initiate actions
- Improved TrackIR support
Support for the TrackIR Virtual Reality Headset has been improved
- Logitech G15 Keyboard Support
Added native Logitech G15 gaming keyboard support
- Bug fixes
Lots of bugs got fixed!
- And many more!
Release Notes: Download
The new version is currently available as a patch to update 2.8.1 to 2.8.2. Hurry and get the next version from one of these download locations:
Downloadlinks - Windows Patch (~879 MB):
» Official Bittorrent
» AAOTracker.com
» More Official Mirrors |
| Kommentaarid: 69 loe/lisa |
67 |
kalle78
07.09.2007 19:04:24
| imho see action delay suckib , quickswap ftw !
| Kommentaarid: 15 loe/lisa |
14 |
Sharky
09.09.2007 17:23:31
vaadake Eesti AA Portaali, lehel www.eestiaa.com .
| Kas Eesti serverit ka on |
ETC on tellinud honor serveri kuid see ei ole veel honoriks tehtud , hetkel on see ka vanemas versioonis kuna serverid.ee -l on väga aeglane tagasiside, ip on: 80.79.115.235:1719
| Kommentaarid: 21 loe/lisa |
20 |
-Kaivo-
09.09.2007 18:01:21
See Humemr on seal liiga tugev.
BTR 14.5 mm ei tee hummerile midagi, liiga tank.Uue versiooniga tuleb vähemalt kumm alt ära
| Kommentaarid: 16 loe/lisa |
15 |
-Liitlane-
11.09.2007 20:51:39
Selline probleem, et sain AA uusima versiooni ilusti peale. Nüüd kui tahan minna mängima, siis kõigepealt laseb serverisse ilusti sisse ära. Ütleb, et punkbuster on ilusti up tp date kuid siis mingi 15 sekundit hiljem kickib mind välja. Jõuan ainult lugeda, et ta ei leia mingit file "punkbstr.exe" vms.
Kasutan Vistat. Kas keegi oskab aidata?
RK:
_________________ www.kinnistuhaldus.ee kortermajade haldusteenuse terviklahendused (haldus-, hooldus- ja raamatupidamisteenus) Põlva- ja Võrumaal! |
| Kommentaarid: 231 loe/lisa |
195 |
Vananematu
12.09.2007 01:21:52
| Võib-olla blokeerib tulemüür pnkbstrA või pnkbstrB jooksmist. Kui ei ole nii, siis võib-olla et need teenused ei ole käivitunudki. Kui ei ole käivitunud, siis mõttekas käivitada win-key+R (run) - services.msc - käivitada vastav pnkbstr teenus.
| Kommentaarid: 31 loe/lisa |
28 |
-Liitlane-
12.09.2007 09:21:32
Saigi sinu õpetuse järgi. Firewallist tuli manuaalselt lisada see lubatud programmide hulka. Toimib. Tänud!
195 |
coolmode
12.09.2007 17:19:14
| Mul oli vistaga sama jama sain kicki pb pärast minule aitas mingi pb programm mis võttis kõik tulemüürid ja värgid maha mis blokkisid teda
14 |
-Liitlane-
14.09.2007 11:29:33
mis PB programm see oli? Ehk saad lingi anda?
195 |
coolmode
14 |
-Kaivo-
15.09.2007 12:16:01
Text to Voice on päris tore asi.
Miksrisse ütled selle sõna siis peaks nagu kõigile ütlema mängus, selle pole veel funkama saand.
