Paganarh
07.06.2007 14:57:19
mitte kõik USAs ei ole õnneks respublikaanid
| Kommentaarid: 15 loe/lisa |
Delta
| Kommentaarid: 141 loe/lisa |
133 |
wicked
15.06.2007 07:53:59
http://www.neogaf.com/forum/showthread.php?t=163612
The article is based on an hour long demo GI was given. I'll list the high points
- Game runs on an evolved version of the Oblivion engine. Third person view has been reworked since the verdict was that the Oblivion version sucked balls.
- Game starts with your birth and your mother's death in a vault hospital. This is essentially the character customization part of the game. Your father hands you up to have your DNA analyzed and you get to pick out all your character traits. Your dad takes off his mask to reveal similar traits to the ones you picked.
- You grow up in the vault and as you grow you get your first book titled "You're Special" which allows you to choose you baseline stats for each of your 7 primary aptitudes. You'll also get your first weapons and wrist computer (menu) as you get older you'll take tests to determine the initial layout of your skills and traits.
- Every aspect of character creation is based on S.P.E.C.I.A.L. system. Of your 14 skills you can tag 3 to grow at a faster rate than the rest as you level up.
- Battle system is called the Vault-tec Assisted Targeting System (V.A.T.S.). The article states. "While you'll certainly be able to tackle enemies in real time using first person shooting, V.A.T.S. lets players pause time and select a target at their leisure". Battle system still uses action points, but once you've used them up you'll still be able to fight targets in real time while they charge back up.
- Game is still violent and gory. One of the featured screens is of a guy's head exploding in super gory detail. Apparently all gory deaths in the game will be in slow motion.
- More than one way to play the game. Go balls out and kill people, or sneak past situations, or perhaps talk your way out of situations.
- Enemies can target you just like you can target them, so you can get injured in very specific points on you body. This is in addition to an all new health/radiation system. This new system has you measuring how radiated certain things (like water) are and how they affect you when you consume them.
- Karma system returns
- XP based system, most XP comes from quests
- Level cap is 20
- 9 - 12 possible endings based on your actions in the game
- No level scaling like oblivion, you walk into a high level area, you die horribly.
- There are NPC's you can hire, but this is not a party based game. |
_________________ I prepared Explosive Runes this morning |
| Kommentaarid: 68 loe/lisa |
63 |
marcor1
15.06.2007 08:16:36
Kõlab hästi...lootus pole veel surnud...
_________________ War. War never changes.
Malkavian: [to a stop sign] No, you stop! |
| Kommentaarid: 70 loe/lisa |
HannesH
15.06.2007 08:27:58
| jääb vaid üle oodata ja kiibitseda veel vähemalt aastake(st)...
| Kommentaarid: 24 loe/lisa |
23 |
Paganarh
15.06.2007 08:37:17
whoa! kõlab ju hästi või mis? tahaks seda lahingusüsteemi lähemalt näha
Timberg
ööKARU
15.06.2007 08:47:07
| Kõlab kuulujutuna.
272 |
Ho Ho
15.06.2007 09:38:28
Hm, 3D, tõenäoliselt lahing midagi sarnast F:BoS'ile, level cap, vähe skille. Keeruliseks läheb neil selliste asjadega vanu fänne meelitada
86 |
Timberg
ööKARU
15.06.2007 09:40:21
Ho Ho, ära asja nii post-apokalüptilistes toonides näe. Teed mu veel kurvaks .(
Bos imes jõhkralt. Vähe skille ka.. agrlhjfdhkl
272 |
15.06.2007 11:21:08
| - Game runs on an evolved version of the Oblivion engine. Third person view has been reworked since the verdict was that the Oblivion version sucked balls. |
selja tagant kaamera seega. nii, isomeetrilisega tegu ei ole. selge.
| - Battle system is called the Vault-tec Assisted Targeting System (V.A.T.S.). The article states. "While you'll certainly be able to tackle enemies in real time using first person shooting, V.A.T.S. lets players pause time and select a target at their leisure". Battle system still uses action points, but once you've used them up you'll still be able to fight targets in real time while they charge back up. |
realtime combat pausivõimalusega. first person lisaks sellele. selge.
| - Game is still violent and gory. One of the featured screens is of a guy's head exploding in super gory detail. Apparently all gory deaths in the game will be in slow motion. |
ma ei ütleks, et see falloudi stiiliga sobib. liiga over-the-top aga eks näis kuidas praktiline lahendus toimib. aga see on pisiasi.
| - Karma system returns |
returns?
| - Level cap is 20 |
levelcap? 20?
oblivion with guns, anyone?
_________________ - londiste
217 |
Timberg
ööKARU
15.06.2007 11:22:17
- one.
