heretic666
05.08.2007 15:02:22
| kas tasuks võtta lähiajal 8800GTS või siis oodata need G92 kaardid ?
| Kommentaarid: 73 loe/lisa |
symmi
05.08.2007 17:18:09
| heretic666 kirjutas: |
| kas tasuks võtta lähiajal 8800GTS või siis oodata need G92 kaardid ? |
Ise võtsin ja olen väga rahul
| Kommentaarid: 27 loe/lisa |
25 |
| Kommentaarid: 92 loe/lisa |
matzz007
05.08.2007 20:56:25
ma ise usun küll et hinnalagus ei tule nüüd väga väike, ning ootan ära selle ning siis vast 8800
_________________ Project Wooden Case |
99 |
minake
05.08.2007 21:22:37
allikas
Unlike previously expected the codename for nVidia's next generation GPU will NOT be "G90" but instead be "G92".
I have some info form NVIDIA insider about the upcoming G92 graphics processors.
G92 will be released in November 2007 timeframe in the form of "GeForce 9800" series.
"G92" GeForce 9800 GTX specs.
- 65nm process technology at TSMC.
- Over one billion transistors.
- Second Generation Unified Shader Architecture.
- Double precsion support (FP64).
- GPGPU native.
- Over one TeraFLOPS of shader processing power.
- MADD+ADD configuration for the shader untis (2+1 FLOPS=3 FLOPS per ALU)
- Fully Scalar design.
- 512-bit memory interface.
- 1024MB GDDR4 graphics memory.
- DirectX 10.1 support.
- OpenGL 3.0 Support.
- eDRAM die for "FREE 4xAA".
- built in Audio Chip.
- built in tesselation unit (in the graphics core"
- Improved AA and AF quality levels
Pros.
65nm process will allow for better yields and better power consumption. power consumption will be lower than that of a GeForce 8800 GTX.
GeForce 9800 GTX will be over two times faster than a GeForce 8800 Ultra in real world games and applcations.
Release date : November 2007. There will be TWO products at launch: The flagship GeForce 9800 GTX and the second fastest GeForce 9800 GTS.
price for the GeForce 9800 GTX will be 549-649 USD.
price for the GeForce 9800 GTS will be 399-449 USD.
| Kommentaarid: 164 loe/lisa |
137 |
05.08.2007 21:23:20
| matzz007 kirjutas: |
| ma ise usun küll et hinnalagus ei tule nüüd väga väike, ning ootan ära selle ning siis vast 8800 |
Toodete müüki tulek on ju teada ja pole ka NV'l karta mingit ATI rünnakut, seega kõik kogused kaunis hästi arvestatavad...mina mingit olulist alet ei ootaks.
Point see, et kõik sõltub sellest palju kaarte/chippe NV'l endal kätte jääb.
Hea näide 6800LE AGP versioon, mis lõppes Saksamaa ladudes super kiiresti... ~2 partiid ja oligi otsas. Pigem on oodata alet ATI rindelt, kui õigeks ajaks 65nm valmis ei saa, sest nemad ei saa üldse endale lubada laojääkide kasvu.
201 |
Ho Ho
05.08.2007 21:34:58
minake, see on juba vana kõlakas ning võib üsna kindlalt väita, et suurem osa neist numbreist on lausvaled
87 |
minake
05.08.2007 21:45:19
| nu ex septembris saab 2kki midagi reaalsemat kusagil n2ha m6ni test v6ib-olla? kuigi ex p2ris reaalselt teab siis kui kaardid myygil ja kasutajad arvamusi jagavad.
137 |
excalibur
05.08.2007 21:48:38
| kui tuleb peajagu üle see kaart siis olen 9800peal
262 |
G80
05.08.2007 22:21:57
| Ho Ho kirjutas: |
minake, see on juba vana kõlakas ning võib üsna kindlalt väita, et suurem osa neist numbreist on lausvaled  |
Suurem osa numbritest laus valed?Mille alusel sa seda ütled,1GB mälu tuleb kindlasti ja 512-bit oleks ka loogiline,65nm pole ka midagi võimatut.