15 |
Marduuhin
108 |
Velociraptor
15.09.2007 18:26:04
See ei ole nagu TS.
sa räägid , ja siis ta kirjutab mängus message "enemy central" või mis iganes sa ütled.
saab häälega reloadida ka.
offical foorumis ja tracker foorumis on juhised olemas , sa pead tirima softi ja siis control panelist treenima oma häält.
| Kommentaarid: 32 loe/lisa |
30 |
whitebread
16.09.2007 01:31:01
ohoh....kohe proovin seda reloadimis asja...
marex
16.09.2007 18:12:30
| Mul on mingi jama sellega, osadesse serveritesse kuhu ma connectn siis peale autoriseerimist kas vikab bunkbuster välja või saadab vanglasse...
| Kommentaarid: 22 loe/lisa |
20 |
coolmode
17.09.2007 16:47:51
| marex kirjutas: |
| Mul on mingi jama sellega, osadesse serveritesse kuhu ma connectn siis peale autoriseerimist kas vikab bunkbuster välja või saadab vanglasse... |
Vanglasse? Selline asi küll ei ole pb pärast
14 |
marex
17.09.2007 17:04:21
| coolmode kirjutas: |
| marex kirjutas: |
Vanglasse? Selline asi küll ei ole pb pärast  |
Ei vahepeal peksab bukbuster välja ja vahepeal peksab otse vanglasse...
20 |
Vananematu
17.09.2007 20:35:46
| marex kirjutas: |
| marex kirjutas: |
Ei vahepeal peksab bukbuster välja ja vahepeal peksab otse vanglasse... |
Ka endal oli mõni aasta tagasi selline tüütus väga paljudes serverites. Ei saanudki asjast aru. Ükskord kui pea igas teises nõnda tegi, siis kirjutasin kuhugi anti-cheat organisatsiooni või mis iganes lehekülg see oli, siis rääkisid et jah olin mingi arusaamatuse tõttu cheaterite nimekirjas. Hiljem kustutati listist ning probleem lahenes, mingiks ajaks. Nüüd enam pole sellist jama olnud.
28 |
kolakoll
18.09.2007 09:46:35
kas peab nüüd kõik versioonid 2.0-2.8 ära installima ,et mängida saaks?
võib piisab sellest , kui ma tõmban lihtsalt viimase?
| Kommentaarid: 10 loe/lisa |
9 |
kalle78
18.09.2007 13:49:44
| kõik versioonid või viimane full install
14 |
Sharky
18.09.2007 15:39:46
| Et mängida pead tõmbama ikkagi viimase versiooni, kuid kui sul vanem versioon olemas on saad lihtsalt uuendada.
20 |
Ernits
18.09.2007 16:29:53
| Sharky kirjutas: |
| Et mängida pead tõmbama ikkagi viimase versiooni, kuid kui sul vanem versioon olemas on saad lihtsalt uuendada. |
Peaaegu .. honor serverid on olemas versioonidele 2.5, 2.6, 2.7, 2.8, 2.8.1, 2.8.2; viimases versioonis on aga kõigem rohkem mängijaid.
| Kommentaarid: 99 loe/lisa |
86 |
whitebread
18.09.2007 18:34:08
osad mängivad ikka veel 2.6-s ja kas keegi teab miks?
Ernits
18.09.2007 20:56:56
| sellepärast et seda saab mängida ka 1.3ghz arvutil 512 mb ramiga, samal ajal saavutades mängitav fps ja ilus pilt?
86 |
paco
| Kommentaarid: 29 loe/lisa |
28 |
whitebread
19.09.2007 21:59:46
| Frankie666 kirjutas: |
| sellepärast et seda saab mängida ka 1.3ghz arvutil 512 mb ramiga, samal ajal saavutades mängitav fps ja ilus pilt? |
ahsoo...nii et mina siis lasen tühjalt Lagi pärast närvi kui saan oma p*tsis raaliga ownida:D
davidco
19.09.2007 22:09:04
muhahahaha, ma kunagi mängisin 2.3ver. celeron 900, mälu 256MB pc133, Geforce mx440 64mb PCI ja sain ka mängitud, aga olin ilgelt närvis lagi pärast ja fragrate oli ka tänu sellele alla igasugust arvestust
_________________ ..... |
| Kommentaarid: 92 loe/lisa |
87 |
Bastardo
19.09.2007 22:48:55
masendav, tegin praegu Rummaget. Sain selle optilise zoomiga relva kätte...on ju loogiline, et selle relva potentsiaali saab kõige paremini ära kasutada siis, kui ma sätin end kohta, kus saan kontrolli all hoida võimalikult suurt ala, mitte ei rabele kuskil kitsastes ruumidas. On? On! Beta teamis mängides on heaks varitsuspunktiks spawni pointi juures üks põõsas, millest saab jälgida kahele poole kulgevat pikka kitsast tänavat ning lisaks veel ka päris mitut katuseharja. Nottisin sellel kohal istudes ühe raundiga mingi viis või kuus vastast maha. Ja mis sai - adminn (ilmselt sai temagi mult kuuli kopsu) kickis mu serverist välja lihtsalt.
