uus teema   vasta Tarkvara »  Arvutimängude foorum »  Fallout 3 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 9, 10, 11 ... 99, 100, 101  järgmine
Paganarh
Paganarh
sõnum 07.06.2007 13:57:19 vasta tsitaadiga
Delta
Delta
sõnum 11.06.2007 07:58:24 vasta tsitaadiga
Eile sai siis klipp senisele youtubele lisaks ka täisversioonis ära vaadatud. Ega muud polegi, kui et nüüd on kole tahtmine taas fallout peale lasta ja tiba mööda vaulte kolistada... icon_biggrin.gif
airgun.planet.ee - õhkrelvad ja taskulambid
Salva kindlustus = probleemid
Kommentaarid: 141 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 133
wicked
wicked
sõnum 15.06.2007 06:53:59 vasta tsitaadiga
http://www.neogaf.com/forum/showthread.php?t=163612
The article is based on an hour long demo GI was given. I'll list the high points
- Game runs on an evolved version of the Oblivion engine. Third person view has been reworked since the verdict was that the Oblivion version sucked balls.
- Game starts with your birth and your mother's death in a vault hospital. This is essentially the character customization part of the game. Your father hands you up to have your DNA analyzed and you get to pick out all your character traits. Your dad takes off his mask to reveal similar traits to the ones you picked.
- You grow up in the vault and as you grow you get your first book titled "You're Special" which allows you to choose you baseline stats for each of your 7 primary aptitudes. You'll also get your first weapons and wrist computer (menu) as you get older you'll take tests to determine the initial layout of your skills and traits.
- Every aspect of character creation is based on S.P.E.C.I.A.L. system. Of your 14 skills you can tag 3 to grow at a faster rate than the rest as you level up.
- Battle system is called the Vault-tec Assisted Targeting System (V.A.T.S.). The article states. "While you'll certainly be able to tackle enemies in real time using first person shooting, V.A.T.S. lets players pause time and select a target at their leisure". Battle system still uses action points, but once you've used them up you'll still be able to fight targets in real time while they charge back up.
- Game is still violent and gory. One of the featured screens is of a guy's head exploding in super gory detail. Apparently all gory deaths in the game will be in slow motion.
- More than one way to play the game. Go balls out and kill people, or sneak past situations, or perhaps talk your way out of situations.
- Enemies can target you just like you can target them, so you can get injured in very specific points on you body. This is in addition to an all new health/radiation system. This new system has you measuring how radiated certain things (like water) are and how they affect you when you consume them.
- Karma system returns
- XP based system, most XP comes from quests
- Level cap is 20
- 9 - 12 possible endings based on your actions in the game
- No level scaling like oblivion, you walk into a high level area, you die horribly.
- There are NPC's you can hire, but this is not a party based game.
Kommentaarid: 68 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 63
marcor1
marcor1
sõnum 15.06.2007 07:16:36 vasta tsitaadiga
Kõlab hästi...lootus pole veel surnud...
War. War never changes.
Malkavian: [to a stop sign] No, you stop!
Kommentaarid: 69 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 63
HannesH
HannesH
sõnum 15.06.2007 07:27:58 vasta tsitaadiga
jääb vaid üle oodata ja kiibitseda veel vähemalt aastake(st)...
Paganarh
Paganarh
sõnum 15.06.2007 07:37:17 vasta tsitaadiga
whoa! kõlab ju hästi või mis? icon_smile.gif tahaks seda lahingusüsteemi lähemalt näha
Timberg
ööKARU
Timberg
sõnum 15.06.2007 07:47:07 vasta tsitaadiga
Kõlab kuulujutuna.
Ho Ho
Ho Ho
sõnum 15.06.2007 08:38:28 vasta tsitaadiga
Hm, 3D, tõenäoliselt lahing midagi sarnast F:BoS'ile, level cap, vähe skille. Keeruliseks läheb neil selliste asjadega vanu fänne meelitada icon_neutral.gif
Timberg
ööKARU
Timberg
sõnum 15.06.2007 08:40:21 vasta tsitaadiga
Ho Ho, ära asja nii post-apokalüptilistes toonides näe. Teed mu veel kurvaks .(
Bos imes jõhkralt. Vähe skille ka.. agrlhjfdhkl
sõnum 15.06.2007 10:21:08 vasta tsitaadiga
selja tagant kaamera seega. nii, isomeetrilisega tegu ei ole. selge.
realtime combat pausivõimalusega. first person lisaks sellele. selge.
ma ei ütleks, et see falloudi stiiliga sobib. liiga over-the-top aga eks näis kuidas praktiline lahendus toimib. aga see on pisiasi.
returns?
- Level cap is 20
levelcap? 20?
oblivion with guns, anyone?
- londiste
Timberg
ööKARU
Timberg
sõnum 15.06.2007 10:22:17 vasta tsitaadiga
- one.
Loodame, et tegu on kuulujutuga.
erick
erick
sõnum 15.06.2007 10:29:58 vasta tsitaadiga
Kõik muu peale level cap'i kõlab ok'lt, kuigi lahing võiks siiski olla mängija valikust sõltuvalt kas real-time või action-point based.