Loodame, et tegu on kuulujutuga.
272 |
erick
15.06.2007 11:29:58
| Kõik muu peale level cap'i kõlab ok'lt, kuigi lahing võiks siiski olla mängija valikust sõltuvalt kas real-time või action-point based.
96 |
Timberg
ööKARU
15.06.2007 12:01:43
Ehk on teemast juba läbi käinud.. ehk mitte.
link
link
272 |
15.06.2007 12:18:34
reinvent, omg
217 |
der hammer
15.06.2007 12:50:57
Suht hästi kõlasid muutused ju..
Tundub nagu kõik tahaks siin samasugust mängu nagu Fallout 2 oli ainult uue graafika ja looga. Kõik uus millegavälja tullakse on sitt.
_________________ Tere. |
| Kommentaarid: 149 loe/lisa |
130 |
Timberg
ööKARU
15.06.2007 13:00:32
totu, oled kõigest täiesti õigesti aru saanud.
fallout.. võiks olla fallout, mitte fallout tactis või fallout bos või fallout oblivion .)
Samas.. graafika arendus, miks mitte. Kuid tõesti.. kui tuleks level 20 cap = vähem skille = vähem võimalusi = igavam mäng.
272 |
15.06.2007 13:02:24
kõik uus millega välja tullakse?
thank god et special vähemalt alles on, viewpoint ja combat system pöörati juba pea peale.
viewpointi osas muidugi veidi rahulikumalt mõeldes tuleb vast pigem tänapäevastele rpgdele omane kaugemalt ülevalt vaade ikka. kuigi 1st personi jutt vihjab klassikalisele 3rd personile jälle.
muide, fallout2 uue graafika ja looga kõlab ikka kuratlikult hästi
selle van bureni techdemo peale kukkus kah lõug natukene laua peale. et nagu, asi oli üsna pädevas arengujärgus juba või nii.
viimati muutis londiste 15.06.2007 13:05:51, muudetud 1 kord |
217 |
Timberg
ööKARU
15.06.2007 13:02:52
| Lont, ära ole kurb. Ehk on ikkagi kuulujutud ja ehk (väike võimalus) tuleb sealt midagi F1, F2 laadset.. röh.
272 |
der hammer
15.06.2007 13:04:19
Samas ,kui sa jääd lvl20 juurde siis on mängus veel vähemalt mingi pinge ja päris supermaniks ei ole võimalik saada.
Mäng peab arenema ,et keegi peale vanade fanboyde seda mängu ostaksid. Ütlen ausalt ,et mingit turn baset rpg-d ma enam mängida ei viitsiks ja väga rahul ,et third person view on. First person oleks muidugi veel parem...
130 |
15.06.2007 13:08:47
aga mina tahaks küll supermaniks saada. igasugused kunstlikud piirangud seebiks.
ja turnbasedi mittemängimise osas, oeh. oleks siis neid vähemalt, et valikuvõimalust oleks...
nagu juba varemgi mainitud, kultusklassikatele järjeks totaalselt teistssuguseid asju teha on eduline ettevõtmine.
saagu järgmine elder scrolls turnbased ja isomeetriline või top-down!
217 |
Timberg
ööKARU
15.06.2007 13:10:55
| londiste kirjutas: |
| saagu järgmine elder scrolls turnbased ja isomeetriline või top-down! |
Mõttearendus: kusjuures üks keskaegne GTA 2 kuluks küll ära.
272 |
15.06.2007 13:13:16
| Timberg kirjutas: |
Mõttearendus: kusjuures üks keskaegne GTA 2 kuluks küll ära. |
et annaks gta näiteks blizzardile teha?
või diablo järje ea-le?
lihtsalt, et mängud areneks või nii?
217 |
Timberg
ööKARU
272 |
Paganarh
15.06.2007 16:39:19
Oh teid vanu kibestunud peere küll hehe.
Ma tean, ma ise samasugune... samas ma isegi ei hellitand lootustki et F3 tuleb täpselt sama mis F1 & F2, ainult et uue mootori ja stooriga. See on lihtsalt võimatu.
Firmad ostavad litsensid ära miljonite eest selleks et sinna veel miljoneid pumbata ja lõpuks kogu see raha topelt kätte saada.
Fänlusega on tehtud ainult üksikud mängud ning need on kah ikka suht prügi.
Fallout muutub. On see paremuse või halvemuse poole, sõltub vaataja perspektiivist. Vanad Falloutid enam tagasi ei tule. Iialgi.
Timberg
ööKARU
15.06.2007 16:42:32
| Paganarh, mis muhedad käibetõed need on? .) A'le järgneb B..
272 |