Ning veel 1 miljard transsi,ei näe midagi ulmelist,ainuke "kahtlane" on see eDRAM die for "FREE 4xAA".Aga ülejäänud numbrid on enam-vähem tõesed imo.
210 |
05.08.2007 22:30:55
| üldine visioon pole tõesti vale... seda enam, et NV võtab asja pigem rahulikult ja tegelikult saavad nad ATI vigadest isegi õppida... otsest vajadust G92 samal ajal kui G80 tuli välja tuua pole.
201 |
Ho Ho
05.08.2007 22:53:56
Defineeri mõiste:
- GPGPU native.
NV ise ütles, et FP64 tugi tuleb ainult Tesla seerias, ehk siis ainult spetsiaalsetes Cuda jaoks mõeldud kaartides.
Paku, kui suur peab olema too eDRAM et sellest ka mingit kasu oleks? XB's on seda 10M ning ka seal suhteliselt madala reso ja 16bit värvikanalitega on seda vähevõitu. Samuti räägi kuidas on võimalik too eDRAM mahutada ära sinna >1B transside eelarvesse, eeldades et nad ei pea >1B all silmas näiteks ~5B transsi
Suht suures seoses eelmise punktiga. Kui kui palju kasu sellisest läbilaskest on, kui tol kaardil peaks olema ka too ülikiire cache? Julgeks öelda, et kui too helesinises unenäos GPUl olev cache on vähegi mõistliku suurusega siis muutub 512bit mälu mõttetuks. Ehk siis kui on 512bit mälu muutub cache mõttetuks. Kaks korraga on raiskamine mis suurt midagi paremaks ei tee.
Äärmiselt kahtlane, see on sisuliselt geometry shaderi edasiarendus ning kõik ju räägivad unified shader architecture'st
Mis on sel erinevat varasema G80'ga?
Põhimõtteliselt ainsad usutavad numbrid on 65nm, >1B transi, teise generatsiooni unified arhitektuur, >1TFLOPS võimsus, Fully Scalar design, DX/OpenGL tugi ja parendatud AA/AF. Neis pole midagi üleloomulikku ning suht palju neist on juba praegu olemas või üsnagi loogilised edasiarendused. 512bit/1024M mäluarhitektuuri osas julgen kahelda. NV'l piisab praegu kõvasti väiksemast läbilaskest võrreldes R600'ga, ma ei imestaks kui NV jätkaks mõnevõrra madalama läbilaskega. 384bit@2.16GHz on Ultra jaoks juba vaat et rohkem kui tarvis, sama läbilaskega R600 jääb väga kaugele maha. Sügiseks mingi 2.5GHz+ GDDR4 peaks olema üsnagi piisav päris pikaks ajaks.
Ehk siis tõesti, seal on üsna mitmeid asju mis peaks üsna peagi kasutusse võetama, samas on seal ka kõvasti muud jama mis üsna kindlasti vale on.
87 |
05.08.2007 23:24:07
Nohh ega sinna ongi lihtsalt kamaluga asju loobitud
Umbes nii, et kõik asjad kokku kogutud ja äkki miski ennustatust ikka täppi läheb
201 |
Xcater
06.08.2007 09:59:47
| GDDR4 nvidia9800GTX.....kas sinna taha on vaja mingit tuumaelektrijaama ka w?