See pagana campimise whinemine ajab mind samavõrra närvi kui nooobiks ja muuks taoline sõimamine. Mis campimises halba on, kui ma selle käigus toon teamile võidu? AA on ikkagi taktika mäng mitte mingi arcade kus jooksed ringi ja rambotsed. Eesmärk number 1: püsi elus. Eesmärk 2: hea, kui suudad enda elus hoidmise käigus ka mõne vastase maha võtta. Kui kogu team nii mängiks, oleksi võit enam vähem taskus. Aga ei, peaeb hädaldama:camper nooob camper nooob stfu omg jne. Siis suure hurraaga arutult vastase kuulide alla hüppama, surma saama ning jälle hädaldama hakkama.
Tänan, sain kah ennast tühjaks hädaldatud
_________________ "Siiski, julgeksin arvata, et siiski antud juhul, nagu ka paljudel, ütleksin isegi, et siiski kõikidel juhtudel oma isikliku arvamuse
põhjendamine omab siiski küllaltki suurt kaalu, eriti valdavalt, ma ütleksin, negatiivse arvamuse puhul" (A. Rüütel) |
| Kommentaarid: 20 loe/lisa |
12 |
GertR
20.09.2007 10:57:47
| Eesmärk number 1 peaks olema missiooni/ülesande täitmine
| Kommentaarid: 4 loe/lisa |
whitebread
20.09.2007 17:09:27
aga võib-olla asi on selles, et nad mõtle samamoodi nagu sina!!?? Campimine on taktika, sellega olen täiesti nõus, aga kui oled ainsana elus ja campid, siis nad tahavad, et kas sa tapad ruttu kõik ära või sured ise ruttu ära, et saaks kohe otsast peale alustada. Lõppude lõpuks nad tahavad punkte saada, aga campimine seda "kiiresti" ei võimalda või ma eksin selle suhtes`?
Mina isiklikult campin ka, aga ma arvestan teistega ja teen rambot, sest ma ei ole nii kõva kutt et ownin kõik ära:D
Vananematu
20.09.2007 20:27:22
| Bastardo kirjutas: |
Tänan, sain kah ennast tühjaks hädaldatud  |
Nii see on. See peitub ikka inimeses eneses. Valus on ju vaadata, kui teine punkte saab (mis iseenesest ei ole mitte midagi väärt). Kui punktid ei ole argumendiks siis virtuaalse tapmise pärast oldakse valmis kasvõi füüsiliselt kraesse kargama ning ma usun, et ilma muule mõtlemata võidakse ka päriselt mõttes teine inimene enda silmis surnuks tunnistada või vihavaenlane luua. Just nagu virtuaalne kill oleks sult tükki küljest rebinud - muidugi seep see toimubki, kui liialt süvenenult virtuaalmaailm omaks võetaks.
See on ju muidugi naeruväärne, kuid kahtlemata ei toimu see vaid virtuaalsel tasandil nii, vaid kõigis elu valdkondades, tööpositsioonidel ning muudel konkureerivatel aladel. Ehk siis pole mitte midagi uut, inimene nurkasurutud olukorras, närvilises olekus või muudes analoogsetes situatsioonides laskub lihtsalt nii primitiivsesse ajusoppi, et tal on mõttes vaid loomalikud käitumisinstinktid. Muidugi loomad vist on isegi arukamad valdkonnas, mis puutub teise vaenu ning "tagasitegemisse", kuna loom tapab vaid siis kui vaja, mitte lihtsalt lõbu pärast.
