08.10.2006 10:06:00
| 486 kirjutas: |
| Far Crys läks sihtimine päris sitaks kui jooksid, kõige parem oli kaugelt lamades mehi headshotidega maha nottida. Üksik laskudega püsis sihik ilusti paigal. |
nojah palju neid mängureid eestis ikka on kes far cry-s falcon-ga sprindi pealt palgamõrvaritele kuuli pähe kihutavad ,teemasse kah,ma pean veidi uurima mis relvad sinna mängu tulevad,kuna mäng toimub tulevikus siis arvata on et mingeid prototüüpe saab näha ,aga tahaks ikka selliseid relvi mis far cry-s kah olid,nt see suur lihanuga mille nimi mul praegu meelde ei tule
EDIT: kiire copy paste wikist:
banaan SCAR: The SCAR (SOF Combat Assault Rifle) in Crysis is the standard assault rifle, which will be able to be modified into a sniper rifle or a CQB rifle. It can also be loaded with special ammunition such as incendiary rounds, and "tag" bullets that carry a transmitter to allow you to track the location of an enemy, as well as a remotely-triggered tranquilizer that will knock the enemy out instantly. The gun loosely resembles an XM8 (based on the HK G36 design) in Crysis.
banaan XM102: This shoulder mounted rocket launcher is able to destroy tanks, helicopters, and vehicles using futuristic targeting technology.
banaan XM2014: This standard shotgun can be modified to include a reflex sight, targeting laser or tactical flashlight.
banaan MPXA: This is a short range submachine gun also able to be modified to include a laser targeting system, reflex sight, tactical flashlight, and silencer.
banaan EM70: This long range electromagnetic rifle fires metal slugs at a staggering velocity of 8 times the speed of sound, or Mach 8. The developers call this weapon the "Anti-Vehicle Rifle".
banaan Frag grenade: Simple frag grenade that the player carries nearly all the time.
banaan Hand-held gatling gun: Heavy weapon which can only be used if the player has a maximum level of power in his suit.
banaan Enemy Weapons: As seen in a beta gameplay movie, players will be able to pick up enemy weapons, such as the AK-74.
banaan Molecular Accelerator: Used by the small multi-tentacled aliens, this weapon allows them to freeze the water and humidity from the air into icicles and hurl them at fast speeds. Unlimited ammo.
banaan Molecular Arrestor: Used by the Hunters. Huge ice guns that fire a freezing ray at the enemy. The frozen target(s) can be shattered easily by bullets.
banaan Singularity Cannon: Used by the aliens, this weapon shoots a "black hole" which creates a large explosion that will attempt to suck anything into it |
EDIT2: Confirmed DX10/SM4.0 Games:
http://www.nvnews.net/vbulletin/showthread.php?t=77741
| Kommentaarid: 92 loe/lisa |
Cooler(-10)
08.10.2006 10:10:23
Äkki mõtled matsetti (õikegiri longap ) vms. see millega dunglis teele ettejäävaid kapsaid maha raiutakse.
| Kommentaarid: 15 loe/lisa |
alliance
The Transporter
17.10.2006 23:52:02
| 486 kirjutas: |
sa proovi päris elus headshotte tha kui jooksed ja hingeldad nagu uppunud kukk
_________________ --- |
| Kommentaarid: 531 loe/lisa |
431 |
CnZ
18.10.2006 00:23:55
| alliance kirjutas: |
| 486 kirjutas: |
sa proovi päris elus headshotte tha kui jooksed ja hingeldad nagu uppunud kukk  |
vahe selles, et Far Cry on rohkem action/arcade shooter, nii et sihik võiks kogu aeg paigal olla.
OFP-st saame aru, näiteks.
| Kommentaarid: 14 loe/lisa |
18.10.2006 06:09:01
Lol poleks pidanud neid viimaseid pilte siia linkima vist HV inimesed kukutasid serveri kokku tsiteerin:
This site is being owned - help me. Damn you digg . 9000+ Unique visitors in only 3 hours is not good for any server. You may download or view the screens by following the links below...