| Kommentaarid: 29 loe/lisa |
26 |
Mario153
06.08.2007 10:43:19
| Xcater kirjutas: |
| GDDR4 nvidia9800GTX.....kas sinna taha on vaja mingit tuumaelektrijaama ka w? |
Väidetavalt võtab poole vähem voolu kui 8800GTX 8) Kui see poole vähem äkki päris tõsi pole siis kõvasti vähem kindlasti
| Kommentaarid: 56 loe/lisa |
50 |
Xcater
06.08.2007 10:59:58
| Mario153 kirjutas: |
| Xcater kirjutas: |
Väidetavalt võtab poole vähem voolu kui 8800GTX 8) Kui see poole vähem äkki päris tõsi pole siis kõvasti vähem kindlasti  |
nuu ei tea jah eks see ole rohkem vist väide aga faki saab selgitada siis kui kellelgi kaart käes:D
26 |
Ho Ho
06.08.2007 11:05:41
Ma pole kuulnud, et võtaks poole vähem. Vähem küll aga numbritest pole keegi rääkinud.
Ise usun, et väga palju vähem ei võta, muidu jääks liiga palju ressurssi lihtsalt niisama seisma. Pigem keerata volti tehases juurde ning tõsta voolutarve kusagile Ultra lähedale ning selle läbi saada hunnikuga võimsust juurde
87 |
06.08.2007 12:29:00
| üldiselt suht savi mida nad selle max loadi tarbimisega teevad(selles mõttes, et võib ka natuke suurem olla kui 8800GTX)...pigem ootaks efektiivset idle(2D) tarbimist, sest enamus aega ju kaart selles seisus.
201 |
NATAS999
06.08.2007 14:23:17
Kui tõesti 549-649 USD tuleb hind, ja eestimaal kah sihukse hinnaga saaks, siis vist ikka novembris teen arvutile "euro-remondi" ära ilmselt, oleneb muidugi ka muudest asjaoludest muidu oli plaan 8800gtx, aga kui juba novembris g92, siis septembris pole mõtet 8800gtx osta või mis.
| Kommentaarid: 41 loe/lisa |
39 |
epohh
06.08.2007 15:15:25
| Magic kirjutas: |
| üldiselt suht savi mida nad selle max loadi tarbimisega teevad(selles mõttes, et võib ka natuke suurem olla kui 8800GTX)...pigem ootaks efektiivset idle(2D) tarbimist, sest enamus aega ju kaart selles seisus. |
Praeguste kõlakate järgi on kaudselt selle probleemi lahenduseks Hybrid SLI, mis peaks tulema nvidia MCP72 või MCP78-ga AMD protsessoritele.
One
08.08.2007 10:39:57
Esimeses postis olevad andmed on bs.
Samal saidil nüüdseks uued andmed:
HEY GUYS I JUST FOUND THIS, ITS EVEN NEWER INFORMATION ON THE 9800 SERIES!
Ive just received word from the most reliable source in the world.....JESUS. He has told me the following about the 9800 JTX (Jesus X-Treme) !
-6500MM (mega metre) process technology, at MSMMMCFPPC
-Over 700 thousand transvestites
-Second Generation Unified Vader Architecture
-Triple precision magnitude flux capacitors
-GPGPUPGPU-PEE-YEW! native
-Over one TeraFARTS of shader processing ability like jedi's
-MAD+AD homosexual party
-Fully secular priesthood design (touch those kiddies with extra fps!)
-1280-bit memory interface (cos god doesn't hold back)
-4TB GDDR7 graphics memory
-DirectX 42.12c support
-OpenJL 500.326.8 compliant shader support
-eDRAM die for "FREE BJ from a priest"
-built in Cunt (for real men)
-built in boobs
-Improved AA and Ahh fuck off quality levels
"Produced by god, patented by jesus"
You made so many spelling mistakes in your version Erik. Im thinking a real Nvidia source would be less sloppy. |
728 |
symmi
08.08.2007 11:19:52
Kas see on nali?
25 |
One
08.08.2007 11:28:22
| symmi kirjutas: |
Kas see on nali?  |
ei, siin teemas on ainult ametlikud faktid
728 |
heretic666
08.08.2007 11:39:15
| ot: |
built in boobs |
G80
08.08.2007 11:58:07
See on mingi "koomiku" välja mõeldis.
