diisel2.0
03.09.2006 11:24:21
| Winterwind kirjutas: |
mitmeid kordi? 29.08.2006 oli esimene kuupäev, see lükati 14.09.2006 peale
siis X1950XTX-i ametlik launch ka ja hinnasula |
24.08 oli esimene, 29.08 teine, 30.08 kolmas ,31.08 neljas siis tehti hüpe 14.09 peale
33 |
anubis
283 |
One
03.09.2006 11:45:54
| see 16 piibuga 199 taalane AIW on jah tore
728 |
03.09.2006 12:09:52
hind kuidagi väga soodne... huh... äkki annab sebida
aga see koht on ka selline, et kas alati ikka asjad kätte saab
201 |
Ho Ho
03.09.2006 12:10:03
"Open Box"
Kas see mitte ei ole teise sõnaga "refurbished"?
87 |
weasel
03.09.2006 12:14:36
Open Box items have been opened and touched and/or returned. Because they originate from different situations, they may or may not include accessories, documentation or retail packaging. Refurbishment is done by the manufacturer. Open Box products are warranted for only 15 days. We recommend that you try out your open box product immediately after receiving it.
_________________ PSN: weaselEST |
| Kommentaarid: 38 loe/lisa |
anubis
03.09.2006 13:16:53
muidex, vahepeal myys zipzoom seda 149$ , ATI parseldab oma AIW kaarte poole hinnaga maha.
peaks ameerikasse emigreeruma
283 |
predator
03.09.2006 13:59:06
| Kas HIS x1800gto/x1900gt IceQ3 versioone siinmail ka poelettidel näha on loota, tavalist x1800gto`d on K`s vist laos mõnes kohas olemas.
154 |
Sponge
04.09.2006 14:40:23
| x1900GT minukaudu saaks tutika, garantii jne , 3300.- club3d , et kui kedagi kotib siis PS
| Kommentaarid: 398 loe/lisa |
323 |
r4ido
04.09.2006 16:15:40
Saatsin eile hilisõhtul maili: "Micheline Hou" <Micheline@club-3d.nl>
FW: When will Club3D X1900RX (sn:CGAX-RX196) will ship to Estonia? [Scanned]
Dear Raido,
Yes is correct. The R1900RX was in shortage by ATI for some time due to the product
transition.
Therefore was not available by us, we will be able to deliver beginning of next week,
so you can get from GNT EE most probably around 22nd. (maybe earlier)
Br, Micheline |
Teadmiseks neile, kes veel ei teadnud
E: parandasin sõnastust viimases lauses
viimati muutis r4ido 04.09.2006 23:38:58, muudetud 2 korda |
| Kommentaarid: 74 loe/lisa |
68 |
Scart
04.09.2006 19:14:56
| täielik müstika... katalyst 6.8 tõi wowi stabiilsusprobleemid, olen proovinud nii 6.6, 6.7 ja 6.8, kõigiga kräshib VPU recovery teatega.
101 |
One
09.09.2006 10:28:01
lasin 3dmark 05-e, videod def kellal, max quality ja E6300 @ 2800mhz
arvasin, et mingi 11k tuleb vast kuna single skoor on ~7.x
a tuli hoopis natuke rohkem
kaartidest pilt ka:
toiteahel nagu X1800XT-l
728 |
-RaiTz-
11.09.2006 00:24:52
| Mul tekkis väike probleem. Ei ole ATi graafika kaartide alal eriline spets, eriti draiverite suhtes. Mis moodi ATi x1300-le kõige uuemaid draivereid saada. Ei saa www.ati.com -is midagi aru mida tõmmata. Ja kas enne uute draiverite peale laskmist on väga oluline vanad maha lasta või saab ilma ka.
| Kommentaarid: 36 loe/lisa |
30 |
11.09.2006 00:30:54
drivers & software / windows xp drivers and software / radeon / catalyst 6.8
ja siis soovitavalt catalyst package, miski ~34mega vms
_________________ - londiste
217 |
WäntWõll
make.believe
300 |
angel
11.09.2006 06:31:41
| -RaiTz- kirjutas: |
| Mul tekkis väike probleem. Ei ole ATi graafika kaartide alal eriline spets, eriti draiverite suhtes. Mis moodi ATi x1300-le kõige uuemaid draivereid saada. Ei saa www.ati.com -is midagi aru mida tõmmata. Ja kas enne uute draiverite peale laskmist on väga oluline vanad maha lasta või saab ilma ka. |
Enne uute peale laskmist peaks kindlalt vanad enne ära tapma. Kui see tehtud siis alles uued peale.