V4ga suur üldistamine:
Mis puutub veel mängu siis ootan juba U3 mootoril põhinevat AA-d Vaadates üldse fps-e siis siuke tunne, et mängud on seisma jäänud. Jah on küll seal reaalsem joonistatud keskkond (crysis, heavy rain jne). On küll mitmesugust füüsikast lähtuvaid efekte rakendatud (crysis, BIA jne) kuid mängud üldiselt seisavad. Vähemalt võrgumängud. AA-s, mis on siiski minu jaoks kõige reaalsem sõdurisimu, on selles väga palju puudu, just füüsika. Loodetavasti toimub selles valdkonnas edasiminek U3 mootorit kasutades. Kuigi tõsi, võrguliiklus muutuks sellest ka aeglasemaks arvatavasti. Aga purustuse aste on hakanud mind viimasel ajal piinama. Kui hääled on enamvähem hirmuäratavad (korraliku helisüsteemi kaudu muidugi) siis purustused mida granaadid ja muud lõhkelaengud tekitavad on jama (igas suuremas võrgumängus). Fear on purustuste osas küll väike edasiareng, kuid põhijoon purustustega manipuleerimiseks on siiski lineaarne, olematu. Silmapiiril vist on mõned tehnikad mida tulevikus võidakse rakendada, et kui kukub majas üks blokk, siis kukuvad ka teised, mis baseeruvad, toetuvad sellel ühel tükil. Muidugi need vähesed võimalikud tehnikad ning reaalsema füüsika integreerimised on arvatavasti väga kaugel praegustest võrgumängudest.
Mängides ühe ja sama mängitavusega tuleb ikka ette hetki kus mõtled: näiteks snaiperina, näed oma mehi liikumas eespool. Vaenlane tuleb, viskab granaadi meestele jalge ette. Ei osata midagi teha, siis tulistad ühe kuuli vastu granaadi serva, mis tõukab granaadi eemale ning päästab elud; või järgmine situatsioon, hakkad relva laadima ning käsi värisedes kukub salv maha, läheb jälle aega et uus võtta ning vana üles korjata (muidugi selle olukorra tõenäosus võiks olla mingi juhusliku generaatoriga tekitatud ning toimuda vaid teatud olukordades, kuulirahe või muudes situatsioonides); või komistad maha relv kukub käest; ning veel, täpselt sihtides kedagi kätte saab mees vaid teise käega lasta, olles eelnevalt muidugi relva uuesti üles korjanud; ning selliseid väikseid detaile tuleb mõttes sadu iga kord ette, kui AA-d mängid, et mis seal kõik olla võiks.
Igal juhul loodan, et selline detailsus ning füüsika kasutus ka ükskord jõuab ühte heasse võrgu sõdurisimulaatorisse. Kuigi olgem ausad, paljud nendest detailidest oleksid juba ammu olnud võimalikud võrgumängudes. Aga miks nii ei teha, ma ei tea. Ju siis ei ole kellelgi veel sellist eeskuju võtta ning vaadatakse et saab ka ju ilma, nii-öelda üldist simuleeritust kasutades.
28 |
Bastardo
20.09.2007 21:28:44
Rääkides konkreetsest, minupoolt kirjeldatud, situatsioonist, siis ma ei olnud ainus ellujäänu teamist ja tõenäoliselt ajaski just see neid närvi, et ma mitte ei surnud vaid tapsin ise pea aegu kõik ära. Kiiresti.