210 |
One
08.08.2007 11:58:49
| G80 kirjutas: |
See on mingi "koomiku" välja mõeldis.  |
samamoodi nagu esimeses postis olevad specid
EDIT:
ah, et kui samast threadist irooniaga post kopida siis on kohe ving lahti?
samas väljamõeldud faktid tunduvad tõesed ja jeesuse teine tulemine näib lähenevat?
viimati muutis Winterwind 08.08.2007 23:53:02, muudetud 1 kord |
728 |
G80
08.08.2007 12:00:46
| Winterwind kirjutas: |
| G80 kirjutas: |
samamoodi nagu esimeses postis olevad specid |
Eks me näe.
Pooled neist on tõsi,olen mina kindel.
Eks see ole nagu G80 oli,keegi ei uskunud,et tuleb selline aga tuli.
210 |
Xcater
08.08.2007 13:39:11
ei tea kas see on võetud aastast 2100 või??keegi näeb tulevikku
26 |
Nu
08.08.2007 14:40:54
Ega siin pole midagi uut. Tulevikku on nähtud NV10 väljatulekust alates kui järgmise (ja vahel ka ülejärgmise)
gen. kaardi specid on ammu enne tegelikku turuletulekut kindlalt teada.
_________________ DO you want it.. And if you had it would you flaunt it...
ss |
157 |
Ho Ho
08.08.2007 17:27:08
| G80 kirjutas: |
| Pooled neist on tõsi,olen mina kindel. |
https://foorum.hinnavaatlus.ee/viewtopic.php?p=3754209#3754209
Kui sealt kokku lugeda asjad, millega nõustusin siis saab hädapärast pooled kokku jah, mis sest et neist pooltest suht suur osa võimsusega miskist otsast seotud pole
87 |
Zonerman
08.08.2007 18:28:06
| G80 kirjutas: |
Hakkab pihta see hala jälle. So? kui midagi paremat pole siis las olla niikaua kuni tuleb täpsem ja parem inf (enamus saitidel on see inf ju siis on seal mingi tõde sees). Pole vaja targutada, et see on BS jne, Me teame, et sa oled fanatic vms ja pole üldse vaimustatud kui selgub mida Nvidia võib välja tuua, pigem halad edasi, et see on võimatu ja see tahab rämedat jahutust ja toidet jne.....
| Kommentaarid: 68 loe/lisa |
67 |
08.08.2007 19:21:57
| Zonerman kirjutas: |
| G80 kirjutas: |
Hakkab pihta see hala jälle. So? kui midagi paremat pole siis las olla niikaua kuni tuleb täpsem ja parem inf (enamus saitidel on see inf ju siis on seal mingi tõde sees). Pole vaja targutada, et see on BS jne, Me teame, et sa oled fanatic vms ja pole üldse vaimustatud kui selgub mida Nvidia võib välja tuua, pigem halad edasi, et see on võimatu ja see tahab rämedat jahutust ja toidet jne..... |
Tüüpiline Ww jälle ajab oma rida .Ma juba harjunud tema sõnamängu ja nvidiastide mahategemisega
Jänes
08.08.2007 22:57:58
Mõnel mehel vist tekkisid märjad unelmad neid ridu lugedes, et kohe oli vaja seda jama siia postitada.
| Kommentaarid: 6 loe/lisa |
MummikAl
09.08.2007 00:04:26
| Jänes kirjutas: |
Mõnel mehel vist tekkisid märjad unelmad neid ridu lugedes, et kohe oli vaja seda jama siia postitada. |
seda kogu teemat võib ju ka jamaks nimetada, kuna täpselt ei tea veel keegi ju midagi
| Kommentaarid: 42 loe/lisa |
39 |
anti666
09.08.2007 14:05:47
seda kogu teemat võib ju ka jamaks nimetada, kuna täpselt ei tea veel keegi ju midagi icon_razz.gif
see pole esimene kord, R600 kohta liikus ka suht palju valeinfot R600 teema alghatamise ajal. Siiski on parem kui teema olemas on, sest muidu arutataks teistes teemades, kuhu see jutt ei kuulu.