_________________ Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738 |
alliance
The Transporter
19.10.2006 22:39:25
mis selle pela keskmised nõuded olid arvutile
431 |
19.10.2006 22:57:14
| mis selle pela keskmised nõuded olid arvutile |
Mitteametlikud nõuded on järgmised(ametlikke veel pole):
Minimum Requirements:
CPU: Athlon 64 3000+/Intel 2.8ghz
Graphics: Nvidia 6600/X800GTO (SM 2.0)
RAM: 768Mb/1Gb on Windows Vista
HDD: 6GB
Internet: 256k+
Optical Drive: DVD
Software: DX9.0c with Windows XP
Recommended Requirements:
CPU: Dual-core CPU (Athlon X2/Pentium D)
Graphics: Nvidia 7800GTX/ATI X1800XT (SM 3.0) or DX10 equivalent
RAM: 1.5Gb
HDD: 6GB
Internet: 512k+ (128k+ upstream)
Optical Drive: DVD
Software: DX10 with Windows Vista
The above specs are simply speculation, but I've put in atleast a few hours researching to get the requirments down to how they are at the moment.
20.10.2006 00:12:50
ooh shit, miinimum kaetud
oot mis ? mu vend ei saagi oma GF4MX'iga pelada ?krt asjata kellasin seda w?
| Kommentaarid: 85 loe/lisa |
alliance
The Transporter
20.10.2006 00:19:40
ma lihtsalt tunnen muret et kas mul piisab praegu arvutist
431 |
20.10.2006 08:28:26
ma lihtsalt tunnen muret et kas mul piisab praegu arvutist  |
Prose osas on sul kõik väga ,sellega ei tohiks mingeid probleeme tekkida ,mäluga võib veidi kitsaks minna ,+1GB juurde peaks su päästma ,kõige suuremaks pudelikaelaks saab kindlasti graafika ,ise olen prose,mälu,op süsteemi,kõvaketta,interneti ühenduse ja DVD rom-ga heas seisus,detsembris tuleb uus võimas graafika kah ja siis peaks praktiliselt kõik settingud põhjas saama mängida seda vista ja DX10 peal
EDIT:
| mikk36 kirjutas: |
oot mis ? mu vend ei saagi oma GF4MX'iga pelada ?krt asjata kellasin seda w? |
See ju DX8,mäng nõuab miinimum DX9,nii ,et jääb ära
pealuu
20.10.2006 09:35:54
| tomorrow kirjutas: |
EDIT:
| mikk36 kirjutas: |
See ju DX8,mäng nõuab miinimum DX9,nii ,et jääb ära  |
mx'id olid vist ikka dx7.
| Kommentaarid: 211 loe/lisa |
170 |
20.10.2006 09:57:28
piisavalt teadlik inimene leiab loodetavasti iroonia kah tollest lausest üles
Mario153
| Kommentaarid: 56 loe/lisa |
50 |
Octane
21.10.2006 12:25:48
| ahvilõust kirjutas: |
Ma ei saa aru kuidas need palmid nii kergelt maha kukuvad  |
sepp viskas granaadi ja selleks see palm ka kukkus
| Kommentaarid: 12 loe/lisa |
posthuman
21.10.2006 13:40:38
Kas dx9 kaardiga ka sel mängul mõte on? Videod vaadates võiks kindlalt väita, et tegu on aegade parima graafikaga. Aga mis kasu on mängust ja tema DX10 efektidest, kui praegused kaardid neid efekte ei võimalda??
Või olen ma millegist valesti aru saanud? Ma ei usu, et hetkel poest ostes mõne kõva kaardi(hind 6000 ja üles) näitaks mängus kõike efekte nagu nad mõeldud näitamaks on
Pealegi on DX10 mõeldud vaid Vista keskkonnale ja XP mehed jäävad sellest rõõmust ilma.. Kas asja point on teenida DX kujul Vista üle pappi või milles, aga mina näen, et selle mängu täisgraafikaga mängimine nõuab ka aegade suuremat pappi ja närvikulu ka lõppkasutajale. DX10 graafika kaart, windows vista, ~2gb mälu ja dual core prose(et mängu ikka normaalselt jooksutada)...