157 |
-RaiTz-
11.09.2006 17:20:39
| Tänud!
30 |
Mastersas
12.09.2006 02:21:01
Keegi tark v6iks oelda kummast kaardist annab rohkem j6udu pigistada: kas 7900GT v6i 1900XT no t6esti ei oska otsustada kumba osta
7900GT peaks saama mingi 800/2000mhz +-
Ati X1900XT oskab keegi oelda palju 6huga ja voltmodidega l2heb ?
eelistaks nagu Ati-t
| Kommentaarid: 203 loe/lisa |
153 |
Elof
12.09.2006 02:23:59
Nende kaartide vahel valides ikka X1900XT
175 |
One
12.09.2006 06:53:35
7900GT-d sa ilma voltmodita küll klokkuma ei saa.
mem-i saad jah aga gpu-d mitte
728 |
KrikU
12.09.2006 11:12:31
7900GT 800mhz core jaoks on tõesti voltmode vaja... muidu läheb keskmiselt 560-600 kanti õhuga ja modifitseerimata jahutusega. Mälu on selline, et läheb vastavalt mälukiibile ja voltmodi ei soovitata teha.
x1900xt on mega ahju kiviga kaart Selle default töötemperatuur tundub ikka kole kõrge olema, vähemalt x1900xtx 650mhz peal 3d reziimis käsi kaardi taha kuuma õhu väljapuhumiskoha juurde pannes on tunne nagu viibiks avalikus peldikus kätekuivatusmasina juures Niiet see r580 töötab kole kõrgetel temperatuuridel. x1900xt kaardil on üks pingeregulaatori junn puudu võrreldes x1900xtx variandiga.
119 |
Smoking
12.09.2006 11:18:23
| KrikU kirjutas: |
x1900xt on mega ahju kiviga kaart Selle default töötemperatuur tundub ikka kole kõrge olema, vähemalt x1900xtx 650mhz peal 3d reziimis käsi kaardi taha kuuma õhu väljapuhumiskoha juurde pannes on tunne nagu viibiks avalikus peldikus kätekuivatusmasina juures Niiet see r580 töötab kole kõrgetel temperatuuridel. x1900xt kaardil on üks pingeregulaatori junn puudu võrreldes x1900xtx variandiga. |
Paljud ei soovitaks GT-le mode teha, aga sellel ei ole ka mõtet , kuna modi tegemine annab vast paarkümmend lisa Mhz-i juurde, kui võrrelda kaardiga, millele ei ole Vmem hardmodi tehtud. Lisaks suureneb kõvasti risk, et toiteahel annab otsad.
298 |
KrikU
12.09.2006 12:08:57
Jah, mina ei tee kunagi mode kaardile ja soovitan ka teistel mitte teha garantii säilimise eesmärgil Õige jutt ühesõnaga
119 |
Smoking
12.09.2006 12:12:33
| KrikU kirjutas: |
Jah, mina ei tee kunagi mode kaardile ja soovitan ka teistel mitte teha garantii säilimise eesmärgil Õige jutt ühesõnaga |
Hardmodid saab vägagi lihtsalt maha. Kaardiga juhutub midagi, modid maha, stock jahutus peale ja garantiisse.
298 |
One
12.09.2006 12:15:27
X1900xT-l on pingeregulaatori junn puudu? kuskohast see info pärineb?
ahi või mitte ahi, kiirust on ka vastavalt.
mis sa mõtled, et vmoditud 7900GT on külmkapp?
| Smoking kirjutas: |
| Kaardiga juhutub midagi, modid maha, stock jahutus peale ja garantiisse. |
kui kaart maaletoojale/tootjale juhtub minema siis küll uut ei saa.
reeglina tõmmatakse kohe vesi peale kui vmodimis kahtlus on
728 |
ajuNolk
12.09.2006 12:20:02
| Olid alles ajad, kui winterwind ja paljud teisedki raskelt kirusid ja hädaldasid, et oi need gf6800seeria kaardid on ikka nii suured ja kuidas küll nad korpusesse mahuvad ja oh seda kuumust mida need nvidia kaardid levitavad... Ühesõnaga oli alles tore aeg eks, kui ati oli väike ja jahe...