_________________ Siin on siis signatuur, mis lisatakse soovikorral minu sõnumitele  |
| Kommentaarid: 9 loe/lisa |
erick
09.08.2007 14:15:32
Sattusin lugema järgmist TheInq'i artiklit: link
Here's the thing. DX10 hardware - such as the GeForce 8800 or the Radeon 2900 - won't work with the new 10.1 features. The 0.1 revision requires completely new hardware for support, thus royally cheesing off many gamers who paid top whack for their new hardware over the last few months on the basis of future game compatibility.
But these gamers shouldn't fret too much - 10.1 adds virtually nothing that they will care about and, more to the point, adds almost nothing that developers are likely to care about. The spec revision basically makes a number of things that are optional in DX10 compulsory under the new standard - such as 32-bit floating point filtering, as opposed to the 16-bit current. 4xAA is a compulsory standard to support in 10.1, whereas graphics vendors can pick and choose their anti-aliasing support currently. |
Kes nüüd usub, et see eraldiseisev eDRAM G92 kiibil on reaalselt olemas?
Tõesti, see on kõige lihtsam ja täiesti perfikaota viis kuidas 4x AA-d lubada. Keegi võiks ainult välja nuputada, kui suur see eDRAM olema peaks, et sinna 2560x1600 @ 4xAA sisse mahuks...
EDIT: leidsin Anandtechist sellised andmed:
| In case anyone is curious, a double buffered 4xAA 32bit color+z framebuffer at 2560x1600 is about 190MB. |
Anandtechi GF 7800 GTXi arhitektuuri artikkel
96 |
Ho Ho
09.08.2007 18:23:35
| erick kirjutas: |
| Keegi võiks ainult välja nuputada, kui suur see eDRAM olema peaks, et sinna 2560x1600 @ 4xAA sisse mahuks |
Doublebufferi puhul on tarvis kuvatava kaadri puhul alles hoida ainult 24(32)bit colourbuffer, pole vaja igasugu Z ja muid puhvreid. Samuti võib selle üsna rahumeeli jätta Vram'i. eDramis aga oleks tarvis hoida kõiki aktiivselt joonistatavaid puhvreid. Ehk siis näiteks 16bit per channel RGBA ja 32bit z+stencil. Per pixel teeb see ilma SSAA'ta umbkaudu 4*2+4=12 baiti. Ilma AA'ta oleks see ~46MiB. Viimasel ajal on AA läinud nii keerukaks, et paljalt neljaga korrutades ei pruugi saada õiget mäluvajadust 4x AA jaoks, pigem jääb see suts väiksemaks. Samas hierarhiline Z puhver peaks ka mõned megad juurde lisama sinna.
Muidugi see on siis kõige elementaarsema renderdamise puhul mida praktiliselt keegi enam eriti ei kasuta Tänapäeval tehakse roppu moodi offscreen renderdamist, näiteks igasugu lightmappide genereerimiseks. Samuti mõned renderdavad veel kõiksugu muid puhvreid kuhu pannakse kirja igasugu muud andmed. Kõige toredam on veel siis, kui mõni otsustab kasutada deferred shadingut kus lihtsamas variandis salvestatakse per pixel jämedalt 24 baiti
[edit]
Wikipedia andmetel võtab Xenose eDram ~105M transsi. G92 vajaks mõistlikuks töötamiseks ~5x rohkem ning ka vähemalt sama palju kordi kiirema lingi otsas. Vaevalt, et NV kavatseb paljalt cachega transside üldarvu pea kahekordistada, see ei anna erilist võitu. Välise kivi kinnitamine aga ajab GPU ühenduste arvu eelarve lõhki. Eriti kui arvestada, et 384bit mälukanalist annab GDDR4'ga veel päris palju välja pigistada.