Kui teami viimane liige laseb end arutult maha tappa, siis meeskond jääb punktidest (eelistaksin siiski rääkida võidust/kaotusest) ilma, mitte aga ei kogu neid. Muidugi jah, kasu pole ka sellest, kui viimasena ellujäänu end kuskile lauasahtlisse peidab ja hiirvaikselt seal passib, lootes, et round saab enne läbi kui tema surma saab.
Siis peaks ehk mängima hoopis tetrist, seal saab ropult punkte, kui neli rida korraga ära kaotad.
Siinkohal soovitaks näiteks Batelfieldi - seal on respawn loetud sekundid pärast surma.
viimati muutis Bastardo 20.09.2007 23:15:47, muudetud 1 kord |
12 |
vilkuur
20.09.2007 21:56:44
Mis on sellel utoopial pistmist reaalsusega
_________________ The first principle is that you must not fool yourself — and you are the easiest person to fool. |
95 |
Vananematu
20.09.2007 23:49:16
| vilkuur kirjutas: |
Mis on sellel utoopial pistmist reaalsusega  |
Mitte et sina, vana AA pelaja sellest aru saaksid. Aga nagu ma ennist rääkisin mitte ainult see, mida reaalseks peetakse vaid mis võimalik oleks. See oli vaid üks näide ning nagu ma teksti alguses märkisin väga üldistav tekst. Minu mõttes ei ole vaid võimalused, mida ka reaalselt tehakse sõjaolukorras kuid mida veel siiski kannatab teha toetudes mängu füüsikamootorile ning lisades omalt poolt improvisatsiooni ning fun factor saab uue tähenduse. Korraliku füüsikatoega mäng ning täpsete laskudega saaks igast kino teha olgu see siis reaalne või mitte. Kui õnnelik tabamus lööb granaati kumeruse pihta kus ekstra granaadi pinda tungimist ei oleks ning lihtsalt riivaks jne siis oleks ma usun võimalik granaat eemale tõugata. Ma ei mõtlegi, et seda tehakse kuid ma mõtlesin lihtsalt mida kõike võiks teha. Ning see oli, vaid üks väga tühine näide.
viimati muutis Vananematu 21.09.2007 20:29:12, muudetud 1 kord |
28 |
whitebread
21.09.2007 10:55:56
Bastardo, mis sa mulle tetrist soovitad ma lihtsalt räägin nii nagu asjad on või vähemasti kuidas asjad tunduvad minu arust
Pihv
21.09.2007 11:07:19
Väga head ideed sul Vananematu, ma usun et see kõik oleks ka hetkel teostatav kuid pole lihtsalt nii häid arvuteid enamustel mängijatel et seda mängu jooksutada. Ja mingi 5% mängurite jaoks ei ole mõtet toota.
Kuid selles võib 100% kindel olla et need ajad pole enam kaugel kui mängud sinnamaani arenevad.
94 |
Lotharius
rallisibul
21.09.2007 15:12:25
Bastardo täiesti nõus, et see whine tüütab täiega ära kui keegi campib. Krt snaiperi ülesanne ongi see, et ta oleks võimalikult varjus ja samas omaks ülevaadet lahinguväljast ning võtaks maha neid keda näeb. OK ma saan aru, et see kui mingi SAW või G vend kuskil põõsas passib on vale, aga samas pole mängu ülesanne otse lampi tulle jooksmine ainult seepärast et mingi vant, kes esimenesena surma saab, ei viitsi oodata.