121 |
angel
12.09.2006 12:26:38
oli jah mõnus aeg kus nVidia oli ahi ja ati oli külm aga vat hääd ajad said otsa.
samas mul näiteks ongi talvel pidevalt külm seega peaks endale ühe ati ahju sisse ostma. Saab powwat mängudes ja ka toa hoijaks soojana 8)
Loota võib et ati uuemad kaardid lähevad jahedamaks aga karta on et see ei juhtu nii pea
157 |
One
12.09.2006 13:18:47
loota on, et G80 näitab alles mis sõna "ahi" tähendab
728 |
predator
12.09.2006 13:31:02
kellelgi siseinfi ka liigub, et kas x1900gt kaarte on loota selle kuu keskpaigaks siia müügile. Huvitav kaart on samas ka 7900gs, võimsusklass peaks sama olema
154 |
angel
12.09.2006 13:33:03
hm mina niipalju kuulsin et ati valmistab suure hoolega X1950 praegast seega X1900 ei leidu eriti. Samas selle kuu lõpus peaks nagu X1900 saadavus jälle taastuma.
157 |
eckh
12.09.2006 15:06:21
loota on, et G80 näitab alles mis sõna "ahi" tähendab  |
on sul mingit inffi mis väidaks et G80 tuleb oluliselt "ahjum" kui R600 ?
103 |
One
12.09.2006 15:09:42
| eckh kirjutas: |
| on sul mingit inffi mis väidaks et G80 tuleb oluliselt "ahjum" kui R600 ? |
G80 on 90nm kaart ja väidetavalt ~450 miljoni transiga.
G71 on 280 miljoni transiga ja 90nm.
loogiliselt võttes peaks asi ikka veits soojem olema kui sama nm peal G71
aga jah - eks näis
728 |
12.09.2006 20:36:05
Ma kuulsin et r600-le pidi tehtama veel parem jahutus kui x1950xt-le,mitte niivõrd vaiksuse kuivõrd performance poolest,Kujutan ette mingit 1,5 kilo kaaluvat vasest,alumilium heatpipe(de)-ga hüper jahutit,aga no jah mis neil muud üle jääb,R600 tuleb kindlalt kuumem kui R580,veidike aitab kuumust vist alandada 80nm transs(saab keegi kinnitada et see tuleb 80nm )Selline spekulatsioon siis minu poolt,mis puutu vmod-i siis ma laseks oma kaardile selle teha ainult siis kui ma olen kindel et,see on hästi jahutatud(loe:vesi )
| Kommentaarid: 92 loe/lisa |
Le Inc
12.09.2006 22:37:29
| Ilmselt saab R600 pingeid muuta läbi tarkvara (nagu X1800 ja X1900 seeria), seega pole v-mod'il erilist vajadust.
| Kommentaarid: 56 loe/lisa |
54 |
KrikU
12.09.2006 23:07:29
Oijah, ma olin tööl kui kirjutasin postituse ja samas sai eelmise päeva õhtul nähtud pilti (tööl ei leidnud xbitlabsi linki üles kuna vaatasin koduarvutist)
Check da pictures: http://www.xbitlabs.com/articles/video/display/radeon-x1900xtx_5.html
Tegelt on x1800xt-l see junn puudu vms
119 |
One
12.09.2006 23:49:58
X1800XT-l ei ole mitte "junni" puudu vaid sinna polegi seda pinge regulaatorit ette nähtud.
X1900XT/XTX-il on see ja X1950XTX-il jälle pole
728 |
KrikU
13.09.2006 00:25:30
X1900XT/XTX-il on see ja X1950XTX-il jälle pole |
Ei ole jah tead ette nähtud, nagu ma arvaks, et see on kuidagi valesti ja puudu... Lihtsalt see määrab toiteahela stabiilsust ja seega on ka mingil määral oluline kellamisel.
119 |
Wiltz
13.09.2006 00:50:25
et kui kõvasti kohalikud siis kah 1900XT'd klokkinud on, keegi on core'i üle 800mhz ka ajanud? mälu üle 1000mhz'i?
9 :: |
226 |
prigo
13.09.2006 08:36:57
Anna mulle üks kaart ja näed kohe tulemusi kah.
Tegelt varsti vahetan 7900gt-x1900xt peale, eks siis näis kuidas asi kellub.
