diisel2.0
03.09.2006 10:24:21
| Winterwind kirjutas: |
mitmeid kordi? 29.08.2006 oli esimene kuupäev, see lükati 14.09.2006 peale
siis X1950XTX-i ametlik launch ka ja hinnasula |
24.08 oli esimene, 29.08 teine, 30.08 kolmas ,31.08 neljas siis tehti hüpe 14.09 peale
33 |
anubis
283 |
One
03.09.2006 10:45:54
| see 16 piibuga 199 taalane AIW on jah tore
728 |
03.09.2006 11:09:52
hind kuidagi väga soodne... huh... äkki annab sebida
aga see koht on ka selline, et kas alati ikka asjad kätte saab
200 |
Ho Ho
03.09.2006 11:10:03
"Open Box"
Kas see mitte ei ole teise sõnaga "refurbished"?
86 |
weasel
03.09.2006 11:14:36
Open Box items have been opened and touched and/or returned. Because they originate from different situations, they may or may not include accessories, documentation or retail packaging. Refurbishment is done by the manufacturer. Open Box products are warranted for only 15 days. We recommend that you try out your open box product immediately after receiving it.
_________________ PSN: weaselEST |
| Kommentaarid: 38 loe/lisa |
anubis
03.09.2006 12:16:53
muidex, vahepeal myys zipzoom seda 149$ , ATI parseldab oma AIW kaarte poole hinnaga maha.
peaks ameerikasse emigreeruma
283 |
predator
03.09.2006 12:59:06
| Kas HIS x1800gto/x1900gt IceQ3 versioone siinmail ka poelettidel näha on loota, tavalist x1800gto`d on K`s vist laos mõnes kohas olemas.
154 |
Sponge
04.09.2006 13:40:23
| x1900GT minukaudu saaks tutika, garantii jne , 3300.- club3d , et kui kedagi kotib siis PS
| Kommentaarid: 398 loe/lisa |
323 |
r4ido
04.09.2006 15:15:40
Saatsin eile hilisõhtul maili: "Micheline Hou" <Micheline@club-3d.nl>
FW: When will Club3D X1900RX (sn:CGAX-RX196) will ship to Estonia? [Scanned]
Dear Raido,
Yes is correct. The R1900RX was in shortage by ATI for some time due to the product
transition.
Therefore was not available by us, we will be able to deliver beginning of next week,
so you can get from GNT EE most probably around 22nd. (maybe earlier)
Br, Micheline |
Teadmiseks neile, kes veel ei teadnud
E: parandasin sõnastust viimases lauses
viimati muutis r4ido 04.09.2006 22:38:58, muudetud 2 korda |
| Kommentaarid: 74 loe/lisa |
68 |
Scart
04.09.2006 18:14:56
| täielik müstika... katalyst 6.8 tõi wowi stabiilsusprobleemid, olen proovinud nii 6.6, 6.7 ja 6.8, kõigiga kräshib VPU recovery teatega.
101 |
One
09.09.2006 09:28:01
lasin 3dmark 05-e, videod def kellal, max quality ja E6300 @ 2800mhz
arvasin, et mingi 11k tuleb vast kuna single skoor on ~7.x
a tuli hoopis natuke rohkem
kaartidest pilt ka:
toiteahel nagu X1800XT-l
728 |
-RaiTz-
10.09.2006 23:24:52
| Mul tekkis väike probleem. Ei ole ATi graafika kaartide alal eriline spets, eriti draiverite suhtes. Mis moodi ATi x1300-le kõige uuemaid draivereid saada. Ei saa www.ati.com -is midagi aru mida tõmmata. Ja kas enne uute draiverite peale laskmist on väga oluline vanad maha lasta või saab ilma ka.
| Kommentaarid: 35 loe/lisa |
29 |
10.09.2006 23:30:54
drivers & software / windows xp drivers and software / radeon / catalyst 6.8
ja siis soovitavalt catalyst package, miski ~34mega vms
_________________ - londiste
215 |
WäntWõll
make.believe
300 |
angel
11.09.2006 05:31:41
| -RaiTz- kirjutas: |
| Mul tekkis väike probleem. Ei ole ATi graafika kaartide alal eriline spets, eriti draiverite suhtes. Mis moodi ATi x1300-le kõige uuemaid draivereid saada. Ei saa www.ati.com -is midagi aru mida tõmmata. Ja kas enne uute draiverite peale laskmist on väga oluline vanad maha lasta või saab ilma ka. |
Enne uute peale laskmist peaks kindlalt vanad enne ära tapma. Kui see tehtud siis alles uued peale.