| Kommentaarid: 69 loe/lisa |
67 |
21.10.2006 13:51:17
| posthuman kirjutas: |
Pealegi on DX10 mõeldud vaid Vista keskkonnale ja XP mehed jäävad sellest rõõmust ilma.. Kas asja point on teenida DX kujul Vista üle pappi või milles, aga mina näen, et selle mängu täisgraafikaga mängimine nõuab ka aegade suuremat pappi ja närvikulu ka lõppkasutajale. DX10 graafika kaart, windows vista, ~2gb mälu ja dual core prose(et mängu ikka normaalselt jooksutada)... |
...Ja kes käseb sul kõik põhjas jooksutada ,olen kindel et isegi medium settingutel teeb see ära nii mitmelegi turul olevale,ja tulevale mängule ,Crysis tuleb ka DX9 peale ja seda saab ka XP all vabalt mängida,ja see tuleb ka DX10 peale kus seda saab vista all mängida,lisaks saab vista all mängida crysis DX9 versiooni(seda siis loodetavasti uue DX9 L versiooniga),hetkel pole palju teada selle kohta mis eeliseid DX10 annab võrreldes DX9-ga,DX10 on ju algusest lõpuni uuesti kirjutatud ja ei käsitle asju nagu DX9 seda teeb.
posthuman
21.10.2006 13:52:51
No ma ei mõelnudki, et XP mehed seda mängida ei saa. Kindlasti ajab asja ära ka barton 2500+ ja gf 6600gt ja graafika võib ka selle riistvara olemasolul olla parem kui nii mõnigi teine välja tulev mäng. Lihtsalt kui juba mängida, siis korralikult
67 |
21.10.2006 13:58:15
Järelikult tuleb nõrgema riistvara omanikel kõvasti slidereid näppida ,et leida hea balanss silmailu ja mängitavuse vahel,mis kasu on über effektidest kui asi jookseb 15 freimi sekundis ,või sellest kui asi jookseb 100+ freimi sekundis ja näeb välja nagu mingi roheline paber kus kriipsujukud ringi sebivad
posthuman
21.10.2006 14:10:54
Noh eks näis mis saama hakkab, vähemalt prose on mul mängu jaoks olemas lisarami pulk ei maksa palju ja jääb üle muretseda talvel mingi videokaart siis vastavuses mänguga
Eks nvidia laseb ka keskmise rahakotiga inimestele välja DX10 kaarte aasta alguses. Näis kuda neil ka powerit jagub. Eks crysis saab olema peamine testi-mäng DX10 kaartide puhul igast tom'i jne saitidel.
67 |
21.10.2006 14:34:39
Eks nvidia laseb ka keskmise rahakotiga inimestele välja DX10 kaarte aasta alguses. Näis kuda neil ka powerit jagub. Eks crysis saab olema peamine testi-mäng DX10 kaartide puhul igast tom'i jne saitidel. |
nn Mainstream DX10 kaardid peaks tulema kevadel 2007(nvidia omad),ATI kohta pole veel kuulnud aga vaevalt et needki palju hiljem tulevad ,kui siia lisada see, et miski vista(tasuta) betaga saab ka kuni 2007 keskpaigani mängida siis ei pruugi DX10 rahakotti auku lüüagi
21.10.2006 16:49:33
| no ma kavatsen ka edaspidi tasuta vistat kasutada, msdnaa programmi abil
Ho Ho
21.10.2006 17:22:24
Kas vahepeal on mõni DX10 video välja lastud? Need mõne kuu-nädala vanused videod on kõik jooksnud DX9 raua peal.
86 |
21.10.2006 21:42:21
| Ho Ho kirjutas: |
| Kas vahepeal on mõni DX10 video välja lastud? Need mõne kuu-nädala vanused videod on kõik jooksnud DX9 raua peal. |
Kui see üksik prototüüp DX10 riistvara peal jooknud video välja arvata mille ma juba tükk aega tagasi siia postitasin,siis vastus sinu küsimusele on ei ,aga arvan,et (tead ise miks) võib novembri lõpust hakata nägema ehtsa DX10 raua peal jooksvaid videoid ,Niipalju kui tean,siis Crytek tegeleb praegu optimiseerimise ja bug-de kõrvaldamisega(sellest ka asjaolu et viimasel ajal pole suuri uudiseid tulnud mängu kohta),mäng ise ja selle põhiosa on valmis juba kuu vähemalt ,kui mitte rohkem.Kuskil mingi kõlakas käis ,et launch date on 7 Veebruar 2007(mis peaks suht tõelähedane olema).
posthuman
21.10.2006 21:42:33
| Ho Ho kirjutas: |
ja ehk seletad kuda tehakse mäng DX10 efektidega, kui meestel pole DX10 kaarti rauas
Ja need videod ON dx10 kaartidega tehtud, osadel lausa kirjas juures, et DX10 effects blablabla
67 |