Kommentaarid: 105 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 95
Timberg
ööKARU
Timberg
sõnum 15.06.2007 11:01:43 vasta tsitaadiga
Ehk on teemast juba läbi käinud.. ehk mitte.
link
link
sõnum 15.06.2007 11:18:34 vasta tsitaadiga
- londiste
der hammer
der hammer
sõnum 15.06.2007 11:50:57 vasta tsitaadiga
Suht hästi kõlasid muutused ju..
Tundub nagu kõik tahaks siin samasugust mängu nagu Fallout 2 oli ainult uue graafika ja looga. Kõik uus millegavälja tullakse on sitt. icon_rolleyes.gif
Tere.
Kommentaarid: 148 loe/lisa Kasutajad arvavad:  :: 2 :: 1 :: 130
Timberg
ööKARU
Timberg
sõnum 15.06.2007 12:00:32 vasta tsitaadiga
totu, oled kõigest täiesti õigesti aru saanud.
fallout.. võiks olla fallout, mitte fallout tactis või fallout bos või fallout oblivion .)
Samas.. graafika arendus, miks mitte. Kuid tõesti.. kui tuleks level 20 cap = vähem skille = vähem võimalusi = igavam mäng.
sõnum 15.06.2007 12:02:24 vasta tsitaadiga
kõik uus millega välja tullakse?
thank god et special vähemalt alles on, viewpoint ja combat system pöörati juba pea peale.
viewpointi osas muidugi veidi rahulikumalt mõeldes tuleb vast pigem tänapäevastele rpgdele omane kaugemalt ülevalt vaade ikka. kuigi 1st personi jutt vihjab klassikalisele 3rd personile jälle.
muide, fallout2 uue graafika ja looga kõlab ikka kuratlikult hästi icon_biggrin.gif
selle van bureni techdemo peale kukkus kah lõug natukene laua peale. et nagu, asi oli üsna pädevas arengujärgus juba või nii.
- londiste
viimati muutis londiste 15.06.2007 12:05:51, muudetud 1 kord
Timberg
ööKARU
Timberg
sõnum 15.06.2007 12:02:52 vasta tsitaadiga
Lont, ära ole kurb. Ehk on ikkagi kuulujutud ja ehk (väike võimalus) tuleb sealt midagi F1, F2 laadset.. röh.
der hammer
der hammer
sõnum 15.06.2007 12:04:19 vasta tsitaadiga
Samas ,kui sa jääd lvl20 juurde siis on mängus veel vähemalt mingi pinge ja päris supermaniks ei ole võimalik saada.
Mäng peab arenema ,et keegi peale vanade fanboyde seda mängu ostaksid. Ütlen ausalt ,et mingit turn baset rpg-d ma enam mängida ei viitsiks ja väga rahul ,et third person view on. First person oleks muidugi veel parem...
Tere.
sõnum 15.06.2007 12:08:47 vasta tsitaadiga
aga mina tahaks küll supermaniks saada. igasugused kunstlikud piirangud seebiks.
ja turnbasedi mittemängimise osas, oeh. oleks siis neid vähemalt, et valikuvõimalust oleks...
nagu juba varemgi mainitud, kultusklassikatele järjeks totaalselt teistssuguseid asju teha on eduline ettevõtmine.
saagu järgmine elder scrolls turnbased ja isomeetriline või top-down!
- londiste
Timberg
ööKARU
Timberg
sõnum 15.06.2007 12:10:55 vasta tsitaadiga
londiste kirjutas:
Mõttearendus: kusjuures üks keskaegne GTA 2 kuluks küll ära.
sõnum 15.06.2007 12:13:16 vasta tsitaadiga
Timberg kirjutas:
londiste kirjutas:
et annaks gta näiteks blizzardile teha?
või diablo järje ea-le?
lihtsalt, et mängud areneks või nii?
- londiste
Timberg
ööKARU
Timberg
sõnum 15.06.2007 13:19:46 vasta tsitaadiga
Natuke meelelahutust.
Kunagise Fallout 3 projekti Van Buren techdemo teile .)
http://www.fileplanet.com/176640/170000/fileinfo/Van-Buren-Tech-Demo
http://www.megaupload.com/?d=SQADZL3G
http://madbrahmin.bonusweb.cz/fallout3/van_buren/vb_demo.rar
Paganarh
Paganarh
sõnum 15.06.2007 15:39:19 vasta tsitaadiga
Oh teid vanu kibestunud peere küll hehe.
Ma tean, ma ise samasugune... samas ma isegi ei hellitand lootustki et F3 tuleb täpselt sama mis F1 & F2, ainult et uue mootori ja stooriga. See on lihtsalt võimatu.
Firmad ostavad litsensid ära miljonite eest selleks et sinna veel miljoneid pumbata ja lõpuks kogu see raha topelt kätte saada.
Fänlusega on tehtud ainult üksikud mängud ning need on kah ikka suht prügi.
Fallout muutub. On see paremuse või halvemuse poole, sõltub vaataja perspektiivist. Vanad Falloutid enam tagasi ei tule. Iialgi.
Timberg
ööKARU
Timberg
sõnum 15.06.2007 15:42:32 vasta tsitaadiga
Paganarh, mis muhedad käibetõed need on? .) A'le järgneb B..
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Fallout 3 mine lehele eelmine  1, 2, 3 ... 9, 10, 11 ... 99, 100, 101  järgmine