117 |
[]Wiz4rd
22.09.2007 12:33:46
| pub ftw
kolakoll
23.09.2007 10:45:40
neile kellel pole just eriti kõva kast
siis teadmiseks: et v2.8.2 on täiesti mängitav ka gf2 64mb kaardiga (prose 2500+ barton ja giga rammi)
9 |
Vananematu
23.09.2007 14:33:24
| kolakoll kirjutas: |
siis teadmiseks: et v2.8.2 on täiesti mängitav ka gf2 64mb kaardiga (prose 2500+ barton ja giga rammi) |
Kusjuures nüüd ma nägin selle oma silmaga ära. Videokaart ei koti AA-d peaaegu üldse. Kui SF snakeplain jooksis keskmiselt kuskil 18 fps siis videokaardi väljavahetamisel 9600XT pealt x1950PRO peale ei muutunud AA-s mitte midagi. Absoluutselt mitte midagi. See kinnitas mu varemaid kahtlusi, et mida versioon edasi, seda rohkem protsessori ressurssi õgitakse. Seda vana U engine kahte ei huvita uued videokaardid mitte karvavõrtki. Protsessor saab vaid korralikku koormust vanale mootorile keerulisi skeeme ning funktsioone üles ehitades.
28 |
raul141
23.09.2007 16:48:13
mälu ka samas minu arust ögivad
_________________ dell somm ding mi poi |
22 |
paadimees
27.09.2007 22:38:25
tere
mul väike probleem: vistas ei lase mängu installida. viskab mingi errori ette ( kahjuks ei jõudnud läbi lugeda) ja ütleb, et proovi uuesti tõmmata ja ehk siis läheb tööle.
Kas kellelgi on ehk sama probleem olnud ja oskab anda lahenduse?
kalle78
28.09.2007 17:58:50
| proovi uuesti installida ja edasta meile kah veateade , ilma selleta pole midagi teha. Muidugi võib dl olla corrupt
14 |
paadimees
28.09.2007 20:20:12
Ühe teise mängu installimise puhul annab veateateks: d3dx9_30.dll was not found. directx-s siis probleem?
hakkan uuesti AA-d tõmbama.
...ja ikka sama jama: failed to install ISKernel files ???
Vananematu
28.09.2007 22:34:35
| paadimees kirjutas: |
...ja ikka sama jama: failed to install ISKernel files ??? |
Kui laptop sitt siis pole midagi teha. R44gi parem meile oma süsteemist.
28 |
paadimees
28.09.2007 23:55:23
AMD Athlon 4800+
mälu 2047MB
ATI Radeon HD2600XT
Probleem lahendatud: installima peab adminnina.
lugesin sellest, aga ei taibanud, et kasutama peab paremat hiireklahvi:)
tänud abi pakkumast ja kaasa mõtlemast.
lemmikuks csar, ehk kohtume lahingus?
viimati muutis paadimees 29.09.2007 16:32:07, muudetud 1 kord |
Velociraptor
29.09.2007 01:09:23
| Vananematu kirjutas: |
Igal juhul loodan, et selline detailsus ning füüsika kasutus ka ükskord jõuab ühte heasse võrgu sõdurisimulaatorisse. Kuigi olgem ausad, paljud nendest detailidest oleksid juba ammu olnud võimalikud võrgumängudes. Aga miks nii ei teha, ma ei tea. Ju siis ei ole kellelgi veel sellist eeskuju võtta ning vaadatakse et saab ka ju ilma, nii-öelda üldist simuleeritust kasutades. |
cant agree more.igasse online mängu tulevad nn "cs lamz0rid" , püsigu CSi juures, ega ärgu nussigu teisi mänge ära.
30 |
lauri23
01.10.2007 20:29:39
Oskab keegi öelda miks mul koguaeg mäng pange paneb ja critical errori ette lööb? Just siis kui saan relva mida tahtsin
29 |
Velociraptor
01.10.2007 22:28:51
tavaliselt wini või muu softiga seotud.
format & reinstall tavaliselt parim lahendus.
mul ka esineb vahest.. kõigil ilmselt
30 |
crypto
02.10.2007 16:02:46
lauri23, AA ja critical error käivad käsikäes, aga kusagil eesti aa foorumis aastaid tagasi oli õpetus Smilodoni poolt, kuidas teatud juhtudel sellest errorist lahti saada, uuri-puuri, äkkist saad vastuse kusagilt sealt kätte...
_________________ 61. Logistikapataljoni võitleja |
| Kommentaarid: 42 loe/lisa |
37 |