157 |
-RaiTz-
11.09.2006 16:20:39
| Tänud!
29 |
Mastersas
12.09.2006 01:21:01
Keegi tark v6iks oelda kummast kaardist annab rohkem j6udu pigistada: kas 7900GT v6i 1900XT no t6esti ei oska otsustada kumba osta
7900GT peaks saama mingi 800/2000mhz +-
Ati X1900XT oskab keegi oelda palju 6huga ja voltmodidega l2heb ?
eelistaks nagu Ati-t
| Kommentaarid: 203 loe/lisa |
153 |
Elof
12.09.2006 01:23:59
Nende kaartide vahel valides ikka X1900XT
175 |
One
12.09.2006 05:53:35
7900GT-d sa ilma voltmodita küll klokkuma ei saa.
mem-i saad jah aga gpu-d mitte
728 |
KrikU
12.09.2006 10:12:31
7900GT 800mhz core jaoks on tõesti voltmode vaja... muidu läheb keskmiselt 560-600 kanti õhuga ja modifitseerimata jahutusega. Mälu on selline, et läheb vastavalt mälukiibile ja voltmodi ei soovitata teha.
x1900xt on mega ahju kiviga kaart Selle default töötemperatuur tundub ikka kole kõrge olema, vähemalt x1900xtx 650mhz peal 3d reziimis käsi kaardi taha kuuma õhu väljapuhumiskoha juurde pannes on tunne nagu viibiks avalikus peldikus kätekuivatusmasina juures Niiet see r580 töötab kole kõrgetel temperatuuridel. x1900xt kaardil on üks pingeregulaatori junn puudu võrreldes x1900xtx variandiga.
119 |
Smoking
12.09.2006 10:18:23
| KrikU kirjutas: |
x1900xt on mega ahju kiviga kaart Selle default töötemperatuur tundub ikka kole kõrge olema, vähemalt x1900xtx 650mhz peal 3d reziimis käsi kaardi taha kuuma õhu väljapuhumiskoha juurde pannes on tunne nagu viibiks avalikus peldikus kätekuivatusmasina juures Niiet see r580 töötab kole kõrgetel temperatuuridel. x1900xt kaardil on üks pingeregulaatori junn puudu võrreldes x1900xtx variandiga. |
Paljud ei soovitaks GT-le mode teha, aga sellel ei ole ka mõtet , kuna modi tegemine annab vast paarkümmend lisa Mhz-i juurde, kui võrrelda kaardiga, millele ei ole Vmem hardmodi tehtud. Lisaks suureneb kõvasti risk, et toiteahel annab otsad.
298 |
KrikU
12.09.2006 11:08:57
Jah, mina ei tee kunagi mode kaardile ja soovitan ka teistel mitte teha garantii säilimise eesmärgil Õige jutt ühesõnaga
119 |
Smoking
12.09.2006 11:12:33
| KrikU kirjutas: |
Jah, mina ei tee kunagi mode kaardile ja soovitan ka teistel mitte teha garantii säilimise eesmärgil Õige jutt ühesõnaga |
Hardmodid saab vägagi lihtsalt maha. Kaardiga juhutub midagi, modid maha, stock jahutus peale ja garantiisse.
298 |
One
12.09.2006 11:15:27
X1900xT-l on pingeregulaatori junn puudu? kuskohast see info pärineb?
ahi või mitte ahi, kiirust on ka vastavalt.
mis sa mõtled, et vmoditud 7900GT on külmkapp?
| Smoking kirjutas: |
| Kaardiga juhutub midagi, modid maha, stock jahutus peale ja garantiisse. |
kui kaart maaletoojale/tootjale juhtub minema siis küll uut ei saa.
reeglina tõmmatakse kohe vesi peale kui vmodimis kahtlus on
728 |