87 |
Flavius
118 |
denis28
21.08.2007 22:07:51
kas praegu oleks üldse mõtet näiteks 8800gtx-i osta?
| Kommentaarid: 67 loe/lisa |
WäntWõll
make.believe
21.08.2007 22:09:53
denis28, Kas sa näed hetkel kiiremat kaarti turul
300 |
denis28
21.08.2007 22:28:27
| Nu ja siis paari kuu pärast tuleb ju G90 välja mis 2 korda kiirem ja enamvähem sama hind?siis on kaputt
NATAS999
21.08.2007 22:48:10
sellise suhtumisega võibki uut arvutit ostma jääda. lga775 on kah juba üsna vana, et suht kindlast tuleb uus socket ja kes teab, vb koos sellega ka midagi uuemat/kiiremat pci-e asemele jne. praegu ma arvan, et osta see 8800gtx ära ja kui g92 tuleb poodi, siis saad ju alati 8800 maha müüa ja g92 asemele osta, kui rahaga muidugi kitsaks ei lähe.
_________________ "Kuidas on see hea?"
-Auto kirurgia kliinik |
39 |
Ho Ho
21.08.2007 23:27:21
LGA775 asendus peaks kohale jõudma järgmise aasta lõpuks koos täiesti uue prosearhitektuuriga
87 |
heikis
21.08.2007 23:29:45
| Ho Ho kirjutas: |
LGA775 asendus peaks kohale jõudma järgmise aasta lõpuks koos täiesti uue prosearhitektuuriga  |
on see mõni täiesti teistsugune socket või vahe on ainult mummukeste arvus?
| Kommentaarid: 339 loe/lisa |
291 |
heretic666
21.08.2007 23:34:20
| ATI kaartidel lähevad ajad vist väga raskeks.
Ho Ho
21.08.2007 23:47:43
| heikis kirjutas: |
| Ho Ho kirjutas: |
on see mõni täiesti teistsugune socket või vahe on ainult mummukeste arvus? |
Prosed on integreeritud mälukontrolleriga. Kahe ja rohkema socketi puhul on nagu AMD et mälu ja põhjasild ühendatakse eri kanaleid pidi külge, ühe socketi kohta veel päris täpselt ei tea et kas on sama kui AMD'l või pannakse ikka kõik tavaar koos mäludega läbi põhjasilla prose külge. Muidu kõlakad räägivad ka triplechannel DDR3'st.
Igal juhul olgu selle mälu ühendamise ja põhjasillaga kuidas on kuid ükski praegune emaplaat seda imelooma nii ehk naa omaks ei võta, muutused on ikka "natuke" liiga suured.
87 |
Mercury
| Kommentaarid: 61 loe/lisa |
60 |
Auron
26.08.2007 20:03:08
Uuem info maikuust?
133 |
Foxxx
26.08.2007 20:14:56
| dreamx, jah, 8800 Ultra 8)
| Kommentaarid: 64 loe/lisa |
61 |
Le Inc
26.08.2007 20:21:23
| denis28 kirjutas: |
| Nu ja siis paari kuu pärast tuleb ju G90 välja mis 2 korda kiirem ja enamvähem sama hind?siis on kaputt |
8800 gtx mürad vähemalt G90 üle. Ehk ülejärgmise põlvkonna saabumisel võid kaardi välja vahetada. Pealegi on SLI tänapäeval (taas)leiutatud, nii et varu on. Kuid kindlasti kaotad rahas ja mitte vähe (peale G92 kukuvad 8800 seeria hinnad kolinal), samas käib see juba arvuti juppide ostmisega kaasas .. üks kõige kehvem investeerimisplatvorm (kui just sellega raha ei teeni).
54 |