Muide, kuna see x1950xtx siis poodidesse jõuab?
| Kommentaarid: 17 loe/lisa |
15 |
WäntWõll
make.believe
13.09.2006 09:34:15
Doctor peebu järgi varsti
Kuupäeva usaldusväärsus on teine teema ja seda jälle lahkama ei hakkaks
300 |
13.09.2006 10:02:34
| prigo kirjutas: |
Muide, kuna see x1950xtx siis poodidesse jõuab? |
zebra-st saab juba vähemalt nädala tellida,iseasi kas neil laos ka on,aga üldiselt ega selliseid high end kaarte müüjad riiulile tolmu koguma ei osta ikka,kui tellitakse toovad suurest laost(leedus,soomes,saksamaal või kusiganes neil need suuremad laod asuvad )
HDTanel
Overclocker
13.09.2006 10:26:46
| prigo kirjutas: |
X1950XTX USA poes nagu oli olemas.. ei tea kas üks vend tellib ka või mitte aga hind on küll haigelt hea samas poodidesse tuleb hind kõrge.
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
Sponge
13.09.2006 15:20:51
6700.- saab kätte x1950xtx
323 |
One
13.09.2006 15:22:14
| Sponge Bob kirjutas: |
6700.- saab kätte x1950xtx  |
poe hind on ikka natuke suurem vast..
oleneb mis firma oma mõtled ka
728 |
Wiltz
13.09.2006 16:32:58
ühesõnaga eestimaal tegelikult keegi nagu neid ATI 1900 seeria isendeid korralikult klokkinud ei olegi jah? tahaks just teada, palju ja kuidas see core siis läheb neil kaartidel, kui võimalik on näiteks õhuga kuni 800ni minna? ja eks mälu peaks neil ka idee poolest 1000mhz vabalt ära minema...välismaistes foorumites on igatahes väga vähesed core 800 lähedale ja veel vähem on üle selle saanud, mäluga tavaliselt 800-900. need arvud on muidugi peale pinge tõstmist, ja see loomulikult huvitab ennast ka
9 :: |
226 |
One
13.09.2006 16:44:32
core teeb 700+ mhz õhuga, veega rohkem. core tahab külma ka - reeglina vähemalt.
mem teeb 850-950mhz oleneb progest millega klokkida ja jahutusest jne
üldiselt neid nvidia ja ati klokke pole mõtet võrrelda.
atil palju karmimad mem timingud ja selleks klokkub vähem.
a selle eest on skooride/fps-i tõus mhz-i kohta suurem
viimati muutis Winterwind 13.09.2006 17:00:30, muudetud 1 kord |
728 |
Elof
175 |
Evil
Hull
13.09.2006 16:50:38
| Wiltz kirjutas: |
ühesõnaga eestimaal tegelikult keegi nagu neid ATI 1900 seeria isendeid korralikult klokkinud ei olegi jah? tahaks just teada, palju ja kuidas see core siis läheb neil kaartidel, kui võimalik on näiteks õhuga kuni 800ni minna? ja eks mälu peaks neil ka idee poolest 1000mhz vabalt ära minema...välismaistes foorumites on igatahes väga vähesed core 800 lähedale ja veel vähem on üle selle saanud, mäluga tavaliselt 800-900. need arvud on muidugi peale pinge tõstmist, ja see loomulikult huvitab ennast ka  |
Õhuga nad küll 800 core ei lähe, mem pole ka mingi imeloom. Veega isegi ei taha core 800 minna, x1800XT vast läheb soojemaga aga x1900 seeria ei taha eriti minna. Üldjuhul mem-i klokkimisel lastakse timme lõdvemaks mis annavad tulemuseks 900+ aga samas lõdvemate timmidega skoorib vähem. Ise sain kunagi oma XTX-i 800/900 vesi ja jahe õhk. Varsti teen midagi vast Crossfire-iga mis peaks andma tulemuseks Core 800 aga selleni on tsipa aega veel.
202 |
One
13.09.2006 16:51:54
diamond pidi X1800 ja X1900 ka agp-le tooma aga jutuks see vaid jäigi.
iseenesest oleks asi rialtoga võimalik aga keegi ei viitsi teha
728 |
flameas
13.09.2006 16:54:09
Kurb lugu, et ei viitsi. usun, et tahtjaid oleks. Ja isegi väga palju. Paljud arvutid ju AGP peal siiamaani
| Kommentaarid: 91 loe/lisa |
81 |
